Passing HP HPE7-A01 Score Feedback | HPE7-A01 VCE Exam Simulator
138
Posted at 10 hour before      View:22 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that PracticeDump HPE7-A01 dumps now are free: https://drive.google.com/open?id=1sZgWbQtK3wQhthT0dyIqD14-bRRHI8Cd
PracticeDump HP HPE7-A01 Dumps are validated by many more candidates, which can guarantee a high success rate. After you use our dumps, you still fail the exam so that PracticeDump will give you FULL REFUND. Or you can choose to free update your exam dumps. With such protections, you don't need to worry.
The ACCP certification validates the knowledge and skills required to design, implement, and manage Aruba wireless networks in enterprise environments. It demonstrates that the certified professional has a deep understanding of Aruba wireless products and technologies, as well as the ability to troubleshoot and optimize Aruba wireless networks.
Free PDF HP - HPE7-A01 - Aruba Certified Campus Access Professional Exam Unparalleled Passing Score FeedbackThis is a wise choice, after using our HPE7-A01 training materials, you will realize your dream of a promotion because you deserve these reports and your efforts will be your best proof. Therefore, when you are ready to review the exam, you can fully trust our products, choose our learning materials. If you don't want to miss out on such a good opportunity, buy it quickly. Thus, users do not have to worry about such trivial issues as typesetting and proofreading, just focus on spending the most practice to use our HPE7-A01 Learning Materials. After careful preparation, I believe you will be able to pass the exam.
HP Aruba Certified Campus Access Professional Exam Sample Questions (Q124-Q129):NEW QUESTION # 124
How is Multicast Transmission Optimization implemented in an HPE Aruba wireless network?
  • A. The optimal rate for sending multicast frames is based on the lowest unicast rate across all associated clients.
  • B. When this option is enabled the minimum default rate for multicast traffic is set to 12 Mbps for 5 GHz
  • C. The optimal rate for sending multicast frames is based on the lowest broadcast rate across all associated clients.
  • D. "The optimal rate for sending multicast frames is based on the highest broadcast rate across all associated clients
multicast transmission optimization is a feature that allows the IAP to select the optimal rate for sending broadcast and multicast frames based on the lowest of unicast rates across all associated clients1. When this option is enabled, multicast traffic can be sent at up to 24 Mbps. The default rate for sending frames for 2.4 GHz is 1 Mbps and 5.0 GHz is 6 Mbps. This option is disabled by default1.
NEW QUESTION # 125
Which statement best describes QoS?
  • A. Determining which traffic passes specified quality metrics
  • B. Identifying specific traffic for special treatment
  • C. Identifying the quality of the connection
  • D. Scoring traffic based on the quality of the contents
QoS stands for Quality of Service and is a mechanism that allows network devices to prioritize and differentiate traffic based on certain criteria, such as application type, source, destination, etc3. QoS involves identifying specific traffic for special treatment and applying policies and actions to improve its performance or meet certain service level agreements (SLAs) . QoS can help network devices to manage congestion, delay, jitter, packet loss, bandwidth allocation, etc., for different types of traffic . QoS can be implemented at various layers of the network stack and across different network domains. References:
https://www.cisco.com/c/en/us/td ... k/qos-overview.html
NEW QUESTION # 126
How do you allow a new VLAN 200 for downstream access switch with VSX pair using VSX LAG?
  • A. vlan trunk add 100 in MLAG1
  • B. vlan trunk add 100 in LAG1 multi-chassis
  • C. vlan trunk allowed 200 in MLAG 1
  • D. vlan trunk allowed all in LAG 1 multi-chassis
NEW QUESTION # 127
You are setting up a customer's 150 headless loT devices that do not support 802.1 X. What should you use?
  • A. Multiple Pre-Shared Keys (MPSK) Local
  • B. HPE Aruba Networking ClearPass profiling with WPA-PSK
  • C. Multiple Pre-Shared Keys (MPSK) with WPA3-AES
  • D. HPE Aruba Networking ClearPass profiling with MAC-AUTH
NEW QUESTION # 128
You must ensure the HPEAruba network you are configuring for a client is capable of plug-and-play provisioning of access points. What enables this capability?
  • A. SRTP
  • B. CSMA
  • C. UCC Service
  • D. LLDP-MED
The capability that enables plug-and-play provisioning of access points in an HPE Aruba network is the UCC Service. The UCC Service is a cloud-based service that allows the access points to automatically discover and connect to the Aruba Central management platform without any manual intervention. The UCC Service also provides zero-touch configuration, firmware updates, and monitoring for the access points1.
B) LLDP-MED: LLDP-MED is a protocol that enhances the interoperability between network devices and IP phones. It does not enable plug-and-play provisioning of access points2.
C) SRTP: SRTP is a protocol that provides encryption and authentication for voice and video traffic. It does not enable plug-and-play provisioning of access points3.
D) CSMA: CSMA is a protocol that regulates how devices share a common medium, such as a wireless channel. It does not enable plug-and-play provisioning of access points.
NEW QUESTION # 129
Our company conducts our business very well rather than unprincipled company which just cuts and pastes content from others and sell them to exam candidates. By virtue of our HPE7-A01 practice materials, many customers get comfortable experiences of Whole Package of Services and of course passing the HPE7-A01 Study Guide successfully. As to some exam candidate are desperately eager for useful HPE7-A01 actual tests, our products help you and other customer who are having an acute shortage of efficient practice materials.
HPE7-A01 VCE Exam Simulator: https://www.practicedump.com/HPE7-A01_actualtests.html
P.S. Free & New HPE7-A01 dumps are available on Google Drive shared by PracticeDump: https://drive.google.com/open?id=1sZgWbQtK3wQhthT0dyIqD14-bRRHI8Cd
