[Hardware] Braindumps NSE5_FNC_AD_7.6 Pdf & NSE5_FNC_AD_7.6 Pdf Free
106
【Hardware】 Braindumps NSE5_FNC_AD_7.6 Pdf & NSE5_FNC_AD_7.6 Pdf Free
Posted at 2/18/2026 23:57:23      View:84 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Pass4sures NSE5_FNC_AD_7.6 dumps for free: https://drive.google.com/open?id=1LldZpjtZUDKtzTLxEwMpJshs6H9MgAwE
As we all know, time and tide waits for no man. If you really want to pass the NSE5_FNC_AD_7.6 exam, you should choose our first-class NSE5_FNC_AD_7.6 study materials. And you cannot miss the opportunities this time for as the most important and indispensable practice materials in this line, we have confidence in the quality of our NSE5_FNC_AD_7.6 practice materials, and offer all after-sales services for your consideration and acceptance.
First and foremost, our company has prepared NSE5_FNC_AD_7.6 free demo in this website for our customers. Second, it is convenient for you to read and make notes with our versions of NSE5_FNC_AD_7.6 exam materials. Last but not least, we will provide considerate on line after sale service for you in twenty four hours a day, seven days a week. So let our NSE5_FNC_AD_7.6 Practice Guide to be your learning partner in the course of preparing for the exam, it will be a wise choice for you to choose our NSE5_FNC_AD_7.6 study dumps.
NSE5_FNC_AD_7.6 Pdf Free | Examinations NSE5_FNC_AD_7.6 Actual QuestionsOne of the most important functions of our APP online vesion which is contained in our NSE5_FNC_AD_7.6 preparation questions are that can support almost all electronic equipment, including the computer, mobile phone and so on. If you want to prepare for your exam by the computer, you can buy our NSE5_FNC_AD_7.6 training quiz, because our products can work well by the computer. Of course, if you prefer to study by your mobile phone, our NSE5_FNC_AD_7.6 study materials also can meet your demand.
Fortinet NSE 5 - FortiNAC-F 7.6 Administrator Sample Questions (Q34-Q39):NEW QUESTION # 34
A FortiNAC-F N+1 HA configuration is shown.
What will occur if CA-2 fails?
  • A. CA-1 and CA-3 will operate as a 1+1 HA cluster with CA-3 acting as a hot standby.
  • B. CA-3 will continue to operate as a secondary in an N+1 HA configuration.
  • C. CA-3 will be promoted to a primary and FortiNAC-F manager will load balance between CA-1 and CA-3.
  • D. CA-3 will be promoted to a primary and share management responsibilities with CA-1.
In an N+1 High Availability (HA) configuration, a single secondary Control and Application (CA) server provides backup for multiple primary CA servers. The FortiNAC-F Manager (FortiNAC-M) acts as the centralized orchestrator for this cluster, monitoring the health of all participating nodes.
According to the FortiNAC-F 7.6.0 N+1 Failover Reference Manual, when a primary CA (such as CA-2 in the exhibit) fails, the secondary CA (CA-3) is automatically promoted by the Manager to take over the specific workload and database functions of that failed primary. Crucially, the documentation specifies that even after this promotion, the system architecture maintains its N+1 logic. The secondary CA effectively "assumes the identity" of the failed primary while continuing to operate within the N+1 framework established by the Manager.
It does not merge with CA-1 to form a traditional 1+1 active/passive cluster (A), nor does it engage in load balancing (D), as FortiNAC-F HA is designed for redundancy and failover rather than active traffic distribution. Furthermore, CA-3 does not "share" management with CA-1 (C); it independently handles the tasks originally assigned to CA-2. Throughout this failover state, the Manager continues to oversee the group, and CA-3 remains the designated secondary unit currently acting in a primary capacity for the downed node until CA-2 is restored.
"In an N+1 Failover Group, the Secondary CA is designed to take over the functionality of any single failed primary component within the group. The FortiNAC Manager monitors the primaries and initiates the failover to the secondary... Once failover occurs, the secondary continues to operate as the backup unit for the failed primary while remaining part of the managed N+1 HA configuration." - FortiNAC-F 7.6.0 N+1 Failover Reference Manual: Failover Behavior Section.
NEW QUESTION # 35
When creating a user or host profile, which three criteria can you apply? (Choose three.)
  • A. Location
  • B. Adapter current VLAN
  • C. An applied access policy
  • D. Host or user attributes
  • E. Host or user group memberships
Answer: A,D,E
The User/Host Profile is the primary mechanism in FortiNAC-F for identifying and categorizing endpoints to determine their level of network access. According to the FortiNAC-F Administration Guide, a profile is built using a combination of criteria that define "Who" is connecting, "What" device they are using, and "Where" they are located on the network.
The three main categories of criteria available in the configuration are:
Host or User Attributes (B): This includes specific details such as the host's operating system, the user's role (e.g., Employee, Contractor), or custom attributes assigned to the record.
Host or User Group Memberships (A): Profiles can be configured to match endpoints that are members of specific internal FortiNAC groups or synchronized directory groups (like LDAP or Active Directory groups). This allows for broad policy application based on organizational structure.
Location (E): The "Where" component allows administrators to restrict a profile match to specific physical or logical areas of the network, such as a particular switch, a group of ports, or a specific SSID.
Criteria like an "applied access policy" (D) are the outcome of a profile match rather than a criterion used to define the profile itself. Similarly, the "Adapter current VLAN" (C) is a dynamic state that changes based on enforcement and is not a standard static identifier used for profile matching.
"User/Host Profiles are used to identify the hosts and users to which a policy will apply. Profiles are created by selecting various criteria in the Who/What (Attributes and Groups) and Where (Locations) sections. Attributes can include Host Role, User Role, and OS. Group memberships allow matching based on internal or directory-based groups. Location criteria allow for filtering based on the device or port where the host is connected." - FortiNAC-F Administration Guide: User/Host Profile Configuration.
NEW QUESTION # 36
In which three ways would deploying a FortiNAC-F Manager into a large environment consisting of several FortiNAC-F CAs simplify management? (Choose three.)
  • A. Pooled licenses
  • B. Global authentication security policies
  • C. Global visibility
  • D. Global version control
  • E. Global infrastructure device inventory
Answer: A,C,D
The FortiNAC-F Manager (FortiNAC-M) is designed as a centralized management platform for large-scale distributed environments where multiple FortiNAC-F Control and Application (CA) appliances are deployed across different sites. According to the FortiNAC-F Manager Administration Guide, the deployment of a Manager simplifies administrative overhead in three specific ways:
First, it provides Global Version Control (B). The Manager serves as a central repository for firmware and software updates, allowing administrators to push specific versions to all managed CAs simultaneously, ensuring consistency across the entire fabric. Second, it enables Pooled Licenses (D). Instead of purchasing and managing individual licenses for every CA, licenses are centralized on the Manager. The Manager then distributes these licenses to the CAs as needed based on their host counts. This "floating" license model optimizes cost and prevents individual sites from running out of capacity while others have excess. Third, it offers Global Visibility (E). The Manager aggregates host and device data from every managed CA into a single console. This "single pane of glass" allows an administrator to search for a specific MAC address or user across the entire global organization without logging into individual servers.
While the Manager can assist with configuration templates, authentication security policies (C) and infrastructure modeling (A) are still predominantly managed at the local CA level to ensure site-specific logic and performance.
"The FortiNAC Manager provides a central management console for multiple FortiNAC-F servers (CAs). Key benefits include: * License Management: Licenses are pooled on the Manager and allocated to managed CAs as needed. * Software Management: Firmware updates can be centrally managed and pushed to all CAs from the Manager. * Centralized Monitoring: Provides a global view of all hosts, adapters, and events across the entire managed environment." - FortiNAC-F Manager Administration Guide: Overview and Benefits.
NEW QUESTION # 37
While deploying FortiNAC-F devices in a 1+1 HA configuration, the administrator has chosen to use the shared IP address option.
Which condition must be met for this type of deployment?
  • A. The isolation network type is Layer 2.
  • B. There is a direct cable link between FortiNAC-F devices.
  • C. The isolation network type is layer 3.
  • D. The primary and secondary administrative interfaces are on the same subnet.
In a 1+1 High Availability (HA) deployment, FortiNAC-F supports two primary methods for management access: individual IP addresses or a Shared IP Address (also known as a Virtual IP or VIP). The Shared IP option is part of a Layer 2 HA design, which simplifies administration by providing a single URL or IP that always points to whichever appliance is currently in the "Active" or "In Control" state.
For a Shared IP configuration to function correctly, the Primary and Secondary administrative interfaces (port1) must be on the same subnet. This requirement exists because the Shared IP is a logical address that is dynamically assigned to the physical interface of the active unit. Since only one unit can own the IP at a time, both units must reside on the same broadcast domain (Layer 2) to ensure that ARP requests for the Shared IP are correctly answered and that the gateway remains reachable regardless of which unit is active. If the appliances were on different subnets (a Layer 3 HA design), a shared IP could not be used because it cannot "float" across different network segments; instead, administrators would need to manage each unit via its unique physical IP or use a FortiNAC Manager.
"For L2 HA configurations, click the Use Shared IP Address checkbox and enter the Shared IP Address information... If your Primary and Secondary Servers are not in the same subnet, do not use a shared IP address. The shared IP address moves between appliances during a failover and recovery and requires both units to reside on the same network." - FortiNAC-F High Availability Reference Manual: Shared IP Configuration.
NEW QUESTION # 38
An organization wants to add a FortiNAC-F Manager to simplify their large FortiNAC-F deployment.
Which two policy types can be managed globally? (Choose two.)
  • A. Authentication
  • B. Endpoint Compliance
  • C. Supplicant EasyConnect
  • D. Network Access
The FortiNAC-F Manager is designed to centralize the management of multiple Control and Application (CA) appliances, ensuring consistent security posture across a distributed enterprise. To achieve this, the Manager allows administrators to define and distribute specific types of policies globally rather than configuring them on each individual CA.
According to the FortiNAC Manager Guide, the two primary policy types that are managed globally are:
Network Access Policies (D): These policies define the "If-Then" logic for network entry. By managing these at the global level, an administrator can ensure that a "Contractor" receives the same restricted access regardless of which branch office or campus they connect to.
Endpoint Compliance Policies (B): Global management of compliance policies-which consist of scans and configurations-allows for a unified security baseline. For example, a global policy can mandate that all Windows devices across the entire organization must have a specific antivirus version installed and active before gaining access to the production network.
While the Manager provides visibility into authentication events and can synchronize directory data, the specific Authentication (A) configurations (like local RADIUS secrets or specific LDAP server links) are often localized to the CA to account for site-specific infrastructure. Supplicant EasyConnect (C) is a feature set for onboarding, but the structural "Global Policy" engine focuses primarily on the Access and Compliance frameworks.
"The FortiNAC Manager enables Global Policy Management, allowing for the creation and distribution of policies across all managed CA appliances. This includes Network Access Policies, which control VLAN and ACL assignment, and Endpoint Compliance Policies, which define the security requirements for hosts. Centralizing these policies ensures that security standards are enforced uniformly across the global network fabric." - FortiNAC Manager Administration Guide: Global Policy Management Overview.
NEW QUESTION # 39
Since One of the significant factors to judge whether one is competent or not is his or her NSE5_FNC_AD_7.6 certificates. So to get NSE5_FNC_AD_7.6 real exam and pass the NSE5_FNC_AD_7.6 exam is important. Generally speaking, certificates function as the fundamental requirement when a company needs to increase manpower in its start-up stage. In this respect, our NSE5_FNC_AD_7.6 practice materials can satisfy your demands if you are now in preparation for a certificate. We will be your best friend to help you achieve success!
NSE5_FNC_AD_7.6 Pdf Free: https://www.pass4sures.top/Fortinet-Network-Security-Expert/NSE5_FNC_AD_7.6-testking-braindumps.html
Fortinet Braindumps NSE5_FNC_AD_7.6 Pdf Except of the advantages on soft type it has more functions and it makes you study while you are playing, Fortinet Braindumps NSE5_FNC_AD_7.6 Pdf Before you buy some things, the reference demo is necessary, Fortinet Braindumps NSE5_FNC_AD_7.6 Pdf We always with the greatest ability to meet the needs of the candidates, You can put all your queries and get a quick and efficient response as well as advice of our experts on NSE5_FNC_AD_7.6 certification tests you want to take.
Furthermore, every project can blindly" follow this NSE5_FNC_AD_7.6 Labs plan without needing to worry about updating or modifying it, If you are busy in your daily routine and cant manage a proper time to sit and prepare for the NSE5_FNC_AD_7.6 Certification test, our NSE5_FNC_AD_7.6 PDF questions file is ideal for you.
Realistic Braindumps NSE5_FNC_AD_7.6 Pdf - Win Your Fortinet Certificate with Top ScoreExcept of the advantages on soft type it has more functions NSE5_FNC_AD_7.6 and it makes you study while you are playing, Before you buy some things, the reference demo is necessary.
To achieve this objective the Pass4sures is offering valid, updated, and easy-to-use Fortinet NSE5_FNC_AD_7.6 exam practice test questions in three different formats.
P.S. Free & New NSE5_FNC_AD_7.6 dumps are available on Google Drive shared by Pass4sures: https://drive.google.com/open?id=1LldZpjtZUDKtzTLxEwMpJshs6H9MgAwE
