[Hardware] Reliable 300-540 Test Syllabus, Test 300-540 Dumps Demo
32
Hardware Reliable 300-540 Test Syllabus, Test 300-540 Dumps Demo
Posted at 4/20/2026 13:09:29      View174 | Replies0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ExamTorrent 300-540 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1qFpZ9136cp99y4teikIfnCFUMaslXIfB
This professionally designed desktop practice exam software is customizable, which helps you to adjust timings and questions of the mock tests. This feature of Windows-based Designing and Implementing Cisco Service Provider Cloud Network Infrastructure software helps you improve time-management abilities and weak areas of the test preparation. We regularly upgrade this Cisco 300-540 Practice Exam software after receiving valuable feedback from experts worldwide.
The customers can immediately start using the Designing and Implementing Cisco Service Provider Cloud Network Infrastructure (300-540) exam dumps of ExamTorrent after buying it. In this way, one can save time and instantly embark on the journey of 300-540 test preparation. 24/7 customer service is also available at ExamTorrent. Feel free to reach our customer support team if you have any questions about our 300-540 Exam Preparation material.
Cisco 300-540 Exam Dumps - Preparation Material For Best Result [2026]ExamTorrent online digital Cisco 300-540 exam questions are the best way to prepare. Using our Cisco 300-540 exam dumps, you will not have to worry about whatever topics you need to master. To practice for a Cisco 300-540 Certification Exam in the ExamTorrent (free test), you should perform a self-assessment. The 300-540 practice test ExamTorrent keeps track of each previous attempt and highlights the improvements with each attempt.
Cisco Designing and Implementing Cisco Service Provider Cloud Network Infrastructure Sample Questions (Q65-Q70):NEW QUESTION # 65
Secure NFVI control and management plane involves:
  • A. Authentication and encryption
  • B. Removing all passwords
  • C. Unrestricted API access
  • D. Public internet access
NEW QUESTION # 66
Which cloud provider connection permits BGP peering?
  • A. AWS-managed VPN
  • B. AWS Direct Connect
  • C. Azure Bastion
  • D. Azure S2S VPN
Comprehensive and Detailed Explanation
Cloud interconnects that support BGP peering must provide a routed Layer-3 adjacency capable of exchanging routing information dynamically. In major cloud architectures:
AWS Direct Connect supports private virtual interfaces (VIFs) where BGP is used between the customer router and AWS to exchange routes.
Azure S2S VPN uses IPsec tunnels with static routing by default; BGP is optional only with specific gateway SKUs, but the question expects the standard, universally correct answer, which is Direct Connect.
Azure Bastion is a remote-access management service and does not support BGP.
AWS-managed VPN uses IPsec tunnels with BGP optional, but in exams, the recognized cloud service specifically associated with BGP support is Direct Connect.
In service provider cloud interconnect design, AWS Direct Connect is the standard, well-defined offering that provides layerized WAN connectivity with BGP support.
NEW QUESTION # 67
An engineer must design a pay-as-you-go solution for their partners. The solution must allow for rapid deployments, be flexible, and scale resources up or down in a hybrid workplace. What must be used?
  • A. Cisco+ Hybrid Cloud for Virtual Desktop Infrastructure
  • B. Cisco+ Hybrid Cloud for Virtualization
  • C. Cisco+ Hybrid Cloud for Bare Metal Compute
  • D. Cisco+ Hybrid Cloud for Service Provider Networking
Comprehensive and Detailed Explanation From Exact Extract from my knowledge of Designing and Implementing Cisco Service Provider Cloud Network Infrastructure Outlines without Any External URL or Links:
Cisco+ Hybrid Cloud is Cisco's as-a-service consumption model that offers pay-as-you-go infrastructure. For ahybrid workplace, the focus is on giving users secure desktop environments from anywhere, with the ability torapidly deployandscale up or downbased on the number of users or partners.
Cisco+Hybrid Cloud for Virtual Desktop Infrastructure (VDI)specifically delivers desktop and app workspaces as an on-demand service. It allows partners to consume desktops elastically, paying for capacity as needed and scaling the underlying compute, storage, and networking without rebuilding the environment.
* Bare Metal Compute and Virtualization offers flexible infrastructure but are aimed at app/workload hosting rather than user desktop workspaces.
* Service Provider Networking addresses network services, not end-user hybrid workplace desktops.
Therefore, for a pay-as-you-go, rapidly deployable, elastic solution in a hybrid workplace,Cisco+ Hybrid Cloud for Virtual Desktop Infrastructureis the correct choice.
NEW QUESTION # 68
Refer to the exhibit. An engineer must design a solution that allows a user to choose which private Cisco Catalyst SD-WAN network they want to connect to AWS. The solution must automatically identify the AWS VPC and other cloud services based on the user credentials. What must be used?
  • A. IPsec VPN
  • B. Segment routing
  • C. AWS Direct Connect
  • D. Transit VPC for AWS
In Cisco Catalyst SD-WAN cloud integration, when the requirement is:
* Automatically discovering AWSVPCs
* Automatically identifying AWSservices
* Allowing the user to choose whichprivate SD-WAN networkconnects to the cloud
* UsingAWS credentials(Access Key / Secret Key) for automatic provisioning
...the Cisco-supported mechanism is theCisco SD-WAN Transit VPC solution.
Why Transit VPC is the correct answer:
* It is specifically designed to integrateCisco SD-WANwith AWS environments.
* Uses AWS APIs and user credentials to automatically discover:
* VPC IDs
* Subnets
* Regions
* Routing tables
* Automatically deploys and configures CSR1000v or Catalyst 8000V routers into the VPC.
* Provides a centralized "hub" in AWS to interconnect multiple SD-WAN sites.
* Enables the user to choose which SD-WAN segments connect to which VPCs.
This matches the requirement ofautomatic cloud resource identification based on user credentials.
Why the other options are incorrect
A). AWS Direct Connect
* This is a physical/private Layer 2 cloud connection.
* It doesnotauto-discover VPCs or integrate through credentials.
* It does not provide automated SD-WAN service provisioning.
C). IPsec VPN
* Works for connectivity but ismanual, not automated.
* Does not identify AWS cloud resources via credentials.
D). Segment routing
* A transport technology used inside SP networks, irrelevant to AWS API-based VPC discovery.
Thus, onlyTransit VPCprovides automatic AWS cloud discovery and integration with SD-WAN.
NEW QUESTION # 69
Control plane high availability within a single VIM is crucial for maintaining __________.
  • A. performance
  • B. stability
  • C. security
  • D. scalability
NEW QUESTION # 70
Being scrupulous in this line over ten years, our experts are background heroes who made the high quality and high accuracy 300-540 study quiz. By abstracting most useful content into the 300-540 guide materials, they have helped former customers gain success easily and smoothly. We can claim that if you prapare with our 300-540 Exam Braindumps for 20 to 30 hours, then you will be confident to pass the exam.
Test 300-540 Dumps Demo: https://www.examtorrent.com/300-540-valid-vce-dumps.html
We can assure you that our 300-540 study materials are all made and sold with our sincere conscience, The quality of 300-540 practice training torrent is checked by our professional experts, Grab the opportunity to learn, pass the Test 300-540 Dumps Demo - Designing and Implementing Cisco Service Provider Cloud Network Infrastructure exam, and grow your career, Cisco Reliable 300-540 Test Syllabus You don't need to worry about how difficulty the exams are, The desktop-based 300-540 practice exam software works on Windows.
While software security continues to scale as a discipline, we can 300-540 expect a massive influx of newbies, The electrical guys came over and said, Come over and see this, you've got to see this.
Reliable 300-540 Test Syllabus | 100% Free Authoritative Test Designing and Implementing Cisco Service Provider Cloud Network Infrastructure Dumps DemoWe can assure you that our 300-540 Study Materials are all made and sold with our sincere conscience, The quality of 300-540 practice training torrent is checked by our professional experts.
Grab the opportunity to learn, pass the Designing and Implementing Cisco Service Provider Cloud Network Infrastructure exam, and grow your career, You don't need to worry about how difficulty the exams are, The desktop-based 300-540 practice exam software works on Windows.
2026 Latest ExamTorrent 300-540 PDF Dumps and 300-540 Exam Engine Free Share: https://drive.google.com/open?id=1qFpZ9136cp99y4teikIfnCFUMaslXIfB
