New Topic
rkisp1: MIPI mis error
62
Posted at 11/20/2019 23:57:04      View18562 | Replies10        Print      Only Author   [Copy Link] 1#
Hi I'm using a custom MIPI Adapter board in Firefly AIO3399J board running Android 8.1 . I'm facing MIPI mis error and its causing issues with the camera streaming.
The following MIPI mis errors are occuring at different instances.
rkisp1: MIPI mis error: 0x00000004
rkisp1: MIPI mis error: 0x00000006
rkisp1: MIPI mis error: 0x00000001
rkisp1: MIPI mis error: 0x00000300
How to diagonise these errors ? Can you help us find what each of this MIPI mis error means ?
Thanks,
Arvind
vip
Rank: 6Rank: 6
Posted at 11/27/2019 17:31:27        Only Author  2#
See kernel/drivers/media/platform/rockchip/isp1/regs.h
and rkisp1_mipi_isr() in kernel/drivers/media/platform/rockchip/isp1/rkisp1.c
Posted at 12/4/2019 21:38:18        Only Author  3#
Yes, I have seen them but knowing which  registers  are set , do not offer much information on the exact reasons for the issue. Can you share the RK3399 MIPI CSI2 datasheet so we can find what these registers are and why they are set.
Right now the registers that are set for my issue  seems to be
CIF_MIPI_SYNC_FIFO_OVFLW for the MIPI mis error 0x00000006 , 0x00000004 and 0x00000001
CIF_MIPI_ERR_SOT_SYNC for the MIPI mis error 0x00000300
If you can tell me what these registers are and in which cases they are set , it would be really helpful.
Thank you for your time ,
Regards,
Arvind
vip
Rank: 6Rank: 6
Posted at 12/12/2019 17:55:07        Only Author  4#
I haven't those register datasheet neither. This is a trial and error process.
Please make sure the frame format is correctly set.
Posted at 12/2/2020 12:11:53        Only Author  5#
penguin Posted at 12/12/2019 17:55
Please make sure the ...
hi buddy ,have you resolved?  i met the problem same as  yours
Posted at 1/15/2026 06:34:59        Only Author  6#
Was Wir Ihnen bieten sind, die neuesten und die umfassendesten Test-Bank von CompTIA 220-1202, die risikolose Kaufgarantie und die rechtzeitige Aktualisierung der CompTIA 220-1202. Sie werden sich beim Kauf unbesorgt fhlen, indem Sie die Demo unserer Software kostenlos zu probieren. Die einjährige kostenfreie Aktualisierung der CompTIA 220-1202 erleichtern Ihre Sorgen bei der Prfungsvorbereitung. Was wir am meisten garantieren ist, dass unsere Software vielen Prfungsteilnehmern bei der Zertifizierung der CompTIA 220-1202 geholfen hat.
Posted at 1/17/2026 12:19:21        Only Author  7#
No second guesses, this content gets my like. The Exam PEGACPBA24V1 Questions material is outstanding, and its free for you to use.
Posted at 1/24/2026 06:57:11        Only Author  8#
hΤMogiExamˤ륳Х`ǤȫƤIIBACPOACertificate in Product Ownership Analysis (IIBA-CPOA)ԇYϷdz˴ФǤg٤˰kչƤrˡMogiExamϤФһĤǤǤϤʤۤȤɤˡMogiExamxΤǤMogiExamṩ놖}YϤϽ~ʤԇYܤ뤳Ȥ뤫ǤMogiExamṩYϤ¤Υȥ`˥󥰥ĩ`뤬˥åץǩ`ȤJ^ԇYĿˤQνYǤMogiExam Ϥʤ¤ԇYоYϤṩޤ顢MogiExam IIBACPOA}֤äƤ顢ԇYֱ椹Ť˜뤳ȤǤϸ񤷤ʤʤȫȻ䤹뤳ȤϤʤݘSԇYܤ뤳ȤǤޤ
Posted at 2/6/2026 06:07:31        Only Author  9#
Im so grateful for your article, it truly grabbed my attention. PDF C-S4CS-2508 Download exam papers are free for everyone! Best of luck on your exams!
Posted at 2/6/2026 15:05:19        Only Author  10#
I am so grateful for your share, this article is truly impressive! Get the Valid exam CKYCA sample online questions that helped me succeed in my careerfor free today!
Return to List
12
