Power button skip
13
Power button skip
Posted at 5/18/2017 15:40:44      View:4941 | Replies:8        Print      Only Author   [Copy Link] 1#
Hi,
I have Vsmart Q8 tvbox (3288) hardware with Android 5.1 built on basis of sources from respective firefly device , so it definitely should have similar hardware as firefly-3288. My problem is that I would like to use  TV box as car-pc and boot it directly after power on, without any use of power button or remote control. Is it possible? I've checked similar threads for Samsung tablets and phones and they use battery animation script to pass reboot command for this purpose. But in my case TV Box does not show any animations in sleep mode, so there should be something different to change.
Thank you,
Jevgenijs
super moderator
Rank: 8Rank: 8
Posted at 5/19/2017 10:00:14        Only Author  2#
It is need some  hardware modification.
Posted at 5/21/2017 06:46:43        Only Author  3#
You need hardware modification. Replace power button with  this piece.
It will detect when you have energy ON and shotcut the power button. Cheers
Posted at 5/28/2017 23:45:31        Only Author  4#
Hmm, won't relay switch board off if it will keep close and not release "button" for some time?
Posted at 1/9/2026 16:28:03        Only Author  5#
Truly an impressive article, I’m grateful for your sharing. Elevate your IT abilities with free Valid HPE0-S59 real test. Best wishes for success!
Posted at 1/12/2026 07:19:04        Only Author  6#
I was really impressed by the depth and breadth of the article. C-THR87-2505 reliable exam topics pdf offers detailed content free of charge to help you in your learning journey.
Posted at 1/20/2026 20:38:58        Only Author  7#
This article is simply awe-inspiring, thank you for sharing it! Free Google-Workspace-Administrator valid exam online resources to help you. Wishing you the best of luck in your exam!
Posted at 1/23/2026 22:25:13        Only Author  8#
This is a stellar article, thank you for sharing it with us. The New study questions Comm-Dev-101 sheet was the key to my promotion and raise. Now it’s free to everyone. Wishing you all a successful career boost!
Posted at 2/8/2026 13:46:40        Only Author  9#
I can’t thank you enough for your article, it’s definitely made an impression. Here’s the Latest H19-413_V1.0 version test I passed to earn my promotion and salary increase. It’s free for you today—best of luck in your career goals!
