I'm currently running Ubuntu 14.04 and have Firefly connected to my home network via 802.11n (2.4Ghz).
With "Firefly-RK3288_Server_Ubuntu14.04_201501271052" I'm seeing 300 kB/s - 1 MB/s.
Other devices in the same room get fairly good bandwidth and reception whereas I'm seeing about 1 MB/s with Firefly. I've also noticed poor WiFi performance in Android as well with the "Firefly-RK3288_Android4.4_201501271047.img".
Here's iwconfig. I turned off power management and the signal seems strong. - wlan0 IEEE 802.11 ESSID:"ESSID"
- Mode:Master Frequency:2.437 GHz Access Point: XX:XX:XX:XX:XX:XX
- Bit Rate:39 Mb/s Tx-Power:32 dBm
- Retry min limit:7 RTS thr:off Fragment thr:off
- Encryption key:off
- Power Managementmode:off
- Link Quality=4/5 Signal level=-67 dBm Noise level=-92 dBm
- Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
- Tx excessive retries:0 Invalid misc:0 Missed beacon:0
Copy the code
Using the "Firefly-RK3288_Ubuntu14.04_201501271612.img" image:
- Mode:Master Frequency:2.437 GHz Access Point: XX:XX:XXX:XX:XX:XX
- Bit Rate:72 Mb/s Tx-Power:32 dBm
- Power Management:off
- Link Quality=5/5 Signal level=-57 dBm Noise level=-91 dBm
Copy the code
Speed test: ![]()
On a Macbook Pro in the same room: ![]()
I will test with the latest Android image and update again. |
