Test XK0-005 Prep, XK0-005 Reliable Exam Simulator
Posted at 4/19/2026 14:31:14
View79
Replies0
P.S. Free 2026 CompTIA XK0-005 dumps are available on Google Drive shared by Actual4test: https://drive.google.com/open?id=1w21r68hKk8ERGLVwF_d5g0MwbA4EmwA8
Actual4test is an authoritative study platform to provide our customers with different kinds of XK0-005 practice torrent to learn, and help them accumulate knowledge and enhance their ability to pass the exam as well as get their expected scores. There are three different versions of our XK0-005 Study Guide: the PDF, the Software and the APP online. To establish our customers' confidence, we offer related free demos for our customers to download before purchase. With our XK0-005 exam questions, you will be confident to win in the XK0-005 exam.
The XK0-005 exam covers a broad range of topics, including system architecture, Linux installation and package management, GNU and Unix commands, devices, Linux filesystems, and file system hierarchy standards. Additionally, it tests the candidate's knowledge of networking concepts, security, and shell scripting. XK0-005 exam format consists of multiple-choice, drag and drop, and performance-based questions. It is a computer-based exam that can be taken at any Pearson VUE testing center.
CompTIA XK0-005 is the latest version of the CompTIA Linux+ certification exam. CompTIA Linux+ Certification Exam certification is designed to validate the skills and knowledge of IT professionals in the Linux operating system. XK0-005 exam is intended for IT professionals who have experience working with Linux and want to demonstrate their proficiency in the subject matter.
CompTIA XK0-005 Reliable Exam Simulator | Latest Real XK0-005 ExamPrinting these XK0-005 valid questions and reading them in a handy paper format is another feature offered by Actual4test CompTIA XK0-005 PDF for test applicants who prefer more conventional reading experience. These incredible features of CompTIA XK0-005 PDF Questions help applicants practice for the XK0-005 exam wherever and whenever they want, according to their timetables.
CompTIA Linux+ Certification Exam Sample Questions (Q633-Q638):NEW QUESTION # 633
A systems administrator is tasked with changing the default shell of a system account in order to disable iterative logins. Which of the following is the best option for the administrator to use as the new shell?
- A. /bin/ sh
- B. /sbin/ setenforce
- C. /sbin/nologin
- D. /bin/bash
The /sbin/nologin shell is a special shell that prevents the user from logging into an interactive session. It is commonly used for system accounts that are not meant to be accessed by users, such as daemon or service accounts. When a user tries to log in with this shell, they will see a message like "This account is currently not available" and the login will fail.
The /sbin/nologin shell is listed as one of the valid shells in the /etc/shells file1.
The CompTIA Linux+ Certification Exam Objectives mention that the candidate should be able to "configure and manage system accounts and groups, including password aging and restricted shells" as part of the Hardware and System Configuration domain2.
The usermod command can be used to change the user's login shell with the -s or --shell option3. For example, to change the shell of a user named daemon to /sbin/nologin, the command would be: sudo usermod -s /sbin/nologin daemon
NEW QUESTION # 634
A systems administrator is deploying three identical, cloud-based servers. The administrator is using the following code to complete the task:
Which of the following technologies is the administrator using?
- A. Terraform
- B. Chef
- C. Puppet
- D. Ansible
The code snippet is written in Terraform language, which is a tool for building, changing, and versioning infrastructure as code. Terraform uses a declarative syntax to describe the desired state of the infrastructure and applies the changes accordingly. The code defines a resource of type aws_instance, which creates an AWS EC2 instance, and sets the attributes such as the AMI ID, instance type, security group IDs, and key name. The code also uses a count parameter to create three identical instances and assigns them different names using the count.index variable. This is the correct technology that the administrator is using. The other options are incorrect because they use different languages and syntaxes for infrastructure as code. References: CompTIA Linux+ (XK0-005) Certification Study Guide, Chapter 19: Managing Cloud and Virtualization Technologies, page 559.
NEW QUESTION # 635
A systems administrator configured firewall rules using firewalld. However, after the system is rebooted, the firewall rules are not present:
The systems administrator makes additional checks:
Which of the following is the reason the firewall rules are not active?
- A. FIREWALL_ARGS has no value assigned.
- B. The wrong system target is activated.
- C. The firewalld service is not enabled.
- D. iptables is conflicting with firewalld.
The reason the firewall rules are not active is that the firewalld service is not enabled. This means that the service will not start automatically at boot time or after a system reload. To enable the firewalld service, the systems administrator needs to use the command sudo systemct1 enable firewalld. This will create a symbolic link from the firewalld service file to the appropriate systemd target, such as multi-user.target. Enabling the service does not start it immediately, so the systems administrator also needs to use the command sudo systemct1 start firewalld or sudo systemct1 reload firewalld to activate the firewall rules.
The other options are not correct reasons for the firewall rules not being active. iptables is not conflicting with firewalld, because firewalld uses iptables as its backend by default. The wrong system target is not activated, because firewalld is independent of the system target and can be enabled for any target. FIREWALL_ARGS has no value assigned, but this is not a problem, because FIREWALL_ARGS is an optional environment variable that can be used to pass additional arguments to the firewalld daemon, such as --debug or --nofork. If FIREWALL_ARGS is empty or not defined, firewalld will use its default arguments. References: firewalld.
service(8) - Linux manual page; firewall-cmd(1) - Linux manual page; systemct1(1) - Linux manual page
NEW QUESTION # 636
A systems administrator was tasked with assigning the temporary IP address/netmask
192.168.168.1/255.255.255.255 to the interface eth0 of a Linux server.
When adding the address, the following error appears:
# ip address add 192.168.168.1/33 dev eth0
Error: any valid prefix is expected rather than "192.168.168.1/33".
Based on the command and its output above, which of the following is the cause of the issue?
- A. The IP address 192.168.168.1 is already in use.
- B. The interface eth0 does not exist.
- C. The CIDR value /33 should be /32 instead.
- D. There is no route to 192.168.168.1/33.
The cause of the issue is that the CIDR value /33 is invalid for an IPv4 address. The CIDR value represents the number of bits in the network prefix of an IP address, and it can range from 0 to 32 for IPv4 addresses. A CIDR value of /33 would imply a network prefix of more than 32 bits, which is impossible for an IPv4 address. To assign a temporary IP address/netmask of
192.168.168.1/255.255.255.255 to eth0, the CIDR value should be /32 instead, which means a network prefix of 32 bits and a host prefix of 0 bits. There is no route to 192.168.168.1/33 is not the cause of the issue, as the ip address add command does not check the routing table. The interface eth0 does not exist is not the cause of the issue, as the ip address add command would display a different error message if the interface does not exist. The IP address 192.168.168.1 is already in use is not the cause of the issue, as the ip address add command would display a different error message if the IP address is already in use.
NEW QUESTION # 637
A systems administrator wants to upgrade /bin/ someapp to a new version, but the administrator does not know the package name. Which of the following will show the RPM package name that provides that binary file?
- A. rpm -i / bin/ someapp
- B. rpm -qf /bin/ someapp
- C. rpm -Vv / bin/ someapp
- D. rpm - P / bin/ some app
The rpm command is used to manage RPM packages on Linux systems. The -qf option queries the package name that provides a given file. Therefore, the command rpm -qf /bin/someapp will show the RPM package name that provides the binary file /bin/someapp. The statements B, C, and D are incorrect because they do not query the package name, but rather verify, remove, or install a package. References: [How to Use RPM Command in Linux with Examples]
NEW QUESTION # 638
If you want to pass the shortest time to pass you exam, just find us. Our XK0-005 Training Materials will have the collective of the questions and answers, it will help you to have a good command of the knowledge point, therefore make it possible for you to pass the exam. Besides money back guarantee if you fail to pass it, or we can change another exam dumps for you for free. All we do is just want to serve you better. Choose us and you will never regret.
XK0-005 Reliable Exam Simulator: https://www.actual4test.com/XK0-005_examcollection.html
- XK0-005 Test Registration 🔇 Latest XK0-005 Practice Materials 🍓 XK0-005 Latest Dumps 🦡 Search for ▛ XK0-005 ▟ and download it for free immediately on [url]www.torrentvce.com 🤨XK0-005 Valid Test Test[/url]
- XK0-005 Mock Exam ❇ XK0-005 Latest Exam Test 👊 XK0-005 Valid Test Test 🥿 The page for free download of { XK0-005 } on ☀ [url]www.pdfvce.com ️☀️ will open immediately 🛫XK0-005 Valid Test Test[/url]
- Free PDF Quiz 2026 XK0-005: CompTIA Linux+ Certification Exam Perfect Test Prep 🍧 Easily obtain free download of ➥ XK0-005 🡄 by searching on ▛ [url]www.pdfdumps.com ▟ 🍼Latest XK0-005 Practice Materials[/url]
- XK0-005 Latest Exam Test 🦑 Latest XK0-005 Practice Materials 🚧 XK0-005 Mock Exam 🎐 Open website ✔ [url]www.pdfvce.com ️✔️ and search for ▶ XK0-005 ◀ for free download 🌾XK0-005 Actual Dumps[/url]
- XK0-005 Exam Introduction 🍑 XK0-005 Test Registration 🐟 XK0-005 Mock Exam 🥨 Copy URL ✔ [url]www.examcollectionpass.com ️✔️ open and search for ⇛ XK0-005 ⇚ to download for free 💍XK0-005 Actual Dumps[/url]
- XK0-005 Valid Exam Vce 🪁 XK0-005 Latest Exam Test 🥗 XK0-005 Test Registration 🎫 Easily obtain XK0-005 for free download through ⮆ [url]www.pdfvce.com ⮄ 😧XK0-005 Valid Exam Vce[/url]
- XK0-005 Study Guide - XK0-005 Free Download pdf - XK0-005 Latest Pdf Vce 📰 Search for XK0-005 and download exam materials for free through ▷ [url]www.examcollectionpass.com ◁ 📠XK0-005 Certification Exam Dumps[/url]
- Unlimited XK0-005 Exam Practice 🦆 XK0-005 Mock Exam 🍴 Unlimited XK0-005 Exam Practice 🖼 Download ➥ XK0-005 🡄 for free by simply entering [url]www.pdfvce.com website ⏯XK0-005 Certification Exam Dumps[/url]
- Pass Guaranteed CompTIA - XK0-005 Accurate Test Prep 🐜 Open [ [url]www.dumpsquestion.com ] enter ➠ XK0-005 🠰 and obtain a free download 🥥XK0-005 Actual Dumps[/url]
- XK0-005 Paper 🔐 XK0-005 Latest Dumps 🦨 Latest XK0-005 Exam Duration 🟢 Immediately open ⏩ [url]www.pdfvce.com ⏪ and search for ☀ XK0-005 ️☀️ to obtain a free download 🧸XK0-005 Paper[/url]
- Pass Guaranteed CompTIA - XK0-005 Accurate Test Prep 🧯 Open [url]www.troytecdumps.com and search for XK0-005 to download exam materials for free 📎Valid Test XK0-005 Test[/url]
- ashadipcomputer.com, quay.io, www.stes.tyc.edu.tw, lms.rilosmals.com, schoolofdoers.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, wanderlog.com, www.stes.tyc.edu.tw, www.notebook.ai, Disposable vapes
2026 Latest Actual4test XK0-005 PDF Dumps and XK0-005 Exam Engine Free Share: https://drive.google.com/open?id=1w21r68hKk8ERGLVwF_d5g0MwbA4EmwA8
