After updating the kernel can't enter fs and terminal can not input
71
Posted at 10/13/2015 10:49:46      View5493 | Replies7        Print      Only Author   [Copy Link] 1#
hi,
I reference http://wiki.t-firefly.com/index.php/Firefly-RK3288/Flash_image/en and flash Firefly-RK3288_Ubuntu14.04_201501271612.img,when I update kernel reference http://wiki.t-firefly.com/index.php/Firefly-RK3288/Build_kernel/en  can't enter fs and can't input on terminal,fllow is detail:
[    9.355094] init: plymouth-upstart-bridge main process (312) terminated with status 1
[    9.365994] init: plymouth-upstart-bridge main process ended, respawning
[    9.382414] 2, baud is:115200
[    9.498739] init: mounted-proc main process (325) terminated with status 1
[    9.923637] systemd-udevd[452]: could not open moddep file '/lib/modules/3.10.0/modules.dep.bin'
* Starting Mount filesystems on boot[ OK ]
* Starting Signal sysvinit that the rootfs is mounted[ OK ]
* Starting Initialize or finalize resolvconf[ OK ]
* Starting Clean /tmp directory[ OK ]
* Stopping Track if upstart is running in a container[ OK ]
* Stopping Clean /tmp directory[ OK ]
* Starting Signal sysvinit that virtual filesystems are mounted[ OK ]
* Starting Bridge udev events into upstart[ OK ]
* Starting Signal sysvinit that remote filesystems are mounted[ OK ]
* Starting device node and kernel event manager[ OK ]
* Starting Signal sysvinit that local filesystems are mounted[ OK ]
* Starting restore software rfkill state[ OK ]
* Starting load modules from /etc/modules[ OK ]
* Starting cold plug devices[ OK ]
* Starting log initial device creation[ OK ]
* Stopping Mount filesystems on boot[ OK ]
* Stopping restore software rfkill state[ OK ]
* Stopping load modules from /etc/modules[ OK ]
* Starting flush early job output to logs[ OK ]
* Starting D-Bus system message bus[ OK ]
* Stopping flush early job output to logs[ OK ]
* Starting SystemD login management service[ OK ]
* Starting set console font[ OK ]
* Stopping set console font[ OK ]
* Starting userspace bootsplash[ OK ]
* Stopping userspace bootsplash[ OK ]
* Starting Send an event to indicate plymouth is up[ OK ]
* Stopping Send an event to indicate plymouth is up[ OK ]
* Starting configure network device security[ OK ]
* Starting system logging daemon[ OK ]
* Starting configure network device[ OK ]
* Starting bluetooth initialization[ OK ]
* Starting bluetooth initialization[fail]
* Starting bluetooth daemon[ OK ]
* Starting Mount network filesystems[ OK ]
* Starting Failsafe Boot Delay[ OK ]
* Starting Turn on/off the ap6335 bluetooth[ OK ]
* Stopping Failsafe Boot Delay[ OK ]
* Starting System V initialisation compatibility[ OK ]
* Stopping Mount network filesystems[ OK ]
[ OK ]ting up X socket directories...
* Stopping System V initialisation compatibility[ OK ]
* Starting System V runlevel compatibility[ OK ]
* Starting save kernel messages[ OK ]
* Starting OpenSSH server[ OK ]
* Starting anac(h)ronistic cron[ OK ]
* Starting regular background program processing daemon[ OK ]
* Stopping save kernel messages[ OK ]
* Stopping anac(h)ronistic cron[ OK ]
[   10.954992] turn on mali power
* Stopping Restore Sound Card State[ OK ]
* Starting configure virtual network devices[ OK ]
[   40.459762] systemd-udevd[457]: timeout 'accelerometer /devices/virtual/input/input3'
[   41.452521] systemd-udevd[457]: timeout: killing 'accelerometer /devices/virtual/input/input3' [485]
[   41.749646] systemd-udevd[457]: 'accelerometer /devices/virtual/input/input3' [485] terminated by signal 9 (Killed)
Posted at 1/15/2026 14:27:36        Only Author  2#
Your article is outstanding, thank you for sharing! Free access to the Test CPB engine version exam resourcesyour pathway to promotions and salary boosts!
Posted at 1/21/2026 07:58:52        Only Author  3#
Thank you for the article, it was a real eye-catching read. Weve made Professional-Cloud-Developer valid test certification cost available, packed with useful content, to help you, free of charge.
Posted at 1/26/2026 14:46:47        Only Author  4#
Thank you for sharing such a positive and motivating article! The SAFe-Agilist reliable test dumps materials exam is almost here. Please send me good vibes!
Posted at 1/31/2026 10:36:21        Only Author  5#
Im thoroughly impressed by your article, thank you for sharing! The FCP_FAC_AD-6.5 reliable exam dumps file exam is right around the corner. Wish me success!
Posted at 2/16/2026 03:13:09        Only Author  6#
I cant help but hit likethis content is that good. Im sharing the Regualer C-BCBDC-2505 update questions that helped me get promoted and earn moregrab them for free!
