Disabling noise reduction RK3399
16
Posted at 9/23/2017 16:10:16      View3847 | Replies4        Print      Only Author   [Copy Link] 1#
What parameter is responsible for disabling noise reduction RK3399 (on/off)? (Android 6 & 7)   I want to disable via Init.d-script.
Compression noise reduct ion with filter matrix up to 7x7.
Compression noise reduction with filter matrix up to 7x7.
Programmable difference table for compression noise reduction.
Programmable distance table for compression noise reduction.
Spatial sampling noise reduction.
Temporal sampling noise reduction.
Optional coefficient for sampling noise reduction.
Max resolution for dynamic image:
Sampling noise reduction: 1920x1080
Compression noise reduction: 4096x2304
ex. for AMLogic noise reduction:
  1. /sys/module/di/parameters/nr2_en
Copy the code
Where is Rockchip setting?
Who knows this information?
Give me email of your best engineer.
Thanks.
Posted at 1/9/2026 17:27:21        Only Author  2#
This article is a gem, thank you for sharing it with us! The C-ARSUM-2508 valid test collection materials resources are excellent, and theres no cost to access them.
Posted at 1/14/2026 21:31:16        Only Author  3#
국제공인자격증을 취득하여 IT업계에서 자신만의 자리를 잡고 싶으신가요? 자격증이 수없이 많은데Amazon AWS-Certified-Developer-Associate 시험패스부터 시작해보실가요? 100%합격가능한  Amazon AWS-Certified-Developer-Associate덤프는Amazon AWS-Certified-Developer-Associate시험문제의 기출문제와 예상문제로 되어있는 퍼펙트한 모음문제집으로서 시험패스율이 100%에 가깝습니다.
Posted at 2/12/2026 13:47:08        Only Author  4#
ΥեȥЩ`ˤϡgHFCP_FCT_AD-7.4ԇYh򥷥ߥ`ȤȤ㤬ޤयYߤϡ򤹤Ȥ˥ѥե`ޥ󥹤k]ˤU|뤿ᡢgHFCP_FCT_AD-7.4ԇY˺ϸǤޤ FCP_FCT_AD-7.4YϤΤΥեȥЩ`ϡĤʿֲ˷ΤޤϡKȵõ㤬ʾΤǡˤg`ʤɤɤʤޤ FCP_FCT_AD-7.4ԇYYˤᡢFCP_FCT_AD-7.4ԇY˺ϸ񤹤Ҫޤ
Posted at 2/20/2026 04:12:38        Only Author  5#
Your article has left a significant mark on me, thank you for it. The Test NP-Con-102 review content is impressive, and its free for you to explore.
