PDII-JPN Pass Test, Valid PDII-JPN Study Notes
140
Posted at 1 hour before      View:2 | Replies:0        Print      Only Author   [Copy Link] 1#
The PDII-JPN test materials are mainly through three learning modes, Pdf, Online and software respectively. Among them, the software model is designed for computer users, can let users through the use of Windows interface to open the PDII-JPN test prep of learning. It is convenient for the user to read. The PDII-JPN test materials have a biggest advantage that is different from some online learning platform which has using terminal number limitation, the PDII-JPN Quiz torrent can meet the client to log in to learn more, at the same time, the user can be conducted on multiple computers online learning, greatly reducing the time, and people can use the machine online of PDII-JPN test prep more conveniently at the same time. As far as concerned, the online mode for mobile phone clients has the same function.
The  web-based practice exam has all the features of the desktop software, but it requires an active internet connection. If you are busy in your daily routine and cant manage a proper time to sit and prepare for the PDII-JPN certification test, our  PDII-JPN PDF Questions file is ideal for you. You can open and use the PDII-JPN Questions from any location at any time on your smartphones, tablets, and laptops. Questions in the  PDII-JPN PDF document are updated, and real.
Unparalleled PDII-JPN Pass Test by TroytecDumpsThe 24/7 support system is there for the students to assist them in the right way and solve their real issues quickly. The TroytecDumps Salesforce PDII-JPN can be used instantly after buying it from us. Free demos and up to 1 year of free updates are also available at SITE. Buy the TroytecDumps Salesforce PDII-JPN Now and Achieve Your Dreams With Us!
Salesforce  Sample Questions (Q41-Q46):NEW QUESTION # 41
開発者がカレンダーを表示するLightning Webコンポーネントを作成しています。このコンポーネントは複数の国で使用されます。ロケールによっては、週の最初の曜日が月曜日、土曜日、または日曜日になることがあります。開発者は、すべてのロケールのユーザーにカレンダーが正しく表示されるようにするために、何をすべきでしょうか?
  • A. 現在のユーザーのロケールから FirstDayOfWeek フィールドを照会します。
  • B. カスタム メタデータ タイプを使用して、キーと値のペアを保存します。
  • C. コンポーネントで UserInfo.getLocale() を使用します。
  • D. @salesforce/i18n モジュールをインポートし、firstDayOfWeek 国際化プロパティを使用します。
When building global applications in Lightning Web Components (LWC), developers should never hardcode locale-specific logic. Salesforce provides a robust Internationalization (i18n) service that exposes the current user's regional settings directly to the JavaScript controller.9 The correct approach is to import the @salesforce/i18n module (Option D). This module contains several properties that are automatically populated based on the logged-in user's Salesforce profile settings.
Specifically, the firstDayOfWeek property 10returns an integer (0 for Sunday, 1 for Monday, etc.) that corresponds to the cultural standard of the user's locale.
Using this built-in property is superior to other methods because:
* It requires no Apex callouts or SOQL queries (unlike Option A and C).
* It is automatically maintained by Salesforce; as global standards change, the platform updates the i18n values, ensuring the component remains compliant without developer intervention.
* It avoids the maintenance overhead of creating custom metadata (Option B) to map every possible locale to a starting day.
By leveraging @salesforce/i18n/firstDayOfWeek, the developer ensures the calendar component is truly global and provides a native, localized experience for every user regardless of their country.
NEW QUESTION # 42
開発者は、取引先の最近連絡した 5 人の取引先責任者を表示する取引先レコードページの Lightning Web コンポーネントを作成しました。Apex メソッド Contacts は連絡先のリストを返し、コンポーネントのプロパティに関連付けられます。
Apex メソッドを接続できるようにするには、上記のコードのどの 2 行を変更する必要がありますか?
2 つの答えを選択してください
  • A. 09 行目から private を削除します。
  • B. @AuraEnabled {cacheable=trues) を 08 行目に追加します。
  • C. @AuraEnabled {cacheable=true) を行 03 に追加します。
  • D. 04行目にpublicを追加します。
To make the Apex method able to be wired, the developer should change two lines in the code: add public to line 04, and add @AuraEnabled(cacheable=true) to line 03. Adding public to line 04 makes the Apex method accessible from outside the class, which is required for the @wire decorator to invoke the method. Adding @AuraEnabled(cacheable=true) to line 03 makes the Apex method cacheable, which means that the method can be invoked by a Lightning web component that uses the @wire decorator. This also improves the performance of the component, as it reduces the number of server trips and leverages the client-side cache. The developer should use this annotation for methods that return data that does not change frequently or does not depend on the user context. Adding @AuraEnabled(cacheable=true) to line 08 is not necessary, as the cacheable attribute only applies to the top-level method that is invoked by the @wire decorator, not to the helper methods that are called within the class. Removing private from line 09 is not necessary, as the helper method can be private as long as it is called from within the class. Reference: [Call Apex Methods from Lightning Web Components], [Marking Methods as Storable or Cacheable]
NEW QUESTION # 43
Account オブジェクトには、アカウントに必要な監査の種類を指定するために使用されるフィールド Audit_Code_c と、割り当てられた監査人であるユーザーのルックアップ zudizar_c があります。アカウントが最初に作成されるとき、ユーザーは Audit_Code を指定します。組織内の各ユーザーには、固有のテキスト フィールド Audit_Code _e があり、これはアカウントの Auditor_c フィールドに正しいユーザーを自動的に割り当てるために使用されます。
コードの効率を最大限に最適化するには何を変更する必要がありますか?
2 つの答えを選択してください
  • A. コードを監査するためのアカウント ID のマップ<Id, リスト<文字列>>を構築します。
  • B. SOQL クエリに WHERE 句を追加して、監査コードでフィルタリングします。
  • C. 最初の SOQL クエリを追加して、すべての個別の監査コードを取得します。
  • D. 監査コードからアカウントへの Map<string, List<Account>> を構築します。
NEW QUESTION # 44
開発者は、無限ループをトリガーするアプリケーション イベントを作成します。
この問題の原因は何でしょうか?
  • A. イベントは「ontouchend」で発生し、処理されません。
  • B. イベント ハンドラーがトリガーを呼び出します。
  • C. イベントはカスタム レンダラから発生します。
  • D. イベントにはプロジェクトに複数のハンドラーが登録されています。
The infinite loop in the application event could be caused by multiple handlers registered in the project. If the event is fired and then handled in such a way that the handling leads to the event being fired again, this can create a loop. Care must be taken to ensure that the handling of the event does not re-trigger the same event unintentionally.References: Aura Components Developer Guide - Application Events
NEW QUESTION # 45
一括安全な Apex トリガを作成するためのベストプラクティスと考えられるステートメントはどれですか?
  • A. レコードをコレクションに追加し、これらのコレクションに対して DML 操作を実行します。
  • B. すべての DML 操作を future メソッド内から実行します。
  • C. DML ステートメントの代わりに、allorNone を £21s= に設定してデータベース メソッドを使用します。
  • D. すべての SOQL ステートメントに LIMIT 50000 を追加します。
Bulk-safe triggers use collections to aggregate DML operations. This practice minimizes the number of DML statements, which is essential for bulk processing.
References: Apex Developer Guide - Bulk Trigger Best Practices
NEW QUESTION # 46
With TroytecDumps, you don't have to waste money, because we offer up to 365 days of free updates of actual PDII-JPN exam questions. These free updates of valid  (PDII-JPN) exam dumps will help you keep preparing as per the new updates. Are you still confused about the authenticity of PDF or  (PDII-JPN) practice exam software? No problem. Visit TroytecDumps try a free demo version of Salesforce PDII-JPN Exam Dumps for your satisfaction. Moreover, the  (PDII-JPN) exam study material of TroytecDumps are cost-effective. You should not miss this golden chance and buy updated and real Salesforce PDII-JPN exam dumps at an affordable price.
Valid PDII-JPN Study Notes: https://www.troytecdumps.com/PDII-JPN-troytec-exam-dumps.html
Be alert and use the helping tools for your preparation for the latest PDII-JPN cbt, Our PDII-JPN study materials are filled with useful knowledge, which will broaden your horizons and update your skills, Salesforce PDII-JPN Pass Test They still fail because they just remember the less important point, Salesforce PDII-JPN Pass Test If you want to simplify the preparation process, here comes a piece of good news for you.
Whether you are a FileMaker developer who is new to web publishing, PDII-JPN Pass Test a web developer who is new to FileMaker, or a complete beginner looking to put your data online, this book is for you.
Why Manage User Access, Be alert and use the helping tools for your preparation for the latest PDII-JPN cbt, Our PDII-JPN study materials are filled with useful knowledge, which will broaden your horizons and update your skills.
2026 PDII-JPN Pass Test | Reliable Salesforce PDII-JPN:  100% PassThey still fail because they just remember the less PDII-JPN important point, If you want to simplify the preparation process, here comes a piece of good news for you, Because we endorse customers' opinions and drive of passing the PDII-JPN certificate, so we are willing to offer help with full-strength.
