New Topic
NCC chip not recognised
75
Posted at 1/17/2019 11:11:57      View9529 | Replies16        Print      Only Author   [Copy Link] 1#
Hi
We have the NCC S1 card in the ROC-RK3399-PC, we have installed the SD card ubuntu image which was on the USB stick. But we cannot see the card in linux, there is no sg driver in the image
We tried..
cat /lib/modules/$(uname -r)/modules.builtin | grep sg.ko
and there are no kernel modules
There is also  no /dev/sgxxx device like the user manual suggests
How do we get it going?
Posted at 1/17/2019 16:37:33        Only Author  2#
Hi, can you see the /dev/mmcblk1 device? If you use the NCC S1 instead of USB Dongle, please use the device node.
Posted at 1/18/2019 07:58:53        Only Author  3#
OK thanks.
I noticed there is only a "lite" version for Arm, and a full cnn version for x86. It the chip limited in some way (for inference) on the ROC-RK3399-PC board?
Posted at 1/18/2019 10:25:19        Only Author  4#
no. you can try port the code for x86 to ROC-RK3399-PC.
Posted at 1/18/2019 10:49:00        Only Author  5#
OK thanks. So there are no limitations on models we can train and run on ARM?
Posted at 1/18/2019 14:24:43        Only Author  6#
You can train models via PLAI on PC and use the model on both x86 and arm.
Posted at 3/25/2019 15:05:46        Only Author  7#
I have same issue. It shows me like..
- 1553493688322 -547784052736- 2-:GTI SDK 4.0.0.rc-1  built on: Jan 25 2019
- 1553493688337 -547784052736- 2-:found deviceIRECT_EMMC_dev_mmcblk1
- 1553493688358 -547784052736- 2-:create Chip2801
MMC_WRITE_MULTIPLE_BLOCK ioctl failed err = -1
- 1553493688381 -547784052736- 0-:Could not load model. Device:/dev/mmcblk1----emmc_write error
- 1553493688381 -547784052736- 0-:could not load model
- 1553493688515 -547784052736- 0-:GtiCnn transform error
Segmentation fault
How can I solve it?
vip
Rank: 6Rank: 6
Posted at 3/25/2019 16:30:49        Only Author  8#
Hi @mj07
Would you post the kernel log?
Posted at 3/25/2019 17:15:00        Only Author  9#
penguin Posted at 3/25/2019 16:30
Hi @mj07
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.154 (daijh@tchip14) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #136 SMP Sun Jan 27 09:49:23 CST 2019
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[    0.000000] bootconsole [uart0] enabled
[    0.000000] On node 0 totalpages: 1007616
[    0.000000]   DMA zone: 15864 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 1007616 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ed0000 s46120 r8192 d31704 u86016
[    0.000000] pcpu-alloc: s46120 r8192 d31704 u86016 alloc=21*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 991752
[    0.000000] Kernel command line: sdfwupdate storagemedia=sd androidboot.mode=sd androidboot.slot_suffix= androidboot.serialno=3cd4fd008755aa77  rw rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 systemd.gpt_auto=0
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB [mem 0xf7e87000-0xf7ec7000] (0MB) mapped at [ffffffc0f7e87000-ffffffc0f7ec6fff]
[    0.000000] Memory: 3936004K/4030464K available (12094K kernel code, 1736K rwdata, 4664K rodata, 1152K init, 766K bss, 94460K reserved, 0K cma-reserved)
[    0.000000] Virtual kernel memory layout:
                   modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
                   vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
                     .init : 0xffffff80090f0000 - 0xffffff8009210000   (  1152 KB)
                     .text : 0xffffff8008080000 - 0xffffff8008c50000   ( 12096 KB)
                   .rodata : 0xffffff8008c50000 - 0xffffff80090f0000   (  4736 KB)
                     .data : 0xffffff8009210000 - 0xffffff80093c2008   (  1737 KB)
                   vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
                             0xffffffbdc0008000 - 0xffffffbdc3e00000   (    61 MB actual)
                   fixed   : 0xffffffbffe7fb000 - 0xffffffbffec00000   (  4116 KB)
                   PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
                   memory  : 0xffffffc000200000 - 0xffffffc0f8000000   (  3966 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]         Build-time adjustment of leaf fanout to 64.
[    0.000000]         RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[    0.000000] ITS: allocated 65536 Devices @a300000 (psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x000000000a290000
[    0.000000] ITS: Allocated 1792 chunks for LPIs
[    0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] CPU0: using LPI pending table @0x000000000a2a0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] rockchip_mmc_get_phase: invalid clk rate
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[    0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.002205] Console: colour dummy device 80x25
[    0.002648] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[    0.003637] pid_max: default: 32768 minimum: 301
[    0.004164] Security Framework initialized
[    0.004630] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.005271] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.006733] Initializing cgroup subsys devices
[    0.007184] Initializing cgroup subsys freezer
[    0.007628] ftrace: allocating 43948 entries in 172 pages
[    0.117031] sched-energy: Sched-energy-costs installed from DT
[    0.117598] CPU0: update cpu_capacity 401
[    0.118041] ASID allocator initialised with 32768 entries
[    0.121754] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.123117] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.125380] Detected VIPT I-cache on CPU1
[    0.125413] CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.125442] CPU1: using LPI pending table @0x0000000000330000
[    0.125485] CPU1: update cpu_capacity 401
[    0.125489] CPU1: Booted secondary processor [410fd034]
[    0.126032] Detected VIPT I-cache on CPU2
[    0.126052] CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.126080] CPU2: using LPI pending table @0x0000000000360000
[    0.126106] CPU2: update cpu_capacity 401
[    0.126109] CPU2: Booted secondary processor [410fd034]
[    0.126627] Detected VIPT I-cache on CPU3
[    0.126648] CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.126675] CPU3: using LPI pending table @0x00000000003b0000
[    0.126701] CPU3: update cpu_capacity 401
[    0.126705] CPU3: Booted secondary processor [410fd034]
[    0.127252] Detected PIPT I-cache on CPU4
[    0.127278] CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.127318] CPU4: using LPI pending table @0x00000000003e0000
[    0.127356] CPU4: update cpu_capacity 1024
[    0.127360] CPU4: Booted secondary processor [410fd082]
[    0.127908] Detected PIPT I-cache on CPU5
[    0.127927] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.127963] CPU5: using LPI pending table @0x00000000f2c10000
[    0.127988] CPU5: update cpu_capacity 1024
[    0.127991] CPU5: Booted secondary processor [410fd082]
[    0.128090] Brought up 6 CPUs
[    0.140442] SMP: Total of 6 processors activated.
[    0.140893] CPU features: detected feature: GIC system register CPU interface
[    0.141586] CPU: All CPU(s) started at EL2
[    0.142018] alternatives: patching kernel code
[    0.143837] devtmpfs: initialized
[    0.161420] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.162354] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.163422] pinctrl core: initialized pinctrl subsystem
[    0.164130] regulator-dummy: no parameters
[    0.164704] NET: Registered protocol family 16
[    0.170411] cpuidle: using governor ladder
[    0.174418] cpuidle: using governor menu
[    0.174808] Registered FIQ tty driver
[    0.175550] vdso: 2 pages (1 code @ ffffff8008c56000, 1 data @ ffffff8009214000)
[    0.176261] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.177057] DMA: preallocated 256 KiB pool for atomic allocations
[    0.192137] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[    0.192214] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[    0.192289] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[    0.192364] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[    0.192439] gpiochip_add_data: registered GPIOs 128 to 159 on device: gpio4
[    0.200860] console [ttyFIQ0] enabled
[    0.201543] bootconsole [uart0] disabled
[    0.202437] Registered fiq debugger ttyFIQ0
[    0.231717] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc3v3-sys[0]'
[    0.231741] vcc3v3_sys: 3300 mV
[    0.231907] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[    0.232142] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc5v0-host-regulator[0]' - status (0)
[    0.232190] vcc5v0_host: no parameters
[    0.232351] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[    0.232477] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc_hub_en-regulator[0]' - status (0)
[    0.232514] vcc_hub_en: no parameters
[    0.232658] reg-fixed-voltage vcc_hub_en-regulator: vcc_hub_en supplying 0uV
[    0.232783] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-dis-en[0]' - status (0)
[    0.232823] vcc_dis_en: no parameters
[    0.232985] reg-fixed-voltage vcc-dis-en: vcc_dis_en supplying 0uV
[    0.233127] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-sd[0]' - status (0)
[    0.233161] vcc_sd: 3300 mV
[    0.233311] reg-fixed-voltage vcc-sd: vcc_sd supplying 3300000uV
[    0.233364] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc5v0-sys[0]'
[    0.233385] vcc5v0_sys: 5000 mV
[    0.233536] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[    0.233585] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[    0.233600] vcc_phy: no parameters
[    0.233743] reg-fixed-voltage vcc-phy-regulator: vcc_phy supplying 0uV
[    0.233866] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-lcd-regulator[0]' - status (0)
[    0.233905] vcc_lcd: no parameters
[    0.234075] reg-fixed-voltage vcc-lcd-regulator: vcc_lcd supplying 0uV
[    0.234614] iommu: Adding device ff650000.vpu_service to group 0
[    0.235235] iommu: Adding device ff660000.rkvdec to group 1
[    0.235818] iommu: Adding device ff8f0000.vop to group 2
[    0.236368] iommu: Adding device ff900000.vop to group 3
[    0.238163] SCSI subsystem initialized
[    0.238676] libata version 3.00 loaded.
[    0.238850] usbcore: registered new interface driver usbfs
[    0.239380] usbcore: registered new interface driver hub
[    0.239936] usbcore: registered new device driver usb
[    0.240441] media: Linux media interface: v0.10
[    0.240879] Linux video capture interface: v2.00
[    0.241332] pps_core: LinuxPPS API ver. 1 registered
[    0.241776] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.242603] PTP clock support registered
[    0.243996] Advanced Linux Sound Architecture Driver Initialized.
[    0.245014] Bluetooth: Core ver 2.21
[    0.245352] NET: Registered protocol family 31
[    0.245760] Bluetooth: HCI device and connection manager initialized
[    0.246326] Bluetooth: HCI socket layer initialized
[    0.246769] Bluetooth: L2CAP socket layer initialized
[    0.247231] Bluetooth: SCO socket layer initialized
[    0.248292] rockchip-cpuinfo cpuinfo: Serial                : 3cd4fd008755aa77
[    0.249468] clocksource: Switched to clocksource arch_sys_counter
[    0.299402] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    0.300325] NET: Registered protocol family 2
[    0.301146] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.302057] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[    0.303561] TCP: Hash tables configured (established 32768 bind 32768)
[    0.304245] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[    0.304963] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[    0.305948] NET: Registered protocol family 1
[    0.306650] RPC: Registered named UNIX socket transport module.
[    0.307176] RPC: Registered udp transport module.
[    0.307615] RPC: Registered tcp transport module.
[    0.308036] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.308627] PCI: CLS 0 bytes, default 64
[    0.309757] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.310577] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.314435] Initialise system trusted keyring
[    0.322882] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.324184] NFS: Registering the id_resolver key type
[    0.324669] Key type id_resolver registered
[    0.325045] Key type id_legacy registered
[    0.325469] fuse init (API version 7.23)
[    0.326200] SGI XFS with security attributes, no debug enabled
[    0.331479] NET: Registered protocol family 38
[    0.331902] Key type asymmetric registered
[    0.332272] Asymmetric key parser 'x509' registered
[    0.332920] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.333594] io scheduler noop registered
[    0.333953] io scheduler deadline registered
[    0.334471] io scheduler cfq registered (default)
[    0.336496] phy phy-ff770000.syscon:phy@f780.0: Looking up phy-supply from device tree
[    0.336508] phy phy-ff770000.syscon:phy@f780.0: Looking up phy-supply property in node /syscon@ff770000/phy@f780 failed
[    0.337996] phy phy-pcie-phy.1: Looking up phy-supply from device tree
[    0.338008] phy phy-pcie-phy.1: Looking up phy-supply property in node /pcie-phy failed
[    0.339955] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[    0.339965] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[    0.339994] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[    0.340236] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[    0.340247] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply property in node /pcie@f8000000 failed
[    0.340262] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    0.340843] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree
[    0.340853] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed
[    0.340865] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    0.341426] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree
[    0.341435] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed
[    0.341446] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    0.883530] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    0.884251] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    0.885548] pwm-backlight backlight: GPIO lookup for consumer enable
[    0.885560] pwm-backlight backlight: using device tree for GPIO lookup
[    0.885573] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
[    0.885584] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
[    0.885595] pwm-backlight backlight: using lookup tables for GPIO lookup
[    0.885606] pwm-backlight backlight: lookup for GPIO enable failed
[    0.885621] pwm-backlight backlight: Looking up power-supply from device tree
[    0.885633] pwm-backlight backlight: Looking up power-supply property in node /backlight failed
[    0.885656] backlight supply power not found, using dummy regulator
[    0.886996] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply from device tree
[    0.887011] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply property in node /vpu_service@ff650000 failed
[    0.887028] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[    0.887974] rk-vcodec ff650000.vpu_service: probe device
[    0.888756] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[    0.890100] rk-vcodec ff650000.vpu_service: could not find power_model node
[    0.890738] rk-vcodec ff650000.vpu_service: init success
[    0.891598] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply from device tree
[    0.891613] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply property in node /rkvdec@ff660000 failed
[    0.891632] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[    0.892662] rk-vcodec ff660000.rkvdec: probe device
[    0.893311] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[    0.894286] rk-vcodec ff660000.rkvdec: could not find power_model node
[    0.894877] rk-vcodec ff660000.rkvdec: init success
[    0.896743] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.897413] dma-pl330 ff6d0000.dma-controller:         DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    0.899718] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.900387] dma-pl330 ff6e0000.dma-controller:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    0.901578] pwm-regulator vdd-log: GPIO lookup for consumer enable
[    0.901587] pwm-regulator vdd-log: using device tree for GPIO lookup
[    0.901597] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log[0]'
[    0.901606] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log[0]'
[    0.901614] pwm-regulator vdd-log: using lookup tables for GPIO lookup
[    0.901622] pwm-regulator vdd-log: lookup for GPIO enable failed
[    0.901662] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    0.901672] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    0.901692] vdd_log: 800 <--> 1100 mV at 998 mV
[    0.901864] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    0.901875] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    0.901920] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    0.901929] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    0.902294] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[    0.904537] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[    0.905621] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-debugger; cannot claim for ff1a0000.serial
[    0.906574] rockchip-pinctrl pinctrl: pin-147 (ff1a0000.serial) status -22
[    0.907183] rockchip-pinctrl pinctrl: could not request pin 147 (gpio4-19) from group uart2c-xfer  on device rockchip-pinctrl
[    0.908182] dw-apb-uart ff1a0000.serial: Error applying setting, reverse things back
[    0.909167] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud = 1500000) is a 16550A
[    0.910965] [drm] Initialized drm 1.1.0 20060810
[    0.914597] [drm] Rockchip DRM driver version: v1.0.1
[    0.916845] mali ff9a0000.gpu: Looking up mali-supply from device tree
[    0.916866] mali ff9a0000.gpu: Failed to get regulator
[    0.917323] mali ff9a0000.gpu: Power control initialization failed
[    0.918207] Unable to detect cache hierarchy for CPU 0
[    0.919425] brd: module loaded
[    0.924867] loop: module loaded
[    0.925712] zram: Added device: zram0
[    0.926317] lkdtm: No crash points registered, enable through debugfs
[    0.928269] register spi return v = :0
[    0.929516] rk_gmac-dwmac fe300000.ethernet: Looking up phy-supply from device tree
[    0.929602] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    0.930224] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    0.930741] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[    0.931259] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    0.931980] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[    0.932608] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    0.938152] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    0.938761] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    0.939205]  Ring mode enabled
[    0.939486]  DMA HW capability register supported
[    0.939883]  Normal descriptors
[    0.940189]  RX Checksum Offload Engine supported (type 2)
[    0.940684]  TX Checksum insertion supported
[    0.941059]  Wake-Up On Lan supported
[    0.941422]  Enable RX Mitigation via HW Watchdog Timer
[    0.942004] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@fe300000[0]' - status (0)
[    1.006781] libphy: stmmac: probed
[    1.007090] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[    1.007671] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[    1.009351] usbcore: registered new interface driver rtl8192cu
[    1.009958] usbcore: registered new interface driver rndis_wlan
[    1.010776] usbcore: registered new interface driver mt7601u
[    1.011357] Rockchip WiFi SYS interface (V1.00) ...
[    1.011907] usbcore: registered new interface driver rtl8150
[    1.012470] usbcore: registered new interface driver r8152
[    1.013016] usbcore: registered new interface driver asix
[    1.013552] usbcore: registered new interface driver ax88179_178a
[    1.014130] usbcore: registered new interface driver cdc_ether
[    1.014701] usbcore: registered new interface driver rndis_host
[    1.015307] usbcore: registered new interface driver cdc_ncm
[    1.015865] usbcore: registered new interface driver qmi_wwan
[    1.016419] usbcore: registered new interface driver cdc_mbim
[    1.018891] rockchip-dwc3 usb0: failed to get drvdata dwc3
[    1.020844] rockchip-dwc3 usb1: failed to get drvdata dwc3
[    1.022298] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.022897] ehci-pci: EHCI PCI platform driver
[    1.023342] ehci-platform: EHCI generic platform driver
[    1.024438] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.025011] ohci-platform: OHCI generic platform driver
[    1.026347] usbcore: registered new interface driver cdc_acm
[    1.026862] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.027604] usbcore: registered new interface driver cdc_wdm
[    1.028137] usbcore: registered new interface driver uas
[    1.028671] usbcore: registered new interface driver usb-storage
[    1.029266] usbcore: registered new interface driver usbserial
[    1.029817] usbcore: registered new interface driver usbserial_generic
[    1.030412] usbserial: USB Serial support registered for generic
[    1.030989] usbcore: registered new interface driver cp210x
[    1.031516] usbserial: USB Serial support registered for cp210x
[    1.032070] usbcore: registered new interface driver ftdi_sio
[    1.032615] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.033285] usbcore: registered new interface driver keyspan
[    1.033819] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    1.034537] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    1.035197] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    1.035867] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    1.036551] usbcore: registered new interface driver option
[    1.037061] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.037719] usbcore: registered new interface driver oti6858
[    1.038241] usbserial: USB Serial support registered for oti6858
[    1.038815] usbcore: registered new interface driver pl2303
[    1.039325] usbserial: USB Serial support registered for pl2303
[    1.039889] usbcore: registered new interface driver qcserial
[    1.040426] usbserial: USB Serial support registered for Qualcomm USB modem
[    1.041083] usbcore: registered new interface driver sierra
[    1.041604] usbserial: USB Serial support registered for Sierra USB modem
[    1.042879] ==gsl_ts_init==
[    1.043147] ret=0
[    1.043563] usbcore: registered new interface driver usbtouchscreen
[    1.044306] sensor_register_slave:mma8452,id=17
[    1.044727] sensor_register_slave:lis3dh,id=7
[    1.045118] sensor_register_slave:mma7660,id=18
[    1.045530] sensor_register_slave:lsm303d,id=22
[    1.045932] sensor_register_slave:gs_mc3230,id=23
[    1.046352] [Gsensor]   gsensor_init
[    1.046682] sensor_register_slave:mpu6880_acc,id=24
[    1.047119] sensor_register_slave:mpu6500_acc,id=25
[    1.047564] sensor_register_slave:lsm330_acc,id=26
[    1.047989] sensor_register_slave:akm8975,id=30
[    1.048391] sensor_register_slave:akm8963,id=31
[    1.048803] sensor_register_slave:l3g4200d,id=45
[    1.049216] sensor_register_slave:l3g20d,id=46
[    1.049626] sensor_register_slave:ewtsa,id=47
[    1.050016] sensor_register_slave:lsm330_gyro,id=51
[    1.050452] sensor_register_slave:cm3217,id=53
[    1.050863] sensor_register_slave:cm3218,id=54
[    1.051665] i2c /dev entries driver
[    1.053162] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    1.053801] fan53555-regulator 0-0040: Looking up vin-supply from device tree
[    1.053860] fan53555-reg: supplied by vcc5v0_sys
[    1.054274] vcc5v0_sys: could not add device link regulator.10 err -2
[    1.055145] vdd_cpu_b: 712 <--> 1500 mV at 1000 mV
[    1.055682] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.055696] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.056230] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    1.056859] fan53555-regulator 0-0041: Looking up vin-supply from device tree
[    1.056899] fan53555-reg: supplied by vcc5v0_sys
[    1.057312] vcc5v0_sys: could not add device link regulator.11 err -2
[    1.058177] vdd_gpu: 712 <--> 1500 mV at 1000 mV
[    1.058690] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.058701] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.059312] rk808 0-001b: Pmic Chip id: 0x0
[    1.063008] rk808 0-001b: GPIO lookup for consumer dvs
[    1.063017] rk808 0-001b: using device tree for GPIO lookup
[    1.063029] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3c0000/pmic@1b[0]'
[    1.063038] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3c0000/pmic@1b[0]'
[    1.063045] rk808 0-001b: using lookup tables for GPIO lookup
[    1.063054] rk808 0-001b: lookup for GPIO dvs failed
[    1.063062] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    1.063631] rk808 0-001b: GPIO lookup for consumer dvs
[    1.063638] rk808 0-001b: using device tree for GPIO lookup
[    1.063646] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3c0000/pmic@1b[1]'
[    1.063654] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3c0000/pmic@1b[1]'
[    1.063661] rk808 0-001b: using lookup tables for GPIO lookup
[    1.063668] rk808 0-001b: lookup for GPIO dvs failed
[    1.063676] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    1.064257] rk808 0-001b: Looking up vcc1-supply from device tree
[    1.064311] DCDC_REG1: supplied by vcc3v3_sys
[    1.064712] vcc3v3_sys: could not add device link regulator.12 err -2
[    1.065163] vdd_center: 750 <--> 1350 mV at 900 mV
[    1.065382] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.065394] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.065442] rk808 0-001b: Looking up vcc2-supply from device tree
[    1.065495] DCDC_REG2: supplied by vcc3v3_sys
[    1.065885] vcc3v3_sys: could not add device link regulator.13 err -2
[    1.066182] vdd_cpu_l: 750 <--> 1350 mV at 900 mV
[    1.066392] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.066403] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.066445] rk808 0-001b: Looking up vcc3-supply from device tree
[    1.066497] DCDC_REG3: supplied by vcc3v3_sys
[    1.066887] vcc3v3_sys: could not add device link regulator.14 err -2
[    1.066917] vcc_ddr: at 3300 mV
[    1.067100] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.067110] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.067156] rk808 0-001b: Looking up vcc4-supply from device tree
[    1.067192] DCDC_REG4: supplied by vcc3v3_sys
[    1.067595] vcc3v3_sys: could not add device link regulator.15 err -2
[    1.067773] vcc_1v8: 1800 mV
[    1.067978] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.067988] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.068035] rk808 0-001b: Looking up vcc6-supply from device tree
[    1.068073] LDO_REG1: supplied by vcc3v3_sys
[    1.068450] vcc3v3_sys: could not add device link regulator.16 err -2
[    1.069304] vcca1v8_codec: 1800 mV
[    1.069515] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.069526] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.069574] rk808 0-001b: Looking up vcc6-supply from device tree
[    1.069609] LDO_REG2: supplied by vcc3v3_sys
[    1.069987] vcc3v3_sys: could not add device link regulator.17 err -2
[    1.070696] vcc1v8_hdmi: 1800 mV
[    1.070890] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.070899] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.070950] rk808 0-001b: Looking up vcc7-supply from device tree
[    1.070986] LDO_REG3: supplied by vcc3v3_sys
[    1.071364] vcc3v3_sys: could not add device link regulator.18 err -2
[    1.072066] vcc1v8_pmu: 1800 mV
[    1.072266] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.072276] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.072328] rk808 0-001b: Looking up vcc9-supply from device tree
[    1.072363] LDO_REG4: supplied by vcc3v3_sys
[    1.072759] vcc3v3_sys: could not add device link regulator.19 err -2
[    1.073473] vccio_sd: 1800 <--> 3300 mV at 3000 mV
[    1.073681] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.073692] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.073751] rk808 0-001b: Looking up vcc9-supply from device tree
[    1.073788] LDO_REG5: supplied by vcc3v3_sys
[    1.074166] vcc3v3_sys: could not add device link regulator.20 err -2
[    1.074866] vcca3v0_codec: 3000 mV
[    1.075071] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.075081] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.075137] rk808 0-001b: Looking up vcc10-supply from device tree
[    1.075175] LDO_REG6: supplied by vcc3v3_sys
[    1.075568] vcc3v3_sys: could not add device link regulator.21 err -2
[    1.076263] vcc_1v5: 1500 mV
[    1.076485] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.076495] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.076554] rk808 0-001b: Looking up vcc7-supply from device tree
[    1.076590] LDO_REG7: supplied by vcc3v3_sys
[    1.076979] vcc3v3_sys: could not add device link regulator.22 err -2
[    1.077675] vcca0v9_hdmi: 900 mV
[    1.077870] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.077879] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.077939] rk808 0-001b: Looking up vcc11-supply from device tree
[    1.077974] LDO_REG8: supplied by vcc3v3_sys
[    1.078352] vcc3v3_sys: could not add device link regulator.23 err -2
[    1.079061] vcc_3v0: 3000 mV
[    1.079257] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.079266] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.079326] rk808 0-001b: Looking up vcc8-supply from device tree
[    1.079361] SWITCH_REG1: supplied by vcc3v3_sys
[    1.079781] vcc3v3_sys: could not add device link regulator.24 err -2
[    1.079811] vcc3v3_s3: at 3300 mV
[    1.079993] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.080003] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.080065] rk808 0-001b: Looking up vcc12-supply from device tree
[    1.080101] SWITCH_REG2: supplied by vcc3v3_sys
[    1.080517] vcc3v3_sys: could not add device link regulator.25 err -2
[    1.080546] vcc3v3_s0: at 3300 mV
[    1.080726] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.080736] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.083918] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[    1.084920] of_get_named_gpiod_flags: can't parse 'pmic,hold-gpio' property of node '/i2c@ff3c0000/pmic@1b[0]'
[    1.084930] rk808 0-001b: Can not read property pmic,hold-gpio
[    1.085446] of_get_named_gpiod_flags: can't parse 'pmic,stby-gpio' property of node '/i2c@ff3c0000/pmic@1b[0]'
[    1.085453] rk808 0-001b: Can not read property pmic,stby-gpio
[    1.086007] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80095fa000
[    1.087185] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80095fc000
[    1.088284] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff80095fe000
[    1.089653] fusb302 7-0022: GPIO lookup for consumer int-n
[    1.089661] fusb302 7-0022: using device tree for GPIO lookup
[    1.089690] of_get_named_gpiod_flags: parsed 'int-n-gpios' property of node '/i2c@ff160000/fusb30x@22[0]' - status (0)
[    1.089715] fusb302 7-0022: GPIO lookup for consumer vbus-5v
[    1.089723] fusb302 7-0022: using device tree for GPIO lookup
[    1.089732] of_get_named_gpiod_flags: can't parse 'vbus-5v-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
[    1.089741] of_get_named_gpiod_flags: can't parse 'vbus-5v-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
[    1.089748] fusb302 7-0022: using lookup tables for GPIO lookup
[    1.089756] fusb302 7-0022: lookup for GPIO vbus-5v failed
[    1.089764] fusb302 7-0022: GPIO lookup for consumer vbus-other
[    1.089771] fusb302 7-0022: using device tree for GPIO lookup
[    1.089778] of_get_named_gpiod_flags: can't parse 'vbus-other-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
[    1.089786] of_get_named_gpiod_flags: can't parse 'vbus-other-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
[    1.089793] fusb302 7-0022: using lookup tables for GPIO lookup
[    1.089800] fusb302 7-0022: lookup for GPIO vbus-other failed
[    1.089808] fusb302 7-0022: GPIO lookup for consumer discharge
[    1.089815] fusb302 7-0022: using device tree for GPIO lookup
[    1.089823] of_get_named_gpiod_flags: can't parse 'discharge-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
[    1.089830] of_get_named_gpiod_flags: can't parse 'discharge-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
[    1.089837] fusb302 7-0022: using lookup tables for GPIO lookup
[    1.089844] fusb302 7-0022: lookup for GPIO discharge failed
[    1.090008] fusb302 7-0022: Can't get property of role, set role to default DRP
[    1.090825] fusb302 7-0022: fusb302 send extcon to disable vbus 5v
[    1.094119] fusb302 7-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[    1.095996] mp8859 7-0066: set mp8859 out 12v ok
[    1.096409] mp8859 7-0066: register ext0 dev0
[    1.096960] mp8859 7-0066: mp8859 register successful
[    1.097426] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff8009622000
[    1.098936] fusb302 4-0022: GPIO lookup for consumer int-n
[    1.098945] fusb302 4-0022: using device tree for GPIO lookup
[    1.098974] of_get_named_gpiod_flags: parsed 'int-n-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]' - status (0)
[    1.098996] fusb302 4-0022: GPIO lookup for consumer vbus-5v
[    1.099003] fusb302 4-0022: using device tree for GPIO lookup
[    1.099027] of_get_named_gpiod_flags: parsed 'vbus-5v-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]' - status (0)
[    1.099049] fusb302 4-0022: GPIO lookup for consumer vbus-other
[    1.099056] fusb302 4-0022: using device tree for GPIO lookup
[    1.099065] of_get_named_gpiod_flags: can't parse 'vbus-other-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[    1.099074] of_get_named_gpiod_flags: can't parse 'vbus-other-gpio' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[    1.099081] fusb302 4-0022: using lookup tables for GPIO lookup
[    1.099088] fusb302 4-0022: lookup for GPIO vbus-other failed
[    1.099095] fusb302 4-0022: GPIO lookup for consumer discharge
[    1.099102] fusb302 4-0022: using device tree for GPIO lookup
[    1.099110] of_get_named_gpiod_flags: can't parse 'discharge-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[    1.099118] of_get_named_gpiod_flags: can't parse 'discharge-gpio' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[    1.099124] fusb302 4-0022: using lookup tables for GPIO lookup
[    1.099131] fusb302 4-0022: lookup for GPIO discharge failed
[    1.099270] fusb302 4-0022: Can't get property of role, set role to default DRP
[    1.108242] fusb302 4-0022: port 1 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[    1.109066] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009624000
[    1.110801] IR NEC protocol handler initialized
[    1.112044] usbcore: registered new interface driver uvcvideo
[    1.112559] USB Video Class driver (1.1.1)
[    1.113488] rockchip-iodomain ff320000.syscon:io-domains: Looking up pmu1830-supply from device tree
[    1.113682] rockchip-iodomain ff770000.syscon:io-domains: Looking up bt656-supply from device tree
[    1.113735] rockchip-iodomain ff770000.syscon:io-domains: Looking up audio-supply from device tree
[    1.113798] rockchip-iodomain ff770000.syscon:io-domains: Looking up sdmmc-supply from device tree
[    1.113858] rockchip-iodomain ff770000.syscon:io-domains: Looking up gpio1830-supply from device tree
[    1.115485] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[    1.116426] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[    1.117747] Bluetooth: Virtual HCI driver ver 1.5
[    1.118296] Bluetooth: HCI UART driver ver 2.3
[    1.118710] Bluetooth: HCI UART protocol H4 registered
[    1.119166] Bluetooth: HCI UART protocol LL registered
[    1.119632] Bluetooth: HCI UART protocol ATH3K registered
[    1.120164] usbcore: registered new interface driver bfusb
[    1.120711] usbcore: registered new interface driver btusb
[    1.121642] cpu cpu0: leakage=23
[    1.121958] cpu cpu0: Looking up cpu-supply from device tree
[    1.123223] cpu cpu4: leakage=47
[    1.123581] cpu cpu4: Looking up cpu-supply from device tree
[    1.124865] cpu cpu0: Looking up cpu-supply from device tree
[    1.125166] cpu cpu0: Looking up cpu-supply from device tree
[    1.125781] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    1.127030] cpu cpu4: Looking up cpu-supply from device tree
[    1.127824] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    1.130576] sdhci: Secure Digital Host Controller Interface driver
[    1.131124] sdhci: Copyright(c) Pierre Ossman
[    1.131526] Synopsys Designware Multimedia Card Interface Driver
[    1.132896] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    1.133582] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    1.134188] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    1.134751] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    1.135633] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[    1.135644] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed
[    1.135673] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[    1.135683] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed
[    1.135700] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    1.136248] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    1.136816] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
[    1.136823] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
[    1.136834] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe310000[0]'
[    1.136842] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe310000[0]'
[    1.136850] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
[    1.136858] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[    1.137655] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    1.138317] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    1.138936] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    1.139496] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[    1.140358] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    1.141081] dwmmc_rockchip fe320000.dwmmc: Looking up vmmc-supply from device tree
[    1.141179] dwmmc_rockchip fe320000.dwmmc: Looking up vqmmc-supply from device tree
[    1.141248] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer cd
[    1.141256] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[    1.141266] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/dwmmc@fe320000[0]'
[    1.141275] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/dwmmc@fe320000[0]'
[    1.141282] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[    1.141289] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO cd failed
[    1.141298] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer wp
[    1.141305] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[    1.141313] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe320000[0]'
[    1.141322] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe320000[0]'
[    1.141329] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[    1.141336] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO wp failed
[    1.141539] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[    1.142317] vccio_sd: ramp_delay not set
[    1.142328] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[    1.153532] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    1.164716] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[    1.165633] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.166728] sdhci-arasan fe330000.sdhci: GPIO lookup for consumer wp
[    1.166738] sdhci-arasan fe330000.sdhci: using device tree for GPIO lookup
[    1.166749] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/sdhci@fe330000[0]'
[    1.166758] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/sdhci@fe330000[0]'
[    1.166767] sdhci-arasan fe330000.sdhci: using lookup tables for GPIO lookup
[    1.166775] sdhci-arasan fe330000.sdhci: lookup for GPIO wp failed
[    1.167887] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply from device tree
[    1.167899] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply property in node /sdhci@fe330000 failed
[    1.167927] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply from device tree
[    1.167937] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe330000 failed
[    1.167954] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[    1.168494] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[    1.195604] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    1.197420] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/power[0]' - status (0)
[    1.197739] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/user[0]' - status (0)
[    1.198070] hidraw: raw HID events driver (C) Jiri Kosina
[    1.199203] usbcore: registered new interface driver usbhid
[    1.199733] usbhid: USB HID core driver
[    1.200213] inv_mpu_iio: inv_mpu_init:746
[    1.202243] rockchip-saradc ff100000.saradc: Looking up vref-supply from device tree
[    1.202256] rockchip-saradc ff100000.saradc: Looking up vref-supply property in node /saradc@ff100000 failed
[    1.202284] ff100000.saradc supply vref not found, using dummy regulator
[    1.204864] usbcore: registered new interface driver snd-usb-audio
[    1.209973] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    1.211189] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.211814] Initializing XFRM netlink socket
[    1.212843] NET: Registered protocol family 10
[    1.214339] NET: Registered protocol family 17
[    1.214779] NET: Registered protocol family 15
[    1.215673] Bluetooth: RFCOMM socket layer initialized
[    1.216153] Bluetooth: RFCOMM ver 1.11
[    1.216556] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.217088] Bluetooth: HIDP socket layer initialized
[    1.217604] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    1.218298] [BT_RFKILL]: Enter rfkill_rk_init
[    1.218870] Key type dns_resolver registered
[    1.219708] sensor_register_slave:mpu6880_gyro,id=50
[    1.220783] Registered cp15_barrier emulation handler
[    1.221333] Registered setend emulation handler
[    1.222875] Loading compiled-in X.509 certificates
[    1.224023] phy phy-ff770000.syscon:usb2-phy@e450.2: Looking up phy-supply from device tree
[    1.224145] vcc5v0_host: could not add device link phy-ff770000.syscon:usb2-phy@e450.2 err -2
[    1.224701] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up phy-supply from device tree
[    1.224710] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
[    1.224988] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up vbus-supply from device tree
[    1.224997] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
[    1.225012] phy phy-ff770000.syscon:usb2-phy@e450.3: Failed to get VBUS supply regulator
[    1.226280] phy phy-ff770000.syscon:usb2-phy@e460.4: Looking up phy-supply from device tree
[    1.226336] vcc5v0_host: could not add device link phy-ff770000.syscon:usb2-phy@e460.4 err -2
[    1.226802] phy phy-ff770000.syscon:usb2-phy@e460.5: Looking up phy-supply from device tree
[    1.226813] phy phy-ff770000.syscon:usb2-phy@e460.5: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed
[    1.227151] phy phy-ff770000.syscon:usb2-phy@e460.5: Looking up vbus-supply from device tree
[    1.227161] phy phy-ff770000.syscon:usb2-phy@e460.5: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed
[    1.227177] phy phy-ff770000.syscon:usb2-phy@e460.5: Failed to get VBUS supply regulator
[    1.228379] phy phy-ff7c0000.phy.6: Looking up phy-supply from device tree
[    1.228388] phy phy-ff7c0000.phy.6: Looking up phy-supply property in node /phy@ff7c0000/dp-port failed
[    1.228493] phy phy-ff7c0000.phy.7: Looking up phy-supply from device tree
[    1.228500] phy phy-ff7c0000.phy.7: Looking up phy-supply property in node /phy@ff7c0000/usb3-port failed
[    1.228851] phy phy-ff800000.phy.8: Looking up phy-supply from device tree
[    1.228859] phy phy-ff800000.phy.8: Looking up phy-supply property in node /phy@ff800000/dp-port failed
[    1.228936] phy phy-ff800000.phy.9: Looking up phy-supply from device tree
[    1.228943] phy phy-ff800000.phy.9: Looking up phy-supply property in node /phy@ff800000/usb3-port failed
[    1.229431] rockchip-drm display-subsystem: dmc is disabled
[    1.230191] rockchip-vop ff900000.vop: missing rockchip,grf property
[    1.230979] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008cee588)
[    1.231730] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[    1.231897] fusb302 7-0022: CC connected in CC2 as UFP
[    1.232893] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008cee588)
[    1.234112] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[    1.234740] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[    1.235536] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    1.237098] mmc1: new DDR MMC card at address 0001
[    1.237544] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008ce4eb8)
[    1.238100] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[    1.238367] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[    1.238389] rockchip-drm display-subsystem: bound fec00000.dp (ops 0xffffff8008ce5ed8)
[    1.238393] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.238394] [drm] No driver support for vblank timestamp query.
[    1.242242] mmcblk1: mmc1:0001 \xffffffc0\xfffffffa\xffffffce 8.00 GiB
[    1.243379]  mmcblk1: unable to read partition table
[    1.328532] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[    1.329547] vccio_sd: ramp_delay not set
[    1.329567] rockchip-iodomain ff770000.syscon:io-domains: Setting to 1800000 done
[    1.332944] mp8859 7-0066: mp8859 get notify
[    1.333334] mp8859 7-0066: mp8859 get ufp 1 dp 0
[    1.334508] mp8859 7-0066: set mp8859 out 12v ok
[    1.353943] rockchip-drm display-subsystem: can't not find any loader display
[    1.354070] mmc_host mmc0: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[    1.355523] rockchip-drm display-subsystem: failed to show loader logo
[    1.356301] Freeing drm_logo memory: 616K
[    1.487520] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1366x768p60, type: 11
[    1.591812] Console: switching to colour frame buffer device 170x48
[    1.628527] rockchip-drm display-subsystem: fb0:  frame buffer device
[    1.635294] mali ff9a0000.gpu: Looking up mali-supply from device tree
[    1.635717] mali ff9a0000.gpu: leakage=26
[    1.636099] mali ff9a0000.gpu: Looking up mali-supply from device tree
[    1.636123] vdd_gpu: could not add device link ff9a0000.gpu err -17
[    1.636135] vdd_gpu: Failed to create debugfs directory
[    1.639304] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[    1.640247] mali ff9a0000.gpu: Protected mode not available
[    1.641285] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    1.641998] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[    1.643088] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 414; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[    1.645355] mali ff9a0000.gpu: Probed as mali0
[    1.650311] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[    1.651184] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 1
[    1.652011] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[    1.652828] xhci-hcd xhci-hcd.8.auto: irq 225, io mem 0xfe800000
[    1.653519] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.654121] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.654767] usb usb1: Product: xHCI Host Controller
[    1.655197] usb usb1: Manufacturer: Linux 4.4.154 xhci-hcd
[    1.655692] usb usb1: SerialNumber: xhci-hcd.8.auto
[    1.656839] hub 1-0:1.0: USB hub found
[    1.657201] hub 1-0:1.0: 1 port detected
[    1.657850] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[    1.658582] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 2
[    1.659308] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.660118] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    1.660780] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.661424] usb usb2: Product: xHCI Host Controller
[    1.661890] usb usb2: Manufacturer: Linux 4.4.154 xhci-hcd
[    1.662383] usb usb2: SerialNumber: xhci-hcd.8.auto
[    1.663451] hub 2-0:1.0: USB hub found
[    1.663863] hub 2-0:1.0: 1 port detected
[    1.665602] xhci-hcd xhci-hcd.8.auto: remove, state 1
[    1.666073] usb usb2: USB disconnect, device number 1
[    1.685740] xhci-hcd xhci-hcd.8.auto: Host not halted after 16000 microseconds.
[    1.686388] xhci-hcd xhci-hcd.8.auto: Host controller not halted, aborting reset.
[    1.687129] xhci-hcd xhci-hcd.8.auto: USB bus 2 deregistered
[    1.687899] xhci-hcd xhci-hcd.8.auto: remove, state 1
[    1.688373] usb usb1: USB disconnect, device number 1
[    1.689444] xhci-hcd xhci-hcd.8.auto: USB bus 1 deregistered
[    1.768993] dwmmc_rockchip fe320000.dwmmc: Successfully tuned phase to 243
[    1.769720] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[    1.772346] mmcblk0: mmc0:aaaa JULIE 14.8 GiB
[    1.788043]  mmcblk0: p1 p2 p3 p4 p5
[    1.869994] phy phy-ff770000.syscon:usb2-phy@e450.3: charger = USB_DCP_CHARGER
[    1.875825] rockchip-dwc3 usb0: USB peripheral connected
[    1.879684] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    1.880280] fusb302 7-0022: PD connected as UFP, fetching 5V
[    1.880514] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 1
[    1.880757] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[    1.880840] xhci-hcd xhci-hcd.9.auto: irq 226, io mem 0xfe900000
[    1.881089] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.881101] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.881111] usb usb1: Product: xHCI Host Controller
[    1.881119] usb usb1: Manufacturer: Linux 4.4.154 xhci-hcd
[    1.881127] usb usb1: SerialNumber: xhci-hcd.9.auto
[    1.882207] hub 1-0:1.0: USB hub found
[    1.882260] hub 1-0:1.0: 1 port detected
[    1.882902] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    1.883164] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 2
[    1.883275] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.883448] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    1.883460] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.883505] usb usb2: Product: xHCI Host Controller
[    1.883514] usb usb2: Manufacturer: Linux 4.4.154 xhci-hcd
[    1.883522] usb usb2: SerialNumber: xhci-hcd.9.auto
[    1.884337] hub 2-0:1.0: USB hub found
[    1.884384] hub 2-0:1.0: 1 port detected
[    1.885168] xhci-hcd xhci-hcd.9.auto: remove, state 1
[    1.885195] usb usb2: USB disconnect, device number 1
[    1.886080] xhci-hcd xhci-hcd.9.auto: USB bus 2 deregistered
[    1.886289] xhci-hcd xhci-hcd.9.auto: remove, state 1
[    1.886312] usb usb1: USB disconnect, device number 1
[    1.887168] xhci-hcd xhci-hcd.9.auto: USB bus 1 deregistered
[    1.890520] ehci-platform fe380000.usb: EHCI Host Controller
[    1.890800] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[    1.890990] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[    1.896768] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    1.898097] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.898749] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.899398] usb usb1: Product: EHCI Host Controller
[    1.899872] usb usb1: Manufacturer: Linux 4.4.154 ehci_hcd
[    1.900369] usb usb1: SerialNumber: fe380000.usb
[    1.902368] hub 1-0:1.0: USB hub found
[    1.902801] hub 1-0:1.0: 1 port detected
[    1.908732] ehci-platform fe3c0000.usb: EHCI Host Controller
[    1.910197] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[    1.911358] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[    1.917853] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    1.918960] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.919609] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.920258] usb usb2: Product: EHCI Host Controller
[    1.920734] usb usb2: Manufacturer: Linux 4.4.154 ehci_hcd
[    1.921231] usb usb2: SerialNumber: fe3c0000.usb
[    1.923617] hub 2-0:1.0: USB hub found
[    1.924032] hub 2-0:1.0: 1 port detected
[    1.926385] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    1.927737] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[    1.928708] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[    1.983990] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    1.984635] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.985284] usb usb3: Product: Generic Platform OHCI controller
[    1.985854] usb usb3: Manufacturer: Linux 4.4.154 ohci_hcd
[    1.986350] usb usb3: SerialNumber: fe3a0000.usb
[    1.988269] hub 3-0:1.0: USB hub found
[    1.988721] hub 3-0:1.0: 1 port detected
[    1.990895] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    1.992004] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[    1.992979] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[    2.000931] mp8859 7-0066: mp8859 get notify
[    2.001342] mp8859 7-0066: mp8859 get ufp 1 dp 1
[    2.002750] mp8859 7-0066: set mp8859 out 12v ok
[    2.049253] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    2.049915] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.050590] usb usb4: Product: Generic Platform OHCI controller
[    2.051132] usb usb4: Manufacturer: Linux 4.4.154 ohci_hcd
[    2.051653] usb usb4: SerialNumber: fe3e0000.usb
[    2.053347] hub 4-0:1.0: USB hub found
[    2.053882] hub 4-0:1.0: 1 port detected
[    2.057300] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    2.058042] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    2.058694] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    2.059257] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    2.060215] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[    2.060243] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed
[    2.060314] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[    2.060340] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed
[    2.060383] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    2.060979] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    2.061588] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
[    2.061609] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
[    2.061635] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe310000[0]'
[    2.061659] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe310000[0]'
[    2.061679] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
[    2.061700] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[    2.062158] platform sdio-pwrseq: GPIO lookup for consumer reset
[    2.062179] platform sdio-pwrseq: using device tree for GPIO lookup
[    2.062244] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0)
[    2.062313] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[    2.075960] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.088039] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[    2.090664] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already present
[    2.091356] hdmi-audio-codec hdmi-audio-codec.7.auto: ASoC: Failed to add ELD: -16
[    2.093001] rk-hdmi-dp-sound hdmi-dp-sound: multicodec <-> ff8a0000.i2s mapping ok
[    2.093849] hdmi-audio-codec hdmi-audio-codec.7.auto: ASoC: Failed to create Playback debugfs file
[    2.096440] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.9 (r)
[    2.096449] =======================================================
[    2.096462] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[    2.096493] =======================================================
[    2.096498] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver v5.2.2.3_24783.20171030) init.
[    2.096506] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    2.096512] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[    2.096516] RTW: module init start
[    2.096520] RTW: rtl8188eu v5.2.2.3_24783.20171030
[    2.096525] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[    2.096530] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: rfkill-wlan driver has not Successful initialized
[    2.096719] usbcore: registered new interface driver rtl8188eu
[    2.096724] RTW: module init ret=0
[    2.097457] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-keys/button@0[0]' - status (0)
[    2.097565] gpio-5 (GPIO Key Power): gpiod_set_debounce: missing set() or set_debounce() operations
[    2.097991] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    2.099803] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:51:38 UTC (1358499098)
[    2.105408] ======== dhd_wlan_init_plat_data ========
[    2.105946] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[    2.106443] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: rfkill-wlan driver has not Successful initialized
[    2.107290] dhd_wlan_init_gpio: unknown oob irqflags !
[    2.107764] dhd_wlan_init_gpio: WL_REG_ON=-1, WL_HOST_WAKE=-1
[    2.108282] dhd_wlan_init_gpio: oob_irq=-1, oob_irq_flags=0x410
[    2.108827] dhd_wifi_platform_load: Enter
[    2.109219] Power-up adapter 'DHD generic adapter'
[    2.109751] wifi_platform_set_power = 1
[    2.110100] ======== PULL WL_REG_ON(-1) HIGH! ========
[    2.110577] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    2.110999] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[    2.113722] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    2.127561] ret 1024
[    2.128183] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '18:02:16', on 'Jan 26 2019'.
[    2.130411] Mali: Mali device driver loaded
[    2.131890] ALSA device list:
[    2.132166]   #0: rk-hdmi-dp-sound
[    2.152661] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[    2.196615] mmc_host mmc2: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[    2.238577] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[    2.288011] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[    2.288826] VFS: Mounted root (ext4 filesystem) on device 179:37.
[    2.298546] devtmpfs: mounted
[    2.299840] Freeing unused kernel memory: 1152K
[    2.313596] usb 2-1: new high-speed USB device number 2 using ehci-platform
[    2.382303] fusb302 7-0022: rec unknown init vdm msg
[    2.412565] wifi_platform_bus_enumerate device present 1
[    2.413054] ======== Card detection to detect SDIO card! ========
[    2.413640] mmc2:mmc host rescan start!
[    2.416553] usb 3-1: new low-speed USB device number 2 using ohci-platform
[    2.431094] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101
[    2.431754] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.432404] usb 2-1: Product: USB 2.0 Hub [MTT]
[    2.434613] hub 2-1:1.0: USB hub found
[    2.435224] hub 2-1:1.0: 4 ports detected
[    2.568952] systemd[1]: System time before build time, advancing clock.
[    2.600639] usb 3-1: New USB device found, idVendor=10c4, idProduct=8105
[    2.601298] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.602030] usb 3-1: Product: USB OPTICAL MOUSE
[    2.602513] usb 3-1: Manufacturer: YSPRINGTECH
[    2.604352] systemd[1]: Failed to insert module 'autofs4': No such file or directory
[    2.611346] input: YSPRINGTECH USB OPTICAL MOUSE as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.0/0003:10C4:8105.0001/input/input1
[    2.632855] random: systemd: uninitialized urandom read (16 bytes read, 83 bits of entropy available)
[    2.639127] random: systemd: uninitialized urandom read (16 bytes read, 84 bits of entropy available)
[    2.643073] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[    2.646703] systemd[1]: Detected architecture arm64.
[    2.657068] systemd[1]: Set hostname to <firefly>.
[    2.664336] hid-generic 0003:10C4:8105.0001: input,hidraw0: USB HID v1.11 Mouse [YSPRINGTECH USB OPTICAL MOUSE] on usb-fe3a0000.usb-1/input0
[    2.702674] usb 2-1.2: new high-speed USB device number 3 using ehci-platform
[    2.722047] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    2.728907] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    2.747679] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 89 bits of entropy available)
[    2.810761] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 93 bits of entropy available)
[    2.978230] usb 2-1.2: New USB device found, idVendor=1e4e, idProduct=0100
[    2.978910] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.979595] usb 2-1.2: Product: USB2.0 Camera
[    2.980000] usb 2-1.2: Manufacturer: Etron Technologies
[    2.983447] uvcvideo: Found UVC 1.00 device USB2.0 Camera (1e4e:0100)
[    2.989609] uvcvideo: UVC non compliance - GET_DEF(PROBE) not supported. Enabling workaround.
[    3.005936] random: systemd: uninitialized urandom read (16 bytes read, 107 bits of entropy available)
[    3.007032] random: systemd: uninitialized urandom read (16 bytes read, 107 bits of entropy available)
[    3.009716] random: systemd: uninitialized urandom read (16 bytes read, 107 bits of entropy available)
[    3.011313] random: systemd: uninitialized urandom read (16 bytes read, 107 bits of entropy available)
[    3.055723] usb 2-1.4: new low-speed USB device number 4 using ehci-platform
[    3.137774] usb 2-1.4: New USB device found, idVendor=046d, idProduct=c31c
[    3.138414] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.139114] usb 2-1.4: Product: USB Keyboard
[    3.139545] usb 2-1.4: Manufacturer: Logitech
[    3.149554] input: Logitech USB Keyboard as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.4/2-1.4:1.0/0003:046D:C31C.0002/input/input2
[    3.204063] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-fe3c0000.usb-1.4/input0
[    3.216150] input: Logitech USB Keyboard as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.4/2-1.4:1.1/0003:046D:C31C.0003/input/input3
[    3.268959] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-fe3c0000.usb-1.4/input1
[    3.370829] random: nonblocking pool is initialized
[    3.495004] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.496683] systemd[1]: Listening on Syslog Socket.
[    3.497976] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.499926] systemd[1]: Created slice User and Session Slice.
[    3.500874] systemd[1]: Reached target Remote File Systems (Pre).
[    3.501982] systemd[1]: Reached target Remote File Systems.
[    3.503222] systemd[1]: Listening on udev Kernel Socket.
[    3.504372] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    3.505660] systemd[1]: Listening on udev Control Socket.
[    3.506768] systemd[1]: Listening on Journal Socket.
[    3.508309] systemd[1]: Created slice System Slice.
[    3.509178] systemd[1]: Reached target Slices.
[    3.511328] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    3.521684] systemd[1]: Starting Remount Root and Kernel File Systems...
[    3.538536] systemd[1]: Starting Load Kernel Modules...
[    3.544516] systemd[1]: Starting Create Static Device Nodes in /dev...
[    3.545729] systemd[1]: Reached target User and Group Name Lookups.
[    3.547063] systemd[1]: Reached target Encrypted Volumes.
[    3.548139] systemd[1]: Reached target Swap.
[    3.577376] systemd[1]: Starting Journal Service...
[    3.582747] systemd[1]: Mounting Debug File System...
[    3.589597] systemd[1]: Starting Set console keymap...
[    3.600839] systemd[1]: Started Remount Root and Kernel File Systems.
[    3.610321] systemd[1]: Started Load Kernel Modules.
[    3.704702] systemd[1]: Mounting Configuration File System...
[    3.709124] systemd[1]: Starting Apply Kernel Variables...
[    3.712583] systemd[1]: Mounting FUSE Control File System...
[    3.725389] systemd[1]: Starting udev Coldplug all Devices...
[    3.729609] systemd[1]: Starting Load/Save Random Seed...
[    3.788001] systemd[1]: Mounted FUSE Control File System.
[    3.788394] systemd[1]: Mounted Debug File System.
[    3.788620] systemd[1]: Mounted Configuration File System.
[    3.789943] systemd[1]: Started Create Static Device Nodes in /dev.
[    3.790964] systemd[1]: Started Apply Kernel Variables.
[    3.791773] systemd[1]: Started Load/Save Random Seed.
[    3.814109] systemd[1]: Started Set console keymap.
[    3.838451] systemd[1]: Reached target Local File Systems (Pre).
[    3.838666] systemd[1]: Reached target Local File Systems.
[    3.840657] systemd[1]: Starting Set console font and keymap...
[    3.842631] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    3.846246] systemd[1]: Starting Raise network interfaces...
[    3.848614] systemd[1]: Starting udev Kernel Device Manager...
[    3.868105] systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
[    3.892800] systemd[1]: Started Journal Service.
[    3.918979] systemd-journald[189]: Received request to flush runtime journal from PID 1
[    4.225518] vendor storage:20160801 ret = -1
[    4.307024] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[    4.307037] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[    4.413479] failed to power up DHD generic adapter, 1 retry left
[    4.429662] wifi_platform_set_power = 0
[    4.429675] ======== PULL WL_REG_ON(-1) LOW! ========
[    4.429681] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    4.429695] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[    4.429701] wifi_platform_bus_enumerate device present 0
[    4.429705] ======== Card detection to remove SDIO card! ========
[    4.429710] mmc2:mmc host rescan start!
[    4.429759] wifi_platform_set_power = 1
[    4.429763] ======== PULL WL_REG_ON(-1) HIGH! ========
[    4.429767] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    4.429771] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[    4.730499] wifi_platform_bus_enumerate device present 1
[    4.730513] ======== Card detection to detect SDIO card! ========
[    4.730520] mmc2:mmc host rescan start!
[    6.607146] cfg80211: World regulatory domain updated:
[    6.607166] cfg80211:  DFS Master region: unset
[    6.607172] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    6.607182] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    6.607192] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    6.607200] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    6.607209] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    6.607219] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    6.607227] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[    6.607235] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    6.607243] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[    6.730555] failed to power up DHD generic adapter, 0 retry left
[    6.746726] wifi_platform_set_power = 0
[    6.746740] ======== PULL WL_REG_ON(-1) LOW! ========
[    6.746746] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    6.746761] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[    6.746766] wifi_platform_bus_enumerate device present 0
[    6.746770] ======== Card detection to remove SDIO card! ========
[    6.746776] mmc2:mmc host rescan start!
[    6.746781] failed to power up DHD generic adapter, max retry reached**
[    6.746824] unregister wifi platform drivers
[    6.746829] wifi_platform_bus_enumerate device present 0
[    6.746832] ======== Card detection to remove SDIO card! ========
[    6.746836] mmc2:mmc host rescan start!
[    6.746840] ======== dhd_wlan_deinit_plat_data ========
[    6.746848] dhd_module_init: Failed to load the driver, try cnt 0
[    6.746894] dhd_module_init: Failed to load driver max retry reached**
[    6.746898] dhd_module_init: Exit err=-19
[   10.825246] tty_port_close_start: tty->count = 1 port count = 2.
[  448.587290] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 8862.555261] rk_gmac-dwmac fe300000.ethernet eth0: Link is Down
[ 8893.617151] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 10Mbps/Half - flow control off
[ 8895.620998] rk_gmac-dwmac fe300000.ethernet eth0: Link is Down
[ 8901.633121] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 10Mbps/Half - flow control off
[ 8911.802550] NETDEV WATCHDOG: eth0 (rk_gmac-dwmac): transmit queue 0 timed out
[ 8911.802855] ------------[ cut here ]------------
[ 8911.802901] WARNING: at net/sched/sch_generic.c:306
[ 8911.802914] Modules linked in:
[ 8911.802953] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.4.154 #136
[ 8911.802967] Hardware name: Firefly roc-rk3399-pc (DT)
[ 8911.802985] task: ffffffc0002da880 task.stack: ffffffc0002f0000
[ 8911.803014] PC is at dev_watchdog+0x1e4/0x234
[ 8911.803032] LR is at dev_watchdog+0x1e4/0x234
[ 8911.803048] pc : [<ffffff8008a6ec48>] lr : [<ffffff8008a6ec48>] pstate: 20000145
[ 8911.803114] sp : ffffffc0f7f12de0
[ 8911.803128] x29: ffffffc0f7f12de0 x28: ffffff8009385000
[ 8911.803160] x27: ffffffc0f7f12ed8 x26: 00000000ffffffff
[ 8911.803182] x25: 0000000000000003 x24: ffffffc0f20acc80
[ 8911.803203] x23: 0000000000000001 x22: ffffff8009385000
[ 8911.803225] x21: ffffffc0f243e3e0 x20: 0000000000000000
[ 8911.803246] x19: ffffffc0f243e000 x18: ffffff80893c9817
[ 8911.803268] x17: 0000000000000000 x16: 0000000000000000
[ 8911.803298] x15: 0000000000000000 x14: 756f2064656d6974
[ 8911.803320] x13: 2030206575657571 x12: 2074696d736e6172
[ 8911.803341] x11: 74203a2963616d77 x10: 642d63616d675f6b
[ 8911.803363] x9 : 7228203068746520 x8 : 3a474f4448435441
[ 8911.803384] x7 : 572056454454454e x6 : ffffff80093c9868
[ 8911.803406] x5 : 0000000000000008 x4 : 0000000000000000
[ 8911.803427] x3 : 0000000000000000 x2 : 0000000000000040
[ 8911.803448] x1 : 0000000000000006 x0 : 0000000000000041
[ 8911.803471]
               PC: 0xffffff8008a6ebc8:
[ 8911.803496] ebc8  f9423260 8b010000 885f7c03 11000463 88027c03 35ffffa2 17ffffbd f9405001
[ 8911.803554] ebe8  b5000041 f9420661 f9405803 f240047f 54000380 f940e085 b983fa63 cb050063
[ 8911.803608] ec08  ab01007f 540002e5 f9405401 f00048b6 91000421 f9005401 394646c0 35000180
[ 8911.803670] ec28  aa1303e0 97ff8dee 2a1403e3 aa0003e2 aa1303e1 b0002ee0 91327800 97dbcc5b
[ 8911.803724] ec48  d4210000 52800020 390646c0 f9410260 f9403801 aa1303e0 d63f0020 17ffffcf
[ 8911.803788] ec68  11000694 91060000 17ffffca f941e276 52800040 9bb75a96 11000694 9102c2c1
[ 8911.803842] ec88  97e4e2be aa1603e0 97ff7917 17ffff92 a9bd7bfd 910003fd a90153f3 f90013f5
[ 8911.803896] eca8  aa0003f3 aa0103f4 aa0203f5 aa1e03e0 d503201f a9007e7f 79400680 79001a60
[ 8911.803962]
               LR: 0xffffff8008a6ebc8:
[ 8911.803978] ebc8  f9423260 8b010000 885f7c03 11000463 88027c03 35ffffa2 17ffffbd f9405001
[ 8911.804032] ebe8  b5000041 f9420661 f9405803 f240047f 54000380 f940e085 b983fa63 cb050063
[ 8911.804261] ec08  ab01007f 540002e5 f9405401 f00048b6 91000421 f9005401 394646c0 35000180
[ 8911.804316] ec28  aa1303e0 97ff8dee 2a1403e3 aa0003e2 aa1303e1 b0002ee0 91327800 97dbcc5b
[ 8911.804369] ec48  d4210000 52800020 390646c0 f9410260 f9403801 aa1303e0 d63f0020 17ffffcf
[ 8911.804432] ec68  11000694 91060000 17ffffca f941e276 52800040 9bb75a96 11000694 9102c2c1
[ 8911.804487] ec88  97e4e2be aa1603e0 97ff7917 17ffff92 a9bd7bfd 910003fd a90153f3 f90013f5
[ 8911.804541] eca8  aa0003f3 aa0103f4 aa0203f5 aa1e03e0 d503201f a9007e7f 79400680 79001a60
[ 8911.804606]
               SP: 0xffffffc0f7f12d60:
[ 8911.804622] 2d60  09385000 ffffff80 00000001 00000000 f20acc80 ffffffc0 00000003 00000000
[ 8911.804677] 2d80  ffffffff 00000000 f7f12ed8 ffffffc0 09385000 ffffff80 f7f12de0 ffffffc0
[ 8911.804740] 2da0  08a6ec48 ffffff80 f7f12de0 ffffffc0 08a6ec48 ffffff80 20000145 00000000
[ 8911.804795] 2dc0  09215000 ffffff80 00836780 00000001 00000000 00000080 ffffffff 00000000
[ 8911.804849] 2de0  f7f12e30 ffffffc0 081018ac ffffff80 09385be8 ffffff80 00000100 00000000
[ 8911.804912] 2e00  f243e410 ffffffc0 08a6ea64 ffffff80 f243e000 ffffffc0 08a6ea64 ffffff80
[ 8911.804967] 2e20  f243e000 ffffffc0 00000000 00000000 f7f12e70 ffffffc0 08101be0 ffffff80
[ 8911.805029] 2e40  f7f13b80 ffffffc0 f243e410 ffffffc0 09215000 ffffff80 091de000 ffffff80
[ 8911.805093]
               X6: 0xffffff80093c97e8:
[ 8911.805109] 97e8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.805171] 9808  00000000 00000000 00000001 00000000 30303020 32303330 37313530 39205d31
[ 8911.805225] 9828  20383238 382e3131 39303530 58205d33 30203a36 66666678 38666666 33393030
[ 8911.805279] 9848  65373963 300a3a38 36613830 38346365 70205d3e 74617473 32203a65 30303030
[ 8911.805341] 9868  0a353431 6e6f6320 6c6f7274 66666f20 64650a0a 3028200a 0a297320 75206e0a
[ 8911.805395] 9888  662d6273 30633365 2e303030 2d627375 2f342e31 75706e69 300a3174 0a30740a
[ 8911.805449] 98a8  472b2054 4c54554e 412b2053 2b204c43 2d205a58 20345a4c 4345532b 504d4f43
[ 8911.805513] 98c8  4c422b20 2044494b 464c452b 4c495455 4b2b2053 20444f4d 4e44492d 3a320a29
[ 8911.805583]
               X18: 0xffffff80893c9797:
[ 8911.805598] 9794  ******** ******** ******** ******** ******** ******** ******** ********
[ 8911.805667] 97b4  ******** ******** ******** ******** ******** ******** ******** ********
[ 8911.805722] 97d4  ******** ******** ******** ******** ******** ******** ******** ********
[ 8911.805785] 97f4  ******** ******** ******** ******** ******** ******** ******** ********
[ 8911.805840] 9814  ******** ******** ******** ******** ******** ******** ******** ********
[ 8911.805903] 9834  ******** ******** ******** ******** ******** ******** ******** ********
[ 8911.805957] 9854  ******** ******** ******** ******** ******** ******** ******** ********
[ 8911.806013] 9874  ******** ******** ******** ******** ******** ******** ******** ********
[ 8911.806077] 9894  ******** ******** ******** ******** ******** ******** ******** ********
[ 8911.806136]
               X19: 0xffffffc0f243df80:
[ 8911.806152] df80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.806214] dfa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.806267] dfc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.806320] dfe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.806382] e000  30687465 00000000 00000000 00000000 00000000 00000000 f2f34f88 ffffffc0
[ 8911.806436] e020  00000000 00000000 00000000 00000000 00000000 00000000 09640000 ffffff80
[ 8911.806490] e040  00000018 00000006 00000003 00000000 093527c8 ffffff80 f2c9e050 ffffffc0
[ 8911.806552] e060  f243ea58 ffffffc0 f243ea58 ffffffc0 f243e070 ffffffc0 f243e070 ffffffc0
[ 8911.806611]
               X21: 0xffffffc0f243e360:
[ 8911.806627] e360  ffffffff 0000ffff 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.806690] e380  00000000 00000000 00000000 00000000 f2f35010 ffffffc0 00000000 00000000
[ 8911.806744] e3a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.806805] e3c0  f20acc00 ffffffc0 00000001 00000001 eec42400 ffffffc0 000003e8 00000000
[ 8911.806859] e3e0  06970696 dead4ead 00000003 00000000 002da880 ffffffc0 00001388 00000000
[ 8911.806913] e400  00000000 00000000 00833fc6 00000001 00000200 dead0000 00000000 00000000
[ 8911.806975] e420  00836780 00000001 08a6ea64 ffffff80 f243e000 ffffffc0 00000003 ffffffff
[ 8911.807029] e440  ffffffff 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.807095]
               X22: 0xffffff8009384f80:
[ 8911.807110] 4f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.807163] 4fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.807226] 4fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.807279] 4fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.807332] 5000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.807385] 5020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.807448] 5040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.807500] 5060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.807567]
               X24: 0xffffffc0f20acc00:
[ 8911.807583] cc00  f243e000 ffffffc0 eec42400 ffffffc0 eec42400 ffffffc0 f208e280 ffffffc0
[ 8911.807638] cc20  f208d100 ffffffc0 f2079f18 ffffffc0 f208d128 ffffffc0 f208d100 ffffffc0
[ 8911.807692] cc40  093549b0 ffffff80 f2148c30 ffffffc0 00000001 00000007 00000000 00000000
[ 8911.807755] cc60  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.807808] cc80  46ba46ba dead4ead ffffffff 00000000 ffffffff ffffffff ffffffff 00000000
[ 8911.807872] cca0  008346af 00000001 00000001 00000000 00000006 00000000 00000000 00000000
[ 8911.807925] ccc0  001c7305 001c7177 000000d5 00000000 00000000 00000000 00000000 00000000
[ 8911.807979] cce0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.808047]
               X27: 0xffffffc0f7f12e58:
[ 8911.808062] 2e58  091de000 ffffff80 09385b98 ffffff80 08a6ea64 ffffff80 f7f12ee0 ffffffc0
[ 8911.808117] 2e78  08081174 ffffff80 091de000 ffffff80 00000001 00000000 00000282 00000000
[ 8911.808181] 2e98  093c6000 ffffff80 09215100 ffffff80 00000100 00000000 09215108 ffffff80
[ 8911.808235] 2eb8  00000002 00000000 00000001 00000000 09385000 ffffff80 f7f12f30 ffffffc0
[ 8911.808300] 2ed8  00000000 00000000 f7f12f90 ffffffc0 080a0b88 ffffff80 091de000 ffffff80
[ 8911.808354] 2ef8  091e5000 ffffff80 00000000 00000000 0a206400 ffffffc0 00000001 00000000
[ 8911.808408] 2f18  002f3d90 ffffffc0 0928b000 ffffff80 f7f13050 ffffffc0 02c3f234 00000000
[ 8911.808472] 2f38  002da880 ffffffc0 f7f12f60 ffffffc0 080f3600 ffffff80 093853a0 ffffff80
[ 8911.808530]
               X28: 0xffffff8009384f80:
[ 8911.808546] 4f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.808608] 4fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.808662] 4fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.808715] 4fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.808778] 5000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.808831] 5020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.808894] 5040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.808948] 5060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8911.809004]
               X29: 0xffffffc0f7f12d60:
[ 8911.809019] 2d60  09385000 ffffff80 00000001 00000000 f20acc80 ffffffc0 00000003 00000000
[ 8911.809083] 2d80  ffffffff 00000000 f7f12ed8 ffffffc0 09385000 ffffff80 f7f12de0 ffffffc0
[ 8911.809137] 2da0  08a6ec48 ffffff80 f7f12de0 ffffffc0 08a6ec48 ffffff80 20000145 00000000
[ 8911.809199] 2dc0  09215000 ffffff80 00836780 00000001 00000000 00000080 ffffffff 00000000
[ 8911.809253] 2de0  f7f12e30 ffffffc0 081018ac ffffff80 09385be8 ffffff80 00000100 00000000
[ 8911.809307] 2e00  f243e410 ffffffc0 08a6ea64 ffffff80 f243e000 ffffffc0 08a6ea64 ffffff80
[ 8911.809371] 2e20  f243e000 ffffffc0 00000000 00000000 f7f12e70 ffffffc0 08101be0 ffffff80
[ 8911.809425] 2e40  f7f13b80 ffffffc0 f243e410 ffffffc0 09215000 ffffff80 091de000 ffffff80
[ 8911.809494] ---[ end trace 81f435ad1c146c6d ]---
[ 8911.809517] Call trace:
[ 8911.809536] Exception stack(0xffffffc0f7f12c10 to 0xffffffc0f7f12d40)
[ 8911.809556] 2c00:                                   ffffffc0f243e000 0000008000000000
[ 8911.809579] 2c20: ffffffc0f7f12de0 ffffff8008a6ec48 ffffff80093ca07a 0000000000000006
[ 8911.809601] 2c40: ffffffc0f7f12c60 0000000600017560 0000000000000000 0000000100000000
[ 8911.809623] 2c60: ffffffc0f7f12d00 ffffff80080ee5d4 ffffffc0f7f12d60 ffffff800904bc9e
[ 8911.809646] 2c80: ffffffc0f243e3e0 ffffff8009385000 0000000000000001 ffffffc0f20acc80
[ 8911.809676] 2ca0: 0000000000000003 00000000ffffffff 0000000000000041 0000000000000006
[ 8911.809697] 2cc0: 0000000000000040 0000000000000000 0000000000000000 0000000000000008
[ 8911.809719] 2ce0: ffffff80093c9868 572056454454454e 3a474f4448435441 7228203068746520
[ 8911.809741] 2d00: 642d63616d675f6b 74203a2963616d77 2074696d736e6172 2030206575657571
[ 8911.809763] 2d20: 756f2064656d6974 0000000000000000 0000000000000000 0000000000000000
[ 8911.809787] [<ffffff8008a6ec48>] dev_watchdog+0x1e4/0x234
[ 8911.809811] [<ffffff80081018ac>] call_timer_fn+0x90/0x160
[ 8911.809840] [<ffffff8008101be0>] run_timer_softirq+0x238/0x244
[ 8911.809862] [<ffffff8008081174>] __do_softirq+0x23c/0x314
[ 8911.809884] [<ffffff80080a0b88>] irq_exit+0x88/0xd0
[ 8911.809906] [<ffffff80080ef484>] __handle_domain_irq+0x84/0xb8
[ 8911.809926] [<ffffff8008080e68>] gic_handle_irq+0xb8/0x184
[ 8911.809942] Exception stack(0xffffffc0002f3d90 to 0xffffffc0002f3ec0)
[ 8911.809968] 3d80:                                   0000000000000000 0000000000000003
[ 8911.809990] 3da0: 00000040eed31000 0000000000000008 00ffffffffffffff 00000031d217cf93
[ 8911.810012] 3dc0: 0000000000689d60 0000000000000003 00000032b5593519 ffffff8008081800
[ 8911.810034] 3de0: 0000000000001000 0000000000000000 0000000034d5d91d 00000040eed31000
[ 8911.810056] 3e00: ffffffc0002da880 0000000000000000 0000000000000000 0000000000000000
[ 8911.810078] 3e20: 0000000030d00800 0000081aeb5f9749 0000000000000002 ffffffc0f21c3600
[ 8911.810100] 3e40: ffffff8009386200 0000000000000001 0000081ae275a930 ffffff800932a968
[ 8911.810131] 3e60: 0000000003485000 0000000002c3f234 0000000000000000 ffffffc0002f3ec0
[ 8911.810153] 3e80: ffffff8008956ca4 ffffffc0002f3ec0 ffffff8008956ca8 0000000060000145
[ 8911.810175] 3ea0: ffffffc0002f3ec0 ffffff8008956ca4 ffffffffffffffff 0000000000000002
[ 8911.810196] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[ 8911.810219] [<ffffff8008956ca8>] cpuidle_enter_state+0x1cc/0x25c
[ 8911.810239] [<ffffff8008956dac>] cpuidle_enter+0x34/0x44
[ 8911.810261] [<ffffff80080e14e0>] call_cpuidle+0x6c/0x74
[ 8911.810290] [<ffffff80080e1794>] cpu_startup_entry+0x2ac/0x2bc
[ 8911.810313] [<ffffff800808d584>] secondary_start_kernel+0x190/0x1bc
[ 8911.810331] [<0000000002c3f178>] 0x2c3f178
[ 8913.659950] rk_gmac-dwmac fe300000.ethernet eth0: Link is Down
[ 8934.702994] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 10Mbps/Half - flow control off
[ 8939.714641] rk_gmac-dwmac fe300000.ethernet eth0: Link is Down
[ 8945.727052] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 10Mbps/Half - flow control off
[ 8955.746511] rk_gmac-dwmac fe300000.ethernet eth0: Link is Down
[ 8958.752514] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 10Mbps/Half - flow control off
[ 8967.770758] rk_gmac-dwmac fe300000.ethernet eth0: Link is Down
[ 8974.784806] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 10Mbps/Half - flow control off
[ 8991.819039] rk_gmac-dwmac fe300000.ethernet eth0: Link is Down
[ 8994.681967] usb 2-1.2: USB disconnect, device number 3
[ 8994.850068] usb 2-1.2: new high-speed USB device number 5 using ehci-platform
[ 8995.125714] usb 2-1.2: New USB device found, idVendor=1e4e, idProduct=0100
[ 8995.125732] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8995.125739] usb 2-1.2: Product: USB2.0 Camera
[ 8995.125745] usb 2-1.2: Manufacturer: Etron Technologies
[ 8995.131743] uvcvideo: Found UVC 1.00 device USB2.0 Camera (1e4e:0100)
[ 8995.137337] uvcvideo: UVC non compliance - GET_DEF(PROBE) not supported. Enabling workaround.
[ 8999.034296] usb 2-1.2: USB disconnect, device number 5
[ 8999.206174] usb 2-1.2: new high-speed USB device number 6 using ehci-platform
[ 8999.483367] usb 2-1.2: New USB device found, idVendor=1e4e, idProduct=0100
[ 8999.483401] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8999.483423] usb 2-1.2: Product: USB2.0 Camera
[ 8999.483444] usb 2-1.2: Manufacturer: Etron Technologies
[ 8999.493364] uvcvideo: Found UVC 1.00 device USB2.0 Camera (1e4e:0100)
[ 8999.500253] uvcvideo: UVC non compliance - GET_DEF(PROBE) not supported. Enabling workaround.
[ 9286.432608] usb 2-1.4: USB disconnect, device number 4
[ 9292.589836] usb 3-1: USB disconnect, device number 2
[ 9294.283311] usb 2-1.4: new low-speed USB device number 7 using ehci-platform
[ 9294.364969] usb 2-1.4: New USB device found, idVendor=10c4, idProduct=8105
[ 9294.365004] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9294.365026] usb 2-1.4: Product: USB OPTICAL MOUSE
[ 9294.365046] usb 2-1.4: Manufacturer: YSPRINGTECH
[ 9294.379012] input: YSPRINGTECH USB OPTICAL MOUSE as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.4/2-1.4:1.0/0003:10C4:8105.0004/input/input4
[ 9294.430978] hid-generic 0003:10C4:8105.0004: input,hidraw0: USB HID v1.11 Mouse [YSPRINGTECH USB OPTICAL MOUSE] on usb-fe3c0000.usb-1.4/input0
[ 9297.898121] usb 3-1: new low-speed USB device number 3 using ohci-platform
[ 9298.084370] usb 3-1: New USB device found, idVendor=046d, idProduct=c31c
[ 9298.084405] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9298.084426] usb 3-1: Product: USB Keyboard
[ 9298.084447] usb 3-1: Manufacturer: Logitech
[ 9298.107873] input: Logitech USB Keyboard as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.0/0003:046D:C31C.0005/input/input5
[ 9298.162355] hid-generic 0003:046D:C31C.0005: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-fe3a0000.usb-1/input0
[ 9298.178184] input: Logitech USB Keyboard as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:046D:C31C.0006/input/input6
[ 9298.231483] hid-generic 0003:046D:C31C.0006: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-fe3a0000.usb-1/input1
[ 9329.501581] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 9454.762826] rk_gmac-dwmac fe300000.ethernet eth0: Link is Down
[ 9456.120261] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9464.783180] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9464.790614] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 9487.836957] rk_gmac-dwmac fe300000.ethernet eth0: Link is Down
[ 9531.930431] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 9641.130301] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9641.131541] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9645.138472] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 9645.138556] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[15526.537533] usb 2-1.2: USB disconnect, device number 6
Posted at 3/25/2019 17:16:01        Only Author  10#
Also have problem with this..
firefly@firefly:~/GTISDK-Linux_aarch64_v4.0.0/Bin/Linux/aarch64$ ./liteSample
Usage:
         ./liteSample -c CNN_Model -f FC_Model -l Lable_File -i Input_Image_File -u Network_Config_File -d device (emmc or ftdi or pcie)
- 1553502717835 -547540041728- 2-:GTI SDK 4.0.0.rc-1  built on: Jan 25 2019
- 1553502717846 -547540041728- 2-:found deviceIRECT_EMMC_dev_mmcblk1
- 1553502717847 -547540041728- 1-:Could not determine the chip, default setting to 2801
- 1553502717847 -547540041728- 2-:create Chip2801
MMC_WRITE_MULTIPLE_BLOCK ioctl failed err = -1
- 1553502717872 -547540041728- 0-:Could not load model. Device:/dev/mmcblk1----emmc_write error
---------- Prediction for /home/firefly/GTISDK-Linux_aarch64_v4.0.0//data/Image_Lite/bridge.bin ----------
Handle one frame error!
Return to List
12
