Questions about the 8ch I2S/PCM RK3288 peripheral
638
Posted at 4/13/2015 21:32:06      View5807 | Replies4        Print      Only Author   [Copy Link] 1#
Hello,
I have some questions regarding the 8ch I2s/PCM peripheral inside the RK3288 SoC (chapter 16 of the manual).
Q1: looking at the timing diagrams starting on page 752 (sections 16.3.1 to 16.3.7), it seems that I2S allows 1 stereo channel only per output, while the DSP/PCM mode allows from 1 to 4 stereo channels on a single output (SDO0). Is it right?
Q2: the peripheral control registers list shows only 1 transmit fifo data register (I2S_TXDR on page 765). How is this unique TX data register connected to the 4 TX FIFOs?
Q3: for that matter what I understand is that the I2S_TXCR::CSR field (page 756) sets the number of stereo channels AND the number of used TX FIFOs. In PCM mode the n FIFOS can be seen as a single FIFO with a depth equal to 32 x n. Is it right?
Q4: in I2S mode, each FIFO is routed to the corresponding I2S_SDOx output. Is it right?
Q5: from the ES8323 codec data sheet it seems that this codec manages only a single stereo stream, wether configured as an I2S or a PCM device. So this would mean that it is not possible to send more than 2 channels when using the firefly board as is. Is it right?
Thanks.
Posted at 1/9/2026 23:12:22        Only Author  2#
Your article was incredibly refreshing, thank you. The Reliable free 300-540 study guide helped me secure a promotion and salary raise. Now its free to all. Best wishes for your career advancements!
Posted at 1/11/2026 05:37:38        Only Author  3#
Perfect content, Im clicking like immediately. Best of luck on your exam! Heres the free C1 exam question content.
Posted at 1/13/2026 01:17:03        Only Author  4#
Thank you for your article, it was a true eye-opener. The Demo PDI test questions were key in securing my promotion and raisenow its your turn! Get them for free!
Posted at 1/19/2026 23:03:26        Only Author  5#
PDFExamDumpsHṩYϣ߀ṩ|ķաُIPDFExamDumpsĿ}PDFExamDumpsṩһM¡@ͿһֱµAZ-500ԇ}YϡңfһAZ-500}ᣬԇ߀ʧԒPDFExamDumpsCȫ~˿@һ߀ʲNأPDFExamDumpsԼYģҲҪPDFExamDumpsġĿԇ܉ɹǧfҪe^PDFExamDumps@Wվe^͵eʧһγɹęC
