[Hardware] Exam Salesforce-Data-Cloud Preview, Salesforce-Data-Cloud Free Braindumps
30
【Hardware】 Exam Salesforce-Data-Cloud Preview, Salesforce-Data-Cloud Free Braindumps
Posted at yesterday 16:50      View:11 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Exam4Labs Salesforce-Data-Cloud dumps from Cloud Storage: https://drive.google.com/open?id=1_vKVsfwJswCuvTrjrXHljM_DpauRpUmB
The Salesforce Salesforce-Data-Cloud pdf format of the Exam4Labs product is easy-to-use. It contains actual Salesforce Data Cloud Accredited Professional Exam (Salesforce-Data-Cloud) exam questions. You can easily download and use Salesforce-Data-Cloud pdf on laptops, tablets, and smartphones. Exam4Labs regularly updates Salesforce Salesforce-Data-Cloud Exam Questions' pdf version so that you always have the latest material. Furthermore, the Salesforce Salesforce-Data-Cloud pdf can be printed enabling paper study.
Choosing our Salesforce vce dumps means you can closer to success. We have rich experienced in the real questions of Salesforce-Data-Cloud actual test. Our Salesforce-Data-Cloud vce files are affordable, latest and best quality with detailed answers and explanations, which can overcome the difficulty of real exam. You will save lots of time and money with our Salesforce-Data-Cloud Braindumps Torrent.
Salesforce Salesforce-Data-Cloud Free Braindumps - Salesforce-Data-Cloud Passing Score FeedbackThe goal of a Salesforce Salesforce-Data-Cloud mock exam is to test exam readiness. Exam4Labs's online Salesforce Data Cloud Accredited Professional Exam Salesforce-Data-Cloud practice test can be accessed online through all major browsers such as Chrome, Firefox, Safari, and Edge. You can also download and install the offline version of Salesforce Data Cloud Accredited Professional Exam Salesforce-Data-Cloud Practice Exam software on Windows-based PCs only. You can prepare for the Salesforce Data Cloud Accredited Professional Exam exam without an internet connection using the offline version of the mock exam.
Salesforce Data Cloud Accredited Professional Exam Sample Questions (Q77-Q82):NEW QUESTION # 77
Cloud Kicks has received a Request to be Forgotten by a customer. In which two ways can Data Cloud honor this request?
  • A. Add the Individual Id to a headerless file and use the delete from file functionality
  • B. Use Data Explorer to locate and manually remove the Individual
  • C. Use the Consent API to suppress processing and deletethe individual and related records from source data streams
  • D. Delete the data from the incoming data stream and perform a full refresh
NEW QUESTION # 78
Which two characteristics describe the Customer 360 data model?
  • A. A Product Sold By Salesforce
  • B. AStatic Model
  • C. A Canonical Model
  • D. A Conceptual Model
The Customer 360 data model is a conceptual model and a canonical model. A conceptual model is a high-level representation of the entities and relationships in a domain of interest, without specifying any implementation details. A canonical model is a common and consistent data model that can be used across different systems and applications. References: [Customer 360 Data Model Overview], [Conceptual Model],
[Canonical Model]
NEW QUESTION # 79
Cloud Kicks plans to do a full deletion of one of its existing data streams and its underlying data lake object (DLO).
What should the consultant consider before deleting the data stream?
  • A. The underlying DLO cannot be mapped to a data model object.
  • B. The data stream must be associated with a data kit.
  • C. The data stream can be deleted without implicitly deleting the underlying DLO.
  • D. The underlying DLO can be used in a data transform.
Data Streams and DLOs: In Salesforce Data Cloud, data streams are used to ingest data, which is then stored in Data Lake Objects (DLOs).
Deletion Considerations: Before deleting a data stream, it's crucial to consider the dependencies and usage of the underlying DLO.
Data Transform Usage:
Impact of Deletion: If the underlying DLO is used in a data transform, deleting the data stream will affect any transforms relying on that DLO.
Dependency Check: Ensure that the DLO is not part of any active data transformations or processes that could be disrupted by its deletion.
Salesforce Data Cloud Documentation: Data Streams
Salesforce Data Cloud Documentation: Data Transforms
NEW QUESTION # 80
A customer has a requirement to receive a notification whenever an activation fails for a particular segment.
Which feature should the consultant use to solution for this use case?
  • A. Dashboard
  • B. Flow
  • C. Report
  • D. Activation alert
The feature that the consultant should use to solution for this use case is C. Activation alert. Activation alerts are notifications that are sent to users when an activation fails or succeeds for a segment. Activation alerts can be configured in the Activation Settings page, where the consultant can specify the recipients, the frequency, and the conditions for sending the alerts. Activation alerts can help the customer to monitor the status of their activations and troubleshoot any issues that may arise. References: Salesforce Data Cloud Consultant Exam Guide, Activation Alerts
NEW QUESTION # 81
A company is seeking advice from a consultant on how to address the challenge of having multiple leads and contacts in Salesforce that share the same email address. The consultant wants to provide a detailed and comprehensive explanation on how Data Cloud can be leveraged to effectively solve this issue.
What should the consultant highlight to address this company's business challenge?
  • A. Identity Resolution
  • B. Identity Resolution
  • C. Data Bundles
  • D. Calculated Insights
Issue Overview: When multiple leads and contacts share the same email address in Salesforce, it can lead to data duplication, inaccurate customer views, and inefficient marketing and sales efforts.
Data Cloud Identity Resolution: Salesforce Data Cloud offers Identity Resolution as a powerful tool to address this issue. It helps in merging and unifying data from multiple sources to create a single, comprehensive customer profile.
Process:
Data Ingestion: Import lead and contact data into Salesforce Data Cloud.
Identity Resolution Rules: Configure Identity Resolution rules to match and merge records based on key identifiers like email addresses.
Unification: The tool consolidates records that share the same email address, eliminating duplicates and ensuring a single view of each customer.
Continuous Updates: As new data comes in, Identity Resolution continuously updates and maintains the unified profiles.
Benefits:
Accurate Customer View: Reduces duplicate records and provides a complete view of each customer's interactions and history.
Improved Efficiency: Streamlines marketing and sales efforts by targeting a unified customer profile.
Salesforce Data Cloud Identity Resolution
Salesforce Help: Identity Resolution Overview
NEW QUESTION # 82
We here guarantee that we will never sell the personal information of our candidates. There is no need for you to worry about the individual privacy under our rigorous privacy Salesforce-Data-Cloud actual test guide. As regards purchasing, our website and Salesforce-Data-Cloud study files are absolutely safe and free of virus. For further consideration we will provide professional IT personnel to guide your installation and the use of our Salesforce-Data-Cloud Exam Questions remotely. So you can buy our Salesforce-Data-Cloud actual test guide without any misgivings. If you have any questions, please you contact us online through the email.
Salesforce-Data-Cloud Free Braindumps: https://www.exam4labs.com/Salesforce-Data-Cloud-practice-torrent.html
Having experience with Salesforce-Data-Cloud exam dumps environment and structure of exam questions greatly help you to perform well in the final Salesforce-Data-Cloud exam, To embrace your expectations and improve your value during your review, you can take joy and challenge theSalesforce-Data-Cloud exam may bring you by the help of our Salesforce-Data-Cloud guide braindumps, In fact, the users of our Salesforce-Data-Cloud exam targeted training have won more than that, but a perpetual wealth of life.
They treat it as a craft, Use of Accessibility Modifiers, Having experience with Salesforce-Data-Cloud exam dumps environment and structure of exam questions greatly help you to perform well in the final Salesforce-Data-Cloud exam.
Salesforce Exam Salesforce-Data-Cloud Preview: Salesforce Data Cloud Accredited Professional Exam - Exam4Labs Good-reputation WebsiteTo embrace your expectations and improve your value during your review, you can take joy and challenge theSalesforce-Data-Cloud Exam may bring you by the help of our Salesforce-Data-Cloud guide braindumps.
In fact, the users of our Salesforce-Data-Cloud exam targeted training have won more than that, but a perpetual wealth of life, I think most of people will choose the latter, because most of the time certificate is a kind of threshold, with Salesforce-Data-Cloud certification, you may have the opportunity to enter the door of an industry.
The Salesforce Data Cloud Accredited Professional Exam certification exam is one of the top-rated career advancement Salesforce-Data-Cloud certifications in the market.
BONUS!!! Download part of Exam4Labs Salesforce-Data-Cloud dumps for free: https://drive.google.com/open?id=1_vKVsfwJswCuvTrjrXHljM_DpauRpUmB
