Can't connect to Wifi connection(Wifi gone in network manager)
543
Posted at 2/17/2016 03:55:29      View5644 | Replies8        Print      Only Author   [Copy Link] 1#
Hi
I can't connect to Wifi connection(Wifi gone in network manager) in Lubuntu.
I can correctly connect with ethernet but it doesn't connect to wifi or pick up any wifi connection or device any more.
Wifi stopped being picked up just after I did some Lubuntu updates and restarted it.
I am using dual-boot Lubuntu firmware.
I did so many customizations, would be very sad too loose everything just to reinstall firmware for working wifi.
Are there terminal commands I can try or uninstall/reinstall network manager to get it to pick up wifi again.
Please help.
Posted at 2/22/2016 10:44:30        Only Author  2#
can you get any error log? show it please
Posted at 3/5/2016 09:36:25        Only Author  3#
Firstly, you should run
  sudo ifconfig -a
to list all the network inferaces.
Then do a WiFi reset:
   sudo /usr/local/bin/wifi-off.sh
   sleep 3
   sudo /usr/local/bin/wifi-on.sh
Check the network interfaces again:
  sudo ifconfig -a
View kernel log:
   sudo dmesg
Please post the result here.
Posted at 3/5/2016 11:01:58        Only Author  4#
busybee Posted at 3/5/2016 09:36
  sudo ifconfig -a
Thanks
I recopied the wifi firmware files AP6335.bin etc. from here - https://github.com/gouwa/hwpacks back and it worked.
Somehow after a 'sudo update' the wifi firmware files went missing.
Posted at 2/8/2026 09:35:25        Only Author  5#
This article is truly an outstanding work, and Ive benefited greatly from it. Free FCSS_LED_AR-7.6 reliable real test answer resources to help you. Wishing you the best of luck in your exam!
Posted at 2/11/2026 23:39:10        Only Author  6#
Im stunned by how wonderful your article is, thank you for sharing it! Im sharing the PEGACPDC25V1 Downloadable PDF questions that helped me achieve my promotion and salary increasefor free!
Posted at 2/20/2026 10:53:54        Only Author  7#
Reading this article, I have gained a completely new understanding of the issue. The extensive content in Latest visual C_ARSOR_2404 cert exam is offered free of charge to support you.
Posted at 3/5/2026 21:41:18        Only Author  8#
What a brilliant piece of writing, thank you for sharing it. Explore the rich content of CFE-Financial-Transactions-and-Fraud-Schemes test format, offered free to assist you.
Posted at 3/7/2026 13:41:22        Only Author  9#
You can try restarting or reinstalling the network manager to fix it. For more simple tips on stable WiFi, WiFiTech Professionals have helpful guides.
