[General] Test 1z0-1077-25 Guide Online & Exam 1z0-1077-25 Bootcamp
55
General Test 1z0-1077-25 Guide Online & Exam 1z0-1077-25 Bootcamp
Posted at 2/18/2026 13:57:58      View135 | Replies1        Print      Only Author   [Copy Link] 1#
2026 Latest Pass4sures 1z0-1077-25 PDF Dumps and 1z0-1077-25 Exam Engine Free Share: https://drive.google.com/open?id=1FoOJdHd1kjMnvukfpahz4zqEsn5g-oEC
That's why Pass4sures offers actual Oracle Order Management Cloud Order to Cash 2025Implementation Professional (1z0-1077-25) exam questions to help candidates pass the exam and save their resources. The Oracle 1z0-1077-25 Exam Questions provided by Pass4sures is of the highest quality, and it enables participants to pass the exam on their first try.
Pass4sures could give you the Oracle 1z0-1077-25 exam questions and answers that with the highest quality. With the material you can successed step by step. Pass4sures's Oracle 1z0-1077-25 exam training materials are absolutely give you a true environment of the test preparation. Our material is highly targeted, just as tailor-made for you. With it you will become a powerful IT experts. Pass4sures's Oracle 1z0-1077-25 Exam Training materials will be most suitable for you. Quickly registered Pass4sures website please, I believe that you will have a windfall.
Free PDF Quiz 2026 Oracle 1z0-1077-25: Oracle Order Management Cloud Order to Cash 2025Implementation Professional C Efficient Test Guide Online1z0-1077-25 Practice Material is from our company which made these 1z0-1077-25 practice materials with accountability. And 1z0-1077-25 Training Materials are efficient products. What is more, 1z0-1077-25 Exam Prep is appropriate and respectable practice material. We know making progress and getting the certificate of 1z0-1077-25 Training Materials will be a matter of course with the most professional experts in command of the newest and the most accurate knowledge in it. Our 1z0-1077-25 exam prep has taken up a large part of market.
Oracle Order Management Cloud Order to Cash 2025Implementation Professional Sample Questions (Q126-Q131):NEW QUESTION # 126
Which task requires manual execution of the Process Supply Chain Orchestration Interface process so that a supply order gets created?
  • A. Back-to-Back Contract Manufacturing
  • B. Min-Max planning replenishing a purchase request
  • C. Planned Order Releases
  • D. Back-to-Back Procurement
  • E. Drop Shipment
Min-Max planning replenishing a purchase request is the task that requires manual execution of the Process Supply Chain Orchestration Interface process so that a supply order gets created. Min-Max planning is a method of inventory replenishment that maintains a minimum and maximum quantity of each item in a warehouse or subinventory.When the quantity of an item falls below the minimum level, a purchase request is generated to replenish the item to the maximum level1. The purchase request is then sent to the Supply Chain Orchestration Interface table, where it waits for the Process Supply Chain Orchestration Interface scheduled process to run.This process creates a supply order based on the purchase request and sends it to the supplier2.
You must run this process manually or schedule it to run periodically3.
Min-Max Planning
Orchestrate Supply Requests from Replenishment Planning
NEW QUESTION # 127
Your supply chain organization needs to include important project information on internal order movement activities. Supply Chain Orchestration can now use file-based data import template as a means of updating project attributes on transfer orders.
Which is the correct sequence of the process?
  • A. SCO gets default values for the project attributes not imported.
    SCO performs a project accounting transaction control (PATC).
    SCO sends validated attributes to Inventory Management for transfer order.
    Inventory management updates transfer order with new attributes.
  • B. SCO performs a project accounting transaction control (PATC).
  • C. SCO sends validated attributes to Inventory Management for transfer order.
  • D. SCO performs a project accounting transaction control (PATC).
This is the correct sequence of the process to update project attributes on transfer orders using file-based data import template.A transfer order is a document that initiates the movement of material between warehouses within the enterprise1.Project attributes are the information that identifies the project, task, and expenditure type for each transfer order line2.You can use file-based data import template to update project attributes on transfer orders by following these steps3:
* SCO gets default values for the project attributes not imported: Supply Chain Orchestration (SCO) is a service that orchestrates the fulfillment of supply requests from various sources, such as sales orders, planning recommendations, or inventory replenishment. SCO gets the default values for the project attributes that are not imported from the file-based data import template. The default values are derived from the project defaulting and enrichment rules that you set up in the Manage Supply Order Defaulting and Enrichment Rules task.
* SCO performs a project accounting transaction control (PATC): SCO performs a validation of the project attributes against the project accounting transaction control (PATC) rules that you define in the Manage Project Transaction Sources task. PATC rules determine whether the project attributes are valid and consistent for each transfer order line. If the project attributes pass the validation, SCO sends them to Inventory Management for transfer order creation. If the project attributes fail the validation, SCO rejects them and logs the errors in the Supply Chain Orchestration Interface table.
* SCO sends validated attributes to Inventory Management for transfer order: SCO sends the validated project attributes along with other transfer order information to Inventory Management for transfer order creation. Inventory Management is a service that manages the flow of material within and across warehouses. Inventory Management creates the transfer order based on the information received from SCO and assigns a unique document number to it.
* Inventory management updates transfer order with new attributes: Inventory Management updates the transfer order with the new project attributes that are imported from the file-based data import template.
You can view the updated project attributes on the transfer order lines in the Manage Transfer Orders page in the Inventory Management work area.
Transfer Order
Project Attributes
Update Project Attributes on Transfer Orders Using File-Based Data Import
[Supply Chain Orchestration]
[Manage Supply Order Defaulting and Enrichment Rules]
[Manage Project Transaction Sources]
[Supply Chain Orchestration Interface]
[Inventory Management]
[Create Transfer Orders]
[Manage Transfer Orders]
NEW QUESTION # 128
Which three statements are true about the Visual Information Builder interface? (Choose three.)
  • A. The Visual Information Builder interface is a simplified drag-and-drop rule editor.
  • B. In the Visual Information Builder interface, you create external interface routing rules by using the
    "Manage External Integration Routing Rules for Sales Orders" page.
  • C. Post-transformation rules and external integration routing rules can be created by using the Visual Information Builder interface.
  • D. In the Visual Information Builder interface, you create external interface routing rules by using the Manage External Integration Routing Rules page.
  • E. Pre-transformation rules and external integration routing rules can be created by using the Visual Information Builder interface.
  • F. The Visual Information Builder interface is the same as the editor for Oracle Business Rules.
Answer: A,D,E
NEW QUESTION # 129
Within Oracle Transaction BI Answers, which two tasks would you use the Analysis Editor to perform?
  • A. Publishing reports to the BI Catalog
  • B. Updating data in transactional tables
  • C. Setting notification events
  • D. Creating prompts and filters
  • E. Setting criteria
Answer: D,E
NEW QUESTION # 130
Your organization utilizes Configurator Cloud to support the majority of their customer sales orders, One of your primary jobs is to create and maintain the various Configurator tasks that support the sales order flows.
A lot of your work is concentrated on Configurator models.
Which two elements are subtabs on the Edit Configurator Model page > Structure tab?
  • A. Item attributes
  • B. Supplemental Structures
  • C. Applicability
  • D. User Interfaces
  • E. Rules
The Edit Configurator Model page is where you can modify the structure, rules, user interfaces, and connectors of a configurator model in Configurator Cloud. The Structure tab is where you can view and edit the features and options that make up the model structure.The Structure tab has two subtabs: Item attributes and Supplemental Structures1.
* Item attributesare the characteristics or properties of the features and options that participate in the model structure.You can use item attributes to define the behavior and appearance of the features and options, such as the default value, the display name, the data type, and the validation rules2.
* Supplemental Structuresare the additional structures that you can create and associate with the model structure. You can use supplemental structures to add more features and options to the model, such as accessories, services, or documentation.You can also use supplemental structures to create different views of the model, such as a technical view or a marketing view3.
How You Modify Configurator Models
Overview of Item Attributes
Overview of Supplemental Structures
NEW QUESTION # 131
If you are worried about your exam, and want to pass the exam just one time, we can do that for you. 1z0-1077-25 exam materials are compiled by experienced experts, and they are quite familiar with the exam center, and therefore the quality can be guaranteed. In addition, you can receive the downloading link and password within ten minutes, so that you can begin your learning immediately. We provide you with free update for one year and the update version for 1z0-1077-25 Exam Torrent will be sent to your email automatically.
Exam 1z0-1077-25 Bootcamp: https://www.pass4sures.top/Order-Management-Cloud/1z0-1077-25-testking-braindumps.html
As long as you choose our dumps as review tool before the exam, you will have a happy result in 1z0-1077-25 exam, which is perfectly obvious, The 1z0-1077-25 pdf, would prove to be the most essential preparation source for your certification at the best price in town, Oracle Test 1z0-1077-25 Guide Online Such characteristic features are hard to find out at any other place, PC version, PDF version and APP version, these three versions of 1z0-1077-25 exam materials you can definitely find the right one for you.
The big switch to digital-only broadcasts is just around the corner, 1z0-1077-25 but do you really know the difference between digital and analog, Code can be embedded into scripts to simulate clicks on advertisements.
Latest updated Test 1z0-1077-25 Guide Online & Reliable Exam 1z0-1077-25 Bootcamp Ensure You a High Passing RateAs long as you choose our dumps as review tool before the exam, you will have a happy result in 1z0-1077-25 Exam, which is perfectly obvious, The 1z0-1077-25 pdf, would prove to be the most essential preparation source for your certification at the best price in town.
Thus the practice exams are far more valuable Reliable 1z0-1077-25 Braindumps Pdf than the vendors' APP files that are often expensive and complex to understand.
DOWNLOAD the newest Pass4sures 1z0-1077-25 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1FoOJdHd1kjMnvukfpahz4zqEsn5g-oEC
Posted at 2/22/2026 12:20:31        Only Author  2#
ITIһԱȤơϤޤITJ^ԇY򐘤ǤޤJ^ԇYITΌT֪RʥƥȤȤƄe˳ITvBWGUJ^ԇY˲μӤYˤȤäƤϤȤƤyȤߤޤԤӖҪǡTech4Exam Health-Fitness-and-Wellness}򤪄ޤ
