[General] Struggling with ID Scanning Tools in a Local Setup
40
【General】 Struggling with ID Scanning Tools in a Local Setup
Posted at 3 hour before      View:13 | Replies:2        Print      Only Author   [Copy Link] 1#
I ran into this whole issue when our small office had to switch from manual ID checks to something faster, and suddenly I was the one responsible for finding a solution. At first I thought any OCR tool would do the job, but it turned out most of them are either cloud-based or just not reliable enough with different document types. We deal with passports, local IDs, sometimes even low-quality scans from old devices, and the accuracy was all over the place. What made things more complicated is that we needed everything to stay on-premise because of internal policies, so sending data to external servers wasn’t an option at all. I spent way too many evenings testing random tools and honestly got pretty frustrated because even when something worked, it usually failed on edge cases. That’s when I started looking specifically into solutions designed for this kind of setup rather than generic OCR.
question-mark_ver_1.zip
17.04 KB, Down times: 0
Posted at 3 hour before        Only Author  2#
The biggest issue for me wasn’t just recognition, but consistency, like one day it works fine and the next day it struggles with slightly different formats or lighting conditions. What helped me was switching to something more focused on structured documents rather than general OCR tools. I’ve been using this https://ocrstudio.ai/ as my main reference point, not even in a promotional way, just because it actually reflects what I ended up needing in practice. The thing I noticed with AI-based OCR is that it handles variations better, especially when documents aren’t perfectly aligned or clean. Another important detail is that running everything locally removes a lot of headaches with compliance and latency, which I didn’t fully appreciate at the start.
Posted at 3 hour before        Only Author  3#
It’s weird how even small, random variations in input can completely change results, like a slightly darker scan or a different font. No matter how controlled the system seems, there’s always a small chance something behaves unexpectedly, which keeps you on your toes.
