[Hardware] C_THR92_2505 Reliable Braindumps Questions, Latest C_THR92_2505 Test Prep
90
Hardware C_THR92_2505 Reliable Braindumps Questions, Latest C_THR92_2505 Test Prep
Posted at 3/9/2026 09:22:00      View156 | Replies0        Print      Only Author   [Copy Link] 1#
You might have seen lots of advertisements about C_THR92_2505 learning question, there are so many types of C_THR92_2505 exam material in the market, why you should choose us? Our reasons are as follow. Our C_THR92_2505 test guide is test-oriented, which makes the preparation become highly efficient. Once you purchase our C_THR92_2505 exam material, your time and energy will reach a maximum utilization. Thus at that time, you would not need to afraid of the cruel society and peer pressure with C_THR92_2505 Certification. In conclusion, a career enables you to live a fuller and safer life. So if you want to take an upper hand and get a well-pleasing career our C_THR92_2505 learning question would be your best friend.
SAP C_THR92_2505 Exam Syllabus Topics:
  • Table Reports: This part measures the skills of a Data Analyst and involves creating, managing, and running Table Reports. It focuses on designing tabular data presentations that facilitate straightforward access to detailed workforce analytics information.
  • Report Consumers: This domain evaluates the understanding of a Business User and focuses on how report consumers interact with and utilize generated reports. It highlights user roles, permissions, and effective report sharing practices to ensure reports serve decision-making needs.
  • Detailed Reporting Tool with Live Data: This section assesses the skills of an Advanced Report Developer and involves working with detailed reports that use live data feeds. It includes building customizable queries and using reporting tools to deliver real-time, actionable data to stakeholders.
  • Advanced Reporting Tool with Replicated Data: This section targets a Reporting Specialist and covers leveraging advanced reporting tools that operate on replicated data. It includes knowledge of data replication concepts and using these tools to perform comprehensive reporting that supports detailed analysis.
Topic 5
  • Canvas Reports and Page Designer: This part measures the capabilities of a Report Administrator and involves creating and customizing reports using Canvas Reports and Page Designer. It covers advanced query construction, formatting, pivot creation, and report distribution to enhance data presentation and usability.
Topic 6
  • Story Reports: This section of the exam measures skills of a Report Creator and covers the creation and management of Story Reports within SAP SuccessFactors. It emphasizes designing queries, configuring pages with widgets, and managing report permissions to generate insightful visualizations.
Latest C_THR92_2505 Test Prep | C_THR92_2505 Test DumpPassing the C_THR92_2505 exam is your best career opportunity. The rich experience with relevant certificates is important for enterprises to open up a series of professional vacancies for your choices. Our website's C_THR92_2505 learning quiz bank and learning materials look up the latest questions and answers based on the topics you choose. This choice will serve as a breakthrough of your entire career, so prepared to be amazed by high quality and accuracy rate of our C_THR92_2505 Study Guide.
SAP Certified Associate - SAP SuccessFactors People Analytics: Reporting Sample Questions (Q14-Q19):NEW QUESTION # 14
Within a Story, you create a query using the Basic User Information table. After you add the Proxy Information table, you notice that some of the basic information records are NO longer displayed in the preview. How do you adjust the query to return the missing records in the preview?
  • A. Remove the related table and add it using the Show Related Tables command from the Action Menu.
  • B. Change the join type to Inner Join.
  • C. Remove the related table and select and drag it from the Available Data section.
  • D. Change the join type to Left Outer Join.
* Join Types in Queries:
* Inner Join: Only returns rows where there is a match in both tables.
* Left Outer Join: Returns all rows from the left table and matching rows from the right table, filling in NULLs where there is no match.
* Scenario:
* Adding the Proxy Information table creates a situation where some records from the Basic User Information table no longer match with Proxy Information.
* Changing the join type to Left Outer Join ensures that all records from the Basic User Information table are included, regardless of matching Proxy Information.
* Steps to Adjust Join Type:
* Edit the query.
* Locate the join between Basic User Information and Proxy Information tables.
* Change the join type from Inner Join to Left Outer Join.
NEW QUESTION # 15
You are creating a Story report on employment and compensation information. You have created two queries to support the story report. The table and the left chart are using an employment query as its data source. The right chart uses a compensation query as its data source. Both queries include the field for the employee Job Title. When you add an input control to the page, it only filters the table and the left chart. What action must you take to configure the input control to effect both charts and the table?
  • A. Update Linked Analysis.
  • B. Convert it to a Story Filter.
  • C. Enable Cascading Effects.
  • D. Set up Linked Dimensions.
* Problem Description
* The input control must filter multiple queries (employment and compensation) by the Job Title field. This requires linking dimensions across the queries.
* Solution: Linked Dimensions
* Configuring Linked Dimensions connects the shared field (Job Title) between the queries. This ensures the input control affects all visuals based on the linked field.
* Why Other Options are Incorrect
* A (Story Filter): Applies filters globally but does not link dimensions between queries.
* B (Update Linked Analysis): Handles interactivity within a single query but not across multiple queries.
* C (Enable Cascading Effects): This is unrelated to linking dimensions.
References
* SAP SuccessFactors Linked Dimensions Guide
NEW QUESTION # 16
You want to create a tile-based dashboard and make it available to users. After you created and named the dashboard, which steps are required?
  • A. Create tiles(s). Select filters. Save dashboard.
  • B. Create tile(s). Select dataset. Share dashboard.
  • C. Select tile(s). Select dataset. Save dashboard.
  • D. Select tile(s). Save dashboard. Share dashboard.
* Creating and Sharing a Tile-Based Dashboard
* After naming the dashboard, the key steps are to select the desired tiles, save the dashboard, and share it with the relevant users.
* Explanation of Correct Answer
* Select tile(s): Ensures the dashboard contains the necessary visualizations.
* Save dashboard: Saves the configuration for later use.
* Share dashboard: Makes the dashboard accessible to the intended audience.
* A: Filters are not always required during the dashboard creation process.
* B: Selecting a dataset is not part of the dashboard creation workflow.
* C: Sharing is mandatory after saving, so this option is incomplete.
References
* SAP SuccessFactors Dashboard Creation Documentation
NEW QUESTION # 17
In a canvas report, to which of the following can you export multipage reports in a single transaction? Note:
There are 3 correct answers to this question.
  • A. Microsoft Word
  • B. Adobe PDF
  • C. Microsoft Excel
  • D. Microsoft PowerPoint
  • E. XML format
Answer: A,B,D
* Exporting Multipage Reports
* Canvas reports support exporting multipage reports in formats that preserve the layout and design, such as Microsoft Word, PowerPoint, and PDF.
* A. Microsoft Excel: Canvas reports do not support exporting multipage layouts to Excel.
* C. XML Format: XML is not supported for multipage exports.
References
* SAP SuccessFactors Canvas Reports Export Options
NEW QUESTION # 18
You are using Report Center to share a canvas report. You share the report with a Dynamic Group (see attached image). Who is the report shared with?
  • A. Employees of the Sales departments and all employees of Atlanta
  • B. Employees of the Sales department of Atlanta
  • C. Employees of the Sales department
  • D. Employees of Atlanta
* Dynamic Groups in SAP SuccessFactors:
* Dynamic groups combine multiple People Pools using logical OR conditions.
* In the given configuration, the report is shared with employees in Atlanta OR employees in the Sales department.
* Explanation of the Result:
* Employees in both conditions are included because the People Pools are treated as separate categories and are not exclusive to each other.
NEW QUESTION # 19
On one hand, we adopt a reasonable price for you, ensures people whoever is rich or poor would have the equal access to buy our useful C_THR92_2505 real study dumps. On the other hand, we provide you the responsible 24/7 service. Our candidates might meet so problems during purchasing and using our C_THR92_2505 prep guide, you can contact with us through the email, and we will give you respond and solution as quick as possible. With the commitment of helping candidates to Pass C_THR92_2505 Exam, we have won wide approvals by our clients. We always take our candidates benefits as the priority, so you can trust us without any hesitation.
Latest C_THR92_2505 Test Prep: https://www.itcerttest.com/C_THR92_2505_braindumps.html
