3V0-25.25 Reliable Exam Cost | 3V0-25.25 Test Result
106
Posted at 3/6/2026 23:28:00      View:130 | Replies:0        Print      Only Author   [Copy Link] 1#
We will provide you with three different versions of our 3V0-25.25 exam questions on our test platform. You have the opportunity to download the three different versions from our test platform. The three different versions of our 3V0-25.25 Test Torrent include the PDF version, the software version and the online version. The three different versions will offer you same questions and answers, but they have different functions.
VMware 3V0-25.25 Exam Syllabus Topics:
  • Install, Configure, Administrate the VMware Solution: This domain covers NSX implementation including deploying Federation, configuring components, creating Edge Clusters and gateways, managing VPC, stateful services, tenancy, integrations, and operational tasks.
  • Plan and Design the VMware Solution: This domain addresses NSX design including architecture, connectivity solutions, multisite deployments, NSX Fleet considerations, and optimization decisions based on given scenarios.
  • VMware Products and Solutions: This domain focuses on VMware's core offerings including vSphere for virtualization, NSX for software-defined networking, and vSAN for storage, enabling private and hybrid cloud environments.
  • IT Architectures, Technologies, Standards: This domain covers foundational IT structural designs like client-server and microservices, implementation technologies such as containerization and APIs, and industry standards like ISO
  • IEC, TOGAF, and security frameworks.
Topic 5
  • Troubleshoot and Optimize the VMware Solution: This domain focuses on identifying and resolving NSX issues using VCF tools, troubleshooting infrastructure and routing problems, and understanding ECMP, high availability, and packet flows.
3V0-25.25 Test Result - 3V0-25.25 Free Brain DumpsOne of the biggest advantages of our 3V0-25.25 learning guide is that it you won’t loss anything if you have a try with our 3V0-25.25 study materials. you can discover the quality of our exam dumps as well as the varied displays that can give the most convenience than you can ever experience. Both of the content and the displays are skillfully design on the purpose that 3V0-25.25 Actual Exam can make your learning more targeted and efficient.
VMware Advanced VMware Cloud Foundation 9.0 Networking Sample Questions (Q13-Q18):NEW QUESTION # 13
An administrator is troubleshooting an issue where workloads connected to a Tier-1 Gateway named T1-App can no longer reach external North/South destinations.
* The Tier-1 is connected to an Active/Standby Tier-0 Gateway named T0-Prod.
Symptoms observed:
* VMs on segments attached to T1-App can ping each other.
* VMs on T1-App cannot reach any external IP outside T0-Prod.
* From a VM on the segment, ping to the T1-App Distributed Router (DR) IP succeeds.
* Ping from the VM to the T1-App Service Router (SR) fails.
* The Edge cluster hosting the T1-App SR shows both Edge nodes Up and Healthy.
* No failover has occurred - the same Edge node is still shown as Active for T1-App.
What is the most likely cause of this issue?
  • A. Localized control plane is enabled on the Tier-1 causing the SR to remain admin-down.
  • B. Static default route is missing on the Tier-1 DR component.
  • C. The overlay network between DR and SR has an MTU mismatch.
  • D. Route advertisement from T1-App to T0-Prod for 100.64.x.x/31 is disabled.
Comprehensive and Detailed 250 to 350 words of Explanation From VMware Cloud Foundation (VCF) documents:
In theNSXmulti-tier routing architecture used by VCF, aTier-1 Gatewayis composed of two primary components: theDistributed Router (DR)and theService Router (SR). The DR runs as a kernel module on every ESXi host in the transport zone, facilitating East-West traffic. The SR resides on the NSX Edge nodes and provides centralized services like North-South connectivity and stateful services.
Communication between the DR (on the ESXi host) and the SR (on the Edge node) occurs over a hidden internal segment known as theRouter Link. This link is encapsulated inGenevejust like VM-to-VM traffic.
When a VM attempts to reach an external destination, the packet is first routed by the DR on the local host.
The DR then encapsulates the packet and sends it across the overlay to the TEP (Tunnel Endpoint) of the Edge node hosting the SR.
If theMTU (Maximum Transmission Unit)is misconfigured on the physical network or the virtual switches, large encapsulated packets will be dropped. However, small packets (like pings between VMs on the same host) might still succeed. In this scenario, the fact that the VM can ping the local DR butcannot reach the SR
-and therefore cannot reach external networks-points to a failure in the transport between the host and the Edge.
If the Geneve-encapsulated packet containing the ping request to the SR's internal interface exceeds the physical network's MTU, it will fail. Since VCF 5.x/9.0 requires a minimum MTU of1600(ideally9000) for the overlay to account for the Geneve overhead, a mismatch anywhere in the fabric will break the DR-to-SR
"backplane" communication. This prevents the Tier-1 from passing any traffic to its Tier-0 uplink, effectively isolating the workloads from North-South traffic.
NEW QUESTION # 14
An administrator has deployed a new VMware Cloud Foundation (VCF) management domain. To be compliant with company policy, backups must be configured to occur anytime a change is made to the NSX configuration. How can the administrator ensure that complete configuration backups are captured every time a change occurs?
  • A. No action is required as by default NSX will automatically perform a complete backup every time a change is made to the configuration.
  • B. Configure an alarm to detect configuration changes and automatically trigger a complete configuration backup.
  • C. Configure a cron job on the NSX Manager to automatically perform an incremental backup of the NSX configuration every hour.
  • D. Create a recurring backup schedule and explicitly indicate that backups should be captured anytime the configuration changes.
InVMware Cloud Foundation (VCF), the protection of theNSX Managerconfiguration is paramount, as it contains the state of the entire software-defined network, including firewall rules, logical switches, and routing topologies. To meet strict compliance requirements for real-time or change-based protection, NSX offers specific automated backup triggers.
Within theNSX Manager UI(under System > Lifecycle > Backup & Restore), an administrator can configure the backup behavior. While a time-based schedule (e.g., daily at 2:00 AM) is common, it does not satisfy the requirement for backups "anytime a change is made." To accomplish this, the administrator must enable the
"Backup on Configuration Change"toggle within the backup scheduling configuration.
When this feature is enabled, the NSX Manager monitors its own management database (DS) for write operations. Once a configuration change is detected (such as adding a segment or modifying a DFW rule), the system initiates an automated backup process. This ensures that the backup repository always contains a near- instantaneous reflection of the current network state, minimizing data loss in the event of a cluster failure.
Option B is incorrect because this feature is not enabled by default; it requires an external SFTP/FTP server to be configured first. Option C (Cron jobs) is an unsupported manual workaround that bypasses the SDDC- native management tools. Option A is redundant as the functionality is built directly into the NSX backup engine. Consequently, the verified method for compliance is to use thenative recurring backup schedule with the "Detect Configuration Change" option enabled.
NEW QUESTION # 15
An administrator is tasked to configure NSX Federation between separate VMware Cloud Foundation (VCF) Fleets. Which requirement must all sites meet before being added to a Global Manager (GM) for NSX Federation?
  • A. All Sites must use the same VTEP VLAN and IP pools.
  • B. All sites must have the same NSX version and build.
  • C. All sites must be managed by the same VCF instance.
  • D. All sites must use identical Tier-0 gateway BGP autonomous system numbers.
NEW QUESTION # 16
An administrator created a new Tier-1 Gateway and is attempting to change the connected gateway for a deployed segment to use the new gateway. In the UI, when the administrator clicks the Connected Gateway dropdown, the new Tier-1 gateway is not shown as an available gateway. What would prevent the new Tier-1 gateway from showing in the list of available gateways?
  • A. The Tier-1 Gateway connectivity policy is set to "None".
  • B. The Tier-1 Gateway is not connected to an NSX Edge Cluster.
  • C. The Tier-1 Gateway and NSX Segment are in different transport zones.
  • D. The Tier-1 Gateway and NSX Segment are connected to different Tier-0 Gateways.
InVMware Cloud Foundationnetworking, the relationship between segments and gateways is governed by the underlyingTransport Zone (TZ)configuration. A Transport Zone defines the potential span of a virtual network-specifically, which hosts and edges can participate in that network.
When an administrator creates anNSX Segment, they must associate it with a specific Transport Zone (either Overlay or VLAN). Similarly, when aTier-1 Gatewayis created, its reach is determined by the Transport Zones available on the Transport Nodes (Edges and ESXi hosts) where it is instantiated. For a Segment to be attached to a Tier-1 Gateway, both objectsmust reside within the same Transport Zone.
If the Segment was created in "Overlay-TZ-01" but the new Tier-1 Gateway is only associated with "Overlay- TZ-02" (or if one is in a VLAN TZ and the other in an Overlay TZ), the NSX Manager UI will filter out the incompatible gateway to prevent an invalid configuration. The logical switch (Segment) cannot bind to a gateway if they do not share a common broadcast or encapsulation domain defined by the Transport Zone.
Option A is incorrect because a Tier-1 Gateway does not strictlyrequirean Edge Cluster unless it is providing stateful services (like NAT, LB, or Firewall). It can exist purely as a distributed component on the hypervisors. Option B (Connectivity Policy) determines if the T1 advertises routes to the T0, but it doesn't prevent a segment from connecting to it. Option D is also incorrect, as a Tier-1 Gateway can be moved between Tier-0s, or even exist without a Tier-0 connection initially. Therefore, theTransport Zone mismatch is the fundamental architectural barrier preventing the gateway from appearing in the selection list.
NEW QUESTION # 17
An administrator is tasked to enable users to configure an individual VPC, but not create subnets. What three NSX roles would the administrator assign to allow access without the ability to create subnets? (Choose three.)
  • A. VPC Admin
  • B. Security Admin
  • C. Network Admin
  • D. Network Operator
  • E. Security Operator
Answer: A,D,E
With the introduction of theVirtual Private Cloud (VPC)consumption model inVCF 9.0and late 5.x releases, Role-Based Access Control (RBAC) has become more granular to support true multi-tenancy. A VPC is designed to be a self-contained "container" for a department's or user's networking resources.
To meet the specific requirement where a user can configure aspects of an individual VPC but is restricted from creating new subnets (which involves modifying the underlying network CIDR blocks and IPAM), a combination of specific roles is required.
* VPC Admin:This is the primary role for the user within their assigned VPC. It allows the user to manage the overall VPC environment, including high-level settings and monitoring. However, the VPC Admin's power is often limited by the specific quotas and policies set by the Enterprise Admin.
* Security Operator:This role allows the user to view security configurations and policies without having the permission to modify the network fabric or create new infrastructure components like subnets. It provides the "read-only" visibility into the security posture of the VPC.
* Network Operator:Similar to the Security Operator, the Network Operator role provides visibility into the networking state-such as routing tables, segment status, and connectivity-without granting the
"Write" permissions required to provision new subnets or alter the network topology.
AssigningNetwork Admin(Option B) orSecurity Admin(Option A) would grant too much privilege, as these roles typically include the ability to create, delete, and modify subnets and firewall policies at a structural level. By combining theVPC Adminrole withOperator-level roles, the administrator ensures the user has the necessary context to manage their assigned resources while strictly adhering to the restriction against creating new network subnets.
NEW QUESTION # 18
Are you preparing for the 3V0-25.25 test recently? You may have a strong desire to get the 3V0-25.25 exam certification. Now, you may be pleasure, ExamsReviews 3V0-25.25 can relieve your exam stress. VMware 3V0-25.25 training camps cover nearly full questions and answers you need, and you can easily acquire the key points, which will contribute to your exam. Besides, VMware training dumps are edited by senior professional with rich hands-on experience and several years' efforts, and it has reliable accuracy and good application. I think you will pass your exam test with ease by the study of 3V0-25.25 Training Material. What's more, if you buy 3V0-25.25 exam practice cram, you will enjoy one year free update. So you do not worry that the information you get will be out of date, you will keep all your knowledge the latest.
3V0-25.25 Test Result: https://www.examsreviews.com/3V0-25.25-pass4sure-exam-review.html
