[General] Exam CPC-CDE-RECERT Demo, New Exam CPC-CDE-RECERT Materials
26
【General】 Exam CPC-CDE-RECERT Demo, New Exam CPC-CDE-RECERT Materials
Posted at 7 day before      View:67 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New CPC-CDE-RECERT dumps are available on Google Drive shared by ExamsReviews: https://drive.google.com/open?id=1jT1kPFfw7FSIz9OLReObN5bDyUTK09oY
Our CPC-CDE-RECERT exam braindumps have become a brand that is good enough to stand out in the market. The high quality product like our CPC-CDE-RECERT study quiz has no need to advertise everywhere, and exerts influential effects which are obvious and everlasting during your preparation. The exam candidates of our CPC-CDE-RECERT Study Materials are the best living and breathing ads. Just look at the comments on the CPC-CDE-RECERT training guide, you will know that how popular they are among the candidates.
You don't need to worry about wasting your precious time but failing to get the CPC-CDE-RECERTcertification. With our CPC-CDE-RECERT practice guide, your success is 100% guaranteed. Tens of thousands of people have used our CPC-CDE-RECERT Study Materials and the pass rate of the exam is high as 98% to 100%. This means as long as you learn with our CPC-CDE-RECERT learning quiz, you will pass the exam without doubt.
Free PDF Quiz Professional CyberArk - Exam CPC-CDE-RECERT DemoAs far as the price of CyberArk CPC-CDE-RECERT exam practice test questions is concerned, these exam practice test questions are being offered at a discounted price. Get benefits from CPC-CDE-RECERT Exam Questions at discounted prices and download them quickly. Best of luck in CPC-CDE-RECERT exam and career!!!
CyberArk CDE-CPC Recertification Sample Questions (Q41-Q46):NEW QUESTION # 41
You are creating a PSM Load Balanced Virtual Server Configuration.
What are the default service ports / protocols used for RDS and the PSM Health Check service?
  • A. RDP/3389 HTTPS/443
    C UDP/53 HTTPS/389
  • B. RDP/389 HTTP/443
  • C. RDP/636 HTTPS/443
In a PSM Load Balanced Virtual Server Configuration, the default service ports/protocols used are RDP/3389 and HTTPS/443. RDP (Remote Desktop Protocol) typically uses port 3389 for remote desktop services, which is essential for PSM functionalities involving remote sessions. HTTPS, which utilizes port 443, is used for the PSM Health Check service to ensure secure and encrypted communication during the monitoring and health verification processes of the PSM services.
NEW QUESTION # 42
Before you can delete a Safe, you must first delete all of its content (accounts and files) permanently. What else must also be achieved before the Safe can be successfully deleted?
  • A. The Safe owners have been removed from the Safe membership.
  • B. The "Save account versions for a period of:" has been set to 0 within the Safe version retention settings.
  • C. The associated CPM user has been removed from the Safe.
  • D. The version retention period has expired for all files.
CyberArk states that a Safe can be deleted only after its contents are deleted permanently, and (critically) objects are only deleted permanently after their retention/versions retention has passed. In the Privilege Cloud Safe management documentation, it notes that accounts are deleted permanently only after their retention period has passed, which is why deletion can be blocked by "non-expired" objects.
The underlying Vault/PACLI behavior is also explicit: "It is only possible to delete a Safe after the version retention period has expired for all files contained in the Safe." So, beyond deleting the content, the version retention period must have expired for all files # B.
NEW QUESTION # 43
When installing PSM on a Windows 2019 Server, under which circumstances should the PSMConnect and PSMAdminConnect users be moved to the domain? (Choose two.)
  • A. When you want to extend PSM sessions beyond one hour
  • B. When you need to enable PSM for Web Support
  • C. When you want to load balance the PSM installation
  • D. When RDS CAL Per User licenses are in use
  • E. When the RDS session broker has a value > 1
Answer: A,D
CyberArk explicitly states that you must move PSM application users (PSMConnect/PSMAdminConnect) to domain users on Windows 2019/2022 when:
* you are using RDS CAL per-user licensing, and
* you want to extend PSM sessions beyond one hour.
NEW QUESTION # 44
When installing the PSM and CPM components on the same Privilege Cloud Connector, what should you consider when hardening?
  • A. PSM settings override the CPM settings when referring to the same parameter.
  • B. They can only be installed on the same Privilege Cloud Connector when installed 'out of Domain'.
  • C. They can only be installed on the same Privilege Cloud Connector when installed 'in Domain'.
  • D. CPM settings override the PSM settings when referring to the same parameter
When installing the PSM and CPM components on the same Privilege Cloud Connector and considering the hardening process, it's important to note that PSM settings override the CPM settings when referring to the same parameter. This hierarchy is crucial in ensuring that the more stringent security settings required by PSM, which typically handles direct interaction with end-user sessions, take precedence over CPM settings.
This setup helps maintain robust security practices by applying the most restrictive configuration where conflicts occur.
NEW QUESTION # 45
You set up your LDAP Directory in CyberArk Identity, but encountered an error during the connection test.
Which scenarios could represent a valid misconfiguration? (Choose 2.)
  • A. All required CA Certificates have been installed on the CyberArk Identity Connector but the LDAP Bind credentials provided are incorrect.
  • B. TCP Port 636 could be blocked by a network firewall, preventing communication between the Secure Tunnel and the LDAP Server.
  • C. TCP Port 636 could be blocked by a network firewall, preventing communication between the CyberArk Identity Connector and the LDAP Server.
  • D. Verify Server Certificate' is activated but the provided hostname is not listed as a Subject Alternative Name (SAN) in the LDAP server's certificate.
From the error message provided, two likely scenarios could represent valid misconfigurations:
* TCP Port 636 could be blocked by a network firewall, preventing communication between the CyberArk Identity Connector and the LDAP Server (A). This is a common issue where firewall settings prevent the secure communication port (typically 636 for LDAPS) from transmitting data between the server and the connector, thus blocking the connection attempt.
* 'Verify Server Certificate' is activated but the provided hostname is not listed as a Subject Alternative Name (SAN) in the LDAP server's certificate (C). This scenario occurs when SSL/TLS security measures are stringent, requiring that the hostname used to connect to the LDAP server must match one listed in the server's SSL certificate. If the hostname does not match, the connection will fail due to SSL certificate validation errors.
NEW QUESTION # 46
If you have a strong desire to get the CyberArk certificate, our CPC-CDE-RECERT study materials are the best choice for you. At present, the certificate has gained wide popularity. So the official test syllabus of the CPC-CDE-RECERT exam begins to become complicated. So you must accept professional guidance. After all, lots of people are striving to compete with many candidates. Powerful competitiveness is crucial to pass the CPC-CDE-RECERT Exam. Maybe you think that our CPC-CDE-RECERT study materials cannot make a difference. But you must know that if you do not have a try, your life will never be improved. It is useless that you speak boast yourself but never act. Please muster up all your courage. No one will laugh at a hardworking person. Our CPC-CDE-RECERT study materials are your good study partner.
New Exam CPC-CDE-RECERT Materials: https://www.examsreviews.com/CPC-CDE-RECERT-pass4sure-exam-review.html
CyberArk Exam CPC-CDE-RECERT Demo Our relationship does not end with your financial deal, CyberArk Exam CPC-CDE-RECERT Demo We have strict information safety system for every user, Besides, you can choose the online test dumps which can simulate the CPC-CDE-RECERT actual test, Want to lear more about CyberArk New Exam CPC-CDE-RECERT Materials Installing and Configuring New Exam CPC-CDE-RECERT Materials certification experience, Our CyberArk CDE-CPC Recertification Exam expert regularly update dumps of CyberArk CPC-CDE-RECERT Exam so that you cannot miss any question in your real exam.
Rebooting your router simply consists of unplugging it from the wall, CPC-CDE-RECERT waiting a couple of seconds, and plugging it back in, By Kevin Hoffman, Our relationship does not end with your financial deal.
CPC-CDE-RECERT Quiz Braindumps - CPC-CDE-RECERT Pass-Sure torrent & CPC-CDE-RECERT Exam TorrentWe have strict information safety system for CPC-CDE-RECERT Pdf Dumps every user, Besides, you can choose the online test dumps which can simulate the CPC-CDE-RECERT actual test, Want to lear more about CyberArk Installing and Configuring CyberArk Certification certification experience?
What's more, part of that ExamsReviews CPC-CDE-RECERT dumps now are free: https://drive.google.com/open?id=1jT1kPFfw7FSIz9OLReObN5bDyUTK09oY
