New Topic
Announcement for releasing SDK of PAD version
1661
administrator
Rank: 9Rank: 9Rank: 9
Posted at 12/23/2014 17:49:45      View9251 | Replies13        Print      Only Author   [Copy Link] 1#
In order to provide a better support on Firefly, out team releases the SDK of PAD version.
This version supports the Display, Touch-Screen and so on.
You can download this SDK on Baidu Cloud  and Google Drive.
Baidu Cloud
Google Drive
Please check the md5 checksum before proceeding:
$ md5sum /path/to/firefly-rk3288_pad_android4.4_git_20141218.tar.gz
4ba44765fa649bc5cddadd8b349aa8af firefly-rk3288_pad_android4.4_git_20141218.tar.gz
If it is correct, uncompress it:
mkdir -p ~/proj/firefly-rk3288_pad
cd ~/proj/firefly-rk3288_pad
tar xf /path/to/firefly-rk3288_pad_android4.4_git_20141218.tar.gz
git reset --hard
git remote add bitbucket https://bitbucket.org/T-Firefly/firefly-rk3288.git
From now on, you can pull from bitbucket:
git pull bitbucket pad:pad
You can also browse the source codes online at https://bitbucket.org/T-Firefly/firefly ... branch/pad
Posted at 12/24/2014 07:12:48        Only Author  2#
  • Why do we use the old SDK (1211) to install the (1218)PAD SDK. Looked through the build and is this upgradable with just the master bitbucket pull to the (1211) or is this a seperate build.  Noticed that PAD was a 4.4.4.r2 revision.
    EDIT:
    Load went just as explained, Just one question for files seem to be protected.  Is this repo by a private group, for would like to change some files and see what can and can't be done.  If so are they waiting until they have completed their goals before they will allow us the personalize builds.  Just curious.
Posted at 12/26/2014 16:26:39        Only Author  3#
Hi cappybob, thanks for pointing out the mistake.
I don't really grasp the meaning of your later added message.
The repo in bitbucket is currently maintained by us. Anyone is
free to fork it and add up his modfication. And we welcome
patches, enhancement suggestions, etc.
Posted at 12/28/2014 04:11:52        Only Author  4#
@busybee
Redid with newer instructions and works as should.  Previous instructions (Wrong) worked, but seem to have a check sum entry for every code entry.  Really strange.  Ready to load first build, if anything really stands out, I'll give everyone a Yell.      THANKS        had to change the name (Rename) download to match instructions, not big problem but I am copy and paste as much as I can to prevent errors as much as possible.
Edit:
Android 4.4.4 is the operating system.  A good start for someone who wants to personalize their own build.  THANKS to the people of PAD.
--cappybob
Posted at 1/3/2015 09:04:08        Only Author  5#
Hi!
Could you add a parameter file that is working for the Android image to your wiki or to the SDK git?
I downloaded the pad version of the SDK and build everything according the wiki, but then I discovered that I had a linux system installed on the firefly. But the linux parameter file is not matching the Android version.
I used this one, extracted from the prebuild Android 4.4 from the firefly download section:
FIRMWARE_VER:4.4.2
MACHINE_MODEL:rk30sdk
MACHINE_ID:007
MANUFACTURER:RK30SDK
MAGIC: 0x5041524B
ATAG: 0x60000800
MACHINE: 3066
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
#KERNEL_IMG: 0x62008000
#FDT_NAME: rk-kernel.dtb
#RECOVER_KEY: 1,1,0,20,0
CMDLINE:console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user)
I flashed the resulting images using linux upgrade_tool. If someone is wondering how to flash resource.img, you need to know that the upgrade_tool supports the undocumented option to name any kind of image:
upgrade_tool di -p parameter
upgrade_tool di -k kernel.img
upgrade_tool di -b boot.img
upgrade_tool di resource resource.img
Thanks to naobsd for the hint!
And last but not least:
After flashing these images and rebooting via "upgrade_tool rd" the firfly didn't start correctly. But the upgrade_tool didn't want to connect again even I pressed reset and recovery button several times.
A power-cycle then brought things back to normal, recovery started and formatted all needed partitions and after that rebooted to Android as expected.
Kind regards
Astralix
Posted at 1/3/2015 11:54:27        Only Author  6#
I like the windows version tool 2.1 from RKCrewTablets for their R-box build for it has a 4G parameter and all I have to  do is replace the new Kernel and resource, then load with the parameter from their R-Box release.  Have had no problems between Kernel and or New Android builds since they are all R-Box.  Their is a lot of difference between the Android SDK and PAD SDK, different set of individuals coding the Pad group are I think Poets at time when you compare the both.
Posted at 1/3/2015 19:53:41        Only Author  7#
@cappybob,
I am not sure what you want to tell me...
@firefly team
The above comments where meant to be added to the how-to wiki http://wiki.t-firefly.com/index. ... 8/Build_android/en.
And there is another one:
If you develop different Android versions for different devices, you often need to change the underlying JAVA version. But you won't like to switch the basic JAVA for your linux system. And for several Android build it is even unnecessary to switch it, as for instance Android L works fine with openJDK-7.
So here is the solution: Just switch the JAVA version locally for the terminal you use to build Android:
export ANDROID_JAVA_TOOLCHAIN="/usr/lib/jvm/jdk1.6.0_45/bin"
export JAVA_HOME="/usr/lib/jvm/jdk1.6.0_45/bin"
and then add the same directory as first to the PATH:
export PATH="/usr/lib/jvm/jdk1.6.0_45/binPATH"
After that your build runs fine using the correct JAVA version.
Astralix
Posted at 1/4/2015 00:57:03        Only Author  8#
@astralix
Basically that I have not had any problem using a uboot file or parameters from any build made for the Firfefly, for any build of Android or Kernel it seems to make little difference of when or build as long as for the Firefly.  The PAD SDK seems to be , I guess Not as Dirty as the original SDK.
---cappybob
Posted at 1/4/2015 07:21:49        Only Author  9#
cappybob, there are no problems but a missing parameter file.
I had installed Linux on my firefly and the Linux compliant parameter file does not match the needs of Android image.
So I was able to download and unpack an Android image for firefly and then copy the parameter file to the master:master and the pad:pad version. Both worked fine.
I just wanted someone to add a parameter file to the code and a comment in the wiki, so other users do not have to search a matching parameter file.
And the pad version differs a bit from the master branch, cause they have different screen layout and pad version is scanning for a I2C touch screen chip, the master branch is not. However if you use your computer monitor as a screen, you wish a much higher screen resolution setting in build.prop as the icons are large and blurry. If you use the system on a mid size TV, it works just fine.
Astralix
vip
Rank: 6Rank: 6
Posted at 1/5/2015 09:46:05        Only Author  10#
parameter can find  in the pad sdk: FFTools/AndroidTool_Release_v2.33.rar
Return to List
12
