[General] Exam 1z0-1075-25 Questions Answers - 1z0-1075-25 Pass4sure Dumps Pdf
【General】 Exam 1z0-1075-25 Questions Answers - 1z0-1075-25 Pass4sure Dumps Pdf
Posted at 3/6/2026 11:18:52      View:104 | Replies:1        Print      Only Author   [Copy Link] 1#
The Oracle 1z0-1075-25 certification exam has grown in popularity in today's modern Oracle era. Success in the 1z0-1075-25 exam gives aspirants the chance to upskill and remain competitive in the challanging job market. Those who successfully crack the Oracle Manufacturing Cloud 2025 Implementation Professional (1z0-1075-25) test prove to their employers that they are skilled enough to get well-paying jobs and promotions. Dumpkiller is aware that preparing with invalid Oracle 1z0-1075-25 Exam Questions wastes money and time.
Our company is a well-known multinational company, has its own complete sales system and after-sales service worldwide. In the same trade at the same time, our 1z0-1075-25 real study dumps have become a critically acclaimed enterprise, so, if you are preparing for the exam qualification and obtain the corresponding certificate, so our company launched 1z0-1075-25 exam questions are the most reliable choice of you. The service tenet of our company and all the staff work mission is: through constant innovation and providing the best quality service, make the 1z0-1075-25 question guide become the best customers electronic test study materials. No matter where you are, as long as you buy the 1z0-1075-25 real study dumps, we will provide you with the most useful and efficient learning materials. As you can see, the advantages of our research materials are as follows.
Oracle 1z0-1075-25 Pass4sure Dumps Pdf & 1z0-1075-25 GuideOur 1z0-1075-25 question torrent not only have reasonable price but also can support practice perfectly, as well as in the update to facilitate instant upgrade for the users in the first place, compared with other education platform on the market, the 1z0-1075-25 Exam Question can be said to have high quality performance. We can sure that you will never regret to download and learn our 1z0-1075-25 study material, and you will pass the 1z0-1075-25 exam at your first try.
Oracle Manufacturing Cloud 2025 Implementation Professional Sample Questions (Q30-Q35):NEW QUESTION # 30
Two work definitions are created in the application: one for Engine Finished Good and the other for Pallet Finished Good. The Engine Finished Good item should have Pallet Finished Good as one of its components.
How can you establish the relationship between the Pallet and Engine work definitions?
  • A. Work definition versions can be used to tie the work orders.
  • B. Create a subinventory to serve as the completion subinventory for yielding Pallet, and then use the same subinventory to serve as the supply subinventory of Pallet in the work definition created for Engine.
  • C. The two work definitions can be tied through Project or Selban numbers.
  • D. Assign a higher priority to the work definition created for Engine and a lower one to the work definition for Pallet.
To establish a relationship between the work definitions of Engine Finished Good and Pallet Finished Good, you can create a common subinventory. This subinventory will serve as the completion subinventory for the Pallet Finished Good and the supply subinventory for the Engine Finished Good. This ensures that the Pallet Finished Good is completed in one process and is then available as a component for the Engine Finished Good.
* Subinventory Linking : Using a common subinventory ties the output from one work definition as an input to another. The Pallet becomes an inventory item that is consumed in the production of the Engine.
Oracle Manufacturing Cloud ' s documentation on work definitions and inventory setups explains how subinventories are used to link different stages of production.
NEW QUESTION # 31
Your client is planning to override the Plant Production Calendar with One or More Date-Effective Work Center Calendars. You need to explain the consideration when using the Override the Plant Production Calendar with One or More Date-Effective Work Center Calendars feature.
Which three statements are true when overriding the production calendar?
  • A. While defining override calendars, you need to ensure that the date effective range for a work center calendar association can be overlapping and contiguous.
  • B. Even if there are override calendars, the lead time calculation in days for an item remains based on the plant calendar and not on work center calendars.
  • C. When the user executes search action in the Review Dispatch List page, if more than one work center are selected and if the start date or completion date is based on Shift-based search, then the operations are queried based on the shifts of the plant calendar only.
  • D. Supplier operations used in outside processing use the work center calendar in work order scheduling.
  • E. The Work Execution Work Area Infolets and Manage Production Exceptions page are based on the plant calendar and not on work center calendars.
Answer: B,C,E
Overriding the plant production calendar with date-effective work center calendars provides flexibility in scheduling specific work centers with different operating hours. However, certain aspects of production planning and execution remain tied to the plant-level calendar. Here are the details:
* Statement A : The Work Execution Work Area Infolets and Manage Production Exceptions page are based on the plant calendar and not on work center calendars - Even when work centers have their own calendars, the high-level overview and exception reporting remain based on the plant calendar.
* Statement C : Lead time calculation in days for an item remains based on the plant calendar - Lead times are calculated using the plant calendar, regardless of work center-specific calendars, ensuring consistency in planning.
* Statement D : Search actions in the Review Dispatch List page query operations based on the plant calendar shifts when multiple work centers are selected - For consistency in dispatching, the system references the plant calendar when shift-based search parameters are used across multiple work centers.
Incorrect Statements:
* Statement B : Date-effective ranges for work center calendars should not overlap for accuracy in scheduling.
* Statement E : Supplier operations in outside processing generally rely on the plant calendar for consistency unless explicitly configured otherwise.
Oracle Manufacturing Cloud documentation on " Calendar Overrides " explains how plant and work center calendars interact and the impact on work execution, scheduling, and reporting
NEW QUESTION # 32
In which three ways does Supply Chain Orchestration enrich supply requests with project details to support outside processing for a project-specific work order?
  • A. Expenditure Type is sat to the expenditure type associated to the outside processing Item.
  • B. Expenditure Item Date is set to the receipt date and Expenditure Organization is set to the manufacturing plant.
  • C. Expenditure Item Date Is set to the requested need-by date and Expenditure Organization is set to the manufacturing plant.
  • D. Supply Chain Orchestration initiates the creation of a requisition with the project details.
  • E. Supply Chain Orchestration initiates the creation of a purchase order without the work order.
Answer: A,C,D
Supply Chain Orchestration (SCO) plays a vital role in managing project-specific work orders, particularly for outside processing. Here's how it enriches supply requests with project details:
* Statement B : Expenditure Item Date is set to the requested need-by date and Expenditure Organization is set to the manufacturing plant - In project-specific work orders, Supply Chain Orchestration assigns the need-by date as the Expenditure Item Date. The Expenditure Organization is typically set to the manufacturing plant handling the work order.
Oracle Fusion Project-Driven Supply Chain documents this behavior, showing how expenditure details are linked to the project for costing purposes.
Statement D : Supply Chain Orchestration initiates the creation of a requisition with the project details - SCO automatically creates a requisition with all relevant project details, such as project number, task, and expenditure information. This ensures that the procurement process is aligned with the project's financial and material requirements.
Reference : Oracle SCM Cloud Supply Chain Orchestration User Guide details the automated creation of requisitions with project data for external processing.
Statement E : Expenditure Type is set to the expenditure type associated with the outside processing item - In Oracle Cloud, expenditure types must align with the specific processing items. SCO ensures that the correct expenditure type is applied to the work order and subsequent requisitions.
Reference : Project Financial Management guides in Oracle SCM Cloud explain how expenditure types are associated with items, ensuring accurate costing.
Statement A : SCO does not initiate the creation of a purchase order without the work order. A work order is essential for processing the outside work, and its absence would disrupt the orchestration process.
Statement C : The Expenditure Item Date is not set to the receipt date but rather to the requested need-by date for proper alignment with project scheduling.
NEW QUESTION # 33
A Manufacturing Engineer in a plant is creating an alternate manufacturing process for an item using its existing work definitions. After copying from the existing work definition, WD1, to the alternate work definition, WD2, the engineer finds that the operation items were not copied in the alternate manufacturing process WD2.
What is the reason for this?
  • A. Item and Structure Name were changed in the new WD2 during creation.
  • B. Start Date was not populated in the new WD2 during creation.
  • C. Item and Structure Name in the existing WD1 were retained in the new WD2 during creation.
  • D. Production Priority was not populated in the new WD2 during creation.
When creating an alternate work definition (WD2) by copying from an existing one (WD1), if the Item and Structure Name were changed during the creation of WD2, the operation items would not be copied. This is because operation items are tied to specific item structures. Changing the structure results in a disconnect between the original operation items and the new work definition.
* Item and Structure Name are critical in ensuring that the operation items (components and materials) are transferred when copying work definitions. If these names are changed, the system does not assume the same items should be used.
Oracle Manufacturing Cloud documentation explains that maintaining consistency in the Item and Structure Name is key when copying work definitions to ensure all operation items are carried over.
NEW QUESTION # 34
Which three statements are true about executing rework work orders with manual control?
  • A. You can perform operation completion only after the assembly has been issued to the work order, and only up to the quantity that the assembly component item Is issued to the work order.
  • B. You cannot cancel the work order after releasing it or after performing any transactions.
  • C. If the group has grouping attributes, only work orders that match the grouping attribute values can be assigned to the groups.
  • D. You can cancel the work order after releasing it and after performing any transactions.
  • E. You must manually issue the assembly item to rework a work order, either partial or full quantity.
Answer: A,B,E
In Oracle Manufacturing Cloud, executing rework work orders with manual control requires certain steps and restrictions to ensure proper tracking of rework activities:
* Statement A : You can perform operation completion only after the assembly item has been issued to the work order. The quantity that can be completed is limited to the quantity of the assembly issued.
* Statement C : The assembly item must be manually issued to the work order, allowing for flexibility to issue either a partial or full quantity depending on the rework requirements.
* Statement D : Once a work order is released and transactions have been performed, it cannot be canceled. This ensures that work orders already in progress are tracked properly.
Incorrect options:
* Statement B : This is incorrect because you cannot cancel the work order after performing transactions.
* Statement E : This statement is irrelevant in the context of executing rework work orders with manual control.
Oracle Cloud SCM documentation explains the steps and restrictions for manually controlling and issuing rework work orders, including limits on cancellation and operation completion.
NEW QUESTION # 35
The Oracle Manufacturing Cloud 2025 Implementation Professional 1z0-1075-25 certification is a valuable credential earned by individuals to validate their skills and competence to perform certain job tasks. Your Oracle Manufacturing Cloud 2025 Implementation Professional 1z0-1075-25 certification is usually displayed as proof that you’ve been trained, educated, and prepared to meet the specific requirement for your professional role. The Oracle Manufacturing Cloud 2025 Implementation Professional 1z0-1075-25 Certification enables you to move ahead in your career later.
1z0-1075-25 Pass4sure Dumps Pdf: https://www.dumpkiller.com/1z0-1075-25_braindumps.html
We will be with you in every stage of your 1z0-1075-25 passleader dumps preparation to give you the most reliable help, Oracle Exam 1z0-1075-25 Questions Answers If you can get the certificate, you will have a better competitive power in the job market and have more opportunity, Oracle Exam 1z0-1075-25 Questions Answers You will get a better job or get a big rise on the position as well as the salary, Yes, we are expert in providing 1z0-1075-25 PDF files in which the topics are comprehensively explained in the form of questions and answers.
Our research on small business formation shows aboutof those Free 1z0-1075-25 Study Material who say in surveys they plan to start a smallsolopreneur business over the next years in our surveys end up doing so.
The client with a history of diabetes insipidus is admitted with polyuria, polydipsia, and mental confusion, We will be with you in every stage of your 1z0-1075-25 passleader dumps preparation to give you the most reliable help.
Take your Preparation to the Next Level with Actual 1z0-1075-25 Questions of DumpkillerIf you can get the certificate, you will have a better competitive Free 1z0-1075-25 Study Material power in the job market and have more opportunity, You will get a better job or get a big rise on the position as well as the salary.
Yes, we are expert in providing 1z0-1075-25 PDF files in which the topics are comprehensively explained in the form of questions and answers, If you are an IT worker, maybe 1z0-1075-25 the IT certification will be of great significance for you to achieve your ambitions.
Posted at 3/7/2026 11:44:02        Only Author  2#
I’m very inspired by this article, thank you for the share! The H12-831_V1.0 valid exam camp file test that helped me earn a promotion and salary raise is free for you today. Best of luck reaching your career goals!
