[General] Three Formats for Fortinet FCSS_SDW_AR-7.6 Exam Questions
96
【General】 Three Formats for Fortinet FCSS_SDW_AR-7.6 Exam Questions
Posted at 2/20/2026 02:18:23      View:117 | Replies:1        Print      Only Author   [Copy Link] 1#
All contents are being explicit to make you have explicit understanding of this exam. Some people slide over ticklish question habitually, but the experts help you get clear about them and no more hiding anymore. Their contribution is praised for their purview is unlimited. None cryptic contents in FCSS_SDW_AR-7.6 practice materials you may encounter.
Fortinet FCSS_SDW_AR-7.6 Exam Syllabus Topics:
  • SD-WAN Basic Setup: This domain covers initial SD-WAN configuration, member and zone setup, and Performance SLA creation for link monitoring.
  • Centralized Management: This domain addresses FortiManager-based SD-WAN deployment, branch configuration implementation, and overlay orchestration using SD-WAN Manager.
  • Rules and Routing: This section focuses on configuring SD-WAN rules for traffic steering and routing policies for path selection and failover.
  • SD-WAN Troubleshooting: This domain focuses on diagnosing SD-WAN rule behavior, routing issues, and ADVPN tunnel problems.
Topic 5
  • Advanced IPsec: This section covers hub-and-spoke topologies, ADVPN configuration, and scalable multihub and multiregion IPsec deployments.
Free PDF Fortinet - Updated FCSS_SDW_AR-7.6 Cert GuideWe always lay great emphasis on the quality of our FCSS_SDW_AR-7.6 study guide. Never have we been complained by our customers in the past ten years. The manufacture of our FCSS_SDW_AR-7.6 real exam is completely according with strict standard. We do not tolerate any small mistake. We have researched an intelligent system to help testing errors of the FCSS_SDW_AR-7.6 Exam Materials. That is why our FCSS_SDW_AR-7.6 practice engine is considered to be the most helpful exam tool in the market.
Fortinet FCSS - SD-WAN 7.6 Architect Sample Questions (Q50-Q55):NEW QUESTION # 50
Refer to the exhibits. The exhibits show two IPsec templates to define Branch IPsec 1 and Branch_IPsec_2. Each template defines a VPN tunnel. The error message that FortiManager displayed when the administrator tried to assign the second template to the FortiGate device is also shown. Which statement best describes the cause of the issue?
  • A. You can assign only one IPsec template to each FortiGate device.
  • B. You should use the same outgoing interface of both templates.
  • C. You can assign only one template with a tunnel type of static to each FortiGate device.
  • D. You should review the branch1_fgt configuration for configured tunnels in the rootVDOM.
FortiManager allows only one IPsec template to be assigned per FortiGate device. The error indicates a conflicting template assignment, meaning assigning both Branch_IPsec_1 and Branch_IPsec_2 to the same device (branch1_fgt) is not permitted.
NEW QUESTION # 51
You are tasked with configuring ADVPN 2.0 on an SD-WAN topology already configured for ADVPN. What should you do to implement ADVPN 2.0 in this scenario?
  • A. Delete the existing ADVPN configuration and configure ADVPN 2.0.
  • B. Update the SD-WAN configuration on the branches.
  • C. Update the IPsec tunnel configurations on the hub.
  • D. Update the IPsec tunnel configuration on the branches.
NEW QUESTION # 52
Refer to the exhibits. You use FortiManager to configure SD-WAN on three branch devices.
When you install the device settings. FortiManager prompts you with the error "Copy Failed" for the device branch1_fat When you click the log button. FortiManager displays the message shown in the exhibit.
Based on the exhibits, which statement best describes the issue and how you can resolve it?
  • A. Check the metadata variable definitions, and review the per-device mapping configuration.
  • B. Check the connection between branch1_fgt and FortiManager
  • C. Remove the installation target for the SD-WAN member port4. You cannot combine metadata variable and installation targets.
  • D. Gateways for all members in a zone must be defined the same way. Specify the gateway of the SD-WAN member port! without metadata variables.
The error message clearly states invalid ip addr for the metadata variable ${sdwan_port1_gw}, which means the per-device value for this variable is not defined or is incorrectly mapped. You must verify the metadata mapping for branch1_fgt to ensure that ${sdwan_port1_gw} is assigned a valid IP address.
NEW QUESTION # 53
SD-WAN interacts with many other FortiGate features. Some of them are required to allow SD-WAN to steer the traffic.
Which three configuration elements that you must configure before FortiGate can steer traffic according to SD-WAN rules? (Choose three.)
  • A. Routing
  • B. Traffic shaping
  • C. Security profiles
  • D. Interfaces
  • E. Firewall policies
Answer: A,D,E
Before FortiGate can steer traffic according to SD-WAN rules, certain configuration elements must be present. The guide states:
"SD-WAN is not a standalone feature and interacts with several fundamental FortiGate configurations. Specifically, you must: (1) Define the interfaces (physical, VLAN, or IPsec) that will act as SD-WAN members, (2) Create firewall policies to allow traffic to be steered by SD-WAN, and (3) Set up routing so that traffic has valid routes via SD-WAN members. Without these, SD-WAN rules will not be able to match or steer any traffic." Security profiles and traffic shaping are not mandatory for basic SD-WAN steering but can be layered on for enhanced security and QoS once foundational elements are present.
[FCSS_SDW_AR-7.4 1-0.docx Q16]
FortiOS 7.4 SD-WAN Concept Guide, "rerequisite Configuration Elements for SD-WAN Steering
NEW QUESTION # 54
An administrator is configuring SD-WAN to load balance their network traffic. Which two things should they consider when setting up SD-WAN? (Choose two.)
  • A. When applicable, FortiGate load balances the traffic through all members that meet the SLA target.
  • B. You can select the outbandwidth hash mode with all strategies that allow load balancing.
  • C. Only the manual and best-quality strategies allow SD-WAN load balancing.
  • D. SD-WAN load balancing is possible only using the best quality and lowest cost (SLA) strategies.
FortiGate load balances traffic across all members that meet the SLA targets, depending on the strategy used.
The outbandwidth hash mode can be selected with load-balancing strategies to distribute traffic based on flow characteristics.
NEW QUESTION # 55
Fortinet FCSS_SDW_AR-7.6 can ensure your success. So here comes Fortinet, who provides you with the Fortinet FCSS_SDW_AR-7.6 exam dumps to get your dream Fortinet FCSS_SDW_AR-7.6 certification with no hassle. Fortinet FCSS_SDW_AR-7.6 Certification will add up to your excellence in your field and leave no space for any doubts in the mind of the hiring team.
FCSS_SDW_AR-7.6 Pdf Braindumps: https://www.exam-killer.com/FCSS_SDW_AR-7.6-valid-questions.html
Posted at 3/6/2026 20:31:34        Only Author  2#
Your article is magnificent, I truly appreciate your generosity in sharing! Get free New 300-740 test braindumps to elevate your IT abilities. Best of luck in your exams!
