[General] NSE4_FGT_AD-7.6 Valid Real Exam - Quiz Fortinet NSE4_FGT_AD-7.6 First-grade Reli
78
【General】 NSE4_FGT_AD-7.6 Valid Real Exam - Quiz Fortinet NSE4_FGT_AD-7.6 First-grade Reli
Posted at 3/7/2026 03:58:43      View:142 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest PDFBraindumps NSE4_FGT_AD-7.6 PDF Dumps and NSE4_FGT_AD-7.6 Exam Engine Free Share: https://drive.google.com/open?id=1x0SNhdWt2gEiy6u9JCUxw3Gzhq-UWyNw
The Exams is committed to making the Fortinet NSE4_FGT_AD-7.6 exam dumps the best NSE4_FGT_AD-7.6 exam study material. To achieve this objective the Exams have hired a team of experienced and qualified Fortinet NSE4_FGT_AD-7.6 Exam trainers. They work together and check all Fortinet NSE4_FGT_AD-7.6 exam questions step by step and ensure the top standard of Fortinet NSE4_FGT_AD-7.6 practice test material all the time.
Fortinet NSE4_FGT_AD-7.6 Exam Syllabus Topics:
  • Routing: This domain covers configuring static routes for packet forwarding and implementing SD-WAN to load balance traffic across multiple WAN links.
  • Firewall Policies and Authentication: This domain focuses on creating firewall policies, configuring SNAT and DNAT for address translation, implementing various authentication methods, and deploying FSSO for user identification.
  • VPN: This domain focuses on implementing meshed or partially redundant IPsec VPN topologies for secure connections.
  • Content Inspection: This domain addresses inspecting encrypted traffic using certificates, understanding inspection modes and web filtering, configuring application control, deploying antivirus scanning modes, and implementing IPS for threat protection.
Topic 5
  • Deployment and System Configuration: This domain covers initial FortiGate setup, logging configuration and troubleshooting, FGCP HA cluster configuration, resource and connectivity diagnostics, FortiGate cloud deployments (CNF and VM), and FortiSASE administration with user onboarding.
Fortinet NSE4_FGT_AD-7.6 Reliable Braindumps Sheet & NSE4_FGT_AD-7.6 Free Brain DumpsThe NSE4_FGT_AD-7.6 learning materials from our company are very convenient for all people, including the convenient buying process, the download way and the study process and so on. Upon completion of your payment on our NSE4_FGT_AD-7.6 exam questions, you will receive the email from us in several minutes, and then you will have the right to use the NSE4_FGT_AD-7.6 Test Guide from our company. In addition, there are three different versions for all people to choose: PDF, Soft and APP versions. According to your actual situation, you can choose the suitable version from our NSE4_FGT_AD-7.6 study question.
Fortinet NSE 4 - FortiOS 7.6 Administrator Sample Questions (Q102-Q107):NEW QUESTION # 102
Refer to the exhibits.
The SSL VPN connection fails when a user attempts to connect to it.
What should the user do to successfully connect to the SSL VPN?
  • A. Change the server IP address.
  • B. Change the SSL VPN port on the client.
  • C. Change the SSL VPN portal to the tunnel.
  • D. Change the idle-timeout.
In the FortiGate SSL-VPN settings, the VPN is configured to listen on port 11443, as shown in the
"Listen on Port" field. However, the VPN client is attempting to connect to https://10.200.1.1:443/, which uses the default HTTPS port (443) instead of the configured port.
To successfully connect, the user must change the SSL VPN port on the client to 11443 so that it matches the listening port defined on the FortiGate device.
NEW QUESTION # 103
You have configured the below commands on a FortiGate.
What would be the impact of this configuration on FortiGate?
  • A. Port1 will be enabled with flexible RPF. and all other interfaces will be enabled for strict RPF
  • B. FortiGate will enable strict RPF on all its interfaces and porti will be exempted from RPF checks.
  • C. FortiGate will enable strict RPF on all its interfaces and porti will be enable for asymmetric routing.
  • D. The global configuration will take precedence and FortiGate will enable strict RPF on all interfaces.
NEW QUESTION # 104
Refer to the exhibits. An administrator configured the Web Filter Profile to block access to all social networking sites except Facebook. However, when users try to access Facebook.com, they are redirected to a FortiGuard web filtering block page.
Based on the exhibits, which configuration change must the administrator make to allow Facebook while blocking all other social networking sites?
  • A. Change the type as Simple in the Static URL Filter section.
  • B. Set the Social Networking action as warning in the FortiGuard Category Based Filter.
  • C. Set the Action as Exempt for www.facebook.com in the Static URL Filter.
  • D. Change the Feature set of Web Filter Profile as Proxy-based.
The FortiGuard category filter is blocking Social Networking, which includes Facebook. Although a static URL filter entry for www.facebook.com exists, its action is set to Monitor, so it does not override the category block. To allow Facebook while blocking other social networking sites, the action for www.facebook.com in the Static URL Filter must be set to Exempt. This explicitly bypasses category filtering for that URL.
NEW QUESTION # 105
Refer to the exhibit showing a debug flow output.
Which two conclusions can you make from the debug flow output? (Choose two.)
  • A. The matching firewall policy denies the traffic.
  • B. The debug flow is for UDP traffic.
  • C. The RPF check fails.
  • D. The default gateway is configured on port2.
Answer: A,D
The default gateway is configured on port2 → The debug output shows find a route:
flag=00000000 gw-0.0.0.0 via port2, which indicates that the default route (0.0.0.0/0) points out port2.
The matching firewall policy denies the traffic → The log line Denied by forward policy check (policy 2) confirms that policy 2 matched and explicitly dropped the traffic.
NEW QUESTION # 106
Refer to the exhibit. The exhibit shows the FortiGuard Category Based Filter section of a corporate web filter profile.
An administrator must block access to download.com, which belongs to the Freeware and Software Downloads category. The administrator must also allow other websites in the same category.
What are two solutions for satisfying the requirement? (Choose two.)
  • A. Configure a static URL filter entry for download.com with Type and Action set to Wildcard and Block, respectively.
  • B. Configure a web override rating for download.com and select Malicious Websites as the subcategory.
  • C. Configure a separate firewall policy with action Deny and an FQDN address object for*.download.com as destination address.
  • D. Set the Freeware and Software Downloads category Action to Warning.
You can create a web rating override to change the website category to someone that is blocked in the web filter profile You can enable the URL Filter in the Web Filter Profile and block the website.
NEW QUESTION # 107
We would like to benefit our customers from different countries who decide to choose our NSE4_FGT_AD-7.6 study guide in the long run, so we cooperation with the leading experts in the field to renew and update our NSE4_FGT_AD-7.6 learning materials. Our leading experts aim to provide you the newest information in this field in order to help you to keep pace with the times and fill your knowledge gap. As long as you bought our NSE4_FGT_AD-7.6 Practice Engine, you are bound to pass the NSE4_FGT_AD-7.6 exam for sure.
NSE4_FGT_AD-7.6 Reliable Braindumps Sheet: https://www.pdfbraindumps.com/NSE4_FGT_AD-7.6_valid-braindumps.html
BONUS!!! Download part of PDFBraindumps NSE4_FGT_AD-7.6 dumps for free: https://drive.google.com/open?id=1x0SNhdWt2gEiy6u9JCUxw3Gzhq-UWyNw
