How can I add Google Play Store to Android 7 for RK3399
62
Posted at 6/19/2017 07:17:14      View15728 | Replies8        Print      Only Author   [Copy Link] 1#
Hello,
The official Android images from Firefly do not contain Google Play store. There is a post in this forum about compiling Android 5.1 with the Google store for RK3288, so I decided to check out if it works for Nougat as well. So I followed the guide in the Wiki to setup a build environment, downloaded the Git repository for Android 7.1, edited the BoardConfig.mk file to enable store, compiled and successfully flashed the image. The new image works very nicely, fast and snappy, but alas - no Google app store!
Does anyone know how to enable support for adding Google accounts and using the Play store on a recent Android for Firefly RK3399? I would appreciate any help in this direction.
Thanks.
Best regards,
ttodorov
super moderator
Rank: 8Rank: 8
Posted at 6/20/2017 09:54:09        Only Author  2#
Hi , we haven't pass google's GMS certification,so we have no plant to support these  .sad for that.
Posted at 7/7/2017 17:02:28        Only Author  3#
Hi Isle,
If there is no plan for GMS on Android 7.1 then is it possible to install GMS on Anroid 5.1 on Rk3399?
Posted at 3/15/2019 15:32:41        Only Author  4#
failed, i think impossible. i have tried install apk from apkmirror and the newer version from apkgeny but failed to run the app.
Posted at 3/16/2019 10:33:34        Only Author  5#
margaretmei Posted at 3/15/2019 15:32
failed, i think impossible. i have tried install apk from apkmirror and the newer version from apkge ...
http://bbs.t-firefly.com/forum.php?mod=viewthread&tid=2431
you can try this.
Posted at 10/26/2025 01:41:42        Only Author  6#
Mj kolega polecił mi https://playjonny.pl i od tamtej pory praktycznie nie gram nigdzie indziej. Gry ładują się szybko, a grafika wygląda super nawet na moim starszym laptopie. Bonusy powitalne są całkiem fajne, a darmowe spiny naprawdę się przydają. Co ważne, wypłaty są uczciwe i nigdy nie miałem problemu z przelewami. Lubię też, że strona jest prosta w obsłudze, nawet jeśli ktoś dopiero zaczyna z kasynami online w Polsce.
Posted at 1/11/2026 01:40:39        Only Author  7#
This is amazing content, Im giving it a like. Free AgilePM-Foundation valid study guide pdf test materials are herewishing you good luck!
Posted at 1/18/2026 13:13:31        Only Author  8#
Im really enjoying this content, definitely hitting like. The C-P2WFI-2023 valid dumps demo test questions are free for allyour key to a successful career!
Posted at 2/7/2026 11:43:01        Only Author  9#
I'm deeply moved by this article, thank you for sharing it! Free PDII valid exam discount voucher materialspromotion and salary increase are just a click away!
