[Android]Firefly RK3399's Freeze state on Booting !!
Posted at 6/22/2017 10:38:21
View6298
Replies5
Hi,
I confuse due to Rk3399's Freeze state on booting. (attached capure image file )
If anyone know it, please help me.
1. Our HW spec : ~ same Firefly reference components
RK3399, DDR( K4B8G1646D-MYK0_8Gb,1600)x4 ,Emmc(32GB), etc.
2. I tried other firefly other image file, but result's same condition !
_Firefly-RK3399_Android6.0_170409
_Firefly-RK3399_Android6.0.1_170515
_Firefly-RK3399_Android7.1.1_170516
3. Debug message ;
▒▒@@@` `@@@ `@` @`@H@`@p@`N@@B@ & 0`BB``@@b@8 pDDDDDD0 @@ B
" 00 0B@HbpbH@`@`@p``N@@B@ &00`BF`D@@b@8 pDDDDDD0 @
" $0 0B@Hbpb`H@`DN`H``N@@ &0DD0
@b`H@HN`p
" 0 0B@Hbpb`H@`DN`H``N@@ "0@F@b`@`H@HN`p`@p0 pDD0 d@`0 pDDDDDD0 @@$ b@p@0 p
" 0$ 0B@Hbpb`H@`DN`H``N@@ " 0 BH@HN`p`@p0 p @@ vHb0 pfDFDffC0 5db2 00 size: 0x1000)
[ 1.351609] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.351620] D1:camsys_platform_probe(1557): Probe ff910000.isp device success
[ 1.352815] D1:camsys_platform_probe(1399): compatible is rockchip,rk3399-isp
[ 1.352815]
[ 1.352832] E:camsys_soc_init(51): camsys_soc_init exit!
[ 1.352883] D1:camsys_mipiphy_probe_cb(205): ff920000.isp mipi phy0 probe success (reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.352883]
[ 1.352905iphy_probe_cb(205): ff920000.isp mipi phy1 probe success (reg_ph size: 0x0)
[ 1.352905]
[ 1.352954] D1:camsys_mipiphy_u_base=0xffffff800ae2e000
[ 1.352983] D1:camsys_mipiphy_probxffffff800b140000
[ 1.353536] D1:camsys_platform_probe(1527)y:
[ 1.353549] D1:camsys_platform_probe(1543): Register memir: 0xffffff800b120000 size: 0x10000)
amsys_init_ext_fsh_module(20): init external flash modulexffffffc005dcd000 size: 0x1000)
[ latform_probe(1557): Probe ff920000.isp device success
[ 1.ly_register: Expected proper parent device for 'test_ac'
[ 1_register: Expected proper parent device for 'test_battery'
[ ermal_zone2: power_allocator: sustainable_power will be estimateer_supply_register: Expected proper parent device for 'test_usb'v8_dvp: supplied by vcc3v3_sys
[ 1.355157] vcca1v8_codec: su
[ 1.355254] vcc_sd: supplied by vcc3v3_sys
[ 1.355348] vcc3v3_sys
[ 1.356626] rk_tsadcv2_temp_to_code: Invalid conve3, temperature=2147483647
[ 1.357162] device-mapper: uevent:57434] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialism
[ 1.357548] Bluetooth: HCI UART driver ver 2.3
[ 1.357RT protocol H4 registered
[ 1.357571] Bluetooth: HCI UART pr[ 1.357987] vdd_cpu_l: supplied by vcc3v3_sys
[ 1.358951]y vcc5v0_sys
[ 1.360473] sdhci: Secure Digital Host Controll[ 1.360486] sdhci: Copyright(c) Pierre Ossman
[ 1.360499]Multimedia Card Interface Driver
[ 1.361291] dwmmc_rockchip supports 32-bit address mode.
[ 1.361374] dwmmc_rockchip fe3ternal DMA controller.
[ 1.361395] dwmmc_rockchip fe310000.d
[ 1.361449] dwmmc_rockchip fe310000.dwmmc: DW MMC controllest data width,256 deep fifo
[ 1.361516] dwmmc_rockchip fe310gulator found
[ 1.361528] dwmmc_rockchip fe310000.dwmmc: No [ 1.362279] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32- 1.362329] dwmmc_rockchip fe320000.dwmmc: Using internal DMA c dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.3623820000.dwmmc: DW MMC controller at irq 26,32 bit host data width,.362493] dwmmc_rockchip fe320000.dwmmc: No vmmc regulatop-iodomain io-domains: Setting to 3300000 done
[ 1.362868] rmains: Setting to 3300000 done
[ 1.378114] mmc_host mmc0: Bu0000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.395082] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.395364] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.397014] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.397034] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.430034] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.431033] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.436213] usbcore: registered new interface driver usbhid
[ 1.436250] usbhid: USB HID core driver
[ 1.436357] inv_mpu_iio: inv_mpu_init:747
[ 1.437107] ashmem: initialized
[ 1.438502] ff100000.saradc supply vref not found, using dummy regulator
[ 1.440070] rknandbase v1.1 2016-01-08
[ 1.440589] usbcore: registered new interface driver snd-usb-audio
[ 1.456575] u32 classifier
[ 1.456592] Actions configured
[ 1.456646] Netfilter messages via NETLINK v0.30.
[ 1.456714] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.457081] ctnetlink v0.93: registering with nfnetlink.
[ 1.457808] xt_time: kernel timezone is -0000
[ 1.458821] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.458970] arp_tables: (C) 2002 David S. Miller
[ 1.459470] Initializing XFRM netlink socket
[ 1.459930] NET: Registered protocol family 10
[ 1.460793] mip6: Mobile IPv6
[ 1.460830] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.462327] sit: IPv6 over IPv4 tunneling driver
[ 1.462798] NET: Registered protocol family 17
[ 1.462831] NET: Registered protocol family 15
[ 1.462876] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.463929] Bridge firewalling registered
[ 1.463944] Ebtables v2.0 registered
[ 1.464152] Bluetooth: RFCOMM TTY layer initialized
[ 1.464168] Bluetooth: RFCOMM socket layer initialized
[ 1.464195] Bluetooth: RFCOMM ver 1.11
[ 1.464217] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.464227] Bluetooth: BNEP filters: protocol multicast
[ 1.464242] Bluetooth: BNEP socket layer initialized
[ 1.464257] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.464271] Bluetooth: HIDP socket layer initialized
[ 1.464305] l2tp_core: L2TP core 464326] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.464342] [kill_wlan_init
ILL]: wlan_platdata_parse_dt: enable wifi power control.KILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 1]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3,64777] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.46478 rfkill_wlan_probe
[ 1.464842] [BT_RFKILL]: Enter rfkill_rk_T_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_g [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,rese5233] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT 1.465263] [BT_RFKILL]: bluetooth_platdata_parse_dt: get propert
[ 1.465592] [BT_RFKILL]: Request irq for bt wakeup host
[ L]: ** disable irq
[ 1.465771] [BT_RFKILL]: bt_default devic.465920] sensor_register_slave:mpu6880_gyro,id=47
[ 1.466444setend emulation handler
[ 1.466640] schedtune: init normali 1.466655] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr:] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ PU[1] min_pwr: 0 max_pwr: 222
[ 1.466693] s min_pwr: 0 max_pwr: 222
[ 1.466704] schedtune: Cpwr: 0 max_pwr: 222
[ 1.466716] schedtune: CLUSTER[4-5ax_pwr: 1108
[ 1.466727] schedtune: CPU[4] min_p108
[ 1.466738] schedtune: CPU[5] min_pwr: 0 1.466749] schedtune: SYSTEM min_pwr: 121 max_pwr: edtune: using normalization constants mul: 3862781856 sh1: 1 sh2schedtune: verify normalization constants...
[ 1.466781] sch4313 => norm_pwr: 1024
[ 1.466792] schedtune: max_pwr/2^1:
tune: max_pwr/2^3: 539 => norm_pwr: 127 1.466801] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 1.466820] sched9 => norm_pwr: 63
[ 1.466830] schedtune: max_pwr/2^5: 13 1.467664] registered taskstats version 1
[ 1.470930] Fre4K (ffffffc0f5c00000 - ffffffc0f6c00000)
[ 1.472083] mmc1: Mot set
[ 1.473982] vdd_gpu: supplied by vcc5v0_sys
[ 1.4ied as 0x0860 r2p0 status 0
[ 1.483914] mmc1: new HS400 Enha address 0001
[ 1.484151] I : [File] : drivers/gpu/arm/midgabase_devfreq.c; [Line] : 265; [Func] : kbase_devfreq_init(); sucel_simple.
[ 1.484767] mali ff9a0000.gpu: Probed as mali0
[1: mmc1:0001 BJNB4R 29.1 GiB
[ 1.486618] mmcblk1boot0: mmc14.00 MiB
[ 1.488316] xhci-hcd xhci-hcd.2.auto: xHCI Host Con] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus644] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version
[ 1.488714] xhci-hcd xhci-hcd.2.auto: irq 232, io mem 0xfe8usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ duct: xHCI Host Controller
[ 1.488942] usb usb5: Manufactured
[ 1.488957] usb usb5: SerialNumber: xhci-hcd.2.auto
[ USB hub found
[ 1.489626] hub 5-0:1.0: 1 port detected
[ hcd.2.auto: xHCI Host Controller
[ 1.490023] xhci-hcd xhci-h registered, assigned bus number 6
[ 1.490104] usb usb6: We hms for LPM for this host, disabling LPM.
[ 1.490218] usb usd, idVendor=1d6b, idProduct=0003
[ 1.490238] usb usb6: New U3, Product=2, SerialNumber=1
[ 1.490255] usb usb6: Product: [ 1.490270] usb usb6: Manufacturer: Linux 4.4.16 xhci-hcd
[ erialNumber: xhci-hcd.2.auto
[ 1.490887] mmcblk1boot1: mmc1:2 4.00 MiB
[ 1.491003] hub 6-0:1.0: USB hub found
[ 1.49rt detected
[ 1.493226] xhci-hcd xhci-hcd.2.auto: remove, stusb usb6: USB disconnect, device number 1
[ 1.495140] mmcblkR partition 3 4.00 MiB
[ 1.495619] parameter: 0x000000000 - 1.495638] uboot: 0x000400000 -- 0x000800000 (4 MB)
[ 0x000800000 -- 0x000c00000 (4 MB)
[ 1.495668] misc: 0x00 (4 MB)
[ 1.495682] resource: 0x001000000 -- 0x0020000006] kernel: 0x002000000 -- 0x003400000 (20 MB)
[ 1.4957103400000 -- 0x005400000 (32 MB)
[ 1.495724] recovery: 0x005000 (32 MB)
[ 1.495738] backup: 0x007400000 -- 0x00e400095753] cache: 0x00e400000 -- 0x016400000 (128 MB)
[ 1.416400000 -- 0x056400000 (1024 MB)
[ 1.495782] metadata: 0x000 (16 MB)
[ 1.495795] baseparamer: 0x057400000 -- 0x05780009] userdata: 0x057800000 -- 0x747800000 (28416 MB)
[ 1.49 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 1.517270] xhci-hcd xhci-hcd.2.auto: Host not halted after 16000 microseconds.
[ 1.517302] xhci-hcd xhci-hcd.2.auto: Host controller not halted, aborting reset.
[ 1.517655] xhci-hcd xhci-hcd.2.auto: USB bus 6 deregistered
[ 1.517677] xhci-hcd xhci-hcd.2.auto: remove, state 1
[ 1.517706] usb usb5: USB disconnect, device number 1
[ 1.518445] xhci-hcd xhci-hcd.2.auto: USB bus 5 deregistered
[ 1.519056] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.519090] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 1.519401] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 1.569990] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1.582006] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.582261] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.582293] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.582320] usb usb5: Product: EHCI Host Controller
[ 1.582342] usb usb5: Manufacturer: Linux 4.4.16 ehci_hcd
[ 1.582363] usb usb5: SerialNumber: fe380000.usb
[ 1.583314] hub 5-0:1.0: USB hub found
[ 1.583386] hub 5-0:1.0: 1 port detected
[ 1.584584] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.584636] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 1.584878] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 1.642321] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.642363] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.642391] usb usb6: Product: Generic Platform OHCI controller
[ 1.642415] usb usb6: Manufacturer: Linux 4.4.16 ohci_hcd
[ 1.642436] usb usb6: SerialNumber: fe3a0000.usb
[ 1.643482] hub 6-0:1.0: USB hub found
[ 1.643548] hub 6-0:1.0: 1 port detected
[ 1.645265] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.645381] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.645417] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.645471] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.645565] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.645589] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.646090] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.662143] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.678185] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 1.679800] asoc-simple-card hdmi-sound: dw-hdmi-hifi <-> ff8a0000.i2s mapping ok
[ 1.696814] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mapping ok
[ 1.702132] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 1.705341] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input1
[ 1.709260] asoc-simple-card spdif-sound: dit-hifi <-> ff870000.spdif mapping ok
[ 1.711881] otg_wakelock_init: No USB transceiver found
[ 1.711964] dhd_module_init: in
[ 1.712001] ======== bcm_wlan_set_plat_data ========
[ 1.712023] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.712045] host_oob_irq: 62
[ 1.712062] host_oob_irq_flags=0x4
[ 1.712072] sensor_init: Probe name sensors
[ 1.712086] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 1.712107] dhd_wifi_platform_load: Enter
[ 1.712150] Power-up adapter 'DHD generic adapter'
[ 1.712220] wifi_platform_set_power = 1
[ 1.712237] ======== PULL WL_REG_ON HIGH! ========
[ 1.712256] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.712275] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.713379] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:03 UTC (1358499003)
[ 1.723233] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.723276] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.723314] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 1.724342] hub 1-1:1.0: USB hub found
[ 1.724604] hub 1-1:1.0: 7 ports detected
u▒ 1.740839]
[ 1.746007] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
