New Topic
Need help with display setup
55
Posted at 9/16/2016 20:54:54      View13600 | Replies19        Print      Only Author   [Copy Link] 1#
Hello,
I have two displays, both have same resolution, it is 800 x 480.
One:
https://www.adafruit.com/product/2407
This can connect only via HDMI.
Second:
https://www.aliexpress.com/item/ ... MI/32297375551.html
This could be connected via HDMI or VGA using driver board.
I was flashing different firmware (MMC; Ubuntu only) for my Firefly-RK3288. I was trying to set up native (800 x 480) resolution, but no success.
1. Ubuntu-14.04_201512031755 (unmodified or with mainline kernel, no difference)
With this version I could see the desktop, but could not set resolution.
1.1 "xrandr" just could not set it. I was making all the steps described in here:
https://wiki.ubuntu.com/X/Config ... etected_resolutions
was constantly getting error "Failed to get size of gamma". I have ignored that message and when I was trying to set resolution to 800 x 480 screen was blinking and returned to 1680x1050.
1.2 was trying to modify xorg.conf, also without success. Maybe I just do not know the right parameters to put in. New resolutions just does not appears in widget.
2. Ubuntu_16.04_201608291523_beta
several days ago I flashed this image and another problem arised. Both displays shows nothing. Nor HDMI, nor VGA are working.
I am more interested in this (or newer) build because of improvements, so I will be happy if you can help me with setting the displays up under this firmware.
I can see the desktop if I connect Firefly to 19" display (that support FullHD), both VGA and HDMI are working, two FullHD monitors are supported. Ok, now I leave VGA cable connected to 19" display, and connect HDMI cable to my small 800x480 display. Result: small display shows nothing, big one is still working fine. If "Monitor" widget in Ubuntu was opened, it will crush and will not start again.
Any solution of this? Can anyone advise me on how to get image on my small displays with correct resolution?
super moderator
Rank: 8Rank: 8
Posted at 9/18/2016 10:46:30        Only Author  2#
Posted at 9/18/2016 18:37:50        Only Author  3#
Thank you, isle!
This build working fine with VGA output. DIsplay with VGA input was detected and correct resolution (800 x 480) was set automatically. What are the steps to make it work? Would be nice to know.
HDMI is not working
glmark2 score is 213.
super moderator
Rank: 8Rank: 8
Posted at 9/19/2016 10:17:50        Only Author  4#
Hi
   Only  connet the HDMI  .and try this cmd to see what did you get  :
cat /var/log/Xorg.0.log
Posted at 9/20/2016 01:52:25        Only Author  5#
Ok, I have followed the behavior using SSH.
When I do connect HDMI display "on the go" (after OS is loaded) I got this log:
<script src="//pastebin.com/embed_js/4xvuZhSP"></script>
If I boot up OS while HDMI is already connected, I am getting this one:
<script src="//pastebin.com/embed_js/D88iHatD"></script>
In both cases, display shows nothing.
super moderator
Rank: 8Rank: 8
Posted at 9/20/2016 09:44:15        Only Author  6#
Hi
the log is missing.
Posted at 9/20/2016 17:22:27        Only Author  7#
Hello, I was checking the links above and it was active...
Ok.  I will try to insert logs here.
  1. [     7.879]
  2. X.Org X Server 1.15.1
  3. Release Date: 2014-04-13
  4. [     7.879] X Protocol Version 11, Revision 0
  5. [     7.879] Build Operating System: Linux 3.2.0-67-highbank armv7l Ubuntu
  6. [     7.879] Current Operating System: Linux firefly 3.14.0 #129 SMP Mon Jun 6 15:15:00 CST 2016 armv7l
  7. [     7.879] Kernel command line: earlyprintk=ttyS2,115200 console=tty0 console=ttyS2,115200 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot linuxroot rw rootfstype=ext4 init=/sbin/init  mtdparts=rk29xxnand:0x00010000@0x00002000(boot),0x00002000@0x00012000(backup),-@0x00014000(linuxroot) storagemedia=emmc loader.timestamp=2015-01-21_16:36:44 androidboot.mode=emmc
  8. [     7.879] Build Date: 12 February 2015  02:55:07PM
  9. [     7.879] xorg-server 2:1.15.1-0ubuntu2.7 (For technical support please see http://www.ubuntu.com/support)
  10. [     7.879] Current version of pixman: 0.30.2
  11. [     7.879]    Before reporting problems, check http://wiki.x.org
  12.     to make sure that you have the latest version.
  13. [     7.879] Markers: (--) probed, (**) from config file, (==) default setting,
  14.     (++) from command line, (!!) notice, (II) informational,
  15.     (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
  16. [     7.879] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan  1 08:00:07 1970
  17. [     7.879] (==) Using config file: "/etc/X11/xorg.conf"
  18. [     7.880] (==) Using config directory: "/etc/X11/xorg.conf.d"
  19. [     7.880] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
  20. [     7.880] (==) ServerLayout "DefaultLayout"
  21. [     7.880] (**) |-->Screen "DefaultScreen" (0)
  22. [     7.880] (**) |   |-->Monitor "<default monitor>"
  23. [     7.881] (**) |   |-->Device "Mali FBDEV"
  24. [     7.881] (==) No monitor specified for screen "DefaultScreen".
  25.     Using a default monitor configuration.
  26. [     7.881] (**) Option "NoTrapSignals" "true"
  27. [     7.881] (**) Option "DontZap" "false"
  28. [     7.881] (**) Option "BlankTime" "0"
  29. [     7.881] (**) Option "StandbyTime" "0"
  30. [     7.881] (**) Option "SuspendTime" "0"
  31. [     7.881] (**) Option "OffTime" "0"
  32. [     7.881] (**) Option "IgnoreABI" "1"
  33. [     7.881] (**) Ignoring ABI Version
  34. [     7.881] (==) Automatically adding devices
  35. [     7.881] (==) Automatically enabling devices
  36. [     7.881] (==) Automatically adding GPU devices
  37. [     7.881] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
  38. [     7.881]    Entry deleted from font path.
  39. [     7.881] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
  40. [     7.881]    Entry deleted from font path.
  41. [     7.881] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
  42. [     7.881]    Entry deleted from font path.
  43. [     7.881] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
  44. [     7.881]    Entry deleted from font path.
  45. [     7.881] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
  46. [     7.881]    Entry deleted from font path.
  47. [     7.881] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
  48. [     7.881]    Entry deleted from font path.
  49. [     7.881] (==) FontPath set to:
  50.     /usr/share/fonts/X11/misc,
  51.     built-ins
  52. [     7.881] (==) ModulePath set to "/usr/lib/arm-linux-gnueabihf/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
  53. [     7.881] (II) The server relies on udev to provide the list of input devices.
  54.     If no devices become available, reconfigure udev or disable AutoAddDevices.
  55. [     7.881] (II) Loader magic: 0xb6f93f10
  56. [     7.881] (II) Module ABI versions:
  57. [     7.881]    X.Org ANSI C Emulation: 0.4
  58. [     7.881]    X.Org Video Driver: 15.0
  59. [     7.881]    X.Org XInput driver : 20.0
  60. [     7.881]    X.Org Server Extension : 8.0
  61. [     7.882] (II) xfree86: Adding drm device (/dev/dri/card0)
  62. [     7.882] Initializing built-in extension Generic Event Extension
  63. [     7.882] Initializing built-in extension SHAPE
  64. [     7.882] Initializing built-in extension MIT-SHM
  65. [     7.882] Initializing built-in extension XInputExtension
  66. [     7.882] Initializing built-in extension XTEST
  67. [     7.882] Initializing built-in extension BIG-REQUESTS
  68. [     7.882] Initializing built-in extension SYNC
  69. [     7.882] Initializing built-in extension XKEYBOARD
  70. [     7.882] Initializing built-in extension XC-MISC
  71. [     7.882] Initializing built-in extension SECURITY
  72. [     7.882] Initializing built-in extension XINERAMA
  73. [     7.882] Initializing built-in extension XFIXES
  74. [     7.882] Initializing built-in extension RENDER
  75. [     7.882] Initializing built-in extension RANDR
  76. [     7.882] Initializing built-in extension COMPOSITE
  77. [     7.882] Initializing built-in extension DAMAGE
  78. [     7.882] Initializing built-in extension MIT-SCREEN-SAVER
  79. [     7.882] Initializing built-in extension DOUBLE-BUFFER
  80. [     7.882] Initializing built-in extension RECORD
  81. [     7.882] Initializing built-in extension DPMS
  82. [     7.883] Initializing built-in extension Present
  83. [     7.883] Initializing built-in extension DRI3
  84. [     7.883] Initializing built-in extension X-Resource
  85. [     7.883] Initializing built-in extension XVideo
  86. [     7.883] Initializing built-in extension XVideo-MotionCompensation
  87. [     7.883] Initializing built-in extension SELinux
  88. [     7.883] Initializing built-in extension XFree86-VidModeExtension
  89. [     7.883] Initializing built-in extension XFree86-DGA
  90. [     7.883] Initializing built-in extension XFree86-DRI
  91. [     7.883] Initializing built-in extension DRI2
  92. [     7.883] (II) LoadModule: "glx"
  93. [     7.886] (WW) Warning, couldn\'t open module glx
  94. [     7.886] (II) UnloadModule: "glx"
  95. [     7.886] (II) Unloading glx
  96. [     7.886] (EE) Failed to load module "glx" (module does not exist, 0)
  97. [     7.886] (II) LoadModule: "armsoc"
  98. [     7.887] (II) Loading /usr/lib/xorg/modules/drivers/armsoc_drv.so
  99. [     7.888] (II) Module armsoc: vendor="X.Org Foundation"
  100. [     7.888]    compiled for 1.15.1, module version = 0.0.1
  101. [     7.888]    Module class: X.Org Video Driver
  102. [     7.888]    ABI class: X.Org Video Driver, version 15.0
  103. [     7.888] (II) ARMSOC: Driver for TI OMAP: exynos5
  104. [     7.888] (++) using VT number 7
  105. [     7.893] (WW) Falling back to old probe method for armsoc
  106. [     7.893] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
  107. [     7.893] (II) ARMSOC(0): Creating default Display subsection in Screen section
  108.     "DefaultScreen" for depth/fbbpp 24/32
  109. [     7.893] (**) ARMSOC(0): Depth 24, (--) framebuffer bpp 32
  110. [     7.893] (==) ARMSOC(0): RGB weight 888
  111. [     7.893] (==) ARMSOC(0): Using gamma correction (1.0, 1.0, 1.0)
  112. [     7.893] (==) ARMSOC(0): Default visual is TrueColor
  113. [     7.894] (II) ARMSOC(0): Chipset: exynos5
  114. [     7.894] (II) ARMSOC(0): Setting the video modes ...
  115. [     7.894] (II) ARMSOC(0): [CRTC:21] HW Cursor using [BO:1]
  116. [     7.894] (II) ARMSOC(0): [CRTC:26] HW Cursor using [BO:2]
  117. [     7.894] (II) ARMSOC(0): Output HDMI-1 has no monitor section
  118. [     7.895] (II) ARMSOC(0): Output VGA-1 has no monitor section
  119. [     7.895] (II) ARMSOC(0): EDID for output HDMI-1
  120. [     7.896] (II) ARMSOC(0): EDID for output VGA-1
  121. [     7.896] (II) ARMSOC(0): Output HDMI-1 disconnected
  122. [     7.896] (II) ARMSOC(0): Output VGA-1 disconnected
  123. [     7.896] (WW) ARMSOC(0): No outputs definitely connected, trying again...
  124. [     7.896] (II) ARMSOC(0): Output HDMI-1 disconnected
  125. [     7.896] (II) ARMSOC(0): Output VGA-1 disconnected
  126. [     7.896] (WW) ARMSOC(0): Unable to find connected outputs - setting 1024x768 initial framebuffer
  127. [     7.896] (II) ARMSOC(0): Got KMS resources
  128. [     7.896] (==) ARMSOC(0): DPI set to (96, 96)
  129. [     7.896] (II) Loading sub module "dri2"
  130. [     7.896] (II) LoadModule: "dri2"
  131. [     7.896] (II) Module "dri2" already built-in
  132. [     7.896] (II) Loading sub module "exa"
  133. [     7.896] (II) LoadModule: "exa"
  134. [     7.896] (II) Loading /usr/lib/xorg/modules/libexa.so
  135. [     7.897] (II) Module exa: vendor="X.Org Foundation"
  136. [     7.897]    compiled for 1.15.1, module version = 2.6.0
  137. [     7.897]    ABI class: X.Org Video Driver, version 15.0
  138. [     7.897] (II) Loading sub module "fb"
  139. [     7.897] (II) LoadModule: "fb"
  140. [     7.897] (II) Loading /usr/lib/xorg/modules/libfb.so
  141. [     7.897] (II) Module fb: vendor="X.Org Foundation"
  142. [     7.897]    compiled for 1.15.1, module version = 1.0.0
  143. [     7.897]    ABI class: X.Org ANSI C Emulation, version 0.4
  144. [     7.897] (--) Depth 24 pixmap format is 32 bpp
  145. [     7.922] (II) ARMSOC(0): Initialized a depth-32 visual for XRGB8888
  146. [     7.922] (II) ARMSOC(0): Soft EXA mode
  147. [     7.923] (II) EXA(0): Driver allocated offscreen pixmaps
  148. [     7.923] (II) EXA(0): Driver registered support for the following operations:
  149. [     7.923] (II)         Solid
  150. [     7.923] (II)         Copy
  151. [     7.923] (II)         Composite (RENDER acceleration)
  152. [     7.923] (II) ARMSOC(0): [DRI2] Setup complete
  153. [     7.923] (II) ARMSOC(0): [DRI2]   DRI driver: armsoc
  154. [     7.923] (==) ARMSOC(0): Backing store enabled
  155. [     7.923] (==) ARMSOC(0): Silken mouse enabled
  156. [     7.923] (II) ARMSOC(0): RandR 1.2 enabled, ignore the following RandR disabled message.
  157. [     7.923] (==) ARMSOC(0): DPMS enabled
  158. [     7.923] (--) RandR disabled
  159. [     7.937] (II) SELinux: Disabled on system
  160. [     7.987] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
  161. [     7.992] (II) config/udev: Adding drm device (/dev/dri/card0) card0 /sys/devices/display-subsystem.4/drm/card0
  162. [     7.992] (II) config/udev: Ignoring already known drm device (/dev/dri/card0)
  163. [     7.993] (II) config/udev: Adding input device gpio_ir_recv (/dev/input/event0)
  164. [     7.993] (**) gpio_ir_recv: Applying InputClass "evdev keyboard catchall"
  165. [     7.993] (II) LoadModule: "evdev"
  166. [     7.993] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
  167. [     7.996] (II) Module evdev: vendor="X.Org Foundation"
  168. [     7.996]    compiled for 1.15.0, module version = 2.8.2
  169. [     7.996]    Module class: X.Org XInput Driver
  170. [     7.996]    ABI class: X.Org XInput driver, version 20.0
  171. [     7.996] (II) Using input driver \'evdev\' for \'gpio_ir_recv\'
  172. [     7.996] (**) gpio_ir_recv: always reports core events
  173. [     7.996] (**) evdev: gpio_ir_recv: Device: "/dev/input/event0"
  174. [     7.996] (--) evdev: gpio_ir_recv: Vendor 0x1 Product 0x1
  175. [     7.996] (--) evdev: gpio_ir_recv: Found keys
  176. [     7.996] (II) evdev: gpio_ir_recv: Configuring as keyboard
  177. [     7.996] (**) Option "config_info" "udev:/sys/devices/gpio-ir-receiver.13/rc/rc0/input0/event0"
  178. [     7.996] (II) XINPUT: Adding extended input device "gpio_ir_recv" (type: KEYBOARD, id 6)
  179. [     7.996] (**) Option "xkb_rules" "evdev"
  180. [     7.996] (**) Option "xkb_model" "pc105"
  181. [     7.996] (**) Option "xkb_layout" "us"
  182. [     7.997] (II) config/udev: Adding input device gpio-keys.12 (/dev/input/event3)
  183. [     7.997] (**) gpio-keys.12: Applying InputClass "evdev keyboard catchall"
  184. [     7.997] (II) Using input driver \'evdev\' for \'gpio-keys.12\'
  185. [     7.997] (**) gpio-keys.12: always reports core events
  186. [     7.997] (**) evdev: gpio-keys.12: Device: "/dev/input/event3"
  187. [     7.997] (--) evdev: gpio-keys.12: Vendor 0x1 Product 0x1
  188. [     7.997] (--) evdev: gpio-keys.12: Found keys
  189. [     7.997] (II) evdev: gpio-keys.12: Configuring as keyboard
  190. [     7.997] (**) Option "config_info" "udev:/sys/devices/gpio-keys.12/input/input3/event3"
  191. [     7.997] (II) XINPUT: Adding extended input device "gpio-keys.12" (type: KEYBOARD, id 7)
  192. [     7.997] (**) Option "xkb_rules" "evdev"
  193. [     7.997] (**) Option "xkb_model" "pc105"
  194. [     7.997] (**) Option "xkb_layout" "us"
  195. [     7.998] (II) config/udev: Adding input device RockchipHDMI HDMI Jack (/dev/input/event2)
  196. [     7.998] (II) No input driver specified, ignoring this device.
  197. [     7.998] (II) This device may have been added with another device file.
  198. [     7.999] (II) config/udev: Adding input device MCE IR Keyboard/Mouse (gpio-rc-recv) (/dev/input/event1)
  199. [     7.999] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): Applying InputClass "evdev pointer catchall"
  200. [     7.999] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): Applying InputClass "evdev keyboard catchall"
  201. [     7.999] (II) Using input driver \'evdev\' for \'MCE IR Keyboard/Mouse (gpio-rc-recv)\'
  202. [     7.999] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): always reports core events
  203. [     7.999] (**) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Device: "/dev/input/event1"
  204. [     7.999] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Vendor 0 Product 0
  205. [     7.999] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found 3 mouse buttons
  206. [     7.999] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found relative axes
  207. [     7.999] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found x and y relative axes
  208. [     7.999] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found keys
  209. [     7.999] (II) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Configuring as mouse
  210. [     7.999] (II) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Configuring as keyboard
  211. [     7.999] (**) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): YAxisMapping: buttons 4 and 5
  212. [     7.999] (**) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
  213. [     7.999] (**) Option "config_info" "udev:/sys/devices/virtual/input/input1/event1"
  214. [     7.999] (II) XINPUT: Adding extended input device "MCE IR Keyboard/Mouse (gpio-rc-recv)" (type: KEYBOARD, id 8)
  215. [     7.999] (**) Option "xkb_rules" "evdev"
  216. [     7.999] (**) Option "xkb_model" "pc105"
  217. [     7.999] (**) Option "xkb_layout" "us"
  218. [     8.000] (II) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): initialized for relative axes.
  219. [     8.000] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) keeping acceleration scheme 1
  220. [     8.000] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) acceleration profile 0
  221. [     8.000] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) acceleration factor: 2.000
  222. [     8.000] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) acceleration threshold: 4
  223. [   171.238] (II) ARMSOC(0): hotplug=1, match=1
  224. [   171.520] (II) ARMSOC(0): EDID vendor "RKC", prod id 17480
  225. [   171.520] (II) ARMSOC(0): DDCModeFromDetailedTiming: Ignoring: We don\'t handle stereo.
  226. [   171.521] (II) ARMSOC(0): Printing DDC gathered Modelines:
  227. [   171.521] (II) ARMSOC(0): Modeline "472x295"x82.0   14.85  472 480 528 584  295 296 299 310 -hsync +vsync (25.4 kHz e)
  228. [   171.521] (II) ARMSOC(0): Modeline "504x378"x84.0   21.07  504 520 568 632  378 379 382 397 -hsync +vsync (33.3 kHz e)
  229. [   171.521] (II) ARMSOC(0): Modeline "600x375"x97.0   29.88  600 624 688 776  375 376 379 397 -hsync +vsync (38.5 kHz e)
  230. [   171.521] (II) ARMSOC(0): Modeline "248x139"x64.0    2.30  248 232 248 248  139 140 143 145 -hsync +vsync (9.3 kHz e)
  231. [   171.521] (II) ARMSOC(0): Modeline "1384x865"x93.0  159.63  1384 1480 1632 1880  865 866 869 913 -hsync +vsync (84.9 kHz e)
  232. [   171.521] (II) ARMSOC(0): Modeline "248x2040"x1275.0  3135.89  248 272 304 360  2040 2041 2044 6832 -hsync +vsync (8710.8 kHz e)
  233. [   171.521] (II) ARMSOC(0): Modeline "11744x376"x235.0  1637.85  11744 12632 13920 16096  376 377 380 433 -hsync +vsync (101.8 kHz e)
  234. [   171.521] (II) ARMSOC(0): Modeline "4112x744"x465.0  2710.87  4112 4504 4968 5824  744 745 748 1001 -hsync +vsync (465.5 kHz e)
  235. [   171.521] (II) ARMSOC(0): Modeline "2040x1275"x105.0  401.49  2040 2208 2432 2824  1275 1276 1279 1354 -hsync +vsync (142.2 kHz e)
  236. [   171.521] (II) ARMSOC(0): Modeline "376x235"x76.0    8.23  376 376 408 440  235 236 239 246 -hsync +vsync (18.7 kHz e)
  237. [   171.521] (II) ARMSOC(0): Modeline "744x465"x62.0   27.97  744 768 840 936  465 466 469 482 -hsync +vsync (29.9 kHz e)
  238. [   171.521] (II) ARMSOC(0): Modeline "248x155"x79.0    3.40  248 232 256 264  155 156 159 163 -hsync +vsync (12.9 kHz e)
  239. [   171.521] (II) ARMSOC(0): Modeline "0x5"x522.0    0.00  0 0 0 0  5 6 9 8 -hsync +vsync (4.2 kHz e)
  240. [   171.521] (II) ARMSOC(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
  241. [   171.521] (II) ARMSOC(0): Modeline "640x480"x0.0   25.18  640 648 744 800  480 482 484 525 -hsync -vsync (31.5 kHz e)
  242. [   171.521] (II) ARMSOC(0): Modeline "1440x480i"x0.0   27.00  1440 1478 1602 1716  480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
  243. [   171.521] (II) ARMSOC(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
  244. [   171.521] (II) ARMSOC(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
  245. [   171.521] (II) ARMSOC(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
  246. [   171.521] (WW) ARMSOC(0): Output HDMI-1: Strange aspect ratio (522/32), consider adding a quirk
  247. [   171.521] (II) ARMSOC(0): EDID vendor "RKC", prod id 17480
  248. [   171.521] (II) ARMSOC(0): DDCModeFromDetailedTiming: Ignoring: We don\'t handle stereo.
  249. [   171.521] (II) ARMSOC(0): Printing DDC gathered Modelines:
  250. [   171.521] (II) ARMSOC(0): Modeline "472x295"x82.0   14.85  472 480 528 584  295 296 299 310 -hsync +vsync (25.4 kHz e)
  251. [   171.521] (II) ARMSOC(0): Modeline "504x378"x84.0   21.07  504 520 568 632  378 379 382 397 -hsync +vsync (33.3 kHz e)
  252. [   171.521] (II) ARMSOC(0): Modeline "600x375"x97.0   29.88  600 624 688 776  375 376 379 397 -hsync +vsync (38.5 kHz e)
  253. [   171.521] (II) ARMSOC(0): Modeline "248x139"x64.0    2.30  248 232 248 248  139 140 143 145 -hsync +vsync (9.3 kHz e)
  254. [   171.521] (II) ARMSOC(0): Modeline "1384x865"x93.0  159.63  1384 1480 1632 1880  865 866 869 913 -hsync +vsync (84.9 kHz e)
  255. [   171.521] (II) ARMSOC(0): Modeline "248x2040"x1275.0  3135.89  248 272 304 360  2040 2041 2044 6832 -hsync +vsync (8710.8 kHz e)
  256. [   171.521] (II) ARMSOC(0): Modeline "11744x376"x235.0  1637.85  11744 12632 13920 16096  376 377 380 433 -hsync +vsync (101.8 kHz e)
  257. [   171.521] (II) ARMSOC(0): Modeline "4112x744"x465.0  2710.87  4112 4504 4968 5824  744 745 748 1001 -hsync +vsync (465.5 kHz e)
  258. [   171.521] (II) ARMSOC(0): Modeline "2040x1275"x105.0  401.49  2040 2208 2432 2824  1275 1276 1279 1354 -hsync +vsync (142.2 kHz e)
  259. [   171.521] (II) ARMSOC(0): Modeline "376x235"x76.0    8.23  376 376 408 440  235 236 239 246 -hsync +vsync (18.7 kHz e)
  260. [   171.522] (II) ARMSOC(0): Modeline "744x465"x62.0   27.97  744 768 840 936  465 466 469 482 -hsync +vsync (29.9 kHz e)
  261. [   171.522] (II) ARMSOC(0): Modeline "248x155"x79.0    3.40  248 232 256 264  155 156 159 163 -hsync +vsync (12.9 kHz e)
  262. [   171.522] (II) ARMSOC(0): Modeline "0x5"x522.0    0.00  0 0 0 0  5 6 9 8 -hsync +vsync (4.2 kHz e)
  263. [   171.522] (II) ARMSOC(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
  264. [   171.522] (II) ARMSOC(0): Modeline "640x480"x0.0   25.18  640 648 744 800  480 482 484 525 -hsync -vsync (31.5 kHz e)
  265. [   171.522] (II) ARMSOC(0): Modeline "1440x480i"x0.0   27.00  1440 1478 1602 1716  480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
  266. [   171.522] (II) ARMSOC(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
  267. [   171.522] (II) ARMSOC(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
  268. [   171.522] (II) ARMSOC(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
Copy the code
  1. [     9.421]
  4. [     9.421] X Protocol Version 11, Revision 0
  5. [     9.421] Build Operating System: Linux 3.2.0-67-highbank armv7l Ubuntu
  6. [     9.421] Current Operating System: Linux firefly 3.14.0 #129 SMP Mon Jun 6 15:15:00 CST 2016 armv7l
  7. [     9.421] Kernel command line: earlyprintk=ttyS2,115200 console=tty0 console=ttyS2,115200 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot linuxroot rw rootfstype=ext4 init=/sbin/init  mtdparts=rk29xxnand:0x00010000@0x00002000(boot),0x00002000@0x00012000(backup),-@0x00014000(linuxroot) storagemedia=emmc loader.timestamp=2015-01-21_16:36:44 androidboot.mode=emmc
  8. [     9.421] Build Date: 12 February 2015  02:55:07PM
  9. [     9.421] xorg-server 2:1.15.1-0ubuntu2.7 (For technical support please see http://www.ubuntu.com/support)
  10. [     9.421] Current version of pixman: 0.30.2
  11. [     9.421]    Before reporting problems, check http://wiki.x.org
  13. [     9.421] Markers: (--) probed, (**) from config file, (==) default setting,
  16. [     9.421] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan  1 08:00:09 1970
  17. [     9.422] (==) Using config file: "/etc/X11/xorg.conf"
  18. [     9.422] (==) Using config directory: "/etc/X11/xorg.conf.d"
  19. [     9.422] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
  20. [     9.422] (==) ServerLayout "DefaultLayout"
  21. [     9.422] (**) |-->Screen "DefaultScreen" (0)
  22. [     9.422] (**) |   |-->Monitor "<default monitor>"
  23. [     9.423] (**) |   |-->Device "Mali FBDEV"
  24. [     9.423] (==) No monitor specified for screen "DefaultScreen".
  26. [     9.423] (**) Option "NoTrapSignals" "true"
  27. [     9.423] (**) Option "DontZap" "false"
  28. [     9.423] (**) Option "BlankTime" "0"
  29. [     9.423] (**) Option "StandbyTime" "0"
  30. [     9.423] (**) Option "SuspendTime" "0"
  31. [     9.423] (**) Option "OffTime" "0"
  32. [     9.423] (**) Option "IgnoreABI" "1"
  33. [     9.423] (**) Ignoring ABI Version
  34. [     9.423] (==) Automatically adding devices
  35. [     9.423] (==) Automatically enabling devices
  36. [     9.423] (==) Automatically adding GPU devices
  37. [     9.423] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
  38. [     9.423]    Entry deleted from font path.
  39. [     9.423] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
  40. [     9.423]    Entry deleted from font path.
  41. [     9.423] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
  42. [     9.423]    Entry deleted from font path.
  43. [     9.423] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
  44. [     9.423]    Entry deleted from font path.
  45. [     9.423] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
  46. [     9.423]    Entry deleted from font path.
  47. [     9.423] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
  48. [     9.423]    Entry deleted from font path.
  49. [     9.423] (==) FontPath set to:
  51.     built-ins
  52. [     9.423] (==) ModulePath set to "/usr/lib/arm-linux-gnueabihf/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
  53. [     9.423] (II) The server relies on udev to provide the list of input devices.
  55. [     9.423] (II) Loader magic: 0xb6f6af10
  56. [     9.423] (II) Module ABI versions:
  57. [     9.423]    X.Org ANSI C Emulation: 0.4
  58. [     9.423]    X.Org Video Driver: 15.0
  59. [     9.423]    X.Org XInput driver : 20.0
  60. [     9.423]    X.Org Server Extension : 8.0
  61. [     9.424] (II) xfree86: Adding drm device (/dev/dri/card0)
  62. [     9.424] Initializing built-in extension Generic Event Extension
  63. [     9.424] Initializing built-in extension SHAPE
  64. [     9.424] Initializing built-in extension MIT-SHM
  65. [     9.424] Initializing built-in extension XInputExtension
  66. [     9.424] Initializing built-in extension XTEST
  67. [     9.424] Initializing built-in extension BIG-REQUESTS
  68. [     9.424] Initializing built-in extension SYNC
  69. [     9.424] Initializing built-in extension XKEYBOARD
  70. [     9.424] Initializing built-in extension XC-MISC
  71. [     9.424] Initializing built-in extension SECURITY
  72. [     9.424] Initializing built-in extension XINERAMA
  73. [     9.424] Initializing built-in extension XFIXES
  74. [     9.424] Initializing built-in extension RENDER
  75. [     9.424] Initializing built-in extension RANDR
  76. [     9.424] Initializing built-in extension COMPOSITE
  77. [     9.424] Initializing built-in extension DAMAGE
  78. [     9.424] Initializing built-in extension MIT-SCREEN-SAVER
  79. [     9.424] Initializing built-in extension DOUBLE-BUFFER
  80. [     9.424] Initializing built-in extension RECORD
  81. [     9.424] Initializing built-in extension DPMS
  82. [     9.424] Initializing built-in extension Present
  83. [     9.424] Initializing built-in extension DRI3
  84. [     9.424] Initializing built-in extension X-Resource
  85. [     9.424] Initializing built-in extension XVideo
  86. [     9.424] Initializing built-in extension XVideo-MotionCompensation
  87. [     9.424] Initializing built-in extension SELinux
  88. [     9.424] Initializing built-in extension XFree86-VidModeExtension
  89. [     9.425] Initializing built-in extension XFree86-DGA
  90. [     9.425] Initializing built-in extension XFree86-DRI
  91. [     9.425] Initializing built-in extension DRI2
  92. [     9.425] (II) LoadModule: "glx"
  93. [     9.428] (WW) Warning, couldn\'t open module glx
  94. [     9.428] (II) UnloadModule: "glx"
  95. [     9.428] (II) Unloading glx
  96. [     9.428] (EE) Failed to load module "glx" (module does not exist, 0)
  97. [     9.428] (II) LoadModule: "armsoc"
  98. [     9.429] (II) Loading /usr/lib/xorg/modules/drivers/armsoc_drv.so
  99. [     9.430] (II) Module armsoc: vendor="X.Org Foundation"
  100. [     9.430]    compiled for 1.15.1, module version = 0.0.1
  101. [     9.430]    Module class: X.Org Video Driver
  102. [     9.430]    ABI class: X.Org Video Driver, version 15.0
  103. [     9.430] (II) ARMSOC: Driver for TI OMAP: exynos5
  104. [     9.430] (++) using VT number 7
  105. [     9.436] (WW) Falling back to old probe method for armsoc
  106. [     9.436] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
  107. [     9.436] (II) ARMSOC(0): Creating default Display subsection in Screen section
  109. [     9.436] (**) ARMSOC(0): Depth 24, (--) framebuffer bpp 32
  110. [     9.436] (==) ARMSOC(0): RGB weight 888
  111. [     9.436] (==) ARMSOC(0): Using gamma correction (1.0, 1.0, 1.0)
  112. [     9.436] (==) ARMSOC(0): Default visual is TrueColor
  113. [     9.436] (II) ARMSOC(0): Chipset: exynos5
  114. [     9.436] (II) ARMSOC(0): Setting the video modes ...
  115. [     9.436] (II) ARMSOC(0): [CRTC:21] HW Cursor using [BO:1]
  116. [     9.436] (II) ARMSOC(0): [CRTC:26] HW Cursor using [BO:2]
  117. [     9.437] (II) ARMSOC(0): Output HDMI-1 has no monitor section
  118. [     9.438] (II) ARMSOC(0): Output VGA-1 has no monitor section
  119. [     9.439] (II) ARMSOC(0): EDID for output HDMI-1
  120. [     9.439] (II) ARMSOC(0): Manufacturer: RKC  Model: 4448  Serial#: 1
  121. [     9.439] (II) ARMSOC(0): Year: 2004  Week: 20
  122. [     9.439] (II) ARMSOC(0): EDID Version: 1.3
  123. [     9.439] (II) ARMSOC(0): Digital Display Input
  124. [     9.439] (II) ARMSOC(0): Max Image Size [cm]: horiz.: 80  vert.: 45
  125. [     9.439] (II) ARMSOC(0): Gamma: 2.20
  126. [     9.439] (II) ARMSOC(0): No DPMS capabilities specified
  127. [     9.439] (II) ARMSOC(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
  128. [     9.439] (II) ARMSOC(0): First detailed timing is preferred mode
  129. [     9.439] (II) ARMSOC(0): redX: 0.625 redY: 0.340   greenX: 0.280 greenY: 0.595
  130. [     9.439] (II) ARMSOC(0): blueX: 0.155 blueY: 0.070   whiteX: 0.283 whiteY: 0.298
  131. [     9.439] (II) ARMSOC(0): Manufacturer\'s mask: 0
  132. [     9.439] (II) ARMSOC(0): #0: hsize: 472  vsize 295  refresh: 82  vid: 5660
  133. [     9.439] (II) ARMSOC(0): #0: hsize: 504  vsize 378  refresh: 84  vid: 22560
  134. [     9.439] (II) ARMSOC(0): #0: hsize: 600  vsize 375  refresh: 97  vid: 9516
  135. [     9.439] (II) ARMSOC(0): #0: hsize: 248  vsize 139  refresh: 64  vid: 50176
  136. [     9.439] (II) ARMSOC(0): #0: hsize: 1384  vsize 865  refresh: 93  vid: 8590
  137. [     9.439] (II) ARMSOC(0): #1: hsize: 2040  vsize 1275  refresh: 105  vid: 11744
  138. [     9.439] (II) ARMSOC(0): #1: hsize: 376  vsize 235  refresh: 76  vid: 4112
  139. [     9.439] (II) ARMSOC(0): #1: hsize: 744  vsize 465  refresh: 62  vid: 574
  140. [     9.439] (II) ARMSOC(0): #1: hsize: 248  vsize 155  refresh: 79  vid: 4864
  141. [     9.439] (II) ARMSOC(0): #1: hsize: 1384  vsize 865  refresh: 93  vid: 8590
  142. [     9.439] (II) ARMSOC(0): Supported detailed timing:
  143. [     9.439] (II) ARMSOC(0): clock: 74.2 MHz   Image Size:  522 x 32 mm
  144. [     9.439] (II) ARMSOC(0): h_active: 1280  h_sync: 1280  h_sync_end 1320 h_blank_end 1650 h_border: 32
  145. [     9.440] (II) ARMSOC(0): v_active: 720  v_sync: 724  v_sync_end 729 v_blanking: 750 v_border: 32
  146. [     9.440] (II) ARMSOC(0): Stereo: left channel on sync
  147. [     9.440] side-by-side interleaved(II) ARMSOC(0): Monitor name: GENERIC
  148. [     9.440] (II) ARMSOC(0): Supported detailed timing:
  149. [     9.440] (II) ARMSOC(0): clock: 74.2 MHz   Image Size:  708 x 398 mm
  150. [     9.440] (II) ARMSOC(0): h_active: 1280  h_sync: 1390  h_sync_end 1430 h_blank_end 1650 h_border: 0
  151. [     9.440] (II) ARMSOC(0): v_active: 720  v_sync: 725  v_sync_end 730 v_blanking: 750 v_border: 0
  152. [     9.440] (II) ARMSOC(0): Supported detailed timing:
  153. [     9.440] (II) ARMSOC(0): clock: 25.2 MHz   Image Size:  530 x 398 mm
  154. [     9.440] (II) ARMSOC(0): h_active: 640  h_sync: 648  h_sync_end 744 h_blank_end 800 h_border: 8
  155. [     9.440] (II) ARMSOC(0): v_active: 480  v_sync: 482  v_sync_end 484 v_blanking: 525 v_border: 8
  156. [     9.440] (II) ARMSOC(0): Supported detailed timing:
  157. [     9.440] (II) ARMSOC(0): clock: 27.0 MHz   Image Size:  531 x 398 mm
  158. [     9.440] (II) ARMSOC(0): h_active: 1440  h_sync: 1478  h_sync_end 1602 h_blank_end 1716 h_border: 0
  159. [     9.440] (II) ARMSOC(0): v_active: 240  v_sync: 244  v_sync_end 247 v_blanking: 262 v_border: 0
  160. [     9.440] (II) ARMSOC(0): Supported detailed timing:
  161. [     9.440] (II) ARMSOC(0): clock: 148.5 MHz   Image Size:  708 x 398 mm
  162. [     9.440] (II) ARMSOC(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
  163. [     9.441] (II) ARMSOC(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
  164. [     9.441] (II) ARMSOC(0): Number of EDID sections to follow: 1
  165. [     9.441] (II) ARMSOC(0): EDID (in hex):
  166. [     9.441] (II) ARMSOC(0):    00ffffffffffff004963484401000000
  167. [     9.441] (II) ARMSOC(0):    140e010380502d780a0dc9a057479827
  168. [     9.441] (II) ARMSOC(0):    12484c00000001010101010101010101
  169. [     9.441] (II) ARMSOC(0):    010101010101000000fa001c1620582c
  170. [     9.441] (II) ARMSOC(0):    2500c48e2100000a000000fa00e02d10
  171. [     9.441] (II) ARMSOC(0):    103e0200138e2100000a011d007251d0
  172. [     9.441] (II) ARMSOC(0):    1e20002845000a2020202020000000fc
  173. [     9.441] (II) ARMSOC(0):    0047454e455249430a20202020200150
  174. [     9.441] (WW) ARMSOC(0): Output HDMI-1: Strange aspect ratio (522/32), consider adding a quirk
  175. [     9.441] (II) ARMSOC(0): EDID vendor "RKC", prod id 17480
  176. [     9.441] (II) ARMSOC(0): DDCModeFromDetailedTiming: Ignoring: We don\'t handle stereo.
  177. [     9.441] (II) ARMSOC(0): Printing DDC gathered Modelines:
  178. [     9.441] (II) ARMSOC(0): Modeline "472x295"x82.0   14.85  472 480 528 584  295 296 299 310 -hsync +vsync (25.4 kHz e)
  179. [     9.441] (II) ARMSOC(0): Modeline "504x378"x84.0   21.07  504 520 568 632  378 379 382 397 -hsync +vsync (33.3 kHz e)
  180. [     9.442] (II) ARMSOC(0): Modeline "600x375"x97.0   29.88  600 624 688 776  375 376 379 397 -hsync +vsync (38.5 kHz e)
  181. [     9.442] (II) ARMSOC(0): Modeline "248x139"x64.0    2.30  248 232 248 248  139 140 143 145 -hsync +vsync (9.3 kHz e)
  182. [     9.442] (II) ARMSOC(0): Modeline "1384x865"x93.0  159.63  1384 1480 1632 1880  865 866 869 913 -hsync +vsync (84.9 kHz e)
  183. [     9.442] (II) ARMSOC(0): Modeline "248x2040"x1275.0  3135.89  248 272 304 360  2040 2041 2044 6832 -hsync +vsync (8710.8 kHz e)
  184. [     9.442] (II) ARMSOC(0): Modeline "11744x376"x235.0  1637.85  11744 12632 13920 16096  376 377 380 433 -hsync +vsync (101.8 kHz e)
  185. [     9.442] (II) ARMSOC(0): Modeline "4112x744"x465.0  2710.87  4112 4504 4968 5824  744 745 748 1001 -hsync +vsync (465.5 kHz e)
  186. [     9.442] (II) ARMSOC(0): Modeline "2040x1275"x105.0  401.49  2040 2208 2432 2824  1275 1276 1279 1354 -hsync +vsync (142.2 kHz e)
  187. [     9.442] (II) ARMSOC(0): Modeline "376x235"x76.0    8.23  376 376 408 440  235 236 239 246 -hsync +vsync (18.7 kHz e)
  188. [     9.442] (II) ARMSOC(0): Modeline "744x465"x62.0   27.97  744 768 840 936  465 466 469 482 -hsync +vsync (29.9 kHz e)
  189. [     9.442] (II) ARMSOC(0): Modeline "248x155"x79.0    3.40  248 232 256 264  155 156 159 163 -hsync +vsync (12.9 kHz e)
  190. [     9.442] (II) ARMSOC(0): Modeline "0x5"x522.0    0.00  0 0 0 0  5 6 9 8 -hsync +vsync (4.2 kHz e)
  191. [     9.442] (II) ARMSOC(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
  192. [     9.442] (II) ARMSOC(0): Modeline "640x480"x0.0   25.18  640 648 744 800  480 482 484 525 -hsync -vsync (31.5 kHz e)
  193. [     9.442] (II) ARMSOC(0): Modeline "1440x480i"x0.0   27.00  1440 1478 1602 1716  480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
  194. [     9.442] (II) ARMSOC(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
  195. [     9.442] (II) ARMSOC(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
  196. [     9.442] (II) ARMSOC(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
  197. [     9.442] (II) ARMSOC(0): Printing probed modes for output HDMI-1
  198. [     9.442] (II) ARMSOC(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz eP)
  199. [     9.442] (II) ARMSOC(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
  200. [     9.442] (II) ARMSOC(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
  201. [     9.442] (II) ARMSOC(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
  202. [     9.442] (II) ARMSOC(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
  203. [     9.442] (II) ARMSOC(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
  204. [     9.442] (II) ARMSOC(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
  205. [     9.442] (II) ARMSOC(0): Modeline "640x480"x60.0   25.18  640 648 744 800  480 482 484 525 -hsync -vsync (31.5 kHz e)
  206. [     9.442] (II) ARMSOC(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
  207. [     9.443] (II) ARMSOC(0): EDID for output VGA-1
  208. [     9.443] (II) ARMSOC(0): Output HDMI-1 connected
  209. [     9.443] (II) ARMSOC(0): Output VGA-1 disconnected
  210. [     9.443] (II) ARMSOC(0): Using exact sizes for initial modes
  211. [     9.443] (II) ARMSOC(0): Output HDMI-1 using initial mode 1280x720
  212. [     9.443] (II) ARMSOC(0): Got KMS resources
  213. [     9.443] (**) ARMSOC(0): Display dimensions: (800, 450) mm
  214. [     9.443] (**) ARMSOC(0): DPI set to (40, 40)
  215. [     9.443] (II) Loading sub module "dri2"
  216. [     9.443] (II) LoadModule: "dri2"
  217. [     9.443] (II) Module "dri2" already built-in
  218. [     9.443] (II) Loading sub module "exa"
  219. [     9.443] (II) LoadModule: "exa"
  220. [     9.444] (II) Loading /usr/lib/xorg/modules/libexa.so
  221. [     9.444] (II) Module exa: vendor="X.Org Foundation"
  222. [     9.444]    compiled for 1.15.1, module version = 2.6.0
  223. [     9.444]    ABI class: X.Org Video Driver, version 15.0
  224. [     9.444] (II) Loading sub module "fb"
  225. [     9.444] (II) LoadModule: "fb"
  226. [     9.444] (II) Loading /usr/lib/xorg/modules/libfb.so
  227. [     9.445] (II) Module fb: vendor="X.Org Foundation"
  228. [     9.445]    compiled for 1.15.1, module version = 1.0.0
  229. [     9.445]    ABI class: X.Org ANSI C Emulation, version 0.4
  230. [     9.445] (--) Depth 24 pixmap format is 32 bpp
  231. [     9.472] (II) ARMSOC(0): Initialized a depth-32 visual for XRGB8888
  232. [     9.472] (II) ARMSOC(0): Soft EXA mode
  233. [     9.472] (II) EXA(0): Driver allocated offscreen pixmaps
  234. [     9.472] (II) EXA(0): Driver registered support for the following operations:
  235. [     9.472] (II)         Solid
  236. [     9.472] (II)         Copy
  237. [     9.472] (II)         Composite (RENDER acceleration)
  238. [     9.472] (II) ARMSOC(0): [DRI2] Setup complete
  239. [     9.472] (II) ARMSOC(0): [DRI2]   DRI driver: armsoc
  240. [     9.472] (==) ARMSOC(0): Backing store enabled
  241. [     9.472] (==) ARMSOC(0): Silken mouse enabled
  242. [     9.474] (II) ARMSOC(0): RandR 1.2 enabled, ignore the following RandR disabled message.
  243. [     9.475] (==) ARMSOC(0): DPMS enabled
  244. [     9.475] (--) RandR disabled
  245. [     9.488] (II) SELinux: Disabled on system
  246. [     9.490] (II) ARMSOC(0): Setting screen physical size to 338 x 190
  247. [     9.547] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
  248. [     9.552] (II) config/udev: Adding drm device (/dev/dri/card0) card0 /sys/devices/display-subsystem.4/drm/card0
  249. [     9.552] (II) config/udev: Ignoring already known drm device (/dev/dri/card0)
  250. [     9.553] (II) config/udev: Adding input device gpio_ir_recv (/dev/input/event0)
  251. [     9.553] (**) gpio_ir_recv: Applying InputClass "evdev keyboard catchall"
  252. [     9.553] (II) LoadModule: "evdev"
  253. [     9.553] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
  254. [     9.560] (II) Module evdev: vendor="X.Org Foundation"
  255. [     9.561]    compiled for 1.15.0, module version = 2.8.2
  256. [     9.561]    Module class: X.Org XInput Driver
  257. [     9.561]    ABI class: X.Org XInput driver, version 20.0
  258. [     9.561] (II) Using input driver \'evdev\' for \'gpio_ir_recv\'
  259. [     9.561] (**) gpio_ir_recv: always reports core events
  260. [     9.561] (**) evdev: gpio_ir_recv: Device: "/dev/input/event0"
  261. [     9.561] (--) evdev: gpio_ir_recv: Vendor 0x1 Product 0x1
  262. [     9.561] (--) evdev: gpio_ir_recv: Found keys
  263. [     9.561] (II) evdev: gpio_ir_recv: Configuring as keyboard
  264. [     9.561] (**) Option "config_info" "udev:/sys/devices/gpio-ir-receiver.13/rc/rc0/input0/event0"
  265. [     9.561] (II) XINPUT: Adding extended input device "gpio_ir_recv" (type: KEYBOARD, id 6)
  266. [     9.561] (**) Option "xkb_rules" "evdev"
  267. [     9.561] (**) Option "xkb_model" "pc105"
  268. [     9.561] (**) Option "xkb_layout" "us"
  269. [     9.562] (II) config/udev: Adding input device gpio-keys.12 (/dev/input/event3)
  270. [     9.562] (**) gpio-keys.12: Applying InputClass "evdev keyboard catchall"
  271. [     9.562] (II) Using input driver \'evdev\' for \'gpio-keys.12\'
  272. [     9.562] (**) gpio-keys.12: always reports core events
  273. [     9.562] (**) evdev: gpio-keys.12: Device: "/dev/input/event3"
  274. [     9.562] (--) evdev: gpio-keys.12: Vendor 0x1 Product 0x1
  275. [     9.562] (--) evdev: gpio-keys.12: Found keys
  276. [     9.562] (II) evdev: gpio-keys.12: Configuring as keyboard
  277. [     9.562] (**) Option "config_info" "udev:/sys/devices/gpio-keys.12/input/input3/event3"
  278. [     9.562] (II) XINPUT: Adding extended input device "gpio-keys.12" (type: KEYBOARD, id 7)
  279. [     9.562] (**) Option "xkb_rules" "evdev"
  280. [     9.562] (**) Option "xkb_model" "pc105"
  281. [     9.562] (**) Option "xkb_layout" "us"
  282. [     9.563] (II) config/udev: Adding input device RockchipHDMI HDMI Jack (/dev/input/event2)
  283. [     9.563] (II) No input driver specified, ignoring this device.
  284. [     9.563] (II) This device may have been added with another device file.
  285. [     9.563] (II) config/udev: Adding input device MCE IR Keyboard/Mouse (gpio-rc-recv) (/dev/input/event1)
  286. [     9.563] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): Applying InputClass "evdev pointer catchall"
  287. [     9.563] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): Applying InputClass "evdev keyboard catchall"
  288. [     9.563] (II) Using input driver \'evdev\' for \'MCE IR Keyboard/Mouse (gpio-rc-recv)\'
  289. [     9.564] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): always reports core events
  290. [     9.564] (**) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Device: "/dev/input/event1"
  291. [     9.564] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Vendor 0 Product 0
  292. [     9.564] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found 3 mouse buttons
  293. [     9.564] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found relative axes
  294. [     9.564] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found x and y relative axes
  295. [     9.564] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found keys
  296. [     9.564] (II) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Configuring as mouse
  297. [     9.564] (II) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Configuring as keyboard
  298. [     9.564] (**) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): YAxisMapping: buttons 4 and 5
  299. [     9.564] (**) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
  300. [     9.564] (**) Option "config_info" "udev:/sys/devices/virtual/input/input1/event1"
  301. [     9.564] (II) XINPUT: Adding extended input device "MCE IR Keyboard/Mouse (gpio-rc-recv)" (type: KEYBOARD, id 8)
  302. [     9.564] (**) Option "xkb_rules" "evdev"
  303. [     9.564] (**) Option "xkb_model" "pc105"
  304. [     9.564] (**) Option "xkb_layout" "us"
  305. [     9.564] (II) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): initialized for relative axes.
  306. [     9.564] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) keeping acceleration scheme 1
  307. [     9.564] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) acceleration profile 0
  308. [     9.564] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) acceleration factor: 2.000
  309. [     9.564] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) acceleration threshold: 4
Copy the code
super moderator
Rank: 8Rank: 8
Posted at 9/21/2016 14:17:59        Only Author  8#
we haven't see  the  Modeline 800X480
Posted at 9/21/2016 15:30:17        Only Author  9#
Yes, but how can i fix it? If I connect same display via VGA, Modeline 800x480 is present and display is working with native resolution. The largest problem is that display, if connected via HDMI, shows absolutely nothing.
super moderator
Rank: 8Rank: 8
Posted at 9/22/2016 09:19:35        Only Author  10#
Have you tested on another firefly board?
Return to List
123
