Unstable network connection in Android Nougat because of TCP offload enabled
23
Posted at 2/20/2019 00:23:57      View9026 | Replies5        Print      Only Author   [Copy Link] 1#
Hello,
I think I'm experiencing similar networking problems as described here and other forums.
https://github.com/Fourdee/DietPi/issues/2028
It looks like different RK3399 devices are affected, for example: NanoPi M4, RockPro64, OrangePI and maybe others.
But what about Firefly-RK3399, is TCP offload enabled there, and if yes, how to disable it?
I think there is no ethtool available in Android Nougat, but maybe there is another way to disable it?
Thank you.
Arthur
vip
Rank: 6Rank: 6
Posted at 2/20/2019 17:42:43        Only Author  2#
Does this affect you in Android? Could you please tell us how to reproduce
the problem in Android?
Posted at 2/22/2019 18:39:39        Only Author  3#
Yes, this happens in Android 7.1.2. I'm using more than 15 pieces of RK3399 devices for different projects.
If I google for "RK3399 network error" or something like that, then I see that NanoPi M4, RockPro64 and OrangePI seem to have an issue which was solved by "ethtool -K eth0 rx off tx off".
I have already build "ethtool" for Android and used it to disable TCP offloading as described in the forums, but it didn't solve the issue.
If I knew, that Firefly-RK3399 with Android7/8 is NOT affected, then I would probably switch to Firefly-RK3399.
Description:
All devices (more than 15) are used 24/7. They are downloading small HTTP content every minute, usually below 100KB, but sometimes about 10 MB.
Usually several times a week one of the devices gets OFFLINE suddenly, sometimes for 5 min., sometimes for 30 min, somtimes for longer than 1h. If you sum all devices this happens nearly every day and sometimes several times a day.
In dmesg-Log I see, that the device switches from 100Mbit link speed to 10Mbit, and than back to 100Mbit. It is offline during this time.
Log:
  1. [1487388.081884] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 10Mbps/Half - flow control off
  2. # So, 17. Feb 2019 08:28:51
  3. [1488648.768330] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
  4. # So, 17. Feb 2019 23:14:46
  5. [1541803.160657] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 10Mbps/Full - flow control off
  6. # So, 17. Feb 2019 23:24:46
  7. [1542403.393871] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
Copy the code
At all switch ports these devices are connected to, I/O errors are logged in the port statistics. The error counter increases, when the device is offline. Other clients connected to the same CISCO 100Mbit switch are not affected.
May Firefly-RK3399 have the same issue?
vip
Rank: 6Rank: 6
Posted at 2/28/2019 14:57:49        Only Author  4#
Can you use iperf for android to reproduce this error?
Posted at 1/10/2026 06:55:29        Only Author  5#
Egal wie anziehend die Werbung ist, ist nicht so berzeugend wie Ihre eigene Erfahrung. Auf unserer Webseite können Sie die Demo der OMG OMG-OCEB2-FUND100 Prfungssoftware kostenlos herunterladen. Wir glauben, solange Sie diese Software, die vielen Leuten bei der OMG OMG-OCEB2-FUND100 geholfen hat, probiert haben, werden Sie diese Software sofort mögen. Benutzen Sie unsere Produkte! Sie können auch ein IT-Spezialist mit OMG OMG-OCEB2-FUND100 Prfungszeugnis werden!
Posted at 3/9/2026 07:30:31        Only Author  6#
Thank you for your powerful article, it made a deep impression. C-TS462-2023 valid test study guide offers free access to a wealth of helpful material, supporting your learning goals.
