[General] 獲取最新的NS0-528證照信息 -所有都在Fast2test
135
【General】 獲取最新的NS0-528證照信息 -所有都在Fast2test
Posted at 2/20/2026 19:32:47      View:83 | Replies:0        Print      Only Author   [Copy Link] 1#
Fast2test就是一個能成就很多IT專業人士夢想的網站。如果你有IT夢,就趕緊來Fast2test吧,它有超級好培訓資料即Fast2test Network Appliance的NS0-528考試培訓資料, 這個培訓資料是每個IT人士都非常渴望的,因為它會讓你通過考試獲得認證,從此以後在職業道路上步步高升。
Network Appliance NS0-528 考試大綱:
主題簡介
主題 1
  • Troubleshooting and Testing: This section of the exam measures the skills of Support Engineers and focuses on the practical skills needed to maintain data integrity. It involves troubleshooting common data protection configuration issues, executing well-defined Disaster Recovery (DR) procedures, and performing data restore operations to recover from data loss.
主題 2
  • NetApp Data Protection Software: This section of the exam measures the skills of DevOps Engineers and focuses on the deployment and administration of NetApp's proprietary data protection software. A key part of this domain involves applying these solutions to protect modern containerized applications running in Kubernetes environments.
主題 3
  • NetApp ONTAP Business Continuity Solutions: This section of the exam measures the skills of Disaster Recovery Specialists and covers advanced business continuity technologies. This includes the configuration and operation of SnapMirror active sync for continuous data replication and the execution of SVM-DR (Storage Virtual Machine Disaster Recovery) operations to ensure high availability.
主題 4
  • Data Protection Solutions: This section of the exam measures the skills of Storage Architects and covers the foundational principles of designing data protection solutions. It focuses on creating comprehensive design documentation, understanding the various components involved, and identifying all critical solution dependencies to ensure a robust and reliable data protection strategy.
主題 5
  • NetApp ONTAP Core Data Protection Features: This section of the exam measures the skills of Systems Administrators and validates core knowledge of data protection and redundancy within the ONTAP environment. It encompasses understanding how data efficiencies impact protection strategies and the practical knowledge required to deploy these data protection solutions effectively in a hybrid cloud infrastructure.
最受推薦的NS0-528證照信息,免費下載NS0-528考試指南幫助妳通過NS0-528考試我們Fast2test Network Appliance的NS0-528考題按照相同的教學大綱,其次是實際的NS0-528認證考試,我們也在不斷升級我們的培訓資料,使你在第一時間得到最好和最新的資訊。當你購買我們NS0-528的考試培訓材料,你所得到的培訓資料有長達一年的免費更新期,你可以隨時延長更新訂閱時間,讓你有更久的時間來準備考試。
最新的 NCIE-Data-Protection NS0-528 免費考試真題 (Q65-Q70):問題 #65
A customer has a MetroCluster configuration and wants to automate the disaster recovery process for unplanned automatic switchover.
Which NetApp tool would accomplish this task?
  • A. ONTAP System Manager
  • B. Active IQ Unified Manager
  • C. SnapCenter
  • D. ONTAP Mediator
答案:B
問題 #66
You experience a node outage as a result of a component failure in a high-availability (HA) pair. You replace the failed component and get thenode booted up again, but are unable to perform the giveback operation.
The onscreen error is:
"Connected to partner, Takeover is not possible: Storage failover mailbox disk state is invalid, Local node has encountered errors while reading the storage failover partner's mailbox disks. Local node missing partner disks" What are two ways to solve this problem? (Choose two.)
  • A. Destroy the mailboxes on both nodes.
  • B. Destroy the root aggregate.
  • C. Correct the shelf cabling errors.
  • D. Correct the failover group configuration.
答案:C,D
問題 #67
In a MetroCluster IP configuration, which two network portsmust be connected to dedicated switches? (Choose two.)
  • A. the port associated with the node management LIF
  • B. the port associated with the cluster LIF
  • C. the port associated with the MetroCluster IP LIF
  • D. the port associated with the intercluster LIF
答案:A,B
問題 #68
Exhibit:
Referring to the exhibit, which two tiers are monitored in the volume capacity? (Choose two)
  • A. licensed
  • B. metadata
  • C. performance
  • D. capacity
答案:C,D
問題 #69
A company just installed SnapCenter to help manage their ONTAP 9.7 environment. The database administrator wants to add new volumes with LUNs for a 10 TB Oracle database.
Which two tools would accomplish this task? (Choose two.)
  • A. SnapCenter Plug-in for Oracle Database
  • C. ONTAP System Manager
  • D. OnCommand Insight
答案:A,C
問題 #70
NS0-528 專業認證是一項擁有極高國際聲譽的專業認證,獲取 NS0-528 全球專業認證,既是你自身技術能力的體現,也將幫助你開創美好的未來,在激烈的竟爭中處於領先位置。有很多已經通過了一些IT認證考試的人使用了 Fast2test 提供的練習題和答案,其中也有通過 NS0-528 認證考試,他們也是利用的這個,Network Appliance NS0-528 考題包括PDF格式和模擬考試測試版本兩種,方便考生利用最新的擬真試題仔細地複習備考。
NS0-528考題套裝: https://tw.fast2test.com/NS0-528-premium-file.html
