New Topic
Technical briefing for Firefly-RK3288£ºUpdates for firmware and Android 4.4 codes
385
super moderator
Rank: 8Rank: 8
Posted at 1/29/2015 15:26:21        Only Author  1#
1. Major updates for the default SDK:
¡¤ Fix debug serial probability can not input(must update parameter at FFTools/parameter/)
¡¤ Add FFTools , including the development of tools, add parameter which contain Linux and Android
¡¤ Support Fireasy
¡¤ Improve Ethernet rate
¡¤ Configure AF_DDV as 2.8V for camera
To upgrade the SDK, please refer to  the Download Android SDK of the default version on wiki.
You can download the newest firmware Firefly-RK3288_Android4.4_201501271047.7z from any of the following cloud storage:
l Baidu Cloud
l Google Drive
2. Major updates for the  pad sdk:
¡¤ Update FFTools, including Android development tools and parameter
¡¤ Fix OV13850 camera direction bug
¡¤ Increase the capacity of mipi dsi cmds
To upgrade the SDK, please refer to theDownload Android SDK of the PAD version on wiki.
You can download the newest firmware Firefly-RK3288_PAD_B101EW05_Android4.4_201501281108.7z from any of the following cloud storage:
l Baidu Cloud
l Google Drive
3. Major updates for Ubuntu 14.04 desktop:
¡¤ Support bluetooth service
¡¤ Display log on screen when booting
You can download the newest firmware Firefly-RK3288_Ubuntu14.04_201501271612.7z from any of the following cloud storage:
l Baidu Cloud
l Google Drive
4. Major updates for Ubuntu 14.04 server:
¡¤ The initial version
To configure you  board for Ubuntu 14.04 server, please refer to  the Ubuntu Server Note on wiki.
You can download the newest firmware Firefly-RK3288_Server_Ubuntu14.04_201501271052.7z from any of the following cloud storage:
l Baidu Cloud
l Google Drive
5. Major updates for DualBoot(default android and Ubuntu 14.04 desktop):
¡¤ Refer to the first and the third paragraphs
You can download the newest firmware Firefly-RK3288_DualBoot_201501271613.7z from any of the following cloud storage:
l Baidu Cloud
l Google Drive
Posted at 2/11/2015 12:18:06        Only Author  2#
Re: Technical briefing for Firefly-RK3288£ºUpdates for firmware and Android 4...
It does not boot  linux system with dual boot update at 29 Jan 2015 that is RK3288_DualBoot_201501271613.7z. There is no problem to boot Android but I can't boot linux system  with this image. So, I replace the resource.img with old resource.img at 11 Dec 2014 and then it is ok to boot linux. Please check the linux booting problem.
vip
Rank: 6Rank: 6
Posted at 2/11/2015 21:40:15        Only Author  3#
        which hardware version? can you show your kernel message.
Posted at 2/12/2015 01:55:59        Only Author  4#
Hi wico,
Are you able to provide a android ROM with DTS/AC3 audio PassTrough (SPIDF, digital optical output, and probably HDMI too)? There are already (since December last year) RK3288 board with this feature available! Please, check on freaktab, firmwares from Ugoos, Tronsmart, Beelink etc. They all have this feature.
Hope you can bring us this nice feature any time soon!
Regards
vip
Rank: 6Rank: 6
Posted at 2/12/2015 09:53:59        Only Author  5#
Re: Technical briefing for Firefly-RK3288£ºUpdates for firmware and Android 4.4 c
As far as I know,  AC3/DTS  requires authorization from soc's vendor,it is not free
Posted at 2/12/2015 09:57:06        Only Author  6#
I'm using the 0930 standard board. There is black screen during linux booting so I connect USB to serial adapter to Firefly. When I see the booting messages, the firefly boots forever.
DDR Version 1.00 20141007
In
Channel a: DDR3 200MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
Channel b: DDR3 200MHz
Memory OK
Memory OK
OUT
U-Boot 2014.10-RK3288-02 (Oct 30 2014 - 09:27:41)
CPU: rk3288
CPU's clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
Board:  Rockchip platform Board
DRAM:  Found dram banks:1
Adding bank:0000000000000000(0000000080000000)
128 MiB
storage init OK!
Using default environment
GetParam
check parameter success
Unknow param: MACHINE_MODEL:rk30sdk!
Unknow param: MACHINE_ID:007!
Unknow param: MANUFACTURER:RK30SDK!
Unknow param: PWR_HLD: 0,0,A,0,1!
failed to prepare fdt from boot!
power key: bank-0 pin-5
can't find dts node for ricoh619
pmic:act8846
Can't find dts node for fuel guage cw201x
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 2014-10-30#2.17
sn:1006120001000000
no fuel gauge found
no fuel gauge found
read logo_on switch from dts [0]
checkKey
vbus = 0
no fuel gauge found
got recovery cmd from misc.
failed to load fdt from recovery!
kernel   @ 0x02000000 (0x00609068)
ramdisk  @ 0x059fc000 (0x00275b8f)
Secure Boot state: 0
bootrk: do_bootm_linux...
Loading Device Tree to 0561b000, end 05636184 ... OK
Add bank:0000000000000000, 0000000080000000
Starting kernel ...
In
SRX
OUT
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
sn:1006120001000000
no fuel gauge found
no fuel gauge found
checkKey
vbus = 0
no fuel gauge found
Starting kernel ...
In
SRX
OUT
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
sn:1006120001000000
no fuel gauge found
no fuel gauge found
checkKey
vbus = 0
no fuel gauge found
Starting kernel ...
Posted at 2/12/2015 10:07:32        Only Author  7#
cgsong, make sure you are using correct power adapter (try to plug in a computer USB and see if it works).
So, I can guess DTS/AC3 sound will never be possible. Nice.
Posted at 2/12/2015 10:22:03        Only Author  8#
I'm using correct power adapter and there is no problem in previous Firefly official image. Wico, please verify linux kernel booting message. When I see the booting message, dts node for fuel guage is something wrong.
vip
Rank: 6Rank: 6
Posted at 2/12/2015 10:25:24        Only Author  9#
have you update your parameter, the cmdline must contain  ttyS2 and earyprintk instead of ttyFIQ0.
you can find it at FFTools/parameter/
Posted at 2/12/2015 10:55:45        Only Author  10#
Thanks.
It is working and I update parameter file wih ttyS2.
Return to List
12
