Board not started - rebooting forever
21
Posted at 12/29/2017 07:57:46      View6554 | Replies9        Print      Only Author   [Copy Link] 1#
Board rebooting forever with next messages on UART:
  1. DDR Version 1.08 20170320
  2. In
  3. soft reset
  4. SRX
  5. Channel 0: DDR3, 800MHz
  6. Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
  7. Channel 1: DDR3, 800MHz
  8. Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
  9. 256B stride
  10. ch 0 ddrconfig = 0x101, ddrsize = 0x2020
  11. ch 1 ddrconfig = 0x101, ddrsize = 0x2020
  12. pmugrf_os_reg[2] = 0x3AA17AA1, stride = 0xD
  13. OUT
  14. Boot1: 2017-03-07, version: 1.06
  15. CPUId = 0x0
  16. ChipType = 0x10, 1899
  17. SdmmcInit=2 0
  18. BootCapSize=100000
  19. UserCapSize=14910MB
  20. FwPartOffset=2000 , 100000
  21. SdmmcInit=0 20
  22. StorageInit ok = 66603
  23. LoadTrustBL
  24. No find bl30.bin
  25. No find bl32.bin
  26. RunBL31 0x10000
  27. NOTICE:  BL31: v1.3(debug):55aa0b4
  28. NOTICE:  BL31: Built : 16:55:03, Mar 31 2017
  29. INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
  30. INFO:    boot cpu mask: 0
  31. WARNING: pmu_power_domain_ctr: 5, 1, error!
  32. INFO:    plat_rockchip_pmu_init(1089): pd status 1e
  33. INFO:    BL31: Initializing runtime services
  34. INFO:    BL31: Preparing for EL3 exit to normal world
  35. INFO:    Entry point address = 0x200000
  36. INFO:    SPSR = 0x3c9
  37. U-Boot 2017.02-RK3399-06 (Aug 29 2017 - 17:28:07)
  38. CPU: rk3399
  39. cpu version = 0
  40. CPU's clock information:
  41.     aplll = 816000000HZ
  42.     apllb = 24000000HZ
  43.     gpll = 800000000HZ
  44.                aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_periph_h = 33333333HZ
  45.                aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
  46.                hclk_periph_l1 = 100000000HZ, pclk_periph_l1 = 50000000HZ
  47.     cpll = 800000000HZ
  48.     dpll = 792000000HZ
  49.     vpll = 24000000HZ
  50.     npll = 24000000HZ
  51.     ppll = 676000000HZ
  52. Board:  Rockchip platform Board
  53. Uboot as second level loader
  54. DRAM:  Found dram banks: 1
  55. Adding bank:0000000000200000(00000000ffe00000)
  56. 128 MiB
  57. SdmmcInit = 0 20
  58. storage init OK!
  59. Using default environment
  60. GetParam
  61. remotectl v0.1
  62. pwm freq=0xb8320
  63. pwm_freq_nstime=0x52d
  64. Load FDT from resource image.
  65. power key: bank-0 pin-5
  66. usb bc: can find node by path: /dwc-control-usb/usb_bc
  67. dwc_otg_check_dpdm: usb bc disconnected
  68. pmic:rk808
  69. can't find dts node for pwm1
  70. set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=66
  71. CPU's clock information:
  72.     aplll = 816000000HZ
  73.     apllb = 24000000HZ
  74.     gpll = 800000000HZ
  75.                aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_periph_h = 33333333HZ
  76.                aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
  77.                hclk_periph_l1 = 100000000HZ, pclk_periph_l1 = 50000000HZ
  78.     cpll = 800000000HZ
  79.     dpll = 792000000HZ
  80.     vpll = 24000000HZ
  81.     npll = 24000000HZ
  82.     ppll = 676000000HZ
  83. SecureBootEn = 0, SecureBootLock = 0
  84. #Boot ver: 2017-08-29#1.06
  85. empty serial no.
  86. normal boot.
  87. checkKey
  88. vbus = 0
  89. board_fbt_key_pressed: ir_keycode = 0x0, frt = 0
  90. no fuel gauge found
  91. no fuel gauge found
  92. failed to find phy node
  93. failed to find panel driver
  94. read logo on state from dts [1]
  95. no fuel gauge found
  96. can't find dts node for deviceinfo
  97. dw_rk_hdmi_register:fail to read deviceinfo
  98. hdmi baseparamer -1x-1@-1--1
  99. rockchip_panel_deinit: failed to find panel deinit funcs
  100. ERROR: [get_entry_ram]: Cannot find logo_kernel.bmp!
  101. failed to display kernel logo
  102. checkKey
  103. vbus = 0
  104. board_fbt_key_pressed: ir_keycode = 0x0, frt = 0
  105. got recovery cmd from misc.
  106. load fdt from resouce.
  107. Secure Boot state: 0
  108. kernel   @ 0x00280000 (0x011f7b60)
  109. ramdisk  @ 0x05bf0000 (0x00778c68)
  110. bootrk: do_bootm_linux...
  111.    Loading Device Tree to 0000000005600000, end 0000000005614c42 ... OK
  112. Add bank:0000000000200000, 00000000f7e00000
  113. WARNING: could not set reg FDT_ERR_BADOFFSET.
  114. Starting kernel ...
  115. [    0.000000] Booting Linux on physical CPU 0x0
  116. [    0.000000] Initializing cgroup subsys cpuset
  117. [    0.000000] Initializing cgroup subsys cpu
  118. [    0.000000] Initializing cgroup subsys cpuacct
  119. [    0.000000] Initializing cgroup subsys schedtune
  120. [    0.000000] Linux version 4.4.55 (omy@tchipserver2) (gcc version 4.9 20150123 (prerelease) (GCC) ) #609 SMP PREEMPT Tue Aug 29 17:29:18 CST 2017
  121. [    0.000000] Boot CPU: AArch64 Processor [410fd034]
  122. [    0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
  123. [    0.000000] bootconsole [uart0] enabled
  124. [    0.000000] hdmi init vic is -1
  125. [    0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
  126. [    0.000000] psci: probing for conduit method from DT.
  127. [    0.000000] psci: PSCIv1.0 detected in firmware.
  128. [    0.000000] psci: Using standard PSCI v0.2 function IDs
  129. [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  130. [    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6ef5000 s45248 r8192 d32576 u86016
  131. [    0.000000] Detected VIPT I-cache on CPU0
  132. [    0.000000] CPU features: enabling workaround for ARM erratum 845719
  133. [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 999432
  134. [    0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x00074000(cache),0x00300000@0x000B4000(system),0x00008000@0x003B4000(metadata),0x00002000@0x003BC000(baseparamer),-@0x003BE000(userdata) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2017-08-29_17:28:07 hdmi.vic=-1 SecureBootCheckOk=0
  135. [    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
  136. [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
  137. [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
  138. [    0.000000] software IO TLB [mem 0xf6ead000-0xf6eed000] (0MB) mapped at [ffffffc0f6ead000-ffffffc0f6eecfff]
  139. [    0.000000] Memory: 3944000K/4061184K available (11198K kernel code, 1374K rwdata, 4952K rodata, 832K init, 1078K bss, 100800K reserved, 16384K cma-reserved)
  140. [    0.000000] Virtual kernel memory layout:
  141. [    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
  142. [    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
  143. [    0.000000]       .init : 0xffffff8009050000 - 0xffffff8009120000   (   832 KB)
  144. [    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008b70000   ( 11200 KB)
  145. [    0.000000]     .rodata : 0xffffff8008b70000 - 0xffffff8009050000   (  4992 KB)
  146. [    0.000000]       .data : 0xffffff8009120000 - 0xffffff8009277a20   (  1375 KB)
  147. [    0.000000]     vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
  148. [    0.000000]               0xffffffbdc0008000 - 0xffffffbdc3e00000   (    61 MB actual)
  149. [    0.000000]     fixed   : 0xffffffbffe7fd000 - 0xffffffbffec00000   (  4108 KB)
  150. [    0.000000]     PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
  151. [    0.000000]     memory  : 0xffffffc000200000 - 0xffffffc0f8000000   (  3966 MB)
  152. [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
  153. [    0.000000] Preemptible hierarchical RCU implementation.
  154. [    0.000000]  Build-time adjustment of leaf fanout to 64.
  155. [    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
  156. [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
  157. [    0.000000] NR_IRQS:64 nr_irqs:64 0
  158. [    0.000000] GIC: Using split EOI/Deactivate mode
  159. [    0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
  160. [    0.000000] ITS: allocated 65536 Devices @f2000000 (psz 64K, shr 0)
  161. [    0.000000] ITS: using cache flushing for cmd queue
  162. [    0.000000] GIC: using LPI property table @0x00000000f2080000
  163. [    0.000000] ITS: Allocated 1792 chunks for LPIs
  164. [    0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
  165. [    0.000000] CPU0: using LPI pending table @0x00000000f2090000
  166. [    0.000000] GIC: using cache flushing for LPI property table
  167. [    0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
  168. [    0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
  169. [    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
  170. [    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
  171. [    0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
  172. [    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
  173. [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  174. [    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  175. [    0.001841] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
  176. [    0.002824] pid_max: default: 32768 minimum: 301
  177. [    0.003329] Security Framework initialized
  178. [    0.003726] SELinux:  Initializing.
  179. [    0.004161] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
  180. [    0.004804] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
  181. [    0.006307] Initializing cgroup subsys freezer
  182. [    0.006744] Initializing cgroup subsys debug
  183. [    0.007989] sched-energy: Sched-energy-costs installed from DT
  184. [    0.008548] CPU0: update cpu_capacity 401
  185. [    0.009004] ASID allocator initialised with 65536 entries
  186. [    0.025833] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
  187. [    0.027050] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
  188. [    0.039215] Detected VIPT I-cache on CPU1
  189. [    0.039246] CPU1: found redistributor 1 region 0:0x00000000fef20000
  190. [    0.039282] CPU1: using LPI pending table @0x00000000f2200000
  191. [    0.039325] CPU1: update cpu_capacity 401
  192. [    0.039329] CPU1: Booted secondary processor [410fd034]
  193. [    0.049215] Detected VIPT I-cache on CPU2
  194. [    0.049233] CPU2: found redistributor 2 region 0:0x00000000fef40000
  195. [    0.049266] CPU2: using LPI pending table @0x00000000f2230000
  196. [    0.049293] CPU2: update cpu_capacity 401
  197. [    0.049296] CPU2: Booted secondary processor [410fd034]
  198. [    0.059252] Detected VIPT I-cache on CPU3
  199. [    0.059270] CPU3: found redistributor 3 region 0:0x00000000fef60000
  200. [    0.059303] CPU3: using LPI pending table @0x00000000f2270000
  201. [    0.059329] CPU3: update cpu_capacity 401
  202. [    0.059333] CPU3: Booted secondary processor [410fd034]
  203. [    0.069293] Detected PIPT I-cache on CPU4
  204. [    0.069320] CPU4: found redistributor 100 region 0:0x00000000fef80000
  205. [    0.069356] CPU4: using LPI pending table @0x00000000f22b0000
  206. [    0.069396] CPU4: update cpu_capacity 1024
  207. [    0.069399] CPU4: Booted secondary processor [410fd082]
  208. [    1.080693] CPU5: failed to come online
  209. [    1.090718] Brought up 5 CPUs
  210. [    1.091004] SMP: Total of 5 processors activated.
  211. [    1.091465] CPU features: detected feature: GIC system register CPU interface
  212. [    1.092149] CPU: All CPU(s) started at EL2
  213. [    1.092573] alternatives: patching kernel code
  214. [    1.094069] devtmpfs: initialized
  215. [    1.113724] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
  216. [    1.114672] futex hash table entries: 2048 (order: 5, 131072 bytes)
  217. [    1.116320] pinctrl core: initialized pinctrl subsystem
  218. [    1.119406] Failed to find legacy iommu devices
  219. [    1.120388] NET: Registered protocol family 16
  220. [    1.121525] schedtune: init normalization constants...
  221. [    1.122021] schedtune: CLUSTER[0-3]      min_pwr:    56 max_pwr:   222
  222. [    1.122645] schedtune: CPU[0]            min_pwr:     0 max_pwr:   222
  223. [    1.123288] schedtune: CPU[1]            min_pwr:     0 max_pwr:   222
  224. [    1.123912] schedtune: CPU[2]            min_pwr:     0 max_pwr:   222
  225. [    1.124535] schedtune: CPU[3]            min_pwr:     0 max_pwr:   222
  226. [    1.125159] schedtune: CLUSTER[4]        min_pwr:    65 max_pwr:  1108
  227. [    1.125781] schedtune: CPU[4]            min_pwr:    65 max_pwr:  1108
  228. [    1.126409] Unable to handle kernel NULL pointer dereference at virtual address 00000010
  229. [    1.127190] pgd = ffffff8009389000
  230. [    1.127517] [00000010] *pgd=00000000f6ffe003, *pud=00000000f6ffe003, *pmd=0000000000000000
  231. [    1.128315] Internal error: Oops: 96000005 [#1] PREEMPT SMP
  232. [    1.128846] Modules linked in:
  233. [    1.129147] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.55 #609
  234. [    1.129727] Hardware name: Firefly-RK3399 Board BOX (Android) (DT)
  235. [    1.130318] task: ffffffc0f2160000 ti: ffffffc0f2168000 task.ti: ffffffc0f2168000
  236. [    1.131031] PC is at schedtune_init+0x20c/0x39c
  237. [    1.131465] LR is at schedtune_init+0x1fc/0x39c
  238. [    1.131898] pc : [<ffffff80080de890>] lr : [<ffffff80080de880>] pstate: 60000045
  239. [    1.132600] sp : ffffffc0f216bcd0
  240. [    1.132918] x29: ffffffc0f216bcd0 x28: ffffff8009127bf0
  241. [    1.133428] x27: ffffffc0f22929a0 x26: ffffff8009127000
  242. [    1.133939] x25: ffffff8008eb8050 x24: ffffffc0f2269400
  243. [    1.134450] x23: ffffff80090f2e40 x22: ffffff8008eb8000
  244. [    1.134960] x21: ffffffc0f2292980 x20: ffffff8009128000
  245. [    1.135471] x19: ffffff800927d000 x18: 0000000000000078
  246. [    1.135981] x17: 000000000000000e x16: 0000000000000007
  247. [    1.136490] x15: ffffff8008bcd000 x14: 0fffffffffffffff
  248. [    1.137001] x13: 0000000000000030 x12: 0101010101010101
  249. [    1.137511] x11: 7f7f7f7f7f7f7f7f x10: 59ff5c335a544f42
  250. [    1.138021] x9 : ffffffffffffffff x8 : 203536202020203a
  251. [    1.138532] x7 : 7277705f6e696d20 x6 : ffffffc0f2269c00
  252. [    1.139043] x5 : ffffff8008baa6b8 x4 : 0000000000000004
  253. [    1.139553] x3 : 0000000000000000 x2 : cb88537fdc8ba637
  254. [    1.140064] x1 : 0000000000000010 x0 : 0000000000000000
  255. [    1.140575]
  256. [    1.140575] PC: 0xffffff80080de810:
  257. [    1.141048] e810  f9400422 51000400 f8607848 aa1903e2 b9401020 f9400c21 51000400 f9003fa8
  258. [    1.141852] e830  8b001020 91068261 f9400407 f940d260 f90043a7 8b080000 f900d260 f9400420
  259. [    1.142652] e850  8b070000 f9000420 d2800401 910263a0 940a15ef f9403fa8 910263a1 f94043a7
  260. [    1.143452] e870  910082c0 aa0803e2 aa0703e3 9401fe57 f9403ba6 f94012a1 f94037a4 f94000c0
  261. [    1.144251] e890  f9400800 f9401000 ca000020 92401c00 b4fff900 d4210000 f94002b5 f9400b00
  262. [    1.145050] e8b0  eb0002bf 54fff3c1 91068277 9400500e f940d262 90007241 91141421 910082c0
  263. [    1.145850] e8d0  f94006e3 d0006ed8 91033318 9401fe3f f94006f6 f940d260 cb0002d6 2a1603e0
  264. [    1.146649] e8f0  940a3de7 2a0003e1 f9000ae0 d3609c02 d368bc03 d0006ec0 91016000 52800017
  265. [    1.147450]
  266. [    1.147450] LR: 0xffffff80080de800:
  267. [    1.147925] e800  f90037a4 f9003ba6 f9400c01 b9400020 f9400422 51000400 f8607848 aa1903e2
  268. [    1.148724] e820  b9401020 f9400c21 51000400 f9003fa8 8b001020 91068261 f9400407 f940d260
  269. [    1.149524] e840  f90043a7 8b080000 f900d260 f9400420 8b070000 f9000420 d2800401 910263a0
  270. [    1.150323] e860  940a15ef f9403fa8 910263a1 f94043a7 910082c0 aa0803e2 aa0703e3 9401fe57
  271. [    1.151123] e880  f9403ba6 f94012a1 f94037a4 f94000c0 f9400800 f9401000 ca000020 92401c00
  272. [    1.151922] e8a0  b4fff900 d4210000 f94002b5 f9400b00 eb0002bf 54fff3c1 91068277 9400500e
  273. [    1.152722] e8c0  f940d262 90007241 91141421 910082c0 f94006e3 d0006ed8 91033318 9401fe3f
  274. [    1.153522] e8e0  f94006f6 f940d260 cb0002d6 2a1603e0 940a3de7 2a0003e1 f9000ae0 d3609c02
  275. [    1.154323]
  276. [    1.154323] SP: 0xffffffc0f216bc50:
  277. [    1.154797] bc50  08eb8000 ffffff80 090f2e40 ffffff80 f2269400 ffffffc0 08eb8050 ffffff80
  278. [    1.155597] bc70  09127000 ffffff80 f22929a0 ffffffc0 09127bf0 ffffff80 f216bcd0 ffffffc0
  279. [    1.156397] bc90  080de880 ffffff80 f216bcd0 ffffffc0 080de890 ffffff80 60000045 00000000
  280. [    1.157196] bcb0  00000001 00000000 0000ffff 00000000 ffffffff ffffffff 00000454 00000000
  281. [    1.157996] bcd0  f216bd90 ffffffc0 08082ba4 ffffff80 080de684 ffffff80 09134b20 ffffff80
  282. [    1.158796] bcf0  f23fcb40 ffffffc0 09126000 ffffff80 09134b20 ffffff80 00000000 00000000
  283. [    1.159596] bd10  090b06e0 ffffff80 090504a0 ffffff80 090b0650 ffffff80 0927b000 ffffff80
  284. [    1.160395] bd30  f2168000 ffffffc0 00000004 00000000 f2269c00 ffffffc0 00000041 00000000
  285. [    1.161199]
  286. [    1.161199] X5: 0xffffff8008baa638:
  287. [    1.161673] a638  00000007 005900c0 00c00060 00c000c0 00c000c0 00c000c0 00c000c0 00a900c0
  288. [    1.162473] a658  00c00015 00c000af 00c00000 0026000e 00c000c0 001f00c0 00c000c0 00c000c0
  289. [    1.163272] a678  00000007 000d0000 002a001b 006d0056 0100008e 0d000000 4e34271a 00000041
  290. [    1.164071] a698  000d0000 00190013 00480038 00970061 09000000 17120d0b 0000001c 00000000
  291. [    1.164871] a6b8  30313030 30333032 30353034 30373036 30393038 31313130 31333132 31353134
  292. [    1.165670] a6d8  31373136 31393138 32313230 32333232 32353234 32373236 32393238 33313330
  293. [    1.166469] a6f8  33333332 33353334 33373336 33393338 34313430 34333432 34353434 34373436
  294. [    1.167268] a718  34393438 35313530 35333532 35353534 35373536 35393538 36313630 36333632
  295. [    1.168070]
  296. [    1.168070] X6: 0xffffffc0f2269b80:
  297. [    1.168544] 9b80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  298. [    1.169343] 9ba0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  299. [    1.170142] 9bc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  300. [    1.170941] 9be0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  301. [    1.171739] 9c00  00000000 00000000 00000000 00000000 f2292980 ffffffc0 00000005 00000000
  302. [    1.172539] 9c20  0000000a 00000000 00000020 0000007d 00000001 00000002 00000001 00000000
  303. [    1.173337] 9c40  00000000 00000000 00000000 00000000 0000102f 00000001 fffea1c1 00000000
  304. [    1.174135] 9c60  00000005 00000000 00001c25 00000000 fffea2e5 00000000 00000004 00000000
  305. [    1.174940]
  306. [    1.174940] X15: 0xffffff8008bccf80:
  307. [    1.175423] cf80  00000000 00000000 00000000 00000000 08434f60 ffffff80 00000000 00000000
  308. [    1.176222] cfa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  309. [    1.177020] cfc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  310. [    1.177819] cfe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  311. [    1.178618] d000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  312. [    1.179418] d020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  313. [    1.180216] d040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  314. [    1.181015] d060  00000000 00000000 00000000 00000000 08434f54 ffffff80 00000000 00000000
  315. [    1.181817]
  316. [    1.181817] X19: 0xffffff800927cf80:
  317. [    1.182300] cf80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  318. [    1.183099] cfa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  319. [    1.183898] cfc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  320. [    1.184697] cfe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  321. [    1.185496] d000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  322. [    1.186294] d020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  323. [    1.187092] d040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  324. [    1.187891] d060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  325. [    1.188692]
  326. [    1.188692] X20: 0xffffff8009127f80:
  327. [    1.189175] 7f80  0924f0e0 ffffff80 0924f170 ffffff80 0924f200 ffffff80 0924f290 ffffff80
  328. [    1.189975] 7fa0  0924f320 ffffff80 0924f3b0 ffffff80 0924f440 ffffff80 0924f4d0 ffffff80
  329. [    1.190774] 7fc0  0924f560 ffffff80 0924f5f0 ffffff80 0924f680 ffffff80 0924f710 ffffff80
  330. [    1.191574] 7fe0  0924f7a0 ffffff80 0924f830 ffffff80 0924f8c0 ffffff80 0924f950 ffffff80
  331. [    1.192373] 8000  092527c8 ffffff80 09252858 ffffff80 092528e8 ffffff80 09252978 ffffff80
  332. [    1.193173] 8020  09252a08 ffffff80 09252a98 ffffff80 09252b28 ffffff80 09252bb8 ffffff80
  333. [    1.193973] 8040  09252c48 ffffff80 09252cd8 ffffff80 09252d68 ffffff80 09252df8 ffffff80
  334. [    1.194771] 8060  09252e88 ffffff80 09252f18 ffffff80 09252fa8 ffffff80 09253038 ffffff80
  335. [    1.195572]
  336. [    1.195572] X21: 0xffffffc0f2292900:
  337. [    1.196055] 2900  616d6f64 00306e69 00000000 00000000 00000000 00000000 00000000 00000000
  338. [    1.196854] 2920  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  339. [    1.197653] 2940  30757063 ffffff00 00000000 00000000 00000000 00000000 00000000 00000000
  340. [    1.198453] 2960  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  341. [    1.199251] 2980  f2292780 ffffffc0 00000001 00000001 f22929c0 ffffffc0 f20e9d00 ffffffc0
  342. [    1.200051] 29a0  00000010 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  343. [    1.200850] 29c0  00000001 00000000 00000400 00000000 00000400 00000000 fffea1c3 00000000
  344. [    1.201649] 29e0  00000000 00000001 000000ff 00000000 00000000 00000000 00000000 00000000
  345. [    1.202450]
  346. [    1.202450] X22: 0xffffff8008eb7f80:
  347. [    1.202933] 7f80  0a646577 54330100 6e697972 6f742067 65726320 20657461 65726f6d 61687420
  348. [    1.203733] 7fa0  6425206e 68635320 75546465 6220656e 74736f6f 20676e69 756f7267 000a7370
  349. [    1.204532] 7fc0  63733601 74646568 3a656e75 696e6920 6f6e2074 6c616d72 74617a69 206e6f69
  350. [    1.205330] 7fe0  736e6f63 746e6174 2e2e2e73 3601000a 65686373 6e757464 6e203a65 6e65206f
  351. [    1.206130] 8000  79677265 646f6d20 64206c65 0a617461 554c4300 52455453 702a255b 005d6c62
  352. [    1.206929] 8020  63733601 74646568 3a656e75 312d2520 6d207337 705f6e69 203a7277 756c3525
  353. [    1.207727] 8040  78616d20 7277705f 3525203a 000a756c 5b555043 005d6425 63733601 74646568
  354. [    1.208526] 8060  3a656e75 69737520 6e20676e 616d726f 617a696c 6e6f6974 6e6f6320 6e617473
  355. [    1.209327]
  356. [    1.209327] X23: 0xffffff80090f2dc0:
  357. [    1.209810] 2dc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  358. [    1.210610] 2de0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  359. [    1.211408] 2e00  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  360. [    1.212207] 2e20  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  361. [    1.213006] 2e40  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  362. [    1.213805] 2e60  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  363. [    1.214604] 2e80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  364. [    1.215404] 2ea0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  365. [    1.216205]
  366. [    1.216205] X24: 0xffffffc0f2269380:
  367. [    1.216687] 9380  00000000 00000000 00000002 00000001 00000000 00000000 09198b10 ffffff80
  368. [    1.217486] 93a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  369. [    1.218285] 93c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  370. [    1.219085] 93e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  371. [    1.219884] 9400  00000000 00000000 f2268a00 ffffffc0 f2292780 ffffffc0 00000005 00000000
  372. [    1.220683] 9420  0000000a 00000000 00000020 0000007d 00000001 00000002 00000001 00000000
  373. [    1.221482] 9440  00000000 00000000 00000000 00000000 0000102f 00000001 fffea1b7 00000000
  374. [    1.222281] 9460  0000000a 00000000 00000b41 00000000 fffea2e4 00000000 00000000 00000000
  375. [    1.223082]
  376. [    1.223082] X25: 0xffffff8008eb7fd0:
  377. [    1.223564] 7fd0  6f6e2074 6c616d72 74617a69 206e6f69 736e6f63 746e6174 2e2e2e73 3601000a
  378. [    1.224364] 7ff0  65686373 6e757464 6e203a65 6e65206f 79677265 646f6d20 64206c65 0a617461
  379. [    1.225163] 8010  554c4300 52455453 702a255b 005d6c62 63733601 74646568 3a656e75 312d2520
  380. [    1.225963] 8030  6d207337 705f6e69 203a7277 756c3525 78616d20 7277705f 3525203a 000a756c
  381. [    1.226762] 8050  5b555043 005d6425 63733601 74646568 3a656e75 69737520 6e20676e 616d726f
  382. [    1.227562] 8070  617a696c 6e6f6974 6e6f6320 6e617473 6d207374 203a6c75 73207525 203a3168
  383. [    1.228359] 8090  73207525 203a3268 000a7525 63733601 74646568 3a656e75 72657620 20796669
  384. [    1.229160] 80b0  6d726f6e 7a696c61 6f697461 6f63206e 6174736e 2e73746e 000a2e2e 63733601
  385. [    1.229961]
  386. [    1.229961] X26: 0xffffff8009126f80:
  387. [    1.230443] 6f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  388. [    1.231243] 6fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  389. [    1.232042] 6fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  390. [    1.232841] 6fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  391. [    1.233640] 7000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  392. [    1.234440] 7020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  393. [    1.235238] 7040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  394. [    1.236038] 7060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  395. [    1.236838]
  396. [    1.236838] X27: 0xffffffc0f2292920:
  397. [    1.237321] 2920  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  398. [    1.238120] 2940  30757063 ffffff00 00000000 00000000 00000000 00000000 00000000 00000000
  399. [    1.238919] 2960  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  400. [    1.239718] 2980  f2292780 ffffffc0 00000001 00000001 f22929c0 ffffffc0 f20e9d00 ffffffc0
  401. [    1.240518] 29a0  00000010 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  402. [    1.241316] 29c0  00000001 00000000 00000400 00000000 00000400 00000000 fffea1c3 00000000
  403. [    1.242114] 29e0  00000000 00000001 000000ff 00000000 00000000 00000000 00000000 00000000
  404. [    1.242912] 2a00  00000001 00000001 00000001 00000001 00000001 ffffffff 00000000 00000000
  405. [    1.243713]
  406. [    1.243713] X28: 0xffffff8009127b70:
  407. [    1.244196] 7b70  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  408. [    1.244995] 7b90  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  409. [    1.245794] 7bb0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  410. [    1.246593] 7bd0  f1840000 ffffffc0 00000800 00000000 00000001 00000000 00000000 00000000
  411. [    1.247392] 7bf0  00000006 00000000 00000013 00000000 00000000 00000000 00000000 00000000
  412. [    1.248192] 7c10  00000000 00000000 00000000 00000000 00000000 00000000 0926e928 ffffff80
  413. [    1.248991] 7c30  00000000 00000000 00000000 00000000 00000000 00000000 0000000a 00000000
  414. [    1.249790] 7c50  00400000 0000000a 00000003 00000000 00000000 00000000 00000000 00000000
  415. [    1.250591]
  416. [    1.250591] X29: 0xffffffc0f216bc50:
  417. [    1.251073] bc50  08eb8000 ffffff80 090f2e40 ffffff80 f2269400 ffffffc0 08eb8050 ffffff80
  418. [    1.251872] bc70  09127000 ffffff80 f22929a0 ffffffc0 09127bf0 ffffff80 f216bcd0 ffffffc0
  419. [    1.252673] bc90  080de880 ffffff80 f216bcd0 ffffffc0 080de890 ffffff80 60000045 00000000
  420. [    1.253471] bcb0  00000001 00000000 0000ffff 00000000 ffffffff ffffffff 00000454 00000000
  421. [    1.254271] bcd0  f216bd90 ffffffc0 08082ba4 ffffff80 080de684 ffffff80 09134b20 ffffff80
  422. [    1.255071] bcf0  f23fcb40 ffffffc0 09126000 ffffff80 09134b20 ffffff80 00000000 00000000
  423. [    1.255870] bd10  090b06e0 ffffff80 090504a0 ffffff80 090b0650 ffffff80 0927b000 ffffff80
  424. [    1.256670] bd30  f2168000 ffffffc0 00000004 00000000 f2269c00 ffffffc0 00000041 00000000
  425. [    1.257470]
  426. [    1.257616] Process swapper/0 (pid: 1, stack limit = 0xffffffc0f2168020)
  427. [    1.258255] Stack: (0xffffffc0f216bcd0 to 0xffffffc0f216c000)
  428. [    1.258805] bcc0:                                   ffffffc0f216bd90 ffffff8008082ba4
  429. [    1.259553] bce0: ffffff80080de684 ffffff8009134b20 ffffffc0f23fcb40 ffffff8009126000
  430. [    1.260300] bd00: ffffff8009134b20 0000000000000000 ffffff80090b06e0 ffffff80090504a0
  431. [    1.261047] bd20: ffffff80090b0650 ffffff800927b000 ffffffc0f2168000 0000000000000004
  432. [    1.261794] bd40: ffffffc0f2269c00 0000000000000041 0000000000000454 ffffff8009126000
  433. [    1.262541] bd60: ffffffc0f23fcb40 5b005d345b555043 ffffff005d005d34 0000000000000000
  434. [    1.263288] bd80: ffffff80090b06e0 cb88537fdc8ba637 ffffffc0f216be20 ffffff8009050df0
  435. [    1.264035] bda0: 000000000000022b ffffff80090405d8 ffffff800927b000 0000000000000002
  436. [    1.264783] bdc0: ffffff8009126000 ffffff80090b0660 ffffff80090b06e0 ffffff8009050400
  437. [    1.265529] bde0: ffffff80090b0650 ffffff800927b000 ffffff8008eb63ed ffffff8008efbc91
  438. [    1.266276] be00: ffffff8008baa478 0000000000000000 0000000200000002 cb88537fdc8ba637
  439. [    1.267024] be20: ffffffc0f216bea0 ffffff8008b62b34 ffffff8008b62b24 0000000000000000
  440. [    1.267770] be40: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  441. [    1.268517] be60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  442. [    1.269264] be80: 0000000000000000 ffffff80090e66e0 0000000000000000 cb88537fdc8ba637
  443. [    1.270012] bea0: 0000000000000000 ffffff8008082690 ffffff8008b62b24 0000000000000000
  444. [    1.270758] bec0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  445. [    1.271505] bee0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  446. [    1.272251] bf00: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  447. [    1.272998] bf20: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  448. [    1.273744] bf40: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  449. [    1.274491] bf60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  450. [    1.275237] bf80: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  451. [    1.275984] bfa0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  452. [    1.276730] bfc0: 0000000000000000 0000000000000005 0000000000000000 0000000000000000
  453. [    1.277477] bfe0: 0000000000000000 0000000000000000 ffffffffffffffff ffffffffffffffff
  454. [    1.278220] Call trace:
  455. [    1.278458] Exception stack(0xffffffc0f216bae0 to 0xffffffc0f216bc10)
  456. [    1.279075] bae0: ffffff800927d000 0000008000000000 ffffffc0f216bcd0 ffffff80080de890
  457. [    1.279822] bb00: 0000000060000045 000000000000003a ffffff800927e000 0000000000002284
  458. [    1.280569] bb20: 0000000000000006 0000000000000000 ffffff8009143618 000000000927e7e8
  459. [    1.281317] bb40: ffffffc0f216bbe0 ffffff80080e8ef0 ffffff8009126000 ffffff80080e8ebc
  460. [    1.282064] bb60: ffffffc0f2292980 ffffff8008eb8000 ffffff80090f2e40 ffffffc0f2269400
  461. [    1.282811] bb80: ffffff8008eb8050 ffffff8009127000 ffffffc0f22929a0 cb88537fdc8ba637
  462. [    1.283558] bba0: 0000000000000000 0000000000000010 cb88537fdc8ba637 0000000000000000
  463. [    1.284305] bbc0: 0000000000000004 ffffff8008baa6b8 ffffffc0f2269c00 7277705f6e696d20
  464. [    1.285052] bbe0: 203536202020203a ffffffffffffffff 59ff5c335a544f42 7f7f7f7f7f7f7f7f
  465. [    1.285797] bc00: 0101010101010101 0000000000000030
  466. [    1.286266] [<ffffff80080de890>] schedtune_init+0x20c/0x39c
  467. [    1.286801] [<ffffff8008082ba4>] do_one_initcall+0x17c/0x198
  468. [    1.287347] [<ffffff8009050df0>] kernel_init_freeable+0x1b8/0x270
  469. [    1.287933] [<ffffff8008b62b34>] kernel_init+0x10/0xf8
  470. [    1.288426] [<ffffff8008082690>] ret_from_fork+0x10/0x40
  471. [    1.288936] Code: f9403ba6 f94012a1 f94037a4 f94000c0 (f9400800)
  472. [    1.289537] ---[ end trace 05def5689d89a2c3 ]---
  473. [    1.290006] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
  474. [    1.290006]
  475. [    1.290879] CPU2: stopping
  476. [    1.291146] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G      D         4.4.55 #609
  477. [    1.291840] Hardware name: Firefly-RK3399 Board BOX (Android) (DT)
  478. [    1.292428] Call trace:
  479. [    1.292670] [<ffffff800808852c>] dump_backtrace+0x0/0x1c8
  480. [    1.293188] [<ffffff8008088708>] show_stack+0x14/0x1c
  481. [    1.293676] [<ffffff800835835c>] dump_stack+0x8c/0xac
  482. [    1.294162] [<ffffff800808e0d8>] handle_IPI+0x140/0x284
  483. [    1.294662] [<ffffff8008080e84>] gic_handle_irq+0x10c/0x154
  484. [    1.295194] Exception stack(0xffffffc0f6f23000 to 0xffffffc0f6f23130)
  485. [    1.295811] 3000: ffffffc0f21c3e20 0000008000000000 ffffffc0f21c3f50 ffffff8008084944
  486. [    1.296558] 3020: 0000000060000045 0000000000000000 ffffffc0f6f1f060 0000000000000000
  487. [    1.297305] 3040: ffffffc0f21c3f50 ffffffc0f21c3e20 0000000000000000 0000000000000000
  488. [    1.298052] 3060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  489. [    1.298799] 3080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  490. [    1.299545] 30a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  491. [    1.300292] 30c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  492. [    1.301038] 30e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  493. [    1.301785] 3100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  494. [    1.302530] 3120: 0000000000000000 0000000000000000
  495. [    1.302999] [<ffffff8008081fb4>] el1_irq+0xb4/0x128
  496. [    1.303468] [<ffffff8008084944>] arch_cpu_idle+0x84/0x160
  497. [    1.303988] [<ffffff80080da9c4>] default_idle_call+0x20/0x28
  498. [    1.304531] [<ffffff80080dabf4>] cpu_startup_entry+0x228/0x37c
  499. [    1.305090] [<ffffff800808dc70>] secondary_start_kernel+0x188/0x194
  500. [    1.305688] [<0000000000282978>] 0x282978
  501. [    1.306073] CPU3: stopping
  502. [    1.306339] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G      D         4.4.55 #609
  503. [    1.307034] Hardware name: Firefly-RK3399 Board BOX (Android) (DT)
  504. [    1.307622] Call trace:
  505. [    1.307863] [<ffffff800808852c>] dump_backtrace+0x0/0x1c8
  506. [    1.308381] [<ffffff8008088708>] show_stack+0x14/0x1c
  507. [    1.308866] [<ffffff800835835c>] dump_stack+0x8c/0xac
  508. [    1.309351] [<ffffff800808e0d8>] handle_IPI+0x140/0x284
  509. [    1.309852] [<ffffff8008080e84>] gic_handle_irq+0x10c/0x154
  510. [    1.310383] Exception stack(0xffffffc0f6f38000 to 0xffffffc0f6f38130)
  511. [    1.311000] 8000: ffffffc0f21c7e20 0000008000000000 ffffffc0f21c7f50 ffffff8008084944
  512. [    1.311747] 8020: 0000000060000045 0000000000000000 ffffffc0f6f34060 0000000000000000
  513. [    1.312494] 8040: ffffffc0f21c7f50 ffffffc0f21c7e20 0000000000000000 0000000000000000
  514. [    1.313240] 8060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  515. [    1.313987] 8080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  516. [    1.314734] 80a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  517. [    1.315480] 80c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  518. [    1.316226] 80e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  519. [    1.316973] 8100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  520. [    1.317717] 8120: 0000000000000000 0000000000000000
  521. [    1.318185] [<ffffff8008081fb4>] el1_irq+0xb4/0x128
  522. [    1.318654] [<ffffff8008084944>] arch_cpu_idle+0x84/0x160
  523. [    1.319173] [<ffffff80080da9c4>] default_idle_call+0x20/0x28
  524. [    1.319716] [<ffffff80080dabf4>] cpu_startup_entry+0x228/0x37c
  525. [    1.320275] [<ffffff800808dc70>] secondary_start_kernel+0x188/0x194
  526. [    1.320872] [<0000000000282978>] 0x282978
  527. [    1.321255] CPU1: stopping
  528. [    1.321522] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G      D         4.4.55 #609
  529. [    1.322216] Hardware name: Firefly-RK3399 Board BOX (Android) (DT)
  530. [    1.322804] Call trace:
  531. [    1.323045] [<ffffff800808852c>] dump_backtrace+0x0/0x1c8
  532. [    1.323564] [<ffffff8008088708>] show_stack+0x14/0x1c
  533. [    1.324049] [<ffffff800835835c>] dump_stack+0x8c/0xac
  534. [    1.324534] [<ffffff800808e0d8>] handle_IPI+0x140/0x284
  535. [    1.325035] [<ffffff8008080e84>] gic_handle_irq+0x10c/0x154
  536. [    1.325566] Exception stack(0xffffffc0f6f0e000 to 0xffffffc0f6f0e130)
  537. [    1.326183] e000: ffffffc0f21bbe20 0000008000000000 ffffffc0f21bbf50 ffffff8008084944
  538. [    1.326930] e020: 0000000060000045 0000000000000000 ffffffc0f6f0a060 0000000000000000
  539. [    1.327677] e040: ffffffc0f21bbf50 ffffffc0f21bbe20 0000000000000000 0000000000000000
  540. [    1.328424] e060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  541. [    1.329171] e080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  542. [    1.329917] e0a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  543. [    1.330663] e0c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  544. [    1.331410] e0e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  545. [    1.332157] e100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  546. [    1.332900] e120: 0000000000000000 0000000000000000
  547. [    1.333368] [<ffffff8008081fb4>] el1_irq+0xb4/0x128
  548. [    1.333835] [<ffffff8008084944>] arch_cpu_idle+0x84/0x160
  549. [    1.334354] [<ffffff80080da9c4>] default_idle_call+0x20/0x28
  550. [    1.334897] [<ffffff80080dabf4>] cpu_startup_entry+0x228/0x37c
  551. [    1.335455] [<ffffff800808dc70>] secondary_start_kernel+0x188/0x194
  552. [    1.336052] [<0000000000282978>] 0x282978
  553. [    1.336437] CPU4: stopping
  554. [    1.336711] CPU: 4 PID: 0 Comm: swapper/4 Tainted: G      D         4.4.55 #609
  555. [    1.337420] Hardware name: Firefly-RK3399 Board BOX (Android) (DT)
  556. [    1.338020] Call trace:
  557. [    1.338271] [<ffffff800808852c>] dump_backtrace+0x0/0x1c8
  558. [    1.338800] [<ffffff8008088708>] show_stack+0x14/0x1c
  559. [    1.339295] [<ffffff800835835c>] dump_stack+0x8c/0xac
  560. [    1.339788] [<ffffff800808e0d8>] handle_IPI+0x140/0x284
  561. [    1.340297] [<ffffff8008080e84>] gic_handle_irq+0x10c/0x154
  562. [    1.340839] Exception stack(0xffffffc0f6f4d000 to 0xffffffc0f6f4d130)
  563. [    1.341466] d000: ffffffc0f21cbe20 0000008000000000 ffffffc0f21cbf50 ffffff8008084944
  564. [    1.342226] d020: 0000000060000045 0000000000000000 ffffffc0f6f49060 0000000000000000
  565. [    1.342986] d040: ffffffc0f21cbf50 ffffffc0f21cbe20 0000000000000000 0000000000000000
  566. [    1.343745] d060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  567. [    1.344504] d080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  568. [    1.345263] d0a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  569. [    1.346022] d0c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  570. [    1.346781] d0e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  571. [    1.347539] d100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  572. [    1.348298] d120: 0000000000000000 0000000000000000
  573. [    1.348772] [<ffffff8008081fb4>] el1_irq+0xb4/0x128
  574. [    1.349249] [<ffffff8008084944>] arch_cpu_idle+0x84/0x160
  575. [    1.349777] [<ffffff80080da9c4>] default_idle_call+0x20/0x28
  576. [    1.350329] [<ffffff80080dabf4>] cpu_startup_entry+0x228/0x37c
  577. [    1.350896] [<ffffff800808dc70>] secondary_start_kernel+0x188/0x194
  578. [    1.351505] [<0000000000282978>] 0x282978
  579. [    1.351899] CRU:
  580. [    1.352091] 00000000: 00000044 00001201 80000000 00000108 00000007 00007f00 00000000 00000000
  581. [    1.352910] 00000020: 00000044 00001201 80000000 00000108 00000007 00007f00 00000000 00000000
  582. [    1.353727] 00000040: 00000042 00001201 8000031f 00000108 00000007 00007f00 00000000 00000000
  583. [    1.354546] 00000060: 00000190 00001206 80000000 00000108 00000007 00007f00 00000000 00000000
  584. [    1.355365] 00000080: 00000190 00001206 80000000 00000108 00000007 00007f00 00000000 00000000
  585. [    1.356182] 000000a0: 0000004b 00001301 80000000 00000108 00000007 00007f00 00000000 00000000
  586. [    1.357001] 000000c0: 000000c6 00001202 8000031f 00000008 00000007 00007f00 00000000 00000000
  587. [    1.357819] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  588. [    1.358637] 00000100: 00000300 00000505 00000140 00006404 00000083 00008581 00008320 00000141
  589. [    1.359456] 00000120: 00000181 00008181 00000141 00000141 00004141 00008343 00003185 00000500
  590. [    1.360274] 00000140: 0000010f 00000300 00004a87 00000103 00009381 00008387 00001103 00001087
  591. [    1.361093] 00000160: 00008247 00000187 00003143 000002dc 00000300 00000300 00000300 00000000
  592. [    1.361911] 00000180: 00006300 00000200 00000200 00000200 00000200 00000200 00003f3f 00000081
  593. [    1.362730] 000001a0: 00000000 00000000 00004141 00000421 00008700 000002dc 00000004 00000381
  594. [    1.363548] 000001c0: 00000381 00000001 00000003 00000087 00000087 00000141 00000141 00008181
  595. [    1.364367] 000001e0: 0000833f 00000007 00008f1f 00008f8f 00008f8f 00008787 00008787 00008787
  596. [    1.365185] 00000200: 000000c5 000000c5 00000000 00000000 00000000 00000000 00000000 00000000
  597. [    1.366003] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  598. [    1.366820] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  599. [    1.367638] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  600. [    1.368457] 00000280: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60
  601. [    1.369276] 000002a0: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 00000000 00000000 00000000 00000000
  602. [    1.370094] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  603. [    1.370912] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  604. [    1.371730] 00000300: 00000000 00000000 00000202 00000000 00000000 00000000 00000000 00000000
  605. [    1.372549] 00000320: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  606. [    1.373366] 00000340: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  607. [    1.374185] 00000360: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  608. [    1.375003] 00000380: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  609. [    1.375821] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  610. [    1.376637] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  611. [    1.377455] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  612. [    1.378273] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  613. [    1.379092] 00000420: 000000bc 00007070 00000000 00000014 00000000 00000000 00000000 00000000
  614. [    1.379909] 00000440: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  615. [    1.380728] 00000460: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  616. [    1.381546] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  617. [    1.382364] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  618. [    1.383182] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  619. [    1.384000] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  620. [    1.384819] 00000500: 00000000 00000000 00640064 00000000 00000003 00000001 00000000 00000000
  621. [    1.385637] 00000520: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  622. [    1.386455] 00000540: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  623. [    1.387274] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  624. [    1.388088] 00000580: 00000004 00000000 00000004 00000000 00000004
  625. [    1.388676] PMU CRU:
  626. [    1.388898] 00000000: 000000a9 00001203 80000000 00000108 00000007 00007f00 00000000 00000000
  627. [    1.389718] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  628. [    1.390538] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  629. [    1.391358] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  630. [    1.392178] 00000080: 0000800d 00001986 00000d0d 0000000d 000002dc 00000200 0bb8ea60 0bb8ea60
  631. [    1.392999] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  632. [    1.393819] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  633. [    1.394639] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  634. [    1.395460] 00000100: 00000000 00000000 00000000 00000000 00000024 00000000 00000000 00000000
  635. [    1.396276] 00000120: 00000000 00000180 00000000 00000000 00000003
  636. [    1.396866] Rebooting in 5 seconds..
Copy the code
Posted at 12/29/2017 09:50:15        Only Author  2#
Try the firmware newest.
Posted at 12/29/2017 19:22:51        Only Author  3#
I tried to use next android 7 firmware Firefly-RK3399_Android7.1.1_MP_170829.img but result is the same.
Posted at 1/8/2018 17:45:20        Only Author  4#
fpgamcu Posted at 12/29/2017 19:22
I tried to use next android 7 firmware Firefly-RK3399_Android7.1.1_MP_170829.img but result is the s ...
It maybe hardware problem
Posted at 5/24/2018 16:47:40        Only Author  5#
Have you solved this problem?
Posted at 1/8/2026 19:34:32        Only Author  6#
Your article was truly eye-catching and impressive, thank you! I used the Sample Media-Cloud-Consultant questions answers to get a promotion and raise. Now its free to all. Best wishes for your professional growth!
Posted at 1/10/2026 05:15:07        Only Author  7#
This article is a masterpiece, Im so grateful for your sharing. Enhance your IT skills with free New exam UiPath-ABAv1 materials. Best wishes for your exams!
Posted at 1/13/2026 02:13:07        Only Author  8#
VMware 2V0-11.25시험이 정말 어렵다는 말을 많이 들으신 만큼 저희 DumpTOP는VMware 2V0-11.25덤프만 있으면VMware 2V0-11.25시험이 정말 쉬워진다고 전해드리고 싶습니다. VMware 2V0-11.25덤프로 시험패스하고 자격증 한방에 따보세요. 자격증 많이 취득하면 더욱 여유롭게 직장생활을 즐길수 있습니다.
restricted members
Posted at 1/13/2026 07:48:55        Only Author  9#
I sincerely appreciate your share; the content of the article is truly astounding! Heres the New PMI-ACP dumps free exam that boosted my career with a promotion and salary increase. Its free today for all! Wishing you success in your career journey.
Posted at 2/13/2026 19:46:46        Only Author  10#
This article is absolutely inspiring, thank you for sharing! The Valid MC-202 exam questions exam is on the horizon. Wish me luck!
