About "Always On"
21
About "Always On"
Posted at 5/20/2015 15:33:30      View5589 | Replies2        Print      Only Author   [Copy Link] 1#
1. I wondered role of all pins from JL8506.
What is role of each pin from JL8506?
- PWR_EN_SYS, CPU_DET, RESET, PWR_INT, PWR_EN_SYS, PWR_LED
This question is for If I removed JL8506 part on circuit.
2. Is there "Always On" function in RK3288(Firefly)?
"Always On" is stand by mode with the least standby power.
3. If there is "Always On" in firefly, which pin is used for this function?
4. How is reference circuit for Always On? Could you send reference circuit? Please add some comments for description.
5. If we need Micom for "Always On", Could you send recommended support list for Micom?
Thank you .
Posted at 5/18/2026 11:16:04        Only Author  2#
JL8506 pins such as PWR_EN_SYS, CPU_DET, RESET, PWR_INT, and PWR_LED are mainly used for power control, reset handling, CPU status detection, and LED indication. If JL8506 Crossy Road is removed, these functions may need external control logic or MCU support.
Posted at 6/4/2026 16:03:42        Only Author  3#
This reminds me of trying to understand the intricate trigger systems in Geometry Dash levels! Just like deciphering these pins, figuring out how each trigger interacts to create a sequence can be a real head-scratcher. It's rewarding when you finally connect the dots, though!
