[General] PSM-I資料和資格考試中的領先提供者&PSM-I:Professional Scrum Master I
138
【General】 PSM-I資料和資格考試中的領先提供者&PSM-I:Professional Scrum Master I
Posted at 2 hour before      View:13 | Replies:0        Print      Only Author   [Copy Link] 1#
此外,這些NewDumps PSM-I考試題庫的部分內容現在是免費的:https://drive.google.com/open?id=11Xykouu5ZwrY7u5EuUooZcbd_isEbft4
NewDumps是促使IT人士成功的最好的催化劑。很多人通過了IT相關認證考試的人就是使用了我們的NewDumps的培訓工具。我們的NewDumps的專家團隊利用自己的經驗為參加Scrum PSM-I 認證考試的很多人研究出了最新的有效的培訓工具,包括Scrum PSM-I 認證考試測試,考前試題,試題答案。我們的NewDumps提供的試題及答案和真正的試題有95%的相似性。使用NewDumps的培訓工具,您的Scrum PSM-I 認證考試是可以很輕鬆的通過的。
你肯定聽說過NewDumps的PSM-I考古題吧?但是,你用過嗎?我們經常會聽到“NewDumps的考古題真是好資料,多虧了它我才通過了考試”這樣的話。NewDumps從使用過考古題的人們那裏得到了很多的好評。這是因為它確實能幫助考生們節省很多時間,並保證大家順利通過考試。
有效的PSM-I資料,最新的考試題庫幫助妳快速通過PSM-I考試您選擇我們的NewDumps來幫助你通過Scrum PSM-I 認證考試試是一個明智的選擇。你可以先線上免費下載NewDumps為你提供的關於Scrum PSM-I 認證考試練習題及答案的試用版本作為嘗試,那樣你會更有信心選擇我們NewDumps的產品來準備Scrum PSM-I 認證考試。如果你考試失敗,我們會全額退款給你。
最新的 Professional Scrum Master PSM-I 免費考試真題 (Q172-Q177):問題 #172
Which of these may a Development Team deliver at the end of a Sprint?
  • A. Failing unit tests, to identify acceptance tests for the next Sprint.
  • B. An increment of working software that is "done".
  • C. An increment of software with minor known bugs in it.
  • D. A single document, if that is what the Scrum Master asked for.
答案:B
解題說明:
The correct answer is C, because a Development Team should deliver an increment of working software that is "done" by the end of a Sprint. The Scrum Guide states that "the Increment is the sum of all the Product Backlog items completed during a Sprint and the value of the increments of all previous Sprints. At the end of a Sprint, the new Increment must be 'Done,' which means it must be in useable condition and meet the Scrum Team's definition of 'Done'."
問題 #173
What happens if the Scrum Team cannot complete its work by the end of the Sprint?
(choose the best answer)
  • A. The Sprint is extended temporarily. Lessons are taken to ensure it does not happen again.
  • B. The Sprint length is unchanged and the Scrum Team continuously learns and adapts.
  • C. The Sprint is extended and future Sprints use this new duration.
答案:B
解題說明:
The best answer is B. The Sprint length is unchanged and the Scrum Team continuously learns and adapts.
According to the Scrum Guide1, "Sprints have consistent durations throughout a development effort. A new Sprint starts immediately after the conclusion of the previous Sprint." Therefore, the Sprint is not extended or shortened based on the completion of the work.
The Scrum Guide also states that "Scrum Teams deliver products iteratively and incrementally, maximizing opportunities for feedback. Incremental deliveries of 'Done' product ensure a potentially useful version of working product is always available." Therefore, the Scrum Team should focus on delivering a potentially releasable Increment of value by the end of the Sprint, even if some work items are not completed.
The Scrum Team should also use the Sprint Retrospective to inspect how the last Sprint went with regards to individuals, interactions, processes, tools, and their Definition of Done. The Scrum Team should identify and order the major items that went well and potential improvements, and create a plan for implementing improvements to the way they do their work. This way, the Scrum Team continuously learns and adapts to changing circumstances and challenges.
問題 #174
When should a Sprint Goal be created?
  • A. At any time during the Sprint.
  • B. During Sprint Planning.
  • C. A Sprint Goal is not mandatory in Scrum.
  • D. It should have been created in the previous Sprint during Product Backlog refinement.
  • E. It must be established before Sprint Planning in order to begin planning.
答案:B
問題 #175
Which of the following might the Scrum Team discuss during a Sprint Retrospective?
  • A. Methods of communication.
  • B. Its Definition of "Done".
  • C. All of the above.
  • D. The way the Scrum Team does Sprint Planning.
  • E. Skills needed to improve the Development Team's ability to deliver.
答案:C
解題說明:
Explanation/Reference:
問題 #176
What is the function or purpose of management in Scrum?
  • A. To continually monitor staffing levels of the Scrum Team.
  • B. To monitor the productivity of the Developers.
  • C. To present the Scrum Teams with insights and resources that help them improve.
  • D. To identify and remove people that are not working hard enough.
答案:C
解題說明:
The correct answer is B. To present the Scrum Teams with insights and resources that help them improve. According to the Scrum Guide1, "The role of management in Scrum is to support the Product Owner with insights and information into high-value product and system capabilities." Management also helps the Scrum Team by providing an environment that fosters agility, learning, and collaboration2. Management does not directly control or monitor the work of the Developers, nor does it interfere with the self-organization and autonomy of the Scrum Team3. Management's function in Scrum is to enable and empower the Scrum Team to deliver value and continuously improve.
問題 #177
在這個都把時間看得如此寶貴的社會裏,選擇NewDumps來幫助你通過Scrum PSM-I 認證考試是划算的。如果你選擇了NewDumps,我們承諾我們將盡力幫助你通過考試,並且還會為你提供一年的免費更新服務。如果你考試失敗,我們會全額退款給你。
PSM-I權威考題: https://www.newdumpspdf.com/PSM-I-exam-new-dumps.html
Scrum PSM-I資料 考試很順利,基本完全覆蓋,唯壹要註意的就是背題庫的時候不能死記硬背,壹點要理解性背誦,最近,參加 Professional Scrum Master I 考試認證的人比較多,NewDumps為了幫助大家通過認證,正在盡最大努力為廣大考生提供具備較高的速度和效率的服務,以節省你的寶貴時間,PSM-I 考試題庫就是這樣的考試指南,它是由我們專業IT認證講師及產品專家精心打造,包括考古題及答案,Scrum PSM-I資料 如果你不知道如何更有效的通過考試,我給你一個建議是選擇一個良好的培訓網站,這樣可以起到事半功倍的效果,Scrum PSM-I認證考試是一個對IT專業人士的知識水準的檢驗的考試。
在天雷下降的那壹刻之下清資倒下的那壹刻烏雲也是消失得無影無蹤了,沈默了壹下,女PSM-I郎中鄭重的提醒道,考試很順利,基本完全覆蓋,唯壹要註意的就是背題庫的時候不能死記硬背,壹點要理解性背誦,最近,參加 Professional Scrum Master I 考試認證的人比較多,NewDumps為了幫助大家通過認證,正在盡最大努力為廣大考生提供具備較高的速度和效率的服務,以節省你的寶貴時間,PSM-I 考試題庫就是這樣的考試指南,它是由我們專業IT認證講師及產品專家精心打造,包括考古題及答案。
完整的PSM-I資料 |第一次嘗試輕鬆學習並通過考試,100%合格率Scrum Professional Scrum Master I如果你不知道如何更有效的通過考試,我給你一個建議是選擇一個良好的培訓網站,這樣可以起到事半功倍的效果,Scrum PSM-I認證考試是一個對IT專業人士的知識水準的檢驗的考試,在PSM-I考試中又有哪些注意問題?
