[General] Cert CIS-Discovery Guide, Latest CIS-Discovery Braindumps Files
【General】 Cert CIS-Discovery Guide, Latest CIS-Discovery Braindumps Files
Posted at yesterday 14:17      View:16 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that Pass4SureQuiz CIS-Discovery dumps now are free: https://drive.google.com/open?id=1cy1h2IOnWms3X9rjJZrKbblc3Aigrbc8
Whereas the CIS-Discovery PDF file is concerned this file is the collection of real, valid, and updated ServiceNow CIS-Discovery exam questions. You can use the ServiceNow CIS-Discovery PDF format on your desktop computer, laptop, tabs, or even on your smartphone and start Certified Implementation Specialist - Discovery (CIS-Discovery) exam questions preparation anytime and anywhere.
To become a ServiceNow CIS-Discovery Certified, candidates are required to demonstrate a deep understanding of ServiceNow Discovery and its related technologies. Certified Implementation Specialist - Discovery certification exam consists of 60 multiple-choice questions, and candidates are given 90 minutes to complete the exam. A passing score of 70% or higher is required to achieve certification.
Latest CIS-Discovery Braindumps Files, CIS-Discovery Latest Test GuideOur CIS-Discovery qualification test guide boosts the self-learning and self-evaluation functions so as to let the clients understand their learning results and learning process of CIS-Discovery exam questions , then find the weak links to improve them. Through the self-learning function the learners can choose the learning methods by themselves and choose the contents which they think are important. Through the self-evaluation function the learners can evaluate their mastery degree of our CIS-Discovery test materials and their learning process.
ServiceNow Certified Implementation Specialist - Discovery Sample Questions (Q73-Q78):NEW QUESTION # 73
Which choice best represents how to modify the functionality shown in this image?
  • A. From the MID Server
  • B. From a Probe
  • C. From a Classifier
  • D. From a Discovery Pattern
The functionality shown in the image is related to the Tracked Configuration files feature of ServiceNow Discovery. This feature allows Discovery to track changes in configuration files on Windows and Unix hosts and store them as configuration items (CIs) in the CMDB1. To modify this functionality, such as adding or removing files to track, changing the file attributes to capture, or defining the CI relationships, one needs to edit the Discovery Pattern that is associated with the Tracked Configuration files classifier2. A Discovery Pattern is a series of operations that tell Discovery how to find and identify an application or a configuration file on a host3.
* 1: Tracked Configuration files - Product Documentation: San Diego - ServiceNow
* 2: Tracked Configuration files pattern - Product Documentation: San Diego - ServiceNow
* 3: Patterns and horizontal discovery - Product Documentation: Tokyo - ServiceNow
NEW QUESTION # 74
After running Discovery and viewing the ECC Queue tab, what are some of the displayed default fields?
(Choose three.)
  • A. Pattern log link
  • B. CMDB CI
  • C. Topic
  • D. Queue
  • E. Discovery schedule name
  • F. Source
  • G. Details
Answer: C,D,F
The ECC Queue tab displays the input and output messages from and to MID Servers. The default fields that are displayed on this tab are:
* Topic: The topic of the message, such as Discovery, Orchestration, or MID Server.
* Queue: The queue name of the message, such as input, output, or error.
* Source: The source of the message, such as the MID Server name, the instance name, or the probe name.
* State: The state of the message, such as ready, processed, or ignored.
* Created: The date and time when the message was created.
* Updated: The date and time when the message was last updated.
Some other fields that can be added to the ECC Queue tab are:
* Details: The details of the message, such as the payload, the response, or the error message.
* Pattern log link: The link to the pattern log file, if the message is related to a pattern execution.
* CMDB CI: The configuration item that is associated with the message, if any.
* Discovery schedule name: The name of the discovery schedule that triggered the message, if any.
References: ECC Queue Processing and Debugging, with "Discovery - Sensors" used as an example, The ECC queue for Discovery
NEW QUESTION # 75
Which choice represents the three best ways of extending Discovery?
  • A. Orchestration, Classifiers, Discovery Patterns
  • B. Classifiers, Probes & Sensors, Discovery Patterns
  • C. Fingerprinting, Classifiers, Discovery Patterns
  • D. Orchestration, Classifiers, Probes & Sensors
  • E. Classifiers, Fingerprinting, Probes & Sensors
ServiceNow Discovery can be extended in three main ways: Classifiers, Probes & Sensors, and Discovery Patterns. Classifiers are used to identify the type of device or application that is being discovered, based on the information returned by a probe. Probes are commands or scripts that are executed on the target device or application to collect data. Sensors are scripts that process the data collected by probes and create or update configuration items (CIs) in the CMDB. Discovery Patterns are graphical representations of the discovery process that can be customized or created to discover specific types of devices or applications, using classifiers, probes, and sensors as building blocks.
Discovery overview - Product Documentation: Vancouver - Now Support Portal Create a Discovery CI classification - Product Documentation: Vancouver - Now Support Portal Discovery probes and sensors - Product Documentation: Vancouver - Now Support Portal Discovery patterns - Product Documentation: Vancouver - Now Support Portal
NEW QUESTION # 76
Which service needs to be running on a host to detect a Windows device?
  • A. SSH
  • B. CM
  • C. WM
  • D. WinkM
NEW QUESTION # 77
Which of the following best describes the relationship between the Tomcat [cmdb_ci_app_server_tomcat] table and the Application Server [cdmb_ci_app_server] table? (Choose two.)
  • A. Tomcat table is a child of the Application Server table
  • B. Tomcat table is a parent of the Application Server table The mid.discovery.max_pattern_payload_size property defines the maximum overall size for the returned payload that comes from patterns. This property is set on the MID Server and applies to all patterns that run on that MID Server. If the payload size exceeds this limit, the pattern execution fails and an error message is logged in the ECC queue. The default value of this property is 10 MB1.
    References: 1: ServiceNow Docs - MID Server properties for Discovery and Service Mapping 2:
    ServiceNow Docs - Discovery payload size and processing
  • C. Tomcat does not extend the Application Server table
  • D. Tomcat table extends the Application Server table
To create a custom horizontal pattern to discover an operating system that is not discovered by the base installation patterns, the following steps are necessary1:
* Select a CI Type: This defines the type of configuration item (CI) that the pattern will discover and create or update in the CMDB. For an operating system, the CI Type should be Operating System or a subtype of it.
* Select Infrastructure Pattern Type: This defines the type of pattern that will be used to discover the CI.
For an operating system, the Infrastructure Pattern Type should be Operating System or a subtype of it.
* Define the pattern logic: This consists of adding operations, variables, and conditions to the pattern to specify how the discovery process will identify and classify the operating system. For example, the pattern can use probes and sensors to query the target device for information such as name, version, vendor, etc.
* Test and publish the pattern: This involves verifying that the pattern works as expected and does not cause any errors or conflicts with other patterns. Once the pattern is tested, it can be published and activated for discovery.
References: 1: Create a horizontal discovery pattern - ServiceNow
NEW QUESTION # 78
Have you been many years at your position but haven't got a promotion? Or are you a new comer in your company and eager to make yourself outstanding? Our CIS-Discovery exam materials can help you. After a few days' studying and practicing with our CIS-Discovery products you will easily pass the examination. God helps those who help themselves. If you choose our CIS-Discovery Study Materials, you will find God just by your side. The only thing you have to do is just to make your choice and study. Isn't it very easy? So know more about our CIS-Discovery study guide right now!
Latest CIS-Discovery Braindumps Files: https://www.pass4surequiz.com/CIS-Discovery-exam-quiz.html
BONUS!!! Download part of Pass4SureQuiz CIS-Discovery dumps for free: https://drive.google.com/open?id=1cy1h2IOnWms3X9rjJZrKbblc3Aigrbc8
