[General] Distinguished NCP-CI-AWS Learning Quiz Shows You Superb Exam Dumps - Prep4SureRe
104
【General】 Distinguished NCP-CI-AWS Learning Quiz Shows You Superb Exam Dumps - Prep4SureRe
Posted at 3/8/2026 11:22:40      View:107 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that Prep4SureReview NCP-CI-AWS dumps now are free: https://drive.google.com/open?id=1-zOpNcOuDpzU2vH3nfae7u_KMaD_IUcr
Similarly, the Prep4SureReview Nutanix NCP-CI-AWS practice test creates an actual exam scenario on each and every step so that you may be well prepared before your actual Nutanix Certified Professional - Cloud Integration - AWS examination time. Hence, it saves you time and money. Prep4SureReview provides three months of free updates if you purchase the Nutanix NCP-CI-AWS Questions and the content of the examination changes after that.
Nutanix NCP-CI-AWS Exam Syllabus Topics:
  • Prepare the AWS cloud environment: This exam segment evaluates your ability to set up the AWS cloud environment, initiate NC2 service subscription, establish implementation criteria, and recognize networking prerequisites.
  • Configuring an NC2 on AWS Environment: This section examines your proficiency in setting up cloud networking and security measures, as well as addressing connectivity issues.
  • Deploying an NC2 on AWS Environment: This portion assesses your knowledge of cloud cluster deployment, cloud provider network configuration, and your skills in addressing cluster deployment challenges.
  • Managing an NC2 on AWS Environment: This exam component tests your understanding of node and cluster management tasks, along with your ability to oversee cluster and cloud resource health.
Exam NCP-CI-AWS Duration, New NCP-CI-AWS Exam Pass4sureCreated on the exact pattern of the actual NCP-CI-AWS tests, Prep4SureReview’s dumps comprise questions and answers and provide all important NCP-CI-AWS information in easy to grasp and simplified content. The easy language does not pose any barrier for any learner. The complex portions of the NCP-CI-AWS certification syllabus have been explained with the help of simulations and real-life based instances. The best part of NCP-CI-AWS Exam Dumps are their relevance, comprehensiveness and precision. You need not to try any other source forNCP-CI-AWS exam preparation. The innovatively crafted dumps will serve you the best; imparting you information in fewer number of questions and answers.
Nutanix Certified Professional - Cloud Integration - AWS Sample Questions (Q43-Q48):NEW QUESTION # 43
To manually create an AWS VPC with Public access to Prism Element for testing purposes, Which components must be created?
  • A. VPC, Delegated Subnets, Route Tables, NAT Gateway, vNets, Load balancer
  • B. VPC, Delegated Subnets, Route Tables, NAT Gateway, Internet Gateway, Load balancer
  • C. VPC Subnets Route Tables NAT Gateway, Internet Gateway, Load balancer
  • D. VPC Subnets Route subnets, Route Tables, NAT Gateway, Internet Gateway, VPN
To manually create an AWS VPC with Public access to Prism Element for testing purposes, the following components must be created:
VPC: A Virtual Private Cloud to provide an isolated network for the resources.
Delegated Subnets: Subnets within the VPC to segment the network and allocate IP ranges.
Route Tables: To define routing rules for the subnets to ensure proper traffic flow.
NAT Gateway: To enable instances in the private subnets to access the internet.
Internet Gateway: To allow direct internet access to instances in the public subnets.
Load Balancer: To distribute traffic across multiple instances for improved availability and redundancy.
Refer to the AWS documentation on VPC creation and Nutanix documentation on network setup for Prism Element access.
NEW QUESTION # 44
What should be checked within Flow Virtual Networking to ensure on premises traffic will be routed correctly?
  • A. Next Hop is the overlay-external-subnet-nonat
  • B. Next Hop is the overlay-external-subnet-nat
  • C. Next Hop is the ERP of the Transit Gateway
  • D. Next Hop is the Transit Gateway P2P link
NEW QUESTION # 45
An administrator has recently deployed an NC2 on AWS cluster in the North Virginia region in availability zone us-east-1z. The clusters UUID is 0005F487-4962-91EA-4C98-C4284D123835.
The cluster is consuming IPs from a 10.78.2.0/24 range.
The AWS VPC has these available CIDR ranges:
* 70.73.0.0/16
* 10.79.107.0/24
* 10.0.0.0/22
The following subnets have been configured in the NC2 AWS VPC:
The following tags have been applied to a Custom Network Security Group:
The Custom Network Security Group is allowing all inbound traffic from the 10.0.0.0/22 network. Which two subnets would be able to receive inbound traffic from AWS instances on a 10.0.0.0/22 network segment"? (Choose two.)
  • A. SQL
  • B. Tier01
  • C. VDl
  • D. Server01
To determine which subnets would be able to receive inbound traffic from AWS instances on a 10.0.0.0/22 network segment, we need to look at the configured subnets and their CIDR ranges, as well as the custom network security group's inbound rules.
Available CIDR ranges in VPC:
70.73.0.0/16
10.79.107.0/24
10.0.0.0/22
Configured Subnets in NC2 AWS VPC:
VDI: 10.78.130.0/22
SQL: 10.78.3.0/24
Server01: 10.78.2.0/24
Server02: 10.79.120.0/24
Tier01: 10.19.101.0/24
Custom Network Security Group Inbound Rule:
Allows all inbound traffic from 10.0.0.0/22.
Given that the custom network security group is allowing inbound traffic from the 10.0.0.0/22 network, we need to identify which of the configured subnets fall within this allowed range.
Analysis:
The subnets 10.78.130.0/22, 10.78.3.0/24, 10.78.2.0/24, 10.79.120.0/24, and 10.19.101.0/24 do not overlap with 10.0.0.0/22. Therefore, none of these subnets would naturally fall within the 10.0.0.0/22 range directly.
However, since the question is about receiving inbound traffic from the 10.0.0.0/22 network and considering security group rules, all subnets mentioned can technically receive traffic if the inbound rules are configured correctly, but since we are strictly asked about the configuration from the image and the overlap in the ranges:
Server01 (10.78.2.0/24) and Tier01 (10.19.101.0/24) will receive traffic because their CIDR ranges do not conflict with the 10.0.0.0/22 range, thus allowing traffic without additional restrictions.
Nutanix Clusters on AWS Administration Guide
AWS VPC and Subnet documentation
Network Security Group rules configuration in Nutanix documentation
NEW QUESTION # 46
What are the supported NC2 on AWS instance types?
  • A. i4i.4xlarge, i3.8xlarge, i7ie.2xlarge
  • B. i3.metal, t2.micro, g4dn.xlarge, M5d.medium
  • C. i7ie.24xlarge, i4i.32xlarge, i3.12xlarge
  • D. i3.metal, i3en.metal, i4i.metal
NEW QUESTION # 47
The cluster is configured as follows:
* 8 nodes
* Prism Central Deployed
* Files Deployed
Following the deployment, the administrator experiences network connectivity issues.
Which reason explains the connectivity issues?
  • A. The 192.168.5.0/24 range does not have enough IP addresses available.
  • B. The 192.168.5.0/24 range is not a valid CIDR range.
  • C. The 192.168.5.0/24 range is reserved by IANA,
  • D. The 192.168.5.0/24 range is reserved for internal cluster usage.
The 192.168.5.0/24 range is often reserved for internal cluster communication within Nutanix deployments.
Using this CIDR range for other purposes could lead to network conflicts and connectivity issues, as it might interfere with the internal operations and communication channels of the Nutanix cluster.
Ensuring that the CIDR range is not overlapping with any reserved ranges is crucial for maintaining proper network connectivity and cluster functionality.
Refer to the Nutanix documentation on network configuration and best practices for NC2 deployments to confirm reserved IP ranges and their appropriate use.
NEW QUESTION # 48
As the saying goes, verbal statements are no guarantee. So we are willing to let you know the advantages of our NCP-CI-AWS study braindumps. In order to let all people have the opportunity to try our products, the experts from our company designed the trial version of our NCP-CI-AWS prep guide for all people. If you have any hesitate to buy our products. You can try the trial version from our company before you buy our NCP-CI-AWS Test Practice files. The trial version will provide you with the demo. More importantly, the demo from our company is free for all people. You will have a deep understanding of the NCP-CI-AWS study braindumps from our company by the free demo.
Exam NCP-CI-AWS Duration: https://www.prep4surereview.com/NCP-CI-AWS-latest-braindumps.html
BONUS!!! Download part of Prep4SureReview NCP-CI-AWS dumps for free: https://drive.google.com/open?id=1-zOpNcOuDpzU2vH3nfae7u_KMaD_IUcr
