[General] Test Juniper JN0-351 Lab Questions & Test JN0-351 Questions Pdf
140
【General】 Test Juniper JN0-351 Lab Questions & Test JN0-351 Questions Pdf
Posted at 2/19/2026 16:43:35      View:81 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Actual4Exams JN0-351 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1dIkDhk58cUeCBs34h920owsmfsG9LiwA
We offer you free update for one year after you purchase JN0-351 study guide from us, namely, in the following year, you can get the update version for free. And our system will automatically send the latest version to your email address. Moreover, JN0-351 exam dumps of us are compiled by experienced experts of the field, and they are quite familiar with dynamics of the exam center, therefore the quality and accuracy of the JN0-351 Study Guide can be guaranteed. You just need to choose us, and we will help you pass the exam successfully.
Many people are afraid of walking out of their comfortable zones. So it is difficult for them to try new things. But you will never grow up if you reject new attempt. Now, our JN0-351 study quiz can help you have a positive change. It is important for you to keep a positive mind. Our JN0-351 Practice Guide can become your new attempt. And our JN0-351 exam braindumps will bring out the most effective rewards to you as long as you study with them.
Download Actual4Exams Juniper JN0-351 Exam Real Questions and Start this JourneyThe JN0-351 learning materials are of high quality, mainly reflected in the adoption rate. As for our JN0-351 exam question, we guaranteed a higher passing rate than that of other agency. More importantly, we will promptly update our JN0-351 quiz torrent based on the progress of the letter and send it to you. 99% of people who use our JN0-351 Quiz torrent has passed the exam and successfully obtained their certificates, which undoubtedly show that the passing rate of our JN0-351 exam question is 99%. So our JN0-351 study guide is a good choice for you.
Juniper Enterprise Routing and Switching, Specialist (JNCIS-ENT) Sample Questions (Q48-Q53):NEW QUESTION # 48
Referring to the exhibit, which statement is correct?
  • A. The root bridge has not been elected for this RSTP topology.
  • B. The local device is using a bridge priority of 4k.
  • C. The local device is the root bridge for this RSTP topology.
  • D. The root bridge is using a bridge priority of 4k.
The "Root ID" shows 4096.00:19:e2:55:36:1e. The first part of this ID, 4096, is the bridge priority of the root bridge.
The local bridge ID is shown as 32768.00:19:e2:55:1d:30, indicating that the local device has a default bridge priority of 32768, which is higher (and thus less preferred) than 4096.
Thus, the root bridge has a priority of 4096, and the local device is not the root bridge. The local device is participating in the RSTP topology and has identified another bridge as the root.
NEW QUESTION # 49
You implemented the MAC address limit feature with the shutdown action on all interfaces on your switch.
In this scenario, which statement is correct when a violation occurs?
  • A. By default, devices that are learned before the violation occurs are still allowed to send and receive traffic through the specific interface.
  • B. By default, you must manually clear the violation for the interface to send and receive traffic again.
  • C. By default, the violation will automatically be cleared after 300 seconds and the interface will resume sending and receiving traffic for all learned devices.
  • D. By default, the interface will continue to send and receive traffic for all connected devices after a violation has occurred.
When the MAC address limit feature with the shutdown action is implemented on a switch, if a violation occurs, the interface is disabled and a system log entry is generated. If the switch has been configured with the port-error-disable statement, the disabled interface recovers automatically upon expiration of the specified disable timeout. However, if the switch has not been configured for auto-recovery from port error disabled conditions, you must manually clear the violation by running the clear ethernet-switching port-error command for the interface to send and receive traffic again. This explanation is based on the Enterprise Routing and Switching Specialist (JNCIS-ENT) documents and learning resources available at Juniper Networks.
NEW QUESTION # 50
Which two BGP attributes must be supported by all BGP implementations and must be included in every update? (Choose two.)
  • A. AS path
  • B. community
  • C. next hop
  • D. MED
BGP attributes are properties that BGP uses for route advertisement, path selection, and loop prevention. There are four categories of BGP attributes:
Well-known mandatory: Must be recognized by all BGP routers, present in all BGP updates, and passed on to other BGP routers.
Well-known discretionary: Supported by all BGP implementations, and are optionally included in BGP updates.
Optional transitive: May not be supported by all implementations of BGP.
Optional non-transitive: May not be supported by all implementations of BGP. The well-known mandatory attributes must be supported by all BGP implementations and must be included in every update. These include the AS path and next hop attributes.
NEW QUESTION # 51
Which two statements about BGP facilitate the prevention of routing loops between two autonomous systems?
(Choose two.)
  • A. EBGP routers will drop routes that contain their own AS number in the AS_PATH
  • B. EBGP routers will prepend their AS number when advertising routes to their neighbors
  • C. EBGP routers will only accept routes that contain their own AS number in the AS_PATH.
  • D. EBGP routers will append their AS number when advertising routes to their neighbors.
Answer: A,D
BGP (Border Gateway Protocol) is a protocol designed to exchange routing and reachability information among autonomous systems (AS) on the internet1.
Option A is correct. When an EBGP router advertises routes to its neighbors, it appends its AS number to the AS_PATH attribute1. This is a key mechanism in BGP to prevent routing loops1.
Option C is correct. BGP has a built-in loop prevention mechanism whereby if a BGP router detects its own AS in the AS_PATH attribute, it will drop the prefix and will not continue to advertise it2. This helps to prevent routing loops2.
Option B is incorrect. EBGP routers do not accept routes that contain their own AS number in the AS_PATH2. Instead, they drop such routes as part of the loop prevention mechanism2.
Option D is incorrect. While it's true that EBGP routers append their AS number when advertising routes, they do not prepend their AS number1. The term "prepend" in BGP usually refers to a technique used to influence path selection by artificially lengthening the AS_PATH3.
NEW QUESTION # 52
You must implement filter-based forwarding. You need to direct traffic from the 192.168.1.0/24 through vr1 and traffic from 10.210.0.128/26 through vr2.
Which configuration is correct in this scenario?
  • A.
  • B.
  • C.
  • D.
NEW QUESTION # 53
With the development of the electronic equipment, there are a lot of changes in the designs of our JN0-351 pass-sure torrent. The most impressive version is the APP online version. Normally, it can be used on all kinds of digital devices. But it also has the special advantage that the online version can be used when you are not online, As long as you use it for the first time in a networked environment, you can use the online version of our JN0-351 learning guide from anywhere without network connection. I believe the online version of our JN0-351 exam questions will be a good choice for you
Test JN0-351 Questions Pdf: https://www.actual4exams.com/JN0-351-valid-dump.html
During nearly ten years, our company has kept on improving ourselves on the JN0-351 study questions, and now we have become the leader in this field, Juniper Test JN0-351 Lab Questions Maybe you can replace the local repair shop, or at least help out your neighbor, Real4exams is providing customers with all IT certification exams Enterprise Routing and Switching, Specialist (JNCIS-ENT) real exam dumps, to make them to pass the JN0-351 test at the first attempt, With innovative science and technology our JN0-351 certification training: Enterprise Routing and Switching, Specialist (JNCIS-ENT) has grown as a professional and accurate exam materials that bring great advantages to all buyers.
Every communication device you own becomes JN0-351 part of the game, Introducing Web Cache Control Protocol, During nearly ten years,our company has kept on improving ourselves on the JN0-351 study questions, and now we have become the leader in this field.
Juniper - JN0-351 - Enterprise Routing and Switching, Specialist (JNCIS-ENT) Accurate Test Lab QuestionsMaybe you can replace the local repair shop, or at least help out your neighbor, Real4exams is providing customers with all IT certification exams Enterprise Routing and Switching, Specialist (JNCIS-ENT) real exam dumps, to make them to pass the JN0-351 test at the first attempt.
So with the help of the JN0-351 study material, you can easily to pass the actual test at first attempt.
P.S. Free 2026 Juniper JN0-351 dumps are available on Google Drive shared by Actual4Exams: https://drive.google.com/open?id=1dIkDhk58cUeCBs34h920owsmfsG9LiwA
