[Hardware] JN0-105 Exams Training | JN0-105 Exam Quizzes
101
【Hardware】 JN0-105 Exams Training | JN0-105 Exam Quizzes
Posted at 2/19/2026 07:46:49      View:89 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest PassReview JN0-105 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1RuqPnWLi4U3qIHGybMySnFsPiTEbqN3J
You can save too much precious time because JN0-105 actual dumps help you to prepare for the JN0-105 certification tests in a very short time. Using PassReview JN0-105 exam preparation material you will be aware of the final Juniper JN0-105 exam pattern and the kind of JN0-105 Exam Questions. Juniper JN0-105 valid dumps will remove your JN0-105 exam fear and you will take the actual Juniper JN0-105 test with confidence. You will perform well in the Junos, Associate (JNCIA-Junos), JN0-105 exam and produce the best results.
Juniper JN0-105 Exam Syllabus Topics:
  • Configuration Basics: Identification of the main elements for configuring Junos devices is discussed in this topic. Moreover, it describes configuring basic components of a Junos device
  • Routing Fundamentals: This topic discusses pointing out basic routing concepts or functionality for Junos devices. Moreover, the topic also describes configuring or monitoring basic routing elements for a Junos device.
  • Operational Monitoring and Maintenance: Different methods of monitoring or maintaining Junos devices are identified in this topic. Lastly, it discusses monitoring or maintenance procedures for a Junos device.
  • Routing Policy and Firewall Filters: The topic of Routing Policy and Firewall Filters covers routing policy and firewall filters on Junos devices. Furthermore, the topic also deals with routing policies and firewall filters on a Junos device.
Free PDF Quiz Valid JN0-105 - Junos, Associate (JNCIA-Junos) Exams TrainingJuniper JN0-105 dumps PDF version is printable and embedded with valid Juniper JN0-105 questions to help you get ready for the JN0-105 exam quickly. Junos, Associate (JNCIA-Junos) (JN0-105) exam dumps pdf are also usable on several smart devices. You can use it anywhere at any time on your smartphones and tablets.
Juniper Junos, Associate (JNCIA-Junos) Sample Questions (Q65-Q70):NEW QUESTION # 65
You are configuring a firewall filter on a Juniper device.
In this scenario, what are two valid terminating actions? (Choose two.)
  • A. 1 count
  • B. 4accept
  • C. 3next term
  • D. 2discarD
In Juniper firewall filter configurations, "discard" and "accept" are two valid terminating actions for a term within a filter. The "discard" action drops the packet, preventing it from reaching its intended destination, while the "accept" action allows the packet to pass through the filter, proceeding to its next hop or destination. "Count" is a non-terminating action that increments a counter every time a packet matches the term but does not inherently determine the packet's fate. "Next term" directs the evaluation to proceed to the next term in the filter for further processing, also a non-terminating action.
NEW QUESTION # 66
Exhibit
{hold:node0}[edit]
root# set system root-authentication ?
Possible completions:
+ apply-groups   Groups from which to inherit configuration data
+ apply-groups-except Don't inherit configuration data from these groups encrypted-password Encrypted password string load-key-file   File (URL) containing one or more ssh keys plain-text-password Prompt for plain text password (autoencrypted)
> ssh-dsa   Secure shell (ssh) DSA public key string
> ssh-rsa   Secure shell (ssh) RSA public key string
{hold:node0}[edit]
root# set system root-authentication plain-text-password
New password:
Retype new password:
{hold:node0}[edit]
root# commit and-quit
[edit interfaces]
'ge-0/0/0'
HA management port cannot be configured
error: configuration check-out failed
{hold:node0}[edit]
root#
You are unable to remotely access your Juniper device using the CLI.
Referring to the exhibit, which command would you add to the existing configuration to enable remote CLI access?
  • A. load factory-default
  • B. set system services ssh
  • C. set system login idle-timeout 20
  • D. set system root-authentication plain-text-password
In Junos OS, remote access to the device's CLI is commonly facilitated through Secure Shell (SSH), a protocol providing secure command-line access over an insecure network. The given exhibit indicates an attempt to set a root authentication password but does not show configuration for enabling remote access services. To enable SSH, which is not shown in the configuration snippet, you need to configure the device to accept SSH connections. This is done by enabling the SSH service within the system services hierarchy of the configuration. The correct command to add to the existing configuration for enabling remote CLI access via SSH isset system services ssh. This command activates the SSH service, allowing secure remote logins to the device.
NEW QUESTION # 67
You have configured some interfaces on a Junos device; however, you have not yet committed the configuration.
What happens if you issue the rollback 0 command in this scenario?
  • A. The interface changes you made are discarded.
  • B. The Junos device is rebooted.
  • C. The factory default configuration is loaded.
  • D. The messages.log file is deleted.
Issuing the rollback 0 command in Junos OS will discard any uncommitted changes and revert to the last committed configuration. This command effectively cancels any configuration changes that have been made but not yet committed, ensuring that the device returns to its previous stable state.
* "rollback 0 ...................................(rolls back the changes just made )" from Useful Juniper Commands.
txt.
* Juniper official documentation: Rolling Back a Configuration.
NEW QUESTION # 68
Which command displays all IPv6 routes in the default routing instance?
  • A. showroute table inet6.1
  • B. showroute table inet.l
  • C. showroute table inet.0
  • D. showroute table inet6.0
In Junos OS, the command to display IPv6 routes in the default routing instance isshow route table inet6.0.
The routing tableinet6.0specifically holds IPv6 routes. The commandshow route table inet.0is used for IPv4 routes, andinet6.1orinet.l(assuminginet.lis a typo forinet.1) are not standard Junos routing tables for displaying IPv6 routes in the default routing instance.
NEW QUESTION # 69
A network administrator is attempting to route traffic on a Juniper switch to one of three different VLANs: Prod, Test, and Dev. Each VLAN has been assigned a numerical value.
In this scenario, what are these numerical values called?
  • A. interfaces
  • B. defaults
  • C. names
  • D. tags
In the context of VLANs (Virtual Local Area Networks) on a Juniper switch, the numerical values assigned to each VLAN, such as those for Prod, Test, and Dev, are known as VLAN tags. These tags are part of the 802.1Q VLAN standard, which allows multiple VLANs to coexist on a single physical network. Each tag uniquely identifies the VLAN to which a frame belongs, enabling the switch to segregate and manage traffic based on VLAN membership. This tagging mechanism allows for efficient traffic separation and management, ensuring that devices within one VLAN do not receive traffic intended for another, thus maintaining network security and efficiency.
NEW QUESTION # 70
There is no exaggeration that you can be confident about your coming exam just after studying with our JN0-105 preparation materials for 20 to 30 hours. Tens of thousands of our customers have benefited from our exam materials and passed their exams with ease. The data showed that our high pass rate is unbelievably 98% to 100%. Without doubt, your success is 100% guaranteed with our JN0-105 training guide. You will be quite surprised by the convenience to have an overview just by clicking into the link, and you can experience all kinds of JN0-105 versions.
JN0-105 Exam Quizzes: https://www.passreview.com/JN0-105_exam-braindumps.html
What's more, part of that PassReview JN0-105 dumps now are free: https://drive.google.com/open?id=1RuqPnWLi4U3qIHGybMySnFsPiTEbqN3J
