CPU temperature fanless
10
Posted at 6/19/2015 13:23:25      View6297 | Replies9        Print      Only Author   [Copy Link] 1#
Hi, is it possible to run the Firefly Rk3288 without the cooling fan, only with the heatsink? Does it overheat when the CPU comes to high usage (e.g. playing 4k videos or playing games)?
Thanks for your answers.
Posted at 6/20/2015 06:37:18        Only Author  2#
larditi:
Have found that one will be safe for anything, for the chip is thermally protected.  I ran my Firefly with an oc'ed kernel with just a heatsink on the cpu.  Abused it and never saw any thing above 60-C, with the fan added it never went above 45-C abused.  There are several apps available from google play which will allow a real time temperature overlay on screen.  Have fun, the temp overlay is something which you may want, if extreme gaming with an extreme oc, for the extra piece of mind.
----cappybob
Posted at 6/28/2015 13:33:20        Only Author  3#
cappybob Posted at 6/20/2015 06:37
larditi:
Have found that one will be safe for anything, for the chip is thermally protected.  I r ...
what kind of heatsink are you using and are you using the acryllic case or an enclosure?
Posted at 6/28/2015 23:14:05        Only Author  4#
e97 Posted at 6/28/2015 13:33
I found an old south bridge mother board and cut my own to fit the acrylic case.  Used a safe heat transferring tape to affix.  Firefly board under acrylic top spaced with SSD attached on bottom acrylic.
later--cappybob
Posted at 10/22/2025 15:28:35        Only Author  5#
To chpu, technologie a hardware mohou být složit, i když j si občas hledm relax pln jinak. Nedvno jsem po dlouhm dni narazil na capospin casino. Ze začtku jsem pr kol prohrl, ale pak jsem odvžn zvýšil szku a nakonec vyhrl pknou čstku, kter m opravdu potšila. Hrči z Česk republiky tam maj speciln bonusy, takže se tam rd vracm, když chci zkusit štst, pobavit se u online her a odpočinout si od technických problmů a diskus o přehřvn zařzen.
restricted members
Posted at 1/8/2026 17:51:09        Only Author  6#
This article is simply breathtaking, thank you for sharing it with us! Good luck on your exams! Free Latest C-S4CPB-2502 test voucher exam papers are now available.
Posted at 1/17/2026 02:31:47        Only Author  7#
This article is truly a valuable source of knowledge, and Ive benefited a lot. New test camp SIE free questions are essential for your career successget them for free!
Posted at 1/30/2026 11:16:27        Only Author  8#
Your article made such an impression on me, Im deeply appreciative. These Reliable study questions CIPT ebook questions helped me climb the career ladder and increase my earnings, and now Im sharing them with you for free!
Posted at 2/8/2026 23:15:48        Only Author  9#
һΤ͘ϕrgojˤʤۥ磻ȥ`ΏITǤꡢץ`ä뤿缱SalesforceJҪȤޤΤ͘ϥϤĿָƤϤޤΤᡢAP-209|ȻشήʤЩ`O뤳ȤˤꡢʤҪ򜺤褦ˤޤ؄eʤΤϡ饤AP-209󥸥Щ`Ǥ饤ĩ`ȤơǺgѧǤWindowsMacAndroidiOSʤɤ򺬤ह٤ƤWeb֥饦ȥƥ򥵥ݩ`ȤޤΥЩ`AP-209ԇY}򤹤٤ƤӥǥХmäǤޤ
Posted at 2/19/2026 15:34:18        Only Author  10#
Your article was so insightful, Ill carry it with me. The AB-730 cost effective dumps test questions are now available for freeyour career success is just a step away!
