Test AZ-305 Simulator Online | Top AZ-305 Dumps
107
Posted at 2/23/2026 04:26:25      View113 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New AZ-305 dumps are available on Google Drive shared by ActualTestsQuiz: https://drive.google.com/open?id=1PcRhINFLVf0iO5RRGjCmqj8G0HRkr7-g
You have seen ActualTestsQuiz's Microsoft AZ-305 Exam Training materials, it is time to make a choice. You can choose other products, but you have to know that ActualTestsQuiz can bring you infinite interests. Only ActualTestsQuiz can guarantee you 100% success. ActualTestsQuiz allows you to have a bright future. And allows you to work in the field of information technology with high efficiency.
For there are some problems with those still in the incubation period of strict control, thus to maintain the AZ-305 quiz guide timely, let the user comfortable working in a better environment. You can completely trust the accuracy of our Microsoft AZ-305 Exam Questions because we will full refund if you failed exam with our training materials.
Top AZ-305 Dumps, Exam AZ-305 Pass GuideAs is known to us, people who want to take the AZ-305 exam include different ages, different fields and so on. It is very important for company to design the AZ-305 exam prep suitable for all people. However, our company has achieved the goal. We can promise that the AZ-305 test questions from our company will be suitable all people. There are many functions about our study materials beyond your imagination. You can purchase our AZ-305 reference guide according to your own tastes. We believe that the understanding of our AZ-305 study materials will be very easy for you.
Microsoft Designing Microsoft Azure Infrastructure Solutions Sample Questions (Q240-Q245):NEW QUESTION # 240
You are designing an Azure web app.
You plan to deploy the web app to the North Europe Azure region and the West Europe Azure region.
You need to recommend a solution for the web app. The solution must meet the following requirements:
Users must always access the web app from the North Europe region, unless the region fails.
The web app must be available to users if an Azure region is unavailable.
Deployment costs must be minimized.
What should you include in the recommendation? To answer, select the appropriate options in the answer area.
Graphical user interface, text, application, chat or text message Description automatically generated
https://docs.microsoft.com/en-us ... ty-traffic-routing-
NEW QUESTION # 241
You plan to migrate on-premises Microsoft SQL Server databases to Azure.
You need to recommend a deployment and resiliency solution that meets the following requirements:
Supports user-initiated backups
Supports multiple automatically replicated instances across Azure regions Minimizes administrative effort to implement and maintain business continuity What should you recommendation? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... eplication-overview
NEW QUESTION # 242
You have an on-premises database that you plan to migrate to Azure.
You need to design the database architecture to meet the following requirements:
Support scaling up and down.
Support geo-redundant backups.
Support a database of up to 75 TB.
Be optimized for online transaction processing (OLTP).
What should you include in the design? To answer, select the appropriate options in the answer area.
NOTE:Each correct selection is worth one point.
Box 1: Azure SQL Database
Azure SQL Database:
Database size always depends on the underlying service tiers (e.g. Basic, Business Critical, Hyperscale).
It supports databases of up to 100 TB with Hyperscale service tier model.
Active geo-replication is a feature that lets you to create a continuously synchronized readable secondary database for a primary database. The readable secondary database may be in the same Azure region as the primary, or, more commonly, in a different region. This kind of readable secondary databases are also known as geo-secondaries, or geo-replicas.
Azure SQL Database and SQL Managed Instance enable you to dynamically add more resources to your database with minimal downtime.
Box 2: Hyperscale
https://medium.com/awesome-azure ... server-on-vm-compar
NEW QUESTION # 243
You have an app that generates 50,000 events daily.
You plan to Stream the events to an Azure event hub and use Event Hubs Capture to implement cold path processing Of the events Output Of Event Hubs Capture will be consumed by a reporting system.
You reed to identify which type of Azure storage must be provisioned to support Event Hubs Capture, and which inbound data format the reporting system must support.
What should you identity? To answer. select the appropriate options in the answer area.
NEW QUESTION # 244
You need to design a highly available Azure SQL database that meets the following requirements:
* Failover between replicas of the database must occur without any data loss.
* The database must remain available in the event of a zone outage.
* Costs must be minimized.
Which deployment option should you use?
  • A. Azure SQL Database Managed Instance Business Critical
  • B. Azure SQL Database Hyperscale
  • C. Azure SQL Database Business Critical
  • D. Azure SQL Database Standard
https://docs.microsoft.com/en-us ... r-business-critical
NEW QUESTION # 245
It is known to us that our AZ-305 study materials are enjoying a good reputation all over the world. Our study materials have been approved by thousands of candidates. You may have some doubts about our product or you may suspect the pass rate of it, but we will tell you clearly, it is totally unnecessary. If you still do not trust us, you can choose to download demo of our AZ-305 Test Torrent. The high quality and the perfect service system after sale of our AZ-305 exam questions have been approbated by our local and international customers. So you can rest assured to buy.
Top AZ-305 Dumps: https://www.actualtestsquiz.com/AZ-305-test-torrent.html
The finicky points can be solved effectively by using our AZ-305 practice materials, Microsoft Test AZ-305 Simulator Online Does your study material work in the actual test, You may wonder why we have this confidence to guarantee you 100% pass exam with our AZ-305 PDF & test engine dumps or AZ-305 actual test questions, You can customize the time and types of these Microsoft Top AZ-305 Dumps Questions.
Listen to Apple Music, Using iPad's Settings app, you can choose the search engine that Safari uses as its default, The finicky points can be solved effectively by using our AZ-305 practice materials.
Trustworthy Test AZ-305 Simulator Online & Leader in Qualification Exams & Valid AZ-305: Designing Microsoft Azure Infrastructure SolutionsDoes your study material work in the actual test, You may wonder why we have this confidence to guarantee you 100% pass exam with our AZ-305 PDF & test engine dumps or AZ-305 actual test questions.
You can customize the time and types of these Microsoft Questions, The AZ-305 dumps are best for your 100% success in Microsoft certification.
