[General] Reliable C-HRHFC-2411 Exam Pattern | Study C-HRHFC-2411 Plan
87
General Reliable C-HRHFC-2411 Exam Pattern | Study C-HRHFC-2411 Plan
Posted at 3/9/2026 05:40:10      View153 | Replies0        Print      Only Author   [Copy Link] 1#
2026 Latest PrepAwayTest C-HRHFC-2411 PDF Dumps and C-HRHFC-2411 Exam Engine Free Share: https://drive.google.com/open?id=1cfTr8Pgn6rTJ3pjseJSkRRsGg0zd95YK
The user-friendly interface of C-HRHFC-2411 Dumps (desktop & web-based) will make your preparation effective. The PrepAwayTest ensures that the C-HRHFC-2411 practice exam will make you competent enough to crack the in-demand C-HRHFC-2411 examination on the first attempt. Real SAP C-HRHFC-2411 dumps of PrepAwayTest come in PDF format as well.
SAP C-HRHFC-2411 Exam Syllabus Topics:
  • Managing Clean Core: This section of the exam measures the skills of SAP Consultants and covers strategies for maintaining a clean core in SAP systems. It emphasizes the importance of minimizing customizations to ensure system integrity and upgradeability. A skill to be measured is identifying unnecessary customizations effectively.
  • Organizational Data Replication from SAP SuccessFactors Employee Central to SAP ERP: This section of the exam measures the skills of SAP HRM Consultants and covers the replication of organizational data from SAP SuccessFactors Employee Central to SAP ERP.
  • SAP SuccessFactors Employee Central Integration Overview and Basic Settings: This section of the exam measures the skills of SAP Consultants and covers the basic settings and overview of integrating SAP SuccessFactors Employee Central with other systems. It focuses on the initial configuration steps necessary for successful integration. One skill to be measured is configuring basic integration settings accurately.
  • SAP SuccessFactors Compound Employee API: This section of the exam measures the skills of SAP Consultants and covers the Compound Employee API, which facilitates employee data replication between systems. It focuses on structuring employee data for efficient transfer. A skill to be measured is utilizing the Compound Employee API for data synchronization.
Topic 5
  • SAP SuccessFactors Employee Central Integration with SAP ERP Scenarios Overview: This section of the exam measures the skills of professionals in understanding various scenarios for integrating SAP SuccessFactors Employee Central with SAP ERP.
Study C-HRHFC-2411 Plan - C-HRHFC-2411 Simulated TestWe will free provide you part of the exercises of SAP Certification C-HRHFC-2411 Exam on the Internet to let you try to test our product's quality. After your trail you will find PrepAwayTest's exercises is the most comprehensive one and is what you want to.
SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Full Cloud/Core Hybrid Sample Questions (Q31-Q36):NEW QUESTION # 31
In a Side-by-Side deployment model, which module can be optional for either SAP ERP or SAP SuccessFactors?
  • A. Time & Attendance
  • B. Organizational Management
  • C. Payroll
  • D. Workforce Analytics
Payroll can remain in either SAP ERP or be moved to SAP SuccessFactors EC Payroll based on customer needs in a Side-by-Side model. It does not mandate replication or coexistence, allowing flexibility.
Reference: Deployment Models - Side-by-Side Setup Guide.
NEW QUESTION # 32
Your customer has multiple SAP ERP Financials systems with similar cost center names. What activity do you recommend?
  • A. Enable the External Object ID field in SAP SuccessFactors Employee Central.
  • B. Implement the ODTF_CC_REPLICAT_IDOCS_MODIFY enhancement spot.
  • C. Create a key mapping in the PAOCFEC_KMAPCOSC table.
  • D. Enable the USE_EXTERNAL_COST_CENTER SAP Integration Suite service process parameter.
PAOCFEC_KMAPCOSCis thekey mapping tableused to distinguish cost centers from different ERP systems, even if they share the same name. This prevents collisions and ensures correct assignment during replication.
Reference: Cost Center Replication Guide - Key Mapping for Multi-ERP Scenarios
NEW QUESTION # 33
Which IDoc will you use to replicate cost center to the SAP SuccessFactors Employee Central Payroll system?
  • A. ODTF_CCTR
  • B. DEBMAS
  • C. COSMAS
  • D. CREMAS
The IDocODTF_CCTRis specifically used forcost center replicationinto SAP SuccessFactors Employee Central or Payroll. Other IDocs like DEBMAS (Customers) or COSMAS (Cost Center Master in classic CO) are not compatible with EC-specific replication flows.
Reference: SAP Cost Center Integration Guide - IDoc Configuration
NEW QUESTION # 34
Which of the following are characteristics of the Employee Central custom objects in organizational replication?Note: There are 2 correct answers to this question.
  • A. Custom objects must be effective dated.
  • B. Custom objects can be created for any organizational structural object.
  • C. Custom objects need to be mapped using custom templates.
  • D. Custom objects should always be multiple use.
NEW QUESTION # 35
You want to clone the transformation template used when you replicate employee master data from SAP SuccessFactors Employee Central to SAP ERP. What must you do before you start the cloning process?
  • A. Define country-specific Infotypes and subtypes for cloning templates customizing.
  • B. Define field mapping for the transformation template group in view cluster VC ECPAO MAP.
  • C. Restrict employee master data replication to certain countries.
  • D. Configure value mapping of subtypes in scope for the field mapping.
NEW QUESTION # 36
As for candidates who will attend the exam, choosing the practicing materials may be a difficult choice. Then just trying C-HRHFC-2411 learning materials of us, with the pass rate is 98.95%, we help the candidates to pass the exam successfully. Many candidates have sent their thanks to us for helping them to pass the exam by using the C-HRHFC-2411 Learning Materials. The reason why we gain popularity in the customers is the high-quality of C-HRHFC-2411 exam dumps. In addition, we provide you with free update for one year after purchasing. Our system will send the latest version to you email address automatically.
Study C-HRHFC-2411 Plan: https://www.prepawaytest.com/SAP/C-HRHFC-2411-practice-exam-dumps.html
P.S. Free & New C-HRHFC-2411 dumps are available on Google Drive shared by PrepAwayTest: https://drive.google.com/open?id=1cfTr8Pgn6rTJ3pjseJSkRRsGg0zd95YK
