[General] 100% Pass Quiz NCP-CI-AWS - Nutanix Certified Professional - Cloud Integration -
94
General 100% Pass Quiz NCP-CI-AWS - Nutanix Certified Professional - Cloud Integration -
Posted at 3/6/2026 12:08:11      View150 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New NCP-CI-AWS dumps are available on Google Drive shared by ITExamSimulator: https://drive.google.com/open?id=1SytNeLiGaC_woe8P0XMCf791scxCJWVm
Our NCP-CI-AWS learning guide are developed in three versions which are the PDF, Software and APP online versions. The PDF version of NCP-CI-AWS training materials is convenient for you to print, the software version can provide practice test for you and the online version of our NCP-CI-AWS Study Materials is for you to read anywhere at any time. If you are hesitating about which version should you choose, you can download our NCP-CI-AWS free demo first to get a firsthand experience before you make any decision.
The Nutanix Certified Professional - Cloud Integration - AWS certification has become very popular to survive in today's difficult job market in the technology industry. Every year, hundreds of Nutanix aspirants attempt the NCP-CI-AWS exam since passing it results in well-paying jobs, salary hikes, skills validation, and promotions. Lack of Real NCP-CI-AWS Exam Questions is their main obstacle during NCP-CI-AWS certification test preparation.
Pass Guaranteed Quiz Nutanix - NCP-CI-AWS - Valid Nutanix Certified Professional - Cloud Integration - AWS Latest ExamprepIf you want to find the best NCP-CI-AWS study materials, the first thing you need to do is to find a bank of questions that suits you. Our NCP-CI-AWS learning material is prepared by experts in strict accordance with the exam outline of the NCP-CI-AWS certification exam, whose main purpose is to help students to pass the exam with the least amount of time and effort. We can claim that if you study with our NCP-CI-AWS Practice Engine for 20 to 30 hours, then you will be sure to pass the exam.
Nutanix Certified Professional - Cloud Integration - AWS Sample Questions (Q64-Q69):NEW QUESTION # 64
An administrator wants to route the outbound and inbound traffic from the NC2 cluster through a proxy server. Which two statements are correct about using a proxy server? (Choose two.)
  • A. The proxy configuration can be changed while tasks for adding or removing nodes are in progress.
  • B. NC2 clusters using Flow Virtual Networking do not support a proxy server.
  • C. The proxy server must be configured only while creating a cluster because the proxy server settings cannot be configured after the cluster is deployed.
  • D. A proxy server is only supported with AOS 6.7.1.6 or higher versions and only with user-created VPCs.
NEW QUESTION # 65
An administrator has been tasked with deploying an NC2 cluster on AWS with the requirement to protect workloads. Which two options are valid to protect the workloads on this cluster? (Choose two.)
  • A. Deploy one-node cluster in another availability zone.
  • B. Use an existing on-prem Nutanix cluster as a disaster recovery target.
  • C. Deploy a cluster across two availability zones.
  • D. Create a second NCZ cluster in a different availability zone.
To protect workloads on an NC2 cluster on AWS, deploying strategies that ensure high availability and disaster recovery are essential. The two valid options are:
Create a Second NC2 Cluster in a Different Availability Zone:
High Availability: Deploying a second NC2 cluster in a different availability zone ensures that workloads can be quickly recovered in case of an availability zone failure.
Disaster Recovery: This setup enables asynchronous replication between clusters, providing a robust disaster recovery solution.
Use an Existing On-Prem Nutanix Cluster as a Disaster Recovery Target:
Hybrid DR: Leveraging an existing on-premises Nutanix cluster for disaster recovery provides a cost-effective and efficient DR solution.
Replication: Set up replication policies to ensure data is consistently copied from the NC2 cluster on AWS to the on-premises cluster.
Why Not Other Options:
One-node cluster in another availability zone: Not a valid DR solution as a single-node cluster cannot provide the required resilience and high availability.
Deploy a cluster across two availability zones: While this can enhance availability, it is not a typical approach for Nutanix clusters which are designed to operate within a single availability zone for simplicity and performance reasons.
Nutanix Cloud Clusters on AWS Administration Guide
Nutanix Disaster Recovery Best Practices
AWS Availability Zones and Disaster Recovery Documentation
NEW QUESTION # 66
An administrator has been tasked with ensuring NC2 VMs are able to access AWS resources. The NC2 VM traffic must not traverse the internet.
in which two ways would the administrator achieve this? (Choose two.)
  • A. By using a Gateway Endpoint
  • B. By using a VPC Peer.
  • C. By using an Interface Endpoint
  • D. By using a NAT Gateway.
To ensure that NC2 VMs can access AWS resources without traversing the internet, the administrator can use AWS VPC Peering and Interface Endpoints. Both methods ensure that traffic stays within the AWS network, maintaining security and efficiency.
Interface Endpoint:
Interface Endpoints allow you to privately connect your VPC to supported AWS services. They use AWS PrivateLink to route traffic directly to services within the AWS network, bypassing the public internet.
Steps:
Create an interface endpoint for the required service in the AWS VPC console.
Ensure the security groups and route tables are configured to allow traffic to the interface endpoint.
VPC Peering:
VPC Peering allows the routing of traffic between VPCs using private IP addresses, without the need for internet gateways, NAT devices, or VPN connections.
Steps:
Create a VPC peering connection between the VPCs.
Update the route tables to direct traffic between the peered VPCs.
Ensure security group rules allow the necessary traffic between VPCs.
AWS VPC Peering Documentation
AWS Interface Endpoint Documentation
NEW QUESTION # 67
An administrator has deployed an NC2 cluster in AWS.
The following configuration decisions were made:
Created a new VPC from the NC2 console as part of the deployment
Selected the Public option for prism access policy
Host type selected was i13en,metal
The administrator now has a goal of provision public internet access to a user VM (UVM),web-1, on the Nutanix cluster. The admin can access Prism Element via the public DNS of the Auto-created load balancer.
The administrator tries to create another network load balancer for the web server access. After creating the load balancer and registering web-1's IP address as a target, the administrator finds that the health check for the VM target is failing and the DNS returns as NOT Found message in the browser.
Why is the issue happening?
  • A. The administrator needs to provision an application load balancer instead of a network load balancer to allow Internet traffic to access the UVM subnet.
  • B. The administrator has not modified the inbound rules under the UVM security group to a/low the network load balancer to access the UVM subnet.
  • C. The administrator has not assigned a public IP to web-1.
  • D. The load balancer is still in a Provisioning state.
For a VM to be accessible over the internet through a load balancer, the VM itself must have a public IP address.
In this case, the health check for the VM target is failing and the DNS returns a "NOT Found" message because web-1 does not have a public IP assigned.
Without a public IP, the load balancer cannot route traffic to web-1 from the internet.
Assigning a public IP to web-1 ensures that the VM can be accessed via the load balancer, resolving the connectivity issue.
Refer to the AWS documentation on network load balancers and public IP assignments, and Nutanix documentation on VM network configurations.
NEW QUESTION # 68
In which two ways should an NC2 on AWS cluster be hibernated manually? (Choose two.)
  • A. Log into Prism, Central, navigate to Planning, find hibernate and resume.
  • B. Log into Prism Element navigate to Settings and select Hibernate/Resume.
  • C. Log into NC2 console, find the cluster name and select Hibernate/Resume from the ellipses.
  • D. Select the cluster under NC2 console and Select Hibernate/Resume on the cluster sur page.
To manually hibernate an NC2 on AWS cluster, the administrator can use the following methods:
Select the cluster under NC2 console and Select Hibernate/Resume on the cluster sur page: Navigate to the specific cluster in the NC2 console and use the provided Hibernate/Resume option.
Log into NC2 console, find the cluster name and select Hibernate/Resume from the ellipses: Access the NC2 console, locate the cluster name, and select the Hibernate/Resume option from the ellipses (three dots) menu.
These options allow for the manual control of the cluster's hibernation state directly within the NC2 console interface.
Nutanix Support & Insights
NEW QUESTION # 69
Learning is sometimes extremely dull and monotonous, so few people have enough interest in learning, so teachers and educators have tried many ways to solve the problem. Research has found that stimulating interest in learning may be the best solution. Therefore, the NCP-CI-AWS Study Materials focus is to reform the rigid and useless memory mode by changing the way in which the NCP-CI-AWS exams are prepared. NCP-CI-AWS study materials combine knowledge with the latest technology to greatly stimulate your learning power.
NCP-CI-AWS Passed: https://www.itexamsimulator.com/NCP-CI-AWS-brain-dumps.html
Once you have paid for our NCP-CI-AWS study materials successfully, our online workers will quickly send you an email which includes our NCP-CI-AWS premium VCE file installation package, Nutanix NCP-CI-AWS Latest Examprep It is downloaded and installed on personal computer which is Microsoft windows system and Java script, Nutanix NCP-CI-AWS Latest Examprep Flexibility, suitable for different candidates.
Most of the time, your team doesn't seem to have the numbers, skills, or time NCP-CI-AWS to keep up with all the work, The Iron Lady objected on the grounds that she didn't want to see a national treasure owned by a foreign government.
TOP NCP-CI-AWS Latest Examprep 100% Pass | Latest Nutanix Nutanix Certified Professional - Cloud Integration - AWS Passed Pass for sureOnce you have paid for our NCP-CI-AWS Study Materials successfully, our online workers will quickly send you an email which includes our NCP-CI-AWS premium VCE file installation package.
It is downloaded and installed on personal computer which is Microsoft NCP-CI-AWS Customizable Exam Mode windows system and Java script, Flexibility, suitable for different candidates, Also, we just pick out the most important knowledge to learn.
Actual Nutanix Certified Professional - Cloud Integration - AWS (NCP-CI-AWS) dumps are designed to help applicants crack the Nutanix NCP-CI-AWS test in a short time.
2026 Latest ITExamSimulator NCP-CI-AWS PDF Dumps and NCP-CI-AWS Exam Engine Free Share: https://drive.google.com/open?id=1SytNeLiGaC_woe8P0XMCf791scxCJWVm
