ANDROID 8.1 AIO-3399J no audio on 3.5mm
66
Posted at 11/2/2018 22:08:08      View13647 | Replies8        Print      Only Author   [Copy Link] 1#
Hi,
I have tested Android 8.1 on AIO-3399J board.  Sound DOES NOT WORK on 3.5mm Jack socket.
Sound works on HDMI only?
How can i fix this.
Rakie
Posted at 11/6/2018 10:04:31        Only Author  2#
Try firmware from firefly website.
Posted at 11/7/2018 17:15:39        Only Author  3#
Hi Leung,
I have tried both images from your website:
AIO-3399J_Android8.1.0_HDMI_180901.img
AIO-3399J_Android8.1.0_HDMI_181025.img
But both donot play audio from 3.5mm Jack?
Please advise on a fix for this
Posted at 11/7/2018 18:12:14        Only Author  4#
Hi Leung,
Pls see debug log :
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.11.07 10:06:08 =~=~=~=~=~=~=~=~=~=~=~=
DDR Version 1.12 20180518
In
Channel 0: DDR3, 800MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
Channel 1: DDR3, 800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x20
ch 1 ddrconfig = 0x101, ddrsize = 0x20
pmugrf_os_reg[2] = 0x32817281, stride = 0x9
OUT
Boot1: 2018-04-08, version: 1.12
CPUId = 0x0
ChipType = 0x10, 215
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
SdmmcInit=0 1
StorageInit ok = 67734
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xa912c
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):65aa5ce
NOTICE:  BL31: Built : 10:47:37, Jun 19 2018
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1151): pd status 3e
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-170-gc4654a6 #16 Wed May 30 08:54:30 UTC 2018 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2
INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Oct 25 2018 - 16:01:51)
CPU: rk3399
cpu version = 0
CPU's clock information:
    aplll = 816000000HZ
    apllb = 24000000HZ
    gpll = 800000000HZ
               aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_periph_h = 33333333HZ
               aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
               hclk_periph_l1 = 100000000HZ, pclk_periph_l1 = 50000000HZ
    cpll = 800000000HZ
    dpll = 800000000HZ
    vpll = 24000000HZ
    npll = 24000000HZ
    ppll = 676000000HZ
Board:        Rockchip platform Board
Uboot as second level loader
DRAM:  Found dram banks: 1
Adding bank:0000000000200000(000000007fe00000)
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x01e00000
128 MiB
SdmmcInit = 0 20
storage init OK!
Using default environment
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
can't find dts node for fixed
usb bc: can find node by path: /dwc-control-usb/usb_bc
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can't find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=66
    aplll = 816000000HZ
    apllb = 24000000HZ
    gpll = 800000000HZ
    cpll = 800000000HZ
    dpll = 800000000HZ
    vpll = 24000000HZ
    npll = 24000000HZ
    ppll = 676000000HZ
Can't find dts node for fuel guage cw201x
can't find dts node for ec-battery
Can't find dts node for charger bq25700
invalide header tag
ca head not found
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 2018-10-25#1.12
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
Rockchip UBOOT DRM driver version: develop-v1.0.0
failed to find phy node
failed to find panel driver
read logo on state from dts [1]
no fuel gauge found
Monitor has basic audio support
drm_rk_selete_output; fail get baseparameter
rk lcdc - 0 dclk set: dclk = 148500000HZ, pll select = 0, div = 1
rockchip_panel_prepare: failed to find panel prepare funcs
CEA mode used vic=31
dw_hdmi_setup HDMI mode
rockchip_panel_enable: failed to find panel prepare funcs
Hit any key to stop autoboot:  0
load fdt from resouce.
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel   @ 0x00280000 (0x0127d808)
ramdisk  @ 0x04bf0000 (0x00178918)
bootrk: do_bootm_linux...
   Loading Device Tree to 0000000004600000, end 00000000046164f1 ... OK
Add bank:0000000000200000, 0000000008200000
Add bank:000000000a200000, 0000000075e00000
WARNING: could not set reg FDT_ERR_BADOFFSET.
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Initializing cgroup subsys schedtune
[    0.000000] Linux version 4.4.126 (liangkd@tchip-server) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #203 SMP PREEMPT Tue Oct 23 15:54:13 CST 2018
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[    0.000000] bootconsole [uart0] enabled
[    0.000000] Reserved memory: failed to reserve memory for node 'stb-devinfo@00000000': base 0x0000000000000000, size 0 MiB
[    0.000000] cma: Reserved 16 MiB at 0x000000007f000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eefb000 s45528 r8192 d32296 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 507912
[    0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.veritymode=/dev/block/platform/ff0f0000.dwmmc/by-name/metadata androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init  mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x00010000@0x00010000(kernel),0x00010000@0x00020000(boot),0x00020000@0x00030000(recovery),0x00038000@0x00050000(backup),0x00002000@0x00088000(security),0x00100000@0x0008a000(cache),0x00500000@0x0018a000(system),0x00008000@0x0068a000(metadata),0x00100000@0x00692000(vendor),0x00100000@0x00794000(oem),0x00000400@0x00894000(frp),-@0x00894400(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2018-10-25_16:01:51 SecureBootCheckOk=0
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] software IO TLB [mem 0x7eeb3000-0x7eef3000] (0MB) mapped at [ffffffc07eeb3000-ffffffc07eef2fff]
[    0.000000] Memory: 1988276K/2064384K available (11006K kernel code, 1654K rwdata, 5372K rodata, 832K init, 1133K bss, 59724K reserved, 16384K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
[    0.000000]       .init : 0xffffff8009090000 - 0xffffff8009160000   (   832 KB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008b40000   ( 11008 KB)
[    0.000000]     .rodata : 0xffffff8008b40000 - 0xffffff8009090000   (  5440 KB)
[    0.000000]       .data : 0xffffff8009160000 - 0xffffff80092fd808   (  1655 KB)
[    0.000000]     vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
[    0.000000]               0xffffffbdc0008000 - 0xffffffbdc2000000   (    31 MB actual)
[    0.000000]     fixed   : 0xffffffbffe7fb000 - 0xffffffbffec00000   (  4116 KB)
[    0.000000]     PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
[    0.000000]     memory  : 0xffffffc000200000 - 0xffffffc080000000   (  2046 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]         Build-time adjustment of leaf fanout to 64.
[    0.000000]         RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[    0.000000] ITS: allocated 65536 Devices @a200000 (psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x000000000a280000
[    0.000000] ITS: Allocated 1792 chunks for LPIs
[    0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] CPU0: using LPI pending table @0x000000000a290000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[    0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001924] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.002911] pid_max: default: 32768 minimum: 301
[    0.003413] Security Framework initialized
[    0.003812] SELinux:  Initializing.
[    0.004252] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.004897] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.006347] Initializing cgroup subsys memory
[    0.006789] Initializing cgroup subsys freezer
[    0.008099] sched-energy: Sched-energy-costs installed from DT
[    0.008663] CPU0: update cpu_capacity 401
[    0.009124] ASID allocator initialised with 32768 entries
[    0.025948] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.027240] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.039356] Detected VIPT I-cache on CPU1
[    0.039387] CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.039421] CPU1: using LPI pending table @0x000000000a3f0000
[    0.039464] CPU1: update cpu_capacity 401
[    0.039468] CPU1: Booted secondary processor [410fd034]
[    0.049341] Detected VIPT I-cache on CPU2
[    0.049361] CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.049394] CPU2: using LPI pending table @0x000000007c020000
[    0.049423] CPU2: update cpu_capacity 401
[    0.049426] CPU2: Booted secondary processor [410fd034]
[    0.059372] Detected VIPT I-cache on CPU3
[    0.059391] CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.059423] CPU3: using LPI pending table @0x000000007c060000
[    0.059449] CPU3: update cpu_capacity 401
[    0.059453] CPU3: Booted secondary processor [410fd034]
[    0.069421] Detected PIPT I-cache on CPU4
[    0.069449] CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.069488] CPU4: using LPI pending table @0x000000007c0b0000
[    0.069528] CPU4: update cpu_capacity 1024
[    0.069531] CPU4: Booted secondary processor [410fd082]
[    0.079447] Detected PIPT I-cache on CPU5
[    0.079465] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.079501] CPU5: using LPI pending table @0x000000007c0e0000
[    0.079528] CPU5: update cpu_capacity 1024
[    0.079531] CPU5: Booted secondary processor [410fd082]
[    0.079614] Brought up 6 CPUs
[    0.092032] SMP: Total of 6 processors activated.
[    0.092486] CPU features: detected feature: GIC system register CPU interface
[    0.093174] CPU: All CPU(s) started at EL2
[    0.093608] alternatives: patching kernel code
[    0.095943] devtmpfs: initialized
[    0.116343] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.117308] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.123368] pinctrl core: initialized pinctrl subsystem
[    0.125388] Failed to find legacy iommu devices
[    0.126195] NET: Registered protocol family 16
[    0.127046] schedtune: init normalization constants...
[    0.127552] schedtune: CLUSTER[0-3]      min_pwr:    56 max_pwr:   222
[    0.128191] schedtune: CPU[0]            min_pwr:     0 max_pwr:   222
[    0.128827] schedtune: CPU[1]            min_pwr:     0 max_pwr:   222
[    0.129463] schedtune: CPU[2]            min_pwr:     0 max_pwr:   222
[    0.130107] schedtune: CPU[3]            min_pwr:     0 max_pwr:   222
[    0.130744] schedtune: CLUSTER[4-5]      min_pwr:    65 max_pwr:  1108
[    0.131379] schedtune: CPU[4]            min_pwr:     0 max_pwr:  1108
[    0.132014] schedtune: CPU[5]            min_pwr:     0 max_pwr:  1108
[    0.132648] schedtune: SYSTEM            min_pwr:   121 max_pwr:  4434
[    0.133284] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[    0.134054] schedtune: verify normalization constants...
[    0.134573] schedtune: max_pwr/2^0: 4313 => norm_pwr:  1024
[    0.135116] schedtune: max_pwr/2^1: 2156 => norm_pwr:   511
[    0.135658] schedtune: max_pwr/2^2: 1078 => norm_pwr:   255
[    0.136200] schedtune: max_pwr/2^3:  539 => norm_pwr:   127
[    0.136742] schedtune: max_pwr/2^4:  269 => norm_pwr:    63
[    0.137284] schedtune: max_pwr/2^5:  134 => norm_pwr:    31
[    0.137834] schedtune: configured to support 5 boost groups
[    0.147868] cpuidle: using governor ladder
[    0.157874] cpuidle: using governor menu
[    0.158271] Registered FIQ tty driver
[    0.158980] vdso: 2 pages (1 code @ ffffff8008b46000, 1 data @ ffffff8009164000)
[    0.159718] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.161743] DMA: preallocated 2048 KiB pool for atomic allocations
[    0.184881] console [pstore-1] enabled
[    0.185487] pstore: Registered ramoops as persistent store backend
[    0.186092] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[    0.189023] fiq debugger fiq mode enabled
[ [    0.189675] console [ttyFIQ0] enabled
[    0.190361] bootconsole [uart0] disabled
[    0.190925] Registered fiq debugger ttyFIQ0
[    0.225110] iommu: Adding device ff650000.vpu_service to group 0
[    0.225204] iommu: Adding device ff660000.rkvdec to group 1
[    0.225301] iommu: Adding device ff670000.iep to group 2
[    0.225392] iommu: Adding device ff8f0000.vop to group 3
[    0.225462] iommu: Adding device ff900000.vop to group 4
[    0.225562] iommu: Adding device ff910000.isp to group 5
[    0.225634] iommu: Adding device ff920000.isp to group 6
[    0.227629] rk_iommu ff670800.iommu: can't get aclk
[    0.227645] rk_iommu ff670800.iommu: can't get hclk
[    0.228498] SCSI subsystem initialized
[    0.228811] usbcore: registered new interface driver usbfs
[    0.228860] usbcore: registered new interface driver hub
[    0.228936] usbcore: registered new device driver usb
[    0.229298] media: Linux media interface: v0.10
[    0.229332] Linux video capture interface: v2.00
[    0.229508] pps_core: LinuxPPS API ver. 1 registered
[    0.229518] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.229538] PTP clock support registered
[    0.232376] Advanced Linux Sound Architecture Driver Initialized.
[    0.232835] Bluetooth: Core ver 2.21
[    0.232866] NET: Registered protocol family 31
[    0.232875] Bluetooth: HCI device and connection manager initialized
[    0.232888] Bluetooth: HCI socket layer initialized
[    0.232900] Bluetooth: L2CAP socket layer initialized
[    0.232925] Bluetooth: SCO socket layer initialized
[    0.233562] rockchip-cpuinfo cpuinfo: Serial                : 3a809135da364fc1
[    0.234038] clocksource: Switched to clocksource arch_sys_counter
[    0.275474] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    0.275713] NET: Registered protocol family 2
[    0.276140] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.276261] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    0.276389] TCP: Hash tables configured (established 16384 bind 16384)
[    0.276462] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    0.276488] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    0.276644] NET: Registered protocol family 1
[    0.277514] Trying to unpack rootfs image as initramfs...
[    0.344420] Freeing initrd memory: 1504K
[    0.344969] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.345056] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.347715] audit: initializing netlink subsys (disabled)
[    0.347806] audit: type=2000 audit(0.343:1): initialized
[    0.356250] VFS: Disk quotas dquot_6.6.0
[    0.356381] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.357393] Registering sdcardfs 0.1
[    0.357959] fuse init (API version 7.23)
[    0.359006]
[    0.359006] TEE Core Framework initialization (ver 1:0.1)
[    0.359031] TEE armv7 Driver initialization
[    0.359365] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[    0.359380] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[    0.359563] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62)
[    0.363340] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.363364] io scheduler noop registered
[    0.363522] io scheduler cfq registered (default)
[    0.364737] phy phy-ff770000.syscon:usb2-phy@e450.0: Failed to get VBUS supply regulator
[    0.365652] phy phy-ff770000.syscon:usb2-phy@e460.2: Failed to get VBUS supply regulator
[    0.370817] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    0.370839] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    0.370853] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    0.894100] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    0.894275] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    0.895217] iep: failed to find iep power down clock source.
[    0.895834] IEP Power ON
[    0.896095] IEP Power OFF
[    0.896234] IEP Driver loaded succesfully
[    0.896529] Module initialized.
[    0.896932] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[    0.897190] rk-vcodec ff650000.vpu_service: probe device
[    0.897240] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07c25d410
[    0.897444] rk-vcodec ff650000.vpu_service: allocator is drm
[    0.897512] rk-vcodec ff650000.vpu_service: checking hw id 0
[    0.898073] rk-vcodec ff650000.vpu_service: could not find power_model node
[    0.898093] rk-vcodec ff650000.vpu_service: init success
[    0.898325] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[    0.902108] rk-vcodec ff660000.rkvdec: probe device
[    0.902162] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07c25dc10
[    0.902327] rk-vcodec ff660000.rkvdec: allocator is drm
[    0.902391] rk-vcodec ff660000.rkvdec: checking hw id 6876
[    0.902837] rk-vcodec ff660000.rkvdec: could not find power_model node
[    0.902853] rk-vcodec ff660000.rkvdec: init success
[    0.904668] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.904690] dma-pl330 ff6d0000.dma-controller:         DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    0.906002] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.906020] dma-pl330 ff6e0000.dma-controller:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    0.907788] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    0.909530] ff180000.serial: ttyS0 at MMIO 0xff16†C‹&Ouml;6v&AElig;& ›+&ucirc; &laquo;#&Ouml;VCC›fVVk
[    0.909827] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-debugger; cannot claim for ff1a0000.serial
[    0.909841] rockchip-pinctrl pinctrl: pin-147 (ff1a0000.serial) status -22
[    0.909854] rockchip-pinctrl pinctrl: could not request pin 147 (gpio4-19) from group uart2c-xfer  on device rockchip-pinctrl
[    0.909864] dw-apb-uart ff1a0000.serial: Error applying setting, reverse things back
[    0.910156] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 38, base_baud = 1500000) is a 16550A
[    0.910562] [drm] Initialized drm 1.1.0 20060810
[    0.913889] [drm] Rockchip DRM driver version: v1.0.1
[    0.914231] rockchip-drm display-subsystem: dmc is disabled
[    0.914501] rockchip-vop ff900000.vop: missing rockchip,grf property
[    0.914766] rockchip-vop ff900000.vop: unable to request PWM
[    0.914793] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[    0.914832] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[    0.914999] rockchip-vop ff8f0000.vop: unable to request PWM
[    0.915018] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[    0.915242] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[    0.915260] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[    0.915362] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    0.916063] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[    0.916080] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    0.916088] [drm] No driver support for vblank timestamp query.
[    1.581680] rockchip-drm display-subsystem: fb0:  frame buffer device
[    1.597679] Unable to detect cache hierarchy for CPU 0
[    1.608915] brd: module loaded
[    1.623586] loop: module loaded
[    1.624145] zram: Added device: zram0
[    1.624974] SCSI Media Changer driver v0.25
[    1.626261] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[    1.626283] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[    1.627074] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[    1.797397] wk2xxx_serial_init()
[    1.797412] wk2xxx_request_port
[    1.797424] ttysWK0 at I/O 0x1 (irq = 104, base_baud = 460800) is a wk2xxx
[    1.797626] uart_add_one_port success for line i:= 0 with right 0
[    1.797638] wk2xxx_request_port
[    1.797649] ttysWK1 at I/O 0x2 (irq = 104, base_baud = 460800) is a wk2xxx
[    1.797834] uart_add_one_port success for line i:= 1 with right 0
[    1.797845] wk2xxx_request_port
[    1.797855] ttysWK2 at I/O 0x3 (irq = 104, base_baud = 460800) is a wk2xxx
[    1.798034] uart_add_one_port success for line i:= 2 with right 0
[    1.798046] wk2xxx_request_port
[    1.798055] ttysWK3 at I/O 0x4 (irq = 104, base_baud = 460800) is a wk2xxx
[    1.798253] uart_add_one_port success for line i:= 3 with right 0
[    1.798264] uart_add_one_port = 0x0
[    1.798288] register spi return v = :0
[    1.798331] register firefly_spi_init spi return v = :0
[    1.798385] tun: Universal TUN/TAP device driver, 1.6
[    1.798396] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.799272] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[    1.799382] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    1.799401] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    1.799412] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[    1.799436] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    1.799595] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[    1.799607] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    1.804623] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    1.804737] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    1.804745]  Ring mode enabled
[    1.804752]  DMA HW capability register supported
[    1.804758]  Normal descriptors
[    1.804767]  RX Checksum Offload Engine supported (type 2)
[    1.804782]  Wake-Up On Lan supported
[    1.804824]  Enable RX Mitigation via HW Watchdog Timer
[    1.878608] libphy: stmmac: probed
[    1.878648] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[    1.878659] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[    1.878668] eth%d: PHY ID 0000ffff at 2 IRQ POLL (stmmac-0:02)
[    1.878676] eth%d: PHY ID 0000ffff at 3 IRQ POLL (stmmac-0:03)
[    1.878684] eth%d: PHY ID 0000ffff at 4 IRQ POLL (stmmac-0:04)
[    1.878692] eth%d: PHY ID 0000ffff at 5 IRQ POLL (stmmac-0:05)
[    1.878700] eth%d: PHY ID 0000ffff at 6 IRQ POLL (stmmac-0:06)
[    1.878708] eth%d: PHY ID 0000ffff at 7 IRQ POLL (stmmac-0:07)
[    1.878717] eth%d: PHY ID 0000ffff at 8 IRQ POLL (stmmac-0:08)
[    1.878725] eth%d: PHY ID 0000ffff at 9 IRQ POLL (stmmac-0:09)
[    1.878733] eth%d: PHY ID 0000ffff at 10 IRQ POLL (stmmac-0:0a)
[    1.878741] eth%d: PHY ID 0000ffff at 11 IRQ POLL (stmmac-0:0b)
[    1.878749] eth%d: PHY ID 0000ffff at 12 IRQ POLL (stmmac-0:0c)
[    1.878757] eth%d: PHY ID 0000ffff at 13 IRQ POLL (stmmac-0:0d)
[    1.878765] eth%d: PHY ID 0000ffff at 14 IRQ POLL (stmmac-0:0e)
[    1.878773] eth%d: PHY ID 0000ffff at 15 IRQ POLL (stmmac-0:0f)
[    1.878781] eth%d: PHY ID 0000ffff at 16 IRQ POLL (stmmac-0:10)
[    1.878788] eth%d: PHY ID 0000ffff at 17 IRQ POLL (stmmac-0:11)
[    1.878796] eth%d: PHY ID 0000ffff at 18 IRQ POLL (stmmac-0:12)
[    1.878804] eth%d: PHY ID 0000ffff at 19 IRQ POLL (stmmac-0:13)
[    1.878812] eth%d: PHY ID 0000ffff at 20 IRQ POLL (stmmac-0:14)
[    1.878820] eth%d: PHY ID 0000ffff at 21 IRQ POLL (stmmac-0:15)
[    1.878827] eth%d: PHY ID 0000ffff at 22 IRQ POLL (stmmac-0:16)
[    1.878835] eth%d: PHY ID 0000ffff at 23 IRQ POLL (stmmac-0:17)
[    1.878843] eth%d: PHY ID 0000ffff at 24 IRQ POLL (stmmac-0:18)
[    1.878851] eth%d: PHY ID 0000ffff at 25 IRQ POLL (stmmac-0:19)
[    1.878858] eth%d: PHY ID 0000ffff at 26 IRQ POLL (stmmac-0:1a)
[    1.878866] eth%d: PHY ID 0000ffff at 27 IRQ POLL (stmmac-0:1b)
[    1.878874] eth%d: PHY ID 0000ffff at 28 IRQ POLL (stmmac-0:1c)
[    1.878882] eth%d: PHY ID 0000ffff at 29 IRQ POLL (stmmac-0:1d)
[    1.878889] eth%d: PHY ID 0000ffff at 30 IRQ POLL (stmmac-0:1e)
[    1.878897] eth%d: PHY ID 0000ffff at 31 IRQ POLL (stmmac-0:1f)
[    1.879785] PPP generic driver version 2.4.2
[    1.879967] PPP BSD Compression module registered
[    1.879981] PPP Deflate Compression module registered
[    1.880010] PPP MPPE Compression module registered
[    1.880027] NET: Registered protocol family 24
[    1.880090] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[    1.880097] CSLIP: code copyright 1989 Regents of the University of California.
[    1.880114] Rockchip WiFi SYS interface (V1.00) ...
[    1.880195] usbcore: registered new interface driver catc
[    1.880235] usbcore: registered new interface driver kaweth
[    1.880251] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    1.880291] usbcore: registered new interface driver pegasus
[    1.880331] usbcore: registered new interface driver rtl8150
[    1.880371] usbcore: registered new interface driver r8152
[    1.880384] hso: drivers/net/usb/hso.c: Option Wireless
[    1.880440] usbcore: registered new interface driver hso
[    1.880488] usbcore: registered new interface driver asix
[    1.880550] usbcore: registered new interface driver ax88179_178a
[    1.880589] usbcore: registered new interface driver cdc_ether
[    1.880629] usbcore: registered new interface driver cdc_eem
[    1.880668] usbcore: registered new interface driver dm9601
[    1.880748] usbcore: registered new interface driver smsc75xx
[    1.880819] usbcore: registered new interface driver smsc95xx
[    1.880859] usbcore: registered new interface driver gl620a
[    1.880902] usbcore: registered new interface driver net1080
[    1.880941] usbcore: registered new interface driver plusb
[    1.881000] usbcore: registered new interface driver rndis_host
[    1.881043] usbcore: registered new interface driver cdc_subset
[    1.881083] usbcore: registered new interface driver zaurus
[    1.881124] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    1.881180] usbcore: registered new interface driver int51x1
[    1.881238] usbcore: registered new interface driver kalmia
[    1.881282] usbcore: registered new interface driver ipheth
[    1.881324] usbcore: registered new interface driver sierra_net
[    1.881364] usbcore: registered new interface driver cx82310_eth
[    1.881412] usbcore: registered new interface driver cdc_ncm
[    1.881470] usbcore: registered new interface driver qmi_wwan
[    1.881514] usbcore: registered new interface driver cdc_mbim
[    1.985077] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    1.986203] rockchip-typec-phy ff7c0000.phy: Needed 1 loops to turn on
[    1.987444] rockchip-dwc3 usb@fe800000: fail to get drvdata hcd
[    1.992622] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[    1.993770] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.993807] ehci-pci: EHCI PCI platform driver
[    1.993869] ehci-platform: EHCI generic platform driver
[    1.997405] ehci-platform fe380000.usb: EHCI Host Controller
[    1.997602] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[    1.997793] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[    2.007403] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    2.007559] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.007591] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.007602] usb usb1: Product: EHCI Host Controller
[    2.007611] usb usb1: Manufacturer: Linux 4.4.126 ehci_hcd
[    2.007620] usb usb1: SerialNumber: fe380000.usb
[    2.008091] hub 1-0:1.0: USB hub found
[    2.008142] hub 1-0:1.0: 1 port detected
[    2.012014] ehci-platform fe3c0000.usb: EHCI Host Controller
[    2.012261] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[    2.012574] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[    2.020754] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    2.021003] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    2.021051] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.021103] usb usb2: Product: EHCI Host Controller
[    2.021116] usb usb2: Manufacturer: Linux 4.4.126 ehci_hcd
[    2.021127] usb usb2: SerialNumber: fe3c0000.usb
[    2.021747] hub 2-0:1.0: USB hub found
[    2.021828] hub 2-0:1.0: 1 port detected
[    2.022752] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.022873] ohci-platform: OHCI generic platform driver
[    2.023366] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    2.023650] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[    2.023910] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[    2.078246] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    2.078295] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.078309] usb usb3: Product: Generic Platform OHCI controller
[    2.078323] usb usb3: Manufacturer: Linux 4.4.126 ohci_hcd
[    2.078335] usb usb3: SerialNumber: fe3a0000.usb
[    2.078934] hub 3-0:1.0: USB hub found
[    2.079006] hub 3-0:1.0: 1 port detected
[    2.079698] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    2.079958] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[    2.080163] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[    2.134903] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    2.134952] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.134967] usb usb4: Product: Generic Platform OHCI controller
[    2.134980] usb usb4: Manufacturer: Linux 4.4.126 ohci_hcd
[    2.134993] usb usb4: SerialNumber: fe3e0000.usb
[    2.135582] hub 4-0:1.0: USB hub found
[    2.135665] hub 4-0:1.0: 1 port detected
[    2.137117] usbcore: registered new interface driver cdc_acm
[    2.137132] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.137216] usbcore: registered new interface driver usblp
[    2.137315] usbcore: registered new interface driver cdc_wdm
[    2.137405] usbcore: registered new interface driver uas
[    2.137590] usbcore: registered new interface driver usb-storage
[    2.137654] usbcore: registered new interface driver ums-alauda
[    2.137744] usbcore: registered new interface driver ums-cypress
[    2.137802] usbcore: registered new interface driver ums-datafab
[    2.137862] usbcore: registered new interface driver ums_eneub6250
[    2.137951] usbcore: registered new interface driver ums-freecom
[    2.138009] usbcore: registered new interface driver ums-isd200
[    2.138067] usbcore: registered new interface driver ums-jumpshot
[    2.138130] usbcore: registered new interface driver ums-karma
[    2.138220] usbcore: registered new interface driver ums-onetouch
[    2.138278] usbcore: registered new interface driver ums-sddr09
[    2.138343] usbcore: registered new interface driver ums-sddr55
[    2.138432] usbcore: registered new interface driver ums-usbat
[    2.138548] usbcore: registered new interface driver usbserial
[    2.138630] usbcore: registered new interface driver usbserial_generic
[    2.138674] usbserial: USB Serial support registered for generic
[    2.138735] usbcore: registered new interface driver option
[    2.138778] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.139070] usbcore: registered new interface driver trancevibrator
[    2.139120] usb20_otg: version 3.10a 21-DEC-2012
[    2.139426] usb20_host: version 3.10a 21-DEC-2012
[    2.140266] usbcore: registered new interface driver xpad
[    2.140356] usbcore: registered new interface driver usb_acecad
[    2.140456] usbcore: registered new interface driver aiptek
[    2.140521] usbcore: registered new interface driver gtco
[    2.140593] usbcore: registered new interface driver hanwang
[    2.140690] usbcore: registered new interface driver kbtab
[    2.140728] ==gsl_ts_init==
[    2.140778] ret=0
[    2.141533] .. rk pwm remotectl v1.1 init
[    2.141862] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[    2.142475] sensor_register_slave:kxtj9,id=11
[    2.142530] sensor_register_slave:mma8452,id=17
[    2.142551] sensor_register_slave:lis3dh,id=7
[    2.142570] sensor_register_slave:mma7660,id=18
[    2.142619] sensor_register_slave:lsm303d,id=22
[    2.142637] sensor_register_slave:gs_mc3230,id=23
[    2.142646] [Gsensor]   gsensor_init
[    2.142664] sensor_register_slave:mpu6880_acc,id=24
[    2.142682] sensor_register_slave:mpu6500_acc,id=25
[    2.142700] sensor_register_slave:lsm330_acc,id=26
[    2.142718] sensor_register_slave:bma2xx_acc,id=27
[    2.142735] sensor_register_slave:akm8975,id=30
[    2.142754] sensor_register_slave:akm8963,id=31
[    2.142772] sensor_register_slave:l3g4200d,id=45
[    2.142791] sensor_register_slave:l3g20d,id=46
[    2.142840] sensor_register_slave:ewtsa,id=47
[    2.142854] sensor_register_slave:lsm330_gyro,id=51
[    2.142868] sensor_register_slave:cm3217,id=53
[    2.142881] sensor_register_slave:cm3218,id=54
[    2.142895] sensor_register_slave:ls_stk3410,id=62
[    2.142909] sensor_register_slave:ps_stk3410,id=67
[    2.143915] i2c /dev entries driver
[    2.144963] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80099ca000
[    2.146196] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    2.146306] fan53555-reg: supplied by vcc5v0_sys
[    2.148366] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    2.148475] fan53555-reg: supplied by vcc5v0_sys
[    2.150617] rk808 0-001b: Pmic Chip id: 0x0
[    2.153703] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    2.153824] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    2.153951] DCDC_REG1: supplied by vcc3v3_sys
[    2.154884] DCDC_REG2: supplied by vcc3v3_sys
[    2.155570] DCDC_REG3: supplied by vcc3v3_sys
[    2.155958] DCDC_REG4: supplied by vcc3v3_sys
[    2.156498] LDO_REG1: supplied by vcc3v3_sys
[    2.157698] LDO_REG2: supplied by vcc3v3_sys
[    2.158793] LDO_REG3: supplied by vcc3v3_sys
[    2.159901] LDO_REG4: supplied by vcc3v3_sys
[    2.161014] LDO_REG5: supplied by vcc3v3_sys
[    2.162059] LDO_REG6: supplied by vcc3v3_sys
[    2.163170] LDO_REG7: supplied by vcc3v3_sys
[    2.164297] LDO_REG8: supplied by vcc3v3_sys
[    2.165435] SWITCH_REG1: supplied by vcc3v3_sys
[    2.165858] SWITCH_REG2: supplied by vcc3v3_sys
[    2.169728] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[    2.170400] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80099cc000
[    2.171372] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80099ce000
[    2.171512] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[    2.171560] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[    2.171575] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer  on device rockchip-pinctrl
[    2.171588] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[    2.172065] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80099d0000
[    2.173396] IR NEC protocol handler initialized
[    2.173447] IR RC5(x/sz) protocol handler initialized
[    2.173466] IR RC6 protocol handler initialized
[    2.173517] IR JVC protocol handler initialized
[    2.173533] IR Sony protocol handler initialized
[    2.173548] IR SANYO protocol handler initialized
[    2.173564] IR Sharp protocol handler initialized
[    2.173579] IR MCE Keyboard/mouse protocol handler initialized
[    2.173594] IR XMP protocol handler initialized
[    2.173897] usbcore: registered new interface driver uvcvideo
[    2.173939] USB Video Class driver (1.1.1)
[    2.173962] CamSys driver version: v0.41.0, CamSys head file version: v1.0.0
[    2.179746] __power_supply_register: Expected proper parent device for 'test_ac'
[    2.179924] __power_supply_register: Expected proper parent device for 'test_battery'
[    2.180289] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[    2.180455] __power_supply_register: Expected proper parent device for 'test_usb'
[    2.184010] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[    2.185024] device-mapper: uevent: version 1.0.3
[    2.185488] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    2.185745] Bluetooth: HCI UART driver ver 2.3
[    2.185791] Bluetooth: HCI UART protocol H4 registered
[    2.185801] Bluetooth: HCI UART protocol LL registered
[    2.185817] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[    2.185826] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[    2.185834] rtk_btusb: Register usb char device interface for BT driver
[    2.186102] usbcore: registered new interface driver rtk_btusb
[    2.186739] cpu cpu0: cpu_leakage=17
[    2.186840] cpu cpu0: cpu_leakage=17
[    2.200395] cpu cpu0: temp=43888, pvtm=148956 (148824 + 132)
[    2.201344] cpu cpu4: cpu_leakage=32
[    2.201457] cpu cpu4: cpu_leakage=32
[    2.214554] cpu cpu4: temp=43888, pvtm=153670 (153600 + 70)
[    2.221248] sdhci: Secure Digital Host Controller Interface driver
[    2.221303] sdhci: Copyright(c) Pierre Ossman
[    2.221325] Synopsys Designware Multimedia Card Interface Driver
[    2.222559] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    2.222735] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    2.222789] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    2.222854] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    2.222888] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.222974] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    2.222986] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    2.224105] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    2.224200] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    2.224253] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    2.224305] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[    2.224329] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.224453] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[    2.225410] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.227439] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[    2.227456] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[    2.254171] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    2.256313] hidraw: raw HID events driver (C) Jiri Kosina
[    2.258914] usbcore: registered new interface driver usbhid
[    2.258928] usbhid: USB HID core driver
[    2.259058] inv_mpu_iio: inv_mpu_init:746
[    2.259717] ashmem: initialized
[    2.263319] ff100000.saradc supply vref not found, using dummy regulator
[    2.265556] rknandbase v1.2 2018-05-08
[    2.266649] usbcore: registered new interface driver snd-usb-audio
[    2.281304] gpiod_direction_output: invalid GPIO
[    2.281352] gpiod_direction_output: invalid GPIO
[    2.281369] gpiod_direction_output: invalid GPIO
[    2.292540] tc358749x 1-000f: tc358749x_i2c_probe success
[    2.295597] mmc0: MAN_BKOPS_EN bit is not set
[    2.299140] rk-hdmi-dp-sound hdmi-dp-sound: i2s-hifi <-> ff8a0000.i2s mapping ok
[    2.301922] u32 classifier
[    2.301952]     Actions configured
[    2.302010] Netfilter messages via NETLINK v0.30.
[    2.302108] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    2.302593] ctnetlink v0.93: registering with nfnetlink.
[    2.303597] xt_time: kernel timezone is -0000
[    2.304540] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.304896] arp_tables: (C) 2002 David S. Miller
[    2.305529] Initializing XFRM netlink socket
[    2.306128] NET: Registered protocol family 10
[    2.307419] mip6: Mobile IPv6
[    2.307491] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    2.308608] sit: IPv6 over IPv4 tunneling driver
[    2.309253] NET: Registered protocol family 17
[    2.309323] NET: Registered protocol family 15
[    2.309374] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    2.309406] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    2.310002] Bridge firewalling registered
[    2.310054] Ebtables v2.0 registered
[    2.310147] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[    2.310309] Bluetooth: RFCOMM TTY layer initialized
[    2.310335] Bluetooth: RFCOMM socket layer initialized
[    2.310358] Bluetooth: RFCOMM ver 1.11
[    2.310384] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    2.310392] Bluetooth: BNEP filters: protocol multicast
[    2.310405] Bluetooth: BNEP socket layer initialized
[    2.310418] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.310429] Bluetooth: HIDP socket layer initialized
[    2.310433] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[    2.310474] l2tp_core: L2TP core driver, V2.0
[    2.310512] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    2.310525] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    2.310685] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[    2.310893] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    2.310946] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[    2.310958] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    2.310966] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    2.311042] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[    2.311050] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    2.311060] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    2.311121] [BT_RFKILL]: Enter rfkill_rk_init
[    2.311151] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[    2.311494] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[    2.311543] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[    2.311575] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[    2.311607] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[    2.311634] rkpart: partition size too small (1)
[    2.311653]      uboot: 0x000400000 -- 0x000800000 (4 MB)
[    2.311663]      trust: 0x000800000 -- 0x000c00000 (4 MB)
[    2.311673]       misc: 0x000c00000 -- 0x001000000 (4 MB)
[    2.311682]   resource: 0x001000000 -- 0x002000000 (16 MB)
[    2.311690]     kernel: 0x002000000 -- 0x004000000 (32 MB)
[    2.311698]       boot: 0x004000000 -- 0x006000000 (32 MB)
[    2.311706]   recovery: 0x006000000 -- 0x00a000000 (64 MB)
[    2.311715]     backup: 0x00a000000 -- 0x011000000 (112 MB)
[    2.311723]   security: 0x011000000 -- 0x011400000 (4 MB)
[    2.311731]      cache: 0x011400000 -- 0x031400000 (512 MB)
[    2.311740]     system: 0x031400000 -- 0x0d1400000 (2560 MB)
[    2.311748]   metadata: 0x0d1400000 -- 0x0d2400000 (16 MB)
[    2.311757]     vendor: 0x0d2400000 -- 0x0f2400000 (512 MB)
[    2.311765]        oem: 0x0f2800000 -- 0x112800000 (512 MB)
[    2.311773]        frp: 0x112800000 -- 0x112880000 (0 MB)
[    2.311781]   userdata: 0x112880000 -- 0x3a3a00000 (10513 MB)
[    2.311858]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
[    2.311914] [BT_RFKILL]: Request irq for bt wakeup host
[    2.311953] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[    2.311971] [BT_RFKILL]: ** disable irq
[    2.312101] [BT_RFKILL]: bt_default device registered.
[    2.312242] sensor_register_slave:mpu6500_gyro,id=49
[    2.312259] sensor_register_slave:mpu6880_gyro,id=50
[    2.313619] Registered cp15_barrier emulation handler
[    2.313718] Registered setend emulation handler
[    2.314391] registered taskstats version 1
[    2.315096] rockchip ion idev is NULL
[    2.315115] rga2 ff680000.rga: rga ion client create success!
[    2.315318] rga: Driver loaded successfully ver:3.02
[    2.320013] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[    2.320204] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 5
[    2.320516] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[    2.320565] xhci-hcd xhci-hcd.10.auto: irq 235, io mem 0xfe800000
[    2.320773] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    2.320791] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.320802] usb usb5: Product: xHCI Host Controller
[    2.320811] usb usb5: Manufacturer: Linux 4.4.126 xhci-hcd
[    2.320820] usb usb5: SerialNumber: xhci-hcd.10.auto
[    2.321286] hub 5-0:1.0: USB hub found
[    2.321325] hub 5-0:1.0: 1 port detected
[    2.321596] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[    2.321869] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 6
[    2.322018] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.322237] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[    2.322259] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.322272] usb usb6: Product: xHCI Host Controller
[    2.322301] usb usb6: Manufacturer: Linux 4.4.126 xhci-hcd
[    2.322329] usb usb6: SerialNumber: xhci-hcd.10.auto
[    2.323282] hub 6-0:1.0: USB hub found
[    2.323334] hub 6-0:1.0: 1 port detected
[    2.326402] xhci-hcd xhci-hcd.10.auto: remove, state 1
[    2.326451] usb usb6: USB disconnect, device number 1
[    2.334063] usb 2-1: new high-speed USB device number 2 using ehci-platform
[    2.350562] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
[    2.350576] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
[    2.350719] xhci-hcd xhci-hcd.10.auto: USB bus 6 deregistered
[    2.350899] xhci-hcd xhci-hcd.10.auto: remove, state 1
[    2.350919] usb usb5: USB disconnect, device number 1
[    2.351340] xhci-hcd xhci-hcd.10.auto: USB bus 5 deregistered
[    2.354285] vendor storage:20160801 ret = 0
[    2.355970] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[    2.356176] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 5
[    2.356487] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[    2.356534] xhci-hcd xhci-hcd.11.auto: irq 236, io mem 0xfe900000
[    2.356723] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    2.356740] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.356750] usb usb5: Product: xHCI Host Controller
[    2.356759] usb usb5: Manufacturer: Linux 4.4.126 xhci-hcd
[    2.356768] usb usb5: SerialNumber: xhci-hcd.11.auto
[    2.357242] hub 5-0:1.0: USB hub found
[    2.357317] hub 5-0:1.0: 1 port detected
[    2.357796] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[    2.358021] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 6
[    2.358203] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.358467] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[    2.358482] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.358492] usb usb6: Product: xHCI Host Controller
[    2.358501] usb usb6: Manufacturer: Linux 4.4.126 xhci-hcd
[    2.358510] usb usb6: SerialNumber: xhci-hcd.11.auto
[    2.358935] hub 6-0:1.0: USB hub found
[    2.359008] hub 6-0:1.0: 1 port detected
[    2.360426] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    2.360535] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    2.360553] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    2.360589] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    2.360615] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.360656] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    2.360665] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    2.360997] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[    2.377585] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.391197] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[    2.394555] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    2.394785] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    2.394835] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    2.394903] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[    2.394964] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.395165] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[    2.396062] dwmmc_rockchip fe320000.dwmmc: allocated mmc-pwrseq
[    2.396377] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[    2.396413] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[    2.407470] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.422316] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[    2.436221] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    2.437485] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mapping ok
[    2.438092] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.439808] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.440679] asoc-simple-card rt5640-sound: rt5640-aif2 <-> ff890000.i2s mapping ok
[    2.442362] asoc-simple-card rt5640-sound: tc358749x-audio <-> ff890000.i2s mapping ok
[    2.442794] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    2.454909] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input1
[    2.455408] usb 2-1: New USB device found, idVendor=1a40, idProduct=0201
[    2.455532] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.455558] usb 2-1: Product: USB 2.0 Hub [MTT]
[    2.457140] hub 2-1:1.0: USB hub found
[    2.457526] hub 2-1:1.0: 7 ports detected
[    2.460040] asoc-simple-card spdif-sound: dit-hifi <-> ff870000.spdif mapping ok
[    2.464493] rk808-rtc rk808-rtc: setting system clock to 2018-10-25 08:24:20 UTC (1540455860)
[    2.465827] It doesn't contain Rogue gpu
[    2.495454] 80     ret 1024
[    2.498185] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 415; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '-14a50f9', rk_ko_ver is '5', built at '15:53:51', on 'Oct 23 2018'.
[    2.498562] Mali: Mali device driver loaded
[    2.499016] input: rk29-keypad as /devices/platform/rockchip-key/input/input2
[    2.499918] ALSA device list:
[    2.499949]   #0: rk-hdmi-dp-sound
[    2.499957]   #1: rockchip,rt5640-codec
[    2.499965]   #2: ROCKCHIP,SPDIF
[    2.500499] Freeing unused kernel memory: 832K
[    2.502310] mmc_host mmc1: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[    2.514305] init: init first stage started!
[    2.515573] init: Using Android DT directory /proc/device-tree/firmware/android/
[    2.610493] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: barrier=1,inode_readahead_blks=8
[    2.610808] init: [libfs_mgr]__mount(source=/dev/block/by-name/system,target=/system,type=ext4)=0: Success
[    2.619533] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: barrier=1,inode_readahead_blks=8
[    2.619652] init: [libfs_mgr]__mount(source=/dev/block/by-name/vendor,target=/vendor,type=ext4)=0: Success
[    2.619875] init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
[    2.619923] init: Loading SELinux policy
[    2.664112] usb 5-1: new low-speed USB device number 2 using xhci-hcd
[    2.718845] audit: type=1403 audit(1540455860.750:2): policy loaded auid=4294967295 ses=4294967295
[    2.719108] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
[    2.719108]
[    2.722761] selinux: SELinux: Loaded file_contexts
[    2.722761]
[    2.723871] random: init: uninitialized urandom read (40 bytes read, 41 bits of entropy available)
[    2.724890] init: init second stage started!
[    2.727489] usb 2-1.7: new high-speed USB device number 3 using ehci-platform
[    2.730847] init: Using Android DT directory /proc/device-tree/firmware/android/
[    2.731291] init: Set boot.mode to emmc
[    2.731380] init: property_set("ro.boot.mode", "emmc") failed: property already set
[    2.733426] selinux: SELinux: Loaded file_contexts
[    2.733426]
[    2.733917] selinux: SELinux: Loaded property_contexts from /system/etc/selinux/plat_property_contexts & /vendor/etc/selinux/nonplat_property_contexts.
[    2.733917]
[    2.733950] init: Running restorecon...
[    2.738394] init: waitid failed: No child processes
[    2.739436] init: Couldn't load property file: Unable to open '/odm/default.prop': No such file or directory: No such file or directory
[    2.741355] init: Created socket '/dev/socket/property_service', mode 666, user 0, group 0
[    2.741565] init: Parsing file /init.rc...
[    2.741992] init: Added '/init.environ.rc' to import list
[    2.742153] init: Added '/init.usb.rc' to import list
[    2.742380] init: Added '/init.rk30board.rc' to import list
[    2.742602] init: Added '/vendor/etc/init/hw/init.rk30board.rc' to import list
[    2.742822] init: Added '/init.usb.configfs.rc' to import list
[    2.743047] init: Added '/init.zygote64_32.rc' to import list
[    2.744390] init: Parsing file /init.environ.rc...
[    2.744544] init: Parsing file /init.usb.rc...
[    2.745047] init: Parsing file /init.rk30board.rc...
[    2.745308] init: Added 'init.rk30board.bootmode.emmc.rc' to import list
[    2.745384] init: Added 'init.rockchip.rc' to import list
[    2.745605] init: Added 'init.connectivity.rc' to import list
[    2.745828] init: Added 'init.box.samba.rc' to import list
[    2.746054] init: Added 'init.rk3399.rc' to import list
[    2.746279] init: Added 'init.tablet.rc' to import list
[    2.746498] init: Added 'init.car.rc' to import list
[    2.746721] init: Added 'init.optee.rc' to import list
[    2.747540] init: Parsing file init.rk30board.bootmode.emmc.rc...
[    2.747607] init: Parsing file init.rockchip.rc...
[    2.747684] init: Added 'init.rk30board.usb.rc' to import list
[    2.747723] init: Added 'init.rk30board.environment.rc' to import list
[    2.747737] init: Added '/init.debug.rc' to import list
[    2.748003] init: Parsing file init.rk30board.usb.rc...
[    2.748227] init: Parsing file init.rk30board.environment.rc...
[    2.748296] init: Parsing file /init.debug.rc...
[    2.748326] init: Unable to open '/init.debug.rc': No such file or directory
[    2.748346] init: /init.rc: 3: Could not import file '/init.debug.rc': No such file or directory
[    2.748391] init: Parsing file init.connectivity.rc...
[    2.748572] init: Parsing file init.box.samba.rc...
[    2.748626] init: Unable to open 'init.box.samba.rc': No such file or directory
[    2.748642] init: /init.rc: 4: Could not import file 'init.box.samba.rc': No such file or directory
[    2.748663] init: Parsing file init.rk3399.rc...
[    2.748766] init: init.rk3399.rc: 25: invalid keyword 'ioprio'
[    2.748876] init: Parsing file init.tablet.rc...
[    2.748916] init: Unable to open 'init.tablet.rc': No such file or directory
[    2.748932] init: /init.rc: 6: Could not import file 'init.tablet.rc': No such file or directory
[    2.748953] init: Parsing file init.car.rc...
[    2.748979] init: Unable to open 'init.car.rc': No such file or directory
[    2.748994] init: /init.rc: 7: Could not import file 'init.car.rc': No such file or directory
[    2.749015] init: Parsing file init.optee.rc...
[    2.749041] init: Unable to open 'init.optee.rc': No such file or directory
[    2.749056] init: /init.rc: 8: Could not import file 'init.optee.rc': No such file or directory
[    2.749598] init: Parsing file /vendor/etc/init/hw/init.rk30board.rc...
[    2.749648] init: Unable to open '/vendor/etc/init/hw/init.rk30board.rc': No such file or directory
[    2.749662] init: /init.rc: 10: Could not import file '/vendor/etc/init/hw/init.rk30board.rc': No such file or directory
[    2.749681] init: Parsing file /init.usb.configfs.rc...
[    2.750156] init: Parsing file /init.zygote64_32.rc...
[    2.750323] init: Parsing directory /system/etc/init...
[    2.751088] init: Parsing file /system/etc/init/android.hidl.allocator@1.0-service.rc...
[    2.751581] init: Parsing file /system/etc/init/atrace.rc...
[    2.752313] init: Parsing file /system/etc/init/atrace_userdebug.rc...
[    2.752843] init: Parsing file /system/etc/init/audioserver.rc...
[    2.753363] init: Parsing file /system/etc/init/bootanim.rc...
[    2.753863] init: Parsing file /system/etc/init/bootstat.rc...
[    2.754346] init: Parsing file /system/etc/init/cameraserver.rc...
[    2.754786] init: Parsing file /system/etc/init/drmserver.rc...
[    2.755320] init: Parsing file /system/etc/init/dumpstate.rc...
[    2.755607] init: Parsing file /system/etc/init/gatekeeperd.rc...
[    2.755864] init: Parsing file /system/etc/init/hwservicemanager.rc...
[    2.756150] init: Parsing file /system/etc/init/init-debug.rc...
[    2.756435] init: Parsing file /system/etc/init/installd.rc...
[    2.756888] init: Parsing file /system/etc/init/keystore.rc...
[    2.757177] init: Parsing file /system/etc/init/lmkd.rc...
[    2.757448] init: Parsing file /system/etc/init/logcatd.rc...
[    2.757789] init: Parsing file /system/etc/init/logd.rc...
[    2.758091] init: Parsing file /system/etc/init/logtagd.rc...
[    2.758386] init: Parsing file /system/etc/init/mdnsd.rc...
[    2.758664] init: Parsing file /system/etc/init/mediadrmserver.rc...
[    2.758960] init: Parsing file /system/etc/init/mediaextractor.rc...
[    2.759236] init: Parsing file /system/etc/init/mediametrics.rc...
[    2.759504] init: Parsing file /system/etc/init/mediaserver.rc...
[    2.759803] init: Parsing file /system/etc/init/mtpd.rc...
[    2.760088] init: Parsing file /system/etc/init/netd.rc...
[    2.760375] init: Parsing file /system/etc/init/perfprofd.rc...
[    2.760646] init: Parsing file /system/etc/init/racoon.rc...
[    2.760939] init: Parsing file /system/etc/init/servicemanager.rc...
[    2.761229] init: Parsing file /system/etc/init/storaged.rc...
[    2.761520] init: Parsing file /system/etc/init/surfaceflinger.rc...
[    2.761833] init: Parsing file /system/etc/init/thermalservice.rc...
[    2.762095] init: Parsing file /system/etc/init/tombstoned.rc...
[    2.762373] init: Parsing file /system/etc/init/uncrypt.rc...
[    2.762675] init: Parsing file /system/etc/init/vdc.rc...
[    2.762966] init: Parsing file /system/etc/init/vold.rc...
[    2.763248] init: Parsing file /system/etc/init/webview_zygote32.rc...
[    2.763538] init: Parsing file /system/etc/init/webview_zygote64.rc...
[    2.763815] init: Parsing file /system/etc/init/wifi-events.rc...
[    2.764219] init: Parsing file /system/etc/init/wificond.rc...
[    2.764529] init: Parsing directory /vendor/etc/init...
[    2.764688] init: Parsing file /vendor/etc/init/android.hardware.audio@2.0-service.rc...
[    2.765060] init: Parsing file /vendor/etc/init/android.hardware.bluetooth@1.0-service.rc...
[    2.765349] init: Parsing file /vendor/etc/init/android.hardware.camera.provider@2.4-service.rc...
[    2.765626] init: Parsing file /vendor/etc/init/android.hardware.cas@1.0-service.rc...
[    2.765901] init: Parsing file /vendor/etc/init/android.hardware.configstore@1.0-service.rc...
[    2.766169] init: Parsing file /vendor/etc/init/android.hardware.drm@1.0-service.rc...
[    2.766471] init: Parsing file /vendor/etc/init/android.hardware.drm@1.0-service.widevine.rc...
[    2.766747] init: Parsing file /vendor/etc/init/android.hardware.gnss@1.0-service.rc...
[    2.767036] init: /vendor/etc/init/android.hardware.gnss@1.0-service.rc: 1: ignored duplicate definition of service 'gnss_service'
[    2.767060] init: Parsing file /vendor/etc/init/android.hardware.graphics.allocator@2.0-service.rc...
[    2.767328] init: Parsing file /vendor/etc/init/android.hardware.graphics.composer@2.1-service.rc...
[    2.767638] init: Parsing file /vendor/etc/init/android.hardware.keymaster@3.0-service.rc...
[    2.767921] init: Parsing file /vendor/etc/init/android.hardware.light@2.0-service.rc...
[    2.768219] init: Parsing file /vendor/etc/init/android.hardware.media.omx@1.0-service.rc...
[    2.768522] init: Parsing file /vendor/etc/init/android.hardware.neuralnetworks@1.0-service-armnn.rc...
[    2.768803] init: Parsing file /vendor/etc/init/android.hardware.power@1.0-service.rc...
[    2.769095] init: Parsing file /vendor/etc/init/android.hardware.sensors@1.0-service.rc...
[    2.769395] init: Parsing file /vendor/etc/init/android.hardware.wifi@1.0-service.rc...
[    2.769690] init: Parsing file /vendor/etc/init/drmservice.rc...
[    2.769973] init: Parsing file /vendor/etc/init/hostapd.android.rc...
[    2.770241] init: Parsing file /vendor/etc/init/rild.rc...
[    2.770484] init: /vendor/etc/init/rild.rc: 1: ignored duplicate definition of service 'ril-daemon'
[    2.770508] init: Parsing file /vendor/etc/init/vndservicemanager.rc...
[    2.770803] init: Parsing file /odm/etc/init...
[    2.770832] init: Unable to open '/odm/etc/init': No such file or directory
[    2.770900] init: processing action (early-init) from (/init.rc:14)
[    2.775993] init: starting service 'ueventd'...
[    2.776504] cgroup: init (1) created nested cgroup for controller "memory" which has incomplete hierarchy support. Nested cgroups may change behavior in the future.
[    2.776529] cgroup: "memory" requires setting use_hierarchy to 1 on the root
[    2.776888] init: processing action (early-init) from (init.rockchip.rc:5)
[    2.781053] init: processing action (wait_for_coldboot_done) from (<Builtin Action>:0)
[    2.783451] random: ueventd: uninitialized urandom read (40 bytes read, 44 bits of entropy available)
[    2.788385] usb 5-1: New USB device found, idVendor=046d, idProduct=c077
[    2.788471] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.788496] usb 5-1: Product: USB Optical Mouse
[    2.788520] usb 5-1: Manufacturer: Logitech
[    2.790427] usb 5-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[    2.791126] ueventd: ueventd started!
[    2.791311] ueventd: Parsing file /ueventd.rc...
[    2.793716] ueventd: Parsing file /vendor/ueventd.rc...
[    2.793819] ueventd: Unable to open '/vendor/ueventd.rc': No such file or directory
[    2.793900] ueventd: Parsing file /odm/ueventd.rc...
[    2.794006] ueventd: Unable to open '/odm/ueventd.rc': No such file or directory
[    2.794292] ueventd: Parsing file /ueventd.rk30board.rc...
[    2.796036] ueventd: /ueventd.rk30board.rc: 56: invalid gid 'net_bt_stack'
[    2.796138] ueventd: /ueventd.rk30board.rc: 57: invalid gid 'net_bt_stack'
[    2.796222] ueventd: /ueventd.rk30board.rc: 58: invalid gid 'net_bt_stack'
[    2.796316] ueventd: /ueventd.rk30board.rc: 60: invalid gid 'net_bt_stack'
[    2.797026] ueventd: /ueventd.rk30board.rc: 114: invalid gid 'trace'
[    2.802399] input: Logitech USB Optical Mouse as /devices/platform/usb@fe900000/fe900000.dwc3/xhci-hcd.11.auto/usb5/5-1/5-1:1.0/0003:046D:C077.0001/input/input3
[    2.811529] selinux: SELinux: Loaded file_contexts
[    2.811529]
[    2.826822] usb 2-1.7: New USB device found, idVendor=0781, idProduct=5583
[    2.826858] usb 2-1.7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.826868] usb 2-1.7: Product: Ultra Fit
[    2.826877] usb 2-1.7: Manufacturer: SanDisk
[    2.826884] usb 2-1.7: SerialNumber: 4C531001480520104392
[    2.827676] usb-storage 2-1.7:1.0: USB Mass Storage device detected
[    2.828461] scsi host0: usb-storage 2-1.7:1.0
[    2.854678] hid-generic 0003:046D:C077.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-xhci-hcd.11.auto-1/input0
[    2.879338] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 110
[    2.881694] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[    2.881734] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[    2.925685] selinux: SELinux: Loaded file_contexts
[    2.925685]
[    3.009276] ueventd: Coldboot took 0.197 seconds
[    3.014384] init: Command 'wait_for_coldboot_done' action=wait_for_coldboot_done (<Builtin Action>:0) returned 0 took 233ms.
[    3.014455] init: processing action (mix_hwrng_into_linux_rng) from (<Builtin Action>:0)
[    3.014503] init: /dev/hw_random not found
[    3.014533] init: processing action (set_mmap_rnd_bits) from (<Builtin Action>:0)
[    3.015121] init: processing action (set_kptr_restrict) from (<Builtin Action>:0)
[    3.015308] init: processing action (keychord_init) from (<Builtin Action>:0)
[    3.015379] keychord: using input dev ff420030.pwm for fevent
[    3.015391] keychord: using input dev rk29-keypad for fevent
[    3.015431] init: processing action (console_init) from (<Builtin Action>:0)
[    3.015474] init: processing action (init) from (/init.rc:44)
[    3.015685] init: Unable to open '/default.prop': Too many symbolic links encountered
[    3.023622] init: Unable to open '/proc/cpu/alignment': No such file or directory
[    3.034598] Registered swp emulation handler
[    3.034784] init: Unable to open '/sys/class/leds/vibrator/trigger': No such file or directory
[    3.034831] init: processing action (init) from (/init.environ.rc:2)
[    3.034971] init: processing action (init) from (/init.rk30board.rc:49)
[    3.035023] init: Unable to open '/sys/module/rockchip_pm/parameters/policy': No such file or directory
[    3.035133] init: processing action (init) from (init.rockchip.rc:16)
[    3.035526] init: processing action (init) from (init.rk30board.environment.rc:1)
[    3.035585] init: processing action (init) from (init.rk3399.rc:30)
[    3.036547] init: processing action (mix_hwrng_into_linux_rng) from (<Builtin Action>:0)
[    3.036598] init: /dev/hw_random not found
[    3.036632] init: processing action (late-init) from (/init.rc:270)
[    3.036703] init: processing action (queue_property_triggers) from (<Builtin Action>:0)
[    3.036759] init: processing action (fs) from (init.rk30board.bootmode.emmc.rc:1)
[    3.038638] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/oem
[    3.040969] EXT4-fs (mmcblk0p14): Ignoring removed nomblk_io_submit option
[    3.043013] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[    3.043253] init: [libfs_mgr]check_fs(): mount(/dev/block/by-name/oem,/oem,ext4)=0: Success
[    3.066166] init: [libfs_mgr]check_fs(): unmount(/oem) succeeded
[    3.067979] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/by-name/oem
[    3.076371] random: e2fsck: uninitialized urandom read (40 bytes read, 52 bits of entropy available)
[    3.110136] random: e2fsck: uninitialized urandom read (40 bytes read, 54 bits of entropy available)
[    3.119510] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[    3.119510]
[    3.119582] e2fsck: oem: clean, 15/32768 files, 6356/131072 blocks
[    3.119582]
[    3.122607] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[    3.122809] init: [libfs_mgr]__mount(source=/dev/block/by-name/oem,target=/oem,type=ext4)=0: Success
[    3.123550] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/cache
[    3.123645] init: [libfs_mgr]Filesystem on /dev/block/by-name/cache was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x2c6
[    3.124099] init: [libfs_mgr]check_fs(): mount(/dev/block/by-name/cache,/cache,ext4)=-1: No such file or directory
[    3.124152] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/by-name/cache
[    3.126870] random: e2fsck: uninitialized urandom read (40 bytes read, 54 bits of entropy available)
[    3.151850] random: e2fsck: uninitialized urandom read (40 bytes read, 54 bits of entropy available)
[    3.205945] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[    3.205945]
[    3.206045] e2fsck: /dev/block/by-name/cache: recovering journal
[    3.206045]
[    3.206067] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[    3.206067]
[    3.206091] e2fsck: Pass 2: Checking directory structure
[    3.206091]
[    3.206113] e2fsck: Pass 3: Checking directory connectivity
[    3.206113]
[    3.206134] e2fsck: Pass 4: Checking reference counts
[    3.206134]
[    3.206184] e2fsck: Pass 5: Checking group summary information
[    3.206184]
[    3.206206] e2fsck: /dev/block/by-name/cache: 20/32768 files (0.0% non-contiguous), 6398/131072 blocks
[    3.206206]
[    3.210650] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[    3.210919] init: [libfs_mgr]__mount(source=/dev/block/by-name/cache,target=/cache,type=ext4)=0: Success
[    3.211645] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
[    3.211770] init: [libfs_mgr]Filesystem on /dev/block/by-name/metadata was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x2c6
[    3.212851] EXT4-fs (mmcblk0p12): Ignoring removed nomblk_io_submit option
[    3.221831] EXT4-fs (mmcblk0p12): recovery complete
[    3.222321] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[    3.222807] init: [libfs_mgr]check_fs(): mount(/dev/block/by-name/metadata,/metadata,ext4)=0: Success
[    3.240590] init: [libfs_mgr]check_fs(): unmount(/metadata) succeeded
[    3.240807] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/by-name/metadata
[    3.244006] random: e2fsck: uninitialized urandom read (40 bytes read, 57 bits of entropy available)
[    3.267735] random: e2fsck: uninitialized urandom read (40 bytes read, 59 bits of entropy available)
[    3.271045] audit: type=1400 audit(1540455861.303:3): avc:  denied  { read } for  pid=239 comm="e2fsck" name="mmcblk0p12" dev="tmpfs" ino=11341 scontext=u:r:fsck:s0 tcontext=ubject_r:metadata_block_device:s0 tclass=blk_file permissive=1
[    3.271136] audit: type=1400 audit(1540455861.303:4): avc:  denied  { open } for  pid=239 comm="e2fsck" path="/dev/block/mmcblk0p12" dev="tmpfs" ino=11341 scontext=u:r:fsck:s0 tcontext=ubject_r:metadata_block_device:s0 tclass=blk_file permissive=1
[    3.271256] audit: type=1400 audit(1540455861.303:5): avc:  denied  { write } for  pid=239 comm="e2fsck" name="mmcblk0p12" dev="tmpfs" ino=11341 scontext=u:r:fsck:s0 tcontext=ubject_r:metadata_block_device:s0 tclass=blk_file permissive=1
[    3.271372] audit: type=1400 audit(1540455861.303:6): avc:  denied  { ioctl } for  pid=239 comm="e2fsck" path="/dev/block/mmcblk0p12" dev="tmpfs" ino=11341 ioctlcmd=127c scontext=u:r:fsck:s0 tcontext=ubject_r:metadata_block_device:s0 tclass=blk_file permissive=1
[    3.292515] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[    3.292515]
[    3.292586] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[    3.292586]
[    3.292604] e2fsck: Pass 2: Checking directory structure
[    3.292604]
[    3.292619] e2fsck: Pass 3: Checking directory connectivity
[    3.292619]
[    3.292634] e2fsck: Pass 4: Checking reference counts
[    3.292634]
[    3.292649] e2fsck: Pass 5: Checking group summary information
[    3.292649]
[    3.292703] e2fsck: /dev/block/by-name/metadata: 13/4096 files (15.4% non-contiguous), 1170/4096 blocks
[    3.292703]
[    3.299203] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[    3.299872] init: [libfs_mgr]__mount(source=/dev/block/by-name/metadata,target=/metadata,type=ext4)=0: Success
[    3.300182] init: [libfs_mgr]Running /system/bin/fsck.f2fs -a /dev/block/by-name/userdata
[    3.304386] random: fsck.f2fs: uninitialized urandom read (40 bytes read, 60 bits of entropy available)
[    3.313801] random: fsck.f2fs: uninitialized urandom read (40 bytes read, 60 bits of entropy available)
[    3.318584] fsck.f2fs: Info: Fix the reported corruption.
[    3.318584]
[    3.318657] fsck.f2fs: Info: Segments per section = 1
[    3.318657]
[    3.318674] fsck.f2fs: Info: Sections per zone = 1
[    3.318674]
[    3.318690] fsck.f2fs: Info: sector size = 512
[    3.318690]
[    3.318705] fsck.f2fs: Info: total sectors = 21531648 (10513 MB)
[    3.318705]
[    3.318720] fsck.f2fs:         Can't find a valid F2FS superblock at 0x0
[    3.318720]
[    3.318735] fsck.f2fs:         Can't find a valid F2FS superblock at 0x1
[    3.318735]
[    3.318753] fsck.f2fs: fsck.f2fs terminated by exit(255)
[    3.318753]
[    3.322363] F2FS-fs (mmcblk0p16): Magic Mismatch, valid(0xf2f52010) - read(0xc81526db)
[    3.322401] F2FS-fs (mmcblk0p16): Can't find valid F2FS filesystem in 1th superblock
[    3.322700] F2FS-fs (mmcblk0p16): Magic Mismatch, valid(0xf2f52010) - read(0xaca8376e)
[    3.322742] F2FS-fs (mmcblk0p16): Can't find valid F2FS filesystem in 2th superblock
[    3.322819] F2FS-fs (mmcblk0p16): Magic Mismatch, valid(0xf2f52010) - read(0xc81526db)
[    3.322841] F2FS-fs (mmcblk0p16): Can't find valid F2FS filesystem in 1th superblock
[    3.322862] F2FS-fs (mmcblk0p16): Magic Mismatch, valid(0xf2f52010) - read(0xaca8376e)
[    3.322881] F2FS-fs (mmcblk0p16): Can't find valid F2FS filesystem in 2th superblock
[    3.323173] init: [libfs_mgr]__mount(source=/dev/block/by-name/userdata,target=/data,type=f2fs)=-1: Invalid argument
[    3.323245] init: [libfs_mgr]Running /system/bin/fsck.f2fs -a /dev/block/by-name/userdata
[    3.340328] fsck.f2fs: Info: Fix the reported corruption.
[    3.340328]
[    3.340455] fsck.f2fs: Info: Segments per section = 1
[    3.340455]
[    3.340497] fsck.f2fs: Info: Sections per zone = 1
[    3.340497]
[    3.340536] fsck.f2fs: Info: sector size = 512
[    3.340536]
[    3.340574] fsck.f2fs: Info: total sectors = 21531648 (10513 MB)
[    3.340574]
[    3.340612] fsck.f2fs:         Can't find a valid F2FS superblock at 0x0
[    3.340612]
[    3.340650] fsck.f2fs:         Can't find a valid F2FS superblock at 0x1
[    3.340650]
[    3.340751] fsck.f2fs: fsck.f2fs terminated by exit(255)
[    3.340751]
[    3.343141] F2FS-fs (mmcblk0p16): Magic Mismatch, valid(0xf2f52010) - read(0xc81526db)
[    3.343185] F2FS-fs (mmcblk0p16): Can't find valid F2FS filesystem in 1th superblock
[    3.343959] init: [libfs_mgr]__mount(source=/dev/block/by-name/userdata,target=/data,type=f2fs)=-1: Invalid argument
[    3.344699] init: [libfs_mgr]fs_mgr_mount_all(): possibly an encryptable blkdev /dev/block/by-name/userdata for mount /data type f2fs
[    3.347501] init: Parsing file /odm/etc/init...
[    3.347595] init: Unable to open '/odm/etc/init': No such file or directory
[    3.347714] init: Command 'mount_all fstab.rk30board' action=fs (init.rk30board.bootmode.emmc.rc:7) returned 2 took 310ms.
[    3.347824] init: processing action (fs) from (/system/etc/init/logd.rc:18)
[    3.348331] init: processing action (fs) from (/system/etc/init/wifi-events.rc:17)
[    3.348408] init: processing action (post-fs) from (/init.rc:303)
[    3.350246] init: Couldn't load property file: Unable to open '/odm/build.prop': No such file or directory: No such file or directory
[    3.352002] init: property_set("ro.board.platform", "rk3399") failed: property already set
[    3.354371] init: property_set("ro.target.product", "tablet") failed: property already set
[    3.354604] init: Couldn't load property file: Unable to open '/factory/factory.prop': No such file or directory: No such file or directory
[    3.357046] init: /recovery not specified in fstab
[    3.360663] init: starting service 'logd'...
[    3.363659] init: starting service 'servicemanager'...
[    3.366369] init: Created socket '/dev/socket/logd', mode 666, user 1036, group 1036
[    3.366987] init: starting service 'hwservicemanager'...
[    3.368030] init: Created socket '/dev/socket/logdr', mode 666, user 1036, group 1036
[    3.369388] init: Created socket '/dev/socket/logdw', mode 222, user 1036, group 1036
[    3.369801] init: Opened file '/proc/kmsg', flags 0
[    3.370003] init: Opened file '/dev/kmsg', flags 1
[    3.371797] init: starting service 'vndservicemanager'...
[    3.377207] selinux: SELinux: Skipping restorecon_recursive(/cache)
[    3.377207]
[    3.382319] init: processing action (post-fs) from (/init.rk30board.rc:10)
[    3.382539] selinux: SELinux: Skipping restorecon_recursive(/metadata)
[    3.382539]
[    3.388137] init: insmod: open("/system/lib/modules/ump.ko") failed: No such file or directory
[    3.388299] init: insmod: open("/system/lib/modules/mali.ko") failed: No such file or directory
[    3.468487] mali ff9a0000.gpu: gpu_leakage=22
[    3.481683] mali ff9a0000.gpu: temp=44444, pvtm=123405 (123369 + 36)
[    3.484799] logd.auditd: start
[    3.484872] logd.klogd: 3480833241
[    3.486096] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[    3.486493] mali ff9a0000.gpu: Protected mode not available
[    3.488632] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[    3.489080] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 389; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[    3.494364] mali ff9a0000.gpu: Probed as mali0
[    3.494860] init: Command 'insmod /vendor/lib/modules/mali_kbase.ko' action=post-fs (/init.rk30board.rc:14) returned 0 took 106ms.
[    3.495026] init: insmod: open("/system/lib/modules/rk30_mirroring.ko") failed: No such file or directory
[    3.495846] init: finit_module for "/system/lib/modules/rk29-ipp.ko" failed: Exec format error
[    3.495990] init: insmod: open("/system/lib/modules/pvrsrvkm.ko") failed: No such file or directory
[    3.501792] zram0: detected capacity change from 0 to 1027579904
[    3.512278] binder: 246:246 ioctl 620a 0 returned -22
[    3.537396] mkswap: Swapspace size: 1003492k, UUID=5f9812b2-f7ce-46d8-90dd-06a949687ef9
[    3.538986] Adding 1003492k swap on /dev/block/zram0.  Priority:-1 extents:1 across:1003492k SS
[    3.539908] init: processing action (post-fs) from (init.rockchip.rc:34)
[    3.540186] init: processing action (post-fs) from (/system/etc/init/atrace.rc:3)
[    3.543693] init: Unable to open '/sys/kernel/tracing/tracing_on': No such file or directory
[    3.543859] init: processing action (post-fs) from (/system/etc/init/atrace_userdebug.rc:6)
[    3.545103] init: processing action (late-fs) from (/init.rc:363)
[    3.546004] init: starting service 'keymaster-3-0'...
[    3.547029] init: processing action (post-fs-data) from (/init.rc:371)
[    3.547971] init: starting service 'vold'...
[    3.549860] init: Created socket '/dev/socket/vold', mode 660, user 0, group 1009
[    3.550299] init: Unable to open '/data/system/entropy.dat': No such file or directory
[    3.550333] init: Created socket '/dev/socket/cryptd', mode 660, user 0, group 1009
[    3.551150] init: Unable to open '/data/misc/recovery/ro.build.fingerprint': No such file or directory
[    3.551672] init: Unable to open '/data/misc/recovery/proc/version': No such file or directory
[    3.566431] init: starting service 'exec 1 (/system/bin/vdc --wait cryptfs init_user0)'...
[    3.567407] init: SVC_EXEC pid 263 (uid 0 gid 0+0 context default) started; waiting...
[    3.634698] init: Service 'exec 1 (/system/bin/vdc --wait cryptfs init_user0)' (pid 263) exited with status 0 waiting took 0.068000 seconds
[    3.643540] init: starting service 'exec 2 (/system/bin/tzdatacheck /system/usr/share/zoneinfo /data/misc/zoneinfo)'...
[    3.644639] init: SVC_EXEC pid 267 (uid 1000 gid 1000+0 context default) started; waiting...
[    3.655332] init: Service 'exec 2 (/system/bin/tzdatacheck /system/usr/share/zoneinfo /data/misc/zoneinfo)' (pid 267) exited with status 0 waiting took 0.012000 seconds
[    3.655561] init: processing action (post-fs-data) from (/init.usb.rc:6)
[    3.656595] init: processing action (post-fs-data) from (/init.rk30board.rc:25)
[    3.658249] init: Unable to find GID for 'system': getpwnam failed: No such file or directory
[    3.659164] init: Unable to open '/etc/ppp/pap-secrets': No such file or directory
[    3.660479] init: processing action (post-fs-data) from (init.rockchip.rc:38)
[    3.661255] tmpfs: Bad mount option background_gc
[    3.662291] init: processing action (post-fs-data) from (init.rk3399.rc:37)
[    3.662480] init: processing action (post-fs-data) from (/system/etc/init/bootstat.rc:3)
[    3.663476] init: processing action (post-fs-data) from (/system/etc/init/logtagd.rc:4)
[    3.664411] init: processing action (post-fs-data) from (/vendor/etc/init/hostapd.android.rc:9)
[    3.664885] init: processing action (load_persist_props_action) from (/init.rc:260)
[    3.664955] init: Couldn't load property file: Unable to open '/data/local.prop': No such file or directory: No such file or directory
[    3.665224] init: starting service 'logd-reinit'...
[    3.666279] init: processing action (load_persist_props_action) from (/system/etc/init/logcatd.rc:31)
[    3.666498] init: processing action (firmware_mounts_complete) from (/init.rc:266)
[    3.666693] init: processing action (early-boot) from (init.rk3399.rc:9)
[    3.668645] init: processing action (early-boot) from (/system/etc/init/installd.rc:5)
[    3.674879] init: processing action (boot) from (/init.rc:554)
[    3.675412] init: Unable to open '/proc/sys/vm/min_free_order_shift': No such file or directory
[    3.676637] logd.daemon: reinit
[    3.677146] init: Service 'logd-reinit' (pid 268) exited with status 0
[    3.677773] init: starting service 'gnss_service'...
[    3.679528] init: starting service 'hidl_memory'...
[    3.680887] init: starting service 'audio-hal-2-0'...
[    3.682319] init: starting service 'bluetooth-1-0'...
[    3.683614] init: starting service 'camera-provider-2-4'...
[    3.684899] init: starting service 'cas-hal-1-0'...
[    3.685218] init: couldn't write 273 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[    3.686539] init: starting service 'configstore-hal-1-0'...
[    3.687908] init: starting service 'drm-hal-1-0'...
[    3.689766] init: starting service 'drm-widevine-hal-1-0'...
[    3.693146] init: starting service 'gralloc-2-0'...
[    3.695299] init: starting service 'hwcomposer-2-1'...
[    3.697116] init: starting service 'light-hal-2-0'...
[    3.699313] init: starting service 'neuralnetworks_hal_service_armnn'...
[    3.701254] init: starting service 'power-hal-1-0'...
[    3.702851] init: starting service 'sensors-hal-1-0'...
[    3.704651] init: starting service 'wifi_hal_legacy'...
[    3.706256] init: starting service 'healthd'...
[    3.708404] init: cannot find '/system/bin/displayd', disabling 'displayd': No such file or directory
[    3.709015] init: starting service 'lmkd'...
[    3.710553] init: starting service 'surfaceflinger'...
[    3.712399] init: starting service 'thermalservice'...
[    3.714831] init: processing action (boot) from (/init.usb.rc:25)
[    3.714955] init: processing action (persist.sys.usb.config=* && boot) from (/init.usb.rc:106)
[    3.715020] init: processing action (boot) from (/init.rk30board.rc:56)
[    3.720307] init: Unable to open '/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold': No such file or directory
[    3.720760] init: Failed to bind socket 'pdx/system/vr/display/client': No such file or directory
[    3.721201] init: Failed to bind socket 'pdx/system/vr/display/manager': No such file or directory
[    3.721531] init: Failed to bind socket 'pdx/system/vr/display/vsync': No such file or directory
[    3.721862] init: Created socket '/dev/socket/lmkd', mode 660, user 1000, group 1000
[    3.753046] selinux: SELinux:  Could not stat /metadata/tee: No such file or directory.
[    3.753046]
[    3.754549] type=1400 audit(1540455861.786:7): avc: denied { read write } for pid=269 comm="android.hardwar" name="vndbinder" dev="tmpfs" ino=10637 scontext=u:r:hal_gnss_default:s0 tcontext=ubject_r:vndbinder_device:s0 tclass=chr_f
[    3.754973] init: processing action (boot) from (/init.rk30board.rc:316)
[    3.755284] init: starting service 'vm_daemon'...
[    3.756534] init: processing action (boot) from (init.rockchip.rc:56)
[    3.756665] init: Unable to find GID for 'net_bt_stack': getpwnam failed: No such file or directory
[    3.756696] init: processing action (boot) from (init.rk30board.usb.rc:1)
[    3.759657] type=1400 audit(1540455861.786:7): avc: denied { read write } for pid=269 comm="android.hardwar" name="vndbinder" dev="tmpfs" ino=10637 scontext=u:r:hal_gnss_default:s0 tcontext=ubject_r:vndbinder_device:s0 tclass=chr_f
[    3.759707] type=1400 audit(1540455861.786:8): avc: denied { open } for pid=269 comm="android.hardwar" path="/dev/vndbinder" dev="tmpfs" ino=10637 scontext=u:r:hal_gnss_default:s0 tcontext=ubject_r:vndbinder_device:s0 tclass=chr_f
[    3.759848] type=1400 audit(1540455861.786:8): avc: denied { open } for pid=269 comm="android.hardwar" path="/dev/vndbinder" dev="tmpfs" ino=10637 scontext=u:r:hal_gnss_default:s0 tcontext=ubject_r:vndbinder_device:s0 tclass=chr_f
[    3.759869] type=1400 audit(1540455861.786:9): avc: denied { getattr } for pid=1 comm="init" path="/vendor/bin/vm" dev="mmcblk0p13" ino=1077 scontext=u:r:init:s0 tcontext=ubject_r:su_exec:s0 tclass=f
[    3.760344] type=1400 audit(1540455861.786:9): avc: denied { getattr } for pid=1 comm="init" path="/vendor/bin/vm" dev="mmcblk0p13" ino=1077 scontext=u:r:init:s0 tcontext=ubject_r:su_exec:s0 tclass=f
[    3.760387] type=1400 audit(1540455861.786:10): avc: denied { ioctl } for pid=269 comm="android.hardwar" path="/dev/vndbinder" dev="tmpfs" ino=10637 ioctlcmd=6209 scontext=u:r:hal_gnss_default:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_f
[    3.760540] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
[    3.760574] init: write: cannot expand '${ro.serialno}'
[    3.761899] type=1400 audit(1540455861.786:10): avc: denied { ioctl } for pid=269 comm="android.hardwar" path="/dev/vndbinder" dev="tmpfs" ino=10637 ioctlcmd=6209 scontext=u:r:hal_gnss_default:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_f
[    3.761932] type=1400 audit(1540455861.793:12): avc: denied { read open } for pid=289 comm="init" path="/vendor/bin/vm" dev="mmcblk0p13" ino=1077 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[    3.763151] type=1400 audit(1540455861.793:12): avc: denied { read open } for pid=289 comm="init" path="/vendor/bin/vm" dev="mmcblk0p13" ino=1077 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[    3.763184] type=1400 audit(1540455861.793:13): avc: denied { transition } for pid=289 comm="init" path="/vendor/bin/vm" dev="mmcblk0p13" ino=1077 scontext=u:r:init:s0 tcontext=u:r:sudaemon:s0 tclass=proc
[    3.768297] file system registered
[    3.779841] using random self ethernet address
[    3.779859] using random host ethernet address
[    3.779948] init: Unable to open '/config/usb_gadget/g1/functions/rndis.gs4/wceis': Permission denied
[    3.782635] init: processing action (boot) from (init.connectivity.rc:2)
[    3.787160] init: processing action (boot) from (init.rk3399.rc:13)
[    3.806439] init: processing action (boot) from (/system/etc/init/bootstat.rc:57)
[    3.814235] init: processing action (boot) from (/system/etc/init/dumpstate.rc:1)
[    3.814484] init: processing action (enable_property_trigger) from (<Builtin Action>:0)
[    3.814702] init: processing action (security.perf_harden=1) from (/init.rc:702)
[    3.814848] init: processing action (ro.debuggable=1) from (/init.rc:730)
[    3.815428] init: starting service 'console'...
[    3.815894] type=1400 audit(1540455861.793:13): avc: denied { transition } for pid=289 comm="init" path="/vendor/bin/vm" dev="mmcblk0p13" ino=1077 scontext=u:r:init:s0 tcontext=u:r:sudaemon:s0 tclass=proc
[    3.818531] type=1400 audit(1540455861.846:23): avc: granted { read } for pid=1 comm="init" name="ttyFIQ0" dev="tmpfs" ino=16132 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[    3.818991] type=1400 audit(1540455861.846:23): avc: granted { read } for pid=1 comm="init" name="ttyFIQ0" dev="tmpfs" ino=16132 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[    3.819019] type=1400 audit(1540455861.846:24): avc: granted { read open } for pid=1 comm="init" path="/dev/ttyFIQ0" dev="tmpfs" ino=16132 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[    3.821671] type=1400 audit(1540455861.846:24): avc: granted { read open } for pid=1 comm="init" path="/dev/ttyFIQ0" dev="tmpfs" ino=16132 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[    3.821682] init: setpgid failed for console: Operation not permitted
[    3.821717] type=1400 audit(1540455861.853:25): avc: granted { read } for pid=291 comm="init" name="ttyFIQ0" dev="tmpfs" ino=16132 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[    3.824715] type=1400 audit(1540455861.853:25): avc: granted { read } for pid=291 comm="init" name="ttyFIQ0" dev="tmpfs" ino=16132 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[    3.824767] type=1400 audit(1540455861.853:26): avc: granted { read open } for pid=291 comm="init" path="/dev/ttyFIQ0" dev="tmpfs" ino=16132 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[    3.825529] init: processing action (ro.boot.mode=emmc) from (/init.rk30board.rc:256)
[    3.826182] drmboot: disagrees about version of symbol module_layout
[    3.826288] init: finit_module for "/drmboot.ko" failed: Exec format error
[    3.826489] init: processing action (ro.factory.hasUMS=false) from (init.rockchip.rc:130)
[    3.827002] init: processing action (sys.usb.config=mtp,adb && sys.usb.configfs=1) from (init.rk30board.usb.rc:43)
[    3.827305] init: processing action (sys.usb.config=mtp,adb && sys.usb.configfs=1) from (/init.usb.configfs.rc:33)
[    3.827562] init: starting service 'adbd'...
[    3.832524] init: Created socket '/dev/socket/adbd', mode 660, user 1000, group 1000
[    3.834512] init: processing action (defaultcrypto) from (/system/etc/init/vdc.rc:2)
[    3.835147] init: starting service 'exec 3 (/system/bin/vdc --wait cryptfs mountdefaultencrypted)'...
[    3.836545] init: SVC_EXEC pid 296 (uid 0 gid 0+0 context default) started; waiting...
[    3.838248] scsi 0:0:0:0: Direct-Access     SanDisk  Ultra Fit        1.00 PQ: 0 ANSI: 6
[    3.841567] healthd: unable to get HAL interface, using defaults
[    3.842814] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    3.843570] sd 0:0:0:0: [sda] 60062500 512-byte logical blocks: (30.8 GB/28.6 GiB)
[    3.844286] healthd: BatteryCurrentNowPath not found
[    3.844317] healthd: BatteryCycleCountPath not found
[    3.845015] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[    3.845114] sd 0:0:0:0: [sda] Write Protect is off
[    3.846587] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    3.860649]  sda: sda1
[    3.861684] read descriptors
[    3.861727] read strings
[    3.864365] init: Service 'exec 3 (/system/bin/vdc --wait cryptfs mountdefaultencrypted)' (pid 296) exited with status 0 waiting took 0.029000 seconds
[    3.868181] sd 0:0:0:0: [sda] Attached SCSI removable disk
rk3399_firefly_aio_mid:/ $ [    4.411705] E:camsys_extdev_register(258): Request RK30_PIN2_PD4(92) failed
[    4.422794] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[    4.423028] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[    4.434132] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[    4.434205] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[    4.434427] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout  on device rockchip-pinctrl
[    4.434648] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[    4.434869] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[    4.445944] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[    4.446179] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[    4.456131] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[    4.456214] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[    4.456434] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout  on device rockchip-pinctrl
[    4.456655] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[    4.456876] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[    4.467911] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[    4.468146] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[    4.495048] random: nonblocking pool is initialized
[    4.500088] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[    4.500493] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[    4.510658] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[    4.510793] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[    4.511007] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout  on device rockchip-pinctrl
[    4.511227] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[    4.511448] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[    4.522722] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[    4.522983] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[    4.533475] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff920000.isp; cannot claim for ff910000.isp
[    4.533489] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[    4.533496] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout  on device rockchip-pinctrl
[    4.533502] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[    4.533507] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[    4.544487] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[    4.544734] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[    4.898686] init: starting service 'bootanim'...
[    5.211621] fsck.f2fs: Info: Fix the reported corruption.
[    5.211621]
[    5.211665] fsck.f2fs: Info: Segments per section = 1
[    5.211665]
[    5.211674] fsck.f2fs: Info: Sections per zone = 1
[    5.211674]
[    5.211683] fsck.f2fs: Info: sector size = 512
[    5.211683]
[    5.211691] fsck.f2fs: Info: total sectors = 21531648 (10513 MB)
[    5.211691]
[    5.211700] fsck.f2fs: Info: MKFS version
[    5.211700]
[    5.211709] fsck.f2fs:   "Linux version 4.4.126 (liangkd@tchip-server) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #203 SMP PREEMPT Tue Oct 23 15:54:13 CST 2018"
[    5.211709]
[    5.211717] fsck.f2fs: Info: FSCK version
[    5.211717]
[    5.211726] fsck.f2fs:   from "Linux version 4.4.126 (liangkd@tchip-server) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #203 SMP PREEMPT Tue Oct 23 15:54:13 CST 2018"
[    5.211726]
[    5.211735] fsck.f2fs:     to "Linux version 4.4.126 (liangkd@tchip-server) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #203 SMP PREEMPT Tue Oct 23 15:54:13 CST 2018"
[    5.211735]
[    5.211744] fsck.f2fs: Info: superblock features = 0 :
[    5.211744]
[    5.211753] fsck.f2fs: Info: superblock encrypt level = 0, salt = 00000000000000000000000000000000
[    5.211753]
[    5.211761] fsck.f2fs: Info: total FS sectors = 21531648 (10513 MB)
[    5.211761]
[    5.211769] fsck.f2fs: Info: CKPT version = 60f65ec6
[    5.211769]
[    5.211777] fsck.f2fs: Info: No error was reported
[    5.211777]
[    5.268302] init: processing action (vold.decrypt=trigger_post_fs_data) from (/init.rc:668)
[    5.268532] init: processing action (post-fs-data) from (/init.rc:371)
[    5.302407] init: starting service 'exec 4 (/system/bin/vdc --wait cryptfs init_user0)'...
[    5.303327] init: SVC_EXEC pid 378 (uid 0 gid 0+0 context default) started; waiting...
[    5.318599] init: Service 'exec 4 (/system/bin/vdc --wait cryptfs init_user0)' (pid 378) exited with status 0 waiting took 0.016000 seconds
[    5.318766] selinux: SELinux: Skipping restorecon_recursive(/data)
[    5.318766]
[    5.318990] init: starting service 'exec 5 (/system/bin/tzdatacheck /system/usr/share/zoneinfo /data/misc/zoneinfo)'...
[    5.319780] init: SVC_EXEC pid 381 (uid 1000 gid 1000+0 context default) started; waiting...
[    5.328700] init: Service 'exec 5 (/system/bin/tzdatacheck /system/usr/share/zoneinfo /data/misc/zoneinfo)' (pid 381) exited with status 0 waiting took 0.009000 seconds
[    5.328816] init: processing action (post-fs-data) from (/init.usb.rc:6)
[    5.330198] init: processing action (post-fs-data) from (/init.rk30board.rc:25)
[    5.331027] init: Unable to find GID for 'system': getpwnam failed: No such file or directory
[    5.331950] init: Unable to open '/etc/ppp/pap-secrets': No such file or directory
[    5.333607] init: processing action (post-fs-data) from (init.rockchip.rc:38)
[    5.337700] init: processing action (post-fs-data) from (init.rk3399.rc:37)
[    5.337867] init: processing action (post-fs-data) from (/system/etc/init/bootstat.rc:3)
[    5.342990] init: processing action (init.svc.bootanim=running && ro.crypto.type=block && post-fs-data) from (/system/etc/init/bootstat.rc:44)
[    5.343431] init: starting service 'exec 6 (/system/bin/bootstat -r post_decrypt_time_elapsed)'...
[    5.344832] init: SVC_EXEC pid 384 (uid 1000 gid 1007+0 context default) started; waiting...
[    5.355699] init: Service 'exec 6 (/system/bin/bootstat -r post_decrypt_time_elapsed)' (pid 384) exited with status 0 waiting took 0.012000 seconds
[    5.355821] init: processing action (post-fs-data) from (/system/etc/init/logtagd.rc:4)
[    5.357544] init: processing action (post-fs-data) from (/vendor/etc/init/hostapd.android.rc:9)
[    5.358547] init: processing action (vold.decrypt=trigger_load_persist_props) from (/init.rc:663)
[    5.358611] init: Couldn't load property file: Unable to open '/data/local.prop': No such file or directory: No such file or directory
[    5.394693] init: property_set("ro.persistent_properties.ready", "true") failed: property already set
[    5.395032] init: starting service 'logd-reinit'...
[    5.396112] init: property_set("ro.boottime.logd-reinit", "5391583766") failed: property already set
[    5.396477] init: processing action (vold.decrypt=trigger_restart_framework) from (/init.rc:676)
[    5.396685] init: ExecStart(update_verifier): Service not found
[    5.396985] init: cannot find '/system/bin/install-recovery.sh', disabling 'flash_recovery': No such file or directory
[    5.397164] init: cannot find '/system/bin/bplus_helper', disabling 'bplus_helper': No such file or directory
[    5.397596] init: service up_eth0 does not have a SELinux domain defined
[    5.397846] init: cannot find '/vendor/bin/rk_store_keybox', disabling 'rk_store_keybox': No such file or directory
[    5.398064] init: cannot find '/system/bin/akmd', disabling 'akmd': No such file or directory
[    5.398412] init: starting service 'ril-daemon'...
[    5.399824] init: starting service 'zygote'...
[    5.401322] init: starting service 'zygote_secondary'...
[    5.402741] init: starting service 'audioserver'...
[    5.402884] init: Created socket '/dev/socket/zygote_secondary', mode 660, user 0, group 1000
[    5.403096] init: Created socket '/dev/socket/zygote', mode 660, user 0, group 1000
[    5.404427] init: starting service 'cameraserver'...
[    5.405289] init: couldn't write 401 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[    5.405817] init: starting service 'drm'...
[    5.407193] init: starting service 'installd'...
[    5.408553] init: starting service 'keystore'...
[    5.410284] init: starting service 'mediadrm'...
[    5.411641] init: starting service 'mediaextractor'...
[    5.412795] init: starting service 'mediametrics'...
[    5.414017] init: starting service 'media'...
[    5.415884] init: starting service 'netd'...
[    5.417299] init: starting service 'storaged'...
[    5.420125] init: starting service 'wificond'...
[    5.421494] init: starting service 'mediacodec'...
[    5.423332] init: starting service 'drmservice'...
[    5.425291] init: starting service 'gatekeeperd'...
[    5.428412] init: cannot find '/system/xbin/perfprofd', disabling 'perfprofd': No such file or directory
[    5.428888] init: starting service 'tombstoned'...
[    5.431155] init: Created socket '/dev/socket/netd', mode 660, user 0, group 1000
[    5.431625] init: Created socket '/dev/socket/dnsproxyd', mode 660, user 0, group 3003
[    5.431915] init: Created socket '/dev/socket/mdns', mode 660, user 0, group 1000
[    5.432160] init: Created socket '/dev/socket/fwmarkd', mode 660, user 0, group 3003
[    5.436672] init: Opened file '/d/mmc0/mmc0:0001/ext_csd', flags 0
[    5.437392] init: processing action (persist.sys.usb.config=adb && vold.decrypt=trigger_restart_framework) from (/init.rk30board.rc:22)
[    5.437910] init: Created socket '/dev/socket/tombstoned_crash', mode 666, user 1000, group 1000
[    5.438262] init: processing action (persist.sys.usb.config=adb && vold.decrypt=trigger_restart_framework) from (/init.rk30board.rc:22)
[    5.443963] init: Created socket '/dev/socket/tombstoned_intercept', mode 666, user 1000, group 1000
[    5.444307] init: Created socket '/dev/socket/tombstoned_java_trace', mode 666, user 1000, group 1000
[    5.452621] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (init.rk30board.usb.rc:64)
[    5.452885] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (/init.usb.configfs.rc:18)
[    5.452956] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/init.usb.configfs.rc:21)
[    5.461736] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (init.rk30board.usb.rc:64)
[    5.461836] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (/init.usb.configfs.rc:18)
[    5.461863] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/init.usb.configfs.rc:21)
[    5.461983] init: Unable to write to '/config/usb_gadget/g1/UDC': Device or resource busy
[    5.469313] logd.daemon: reinit
[    5.471193] init: processing action (sys.serialno=*) from (/init.rk30board.rc:271)
[    5.471520] init: Service 'logd-reinit' (pid 396) exited with status 0
[    5.471809] init: Sending signal 9 to service 'adbd' (pid 294) process group...
[    5.472726] configfs-gadget gadget: unbind function 'Function FS Gadget'/ffffffc069c57c38
[    5.472819] android_work: did not send uevent (0 0           (null))
[    5.484688] init: Successfully killed process cgroup uid 0 pid 294 in 12ms
[    5.485113] init: Service 'adbd' (pid 294) killed by signal 9
[    5.498394] init: Service 'drmservice' (pid 413) exited with status 0
[    5.619301] Freeing drm_logo memory: 820K
[    5.678818] selinux: avc:  denied  { set } for property=telephony.lteOnCdmaDevice pid=397 uid=0 gid=1001 scontext=u:r:rild:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
[    5.678818]
[    6.023183] type=1400 audit(1540455861.853:26): avc: granted { read open } for pid=291 comm="init" path="/dev/ttyFIQ0" dev="tmpfs" ino=16132 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[    6.023224] type=1400 audit(1540455864.053:27): avc: denied { execute_no_trans } for pid=462 comm="HwBinder:271_1" path="/vendor/bin/sh" dev="mmcblk0p13" ino=1031 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:vendor_shell_exec:s0 tclass=f
[    6.038509] type=1400 audit(1540455864.053:27): avc: denied { execute_no_trans } for pid=462 comm="HwBinder:271_1" path="/vendor/bin/sh" dev="mmcblk0p13" ino=1031 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:vendor_shell_exec:s0 tclass=f
[    6.038561] type=1400 audit(1540455864.070:28): avc: denied { getattr } for pid=462 comm="sh" path="/vendor/bin/vm" dev="mmcblk0p13" ino=1077 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[    6.039653] type=1400 audit(1540455864.070:28): avc: denied { getattr } for pid=462 comm="sh" path="/vendor/bin/vm" dev="mmcblk0p13" ino=1077 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[    6.039680] type=1400 audit(1540455864.070:30): avc: denied { read open } for pid=464 comm="sh" path="/vendor/bin/vm" dev="mmcblk0p13" ino=1077 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[    6.040165] type=1400 audit(1540455864.070:30): avc: denied { read open } for pid=464 comm="sh" path="/vendor/bin/vm" dev="mmcblk0p13" ino=1077 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[    6.040189] type=1400 audit(1540455864.070:31): avc: denied { execute_no_trans } for pid=464 comm="sh" path="/vendor/bin/vm" dev="mmcblk0p13" ino=1077 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[    6.081450] init: Untracked pid 467 exited with status 0
[    6.138847] init: Untracked pid 478 exited with status 0
[    6.353998] audit: audit_lost=1 audit_rate_limit=20 audit_backlog_limit=64
[    6.354022] audit: rate limit exceeded
[    6.946562] init: Untracked pid 470 killed by signal 1
[    6.960126] init: Untracked pid 481 killed by signal 1
[    7.413479] capability: warning: `main' uses 32-bit capabilities (legacy support in use)
[    8.578818] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[    8.603370] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[    8.799044] init: processing action (sys.sysctl.extra_free_kbytes=*) from (/init.rc:692)
[    8.828581] init: starting service 'adbd'...
[    8.829568] init: property_set("ro.boottime.adbd", "8824976070") failed: property already set
[    8.830798] init: Created socket '/dev/socket/adbd', mode 660, user 1000, group 1000
[    8.835600] read descriptors
[    8.835661] read strings
[    8.836363] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/init.usb.configfs.rc:21)
[    9.243115] acc_open
[    9.243176] acc_release
[    9.373412] rk_gmac-dwmac fe300000.ethernet: rk_get_eth_addr: mac address: c6:ec:52:e3:bb:43
[    9.373430] eth0: device MAC address c6:ec:52:e3:bb:43
[    9.536521] type=1400 audit(1540455864.070:31): avc: denied { execute_no_trans } for pid=464 comm="sh" path="/vendor/bin/vm" dev="mmcblk0p13" ino=1077 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[    9.536589] type=1400 audit(1540455867.566:75): avc: denied { read } for pid=406 comm="Binder:406_1" name="u:object_r:ctsgts_prop:s0" dev="tmpfs" ino=16040 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[    9.536788] type=1400 audit(1540455867.566:75): avc: denied { read } for pid=406 comm="Binder:406_1" name="u:object_r:ctsgts_prop:s0" dev="tmpfs" ino=16040 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[    9.536821] type=1400 audit(1540455867.566:76): avc: denied { open } for pid=406 comm="Binder:406_1" path="/dev/__properties__/u:object_r:ctsgts_prop:s0" dev="tmpfs" ino=16040 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[    9.536961] type=1400 audit(1540455867.566:76): avc: denied { open } for pid=406 comm="Binder:406_1" path="/dev/__properties__/u:object_r:ctsgts_prop:s0" dev="tmpfs" ino=16040 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[    9.536990] type=1400 audit(1540455867.566:77): avc: denied { getattr } for pid=406 comm="Binder:406_1" path="/dev/__properties__/u:object_r:ctsgts_prop:s0" dev="tmpfs" ino=16040 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[    9.562663] sdcardfs version 2.0
[    9.562682] sdcardfs: dev_name -> /data/media
[    9.562687] sdcardfs: options -> fsuid=1023,fsgid=1023,multiuser,derive_gid,mask=6,userid=0,gid=1015
[    9.562693] sdcardfs: mnt -> ffffffc04d3aac60
[    9.562737] sdcardfs: mounted on top of /data/media type f2fs
[    9.569588] Remount options were mask=23,gid=9997 for vfsmnt ffffffc04b8cc020.
[    9.569614] sdcardfs : options - debug:1
[    9.569619] sdcardfs : options - gid:9997
[    9.569623] sdcardfs : options - mask:23
[    9.571032] Remount options were mask=7,gid=9997 for vfsmnt ffffffc04b8ccc60.
[    9.571049] sdcardfs : options - debug:1
[    9.571053] sdcardfs : options - gid:9997
[    9.571057] sdcardfs : options - mask:7
[    9.630632] init: starting service 'webview_zygote32'...
[    9.642482] init: Created socket '/dev/socket/webview_zygote', mode 660, user 1053, group 1000
[   11.193552] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   11.212898] sdcardfs version 2.0
[   11.212969] sdcardfs: dev_name -> /mnt/media_rw/28A4-542D
[   11.212978] sdcardfs: options -> fsuid=1023,fsgid=1023,mask=6,userid=0,gid=1015
[   11.212983] sdcardfs: mnt -> ffffffc064d43520
[   11.213037] sdcardfs: mounted on top of /mnt/media_rw/28A4-542D type vfat
[   11.214458] Remount options were mask=18,gid=9997 for vfsmnt ffffffc04b8b8c60.
[   11.214476] sdcardfs : options - debug:1
[   11.214480] sdcardfs : options - gid:9997
[   11.214485] sdcardfs : options - mask:18
[   11.215893] Remount options were mask=18,gid=9997 for vfsmnt ffffffc04b8b9c20.
[   11.215907] sdcardfs : options - debug:1
[   11.215911] sdcardfs : options - gid:9997
[   11.215914] sdcardfs : options - mask:18
[   11.531642] init: Service 'bootanim' (pid 368) exited with status 0
[   11.669255] init: processing action (sys.boot_completed=1) from (/init.rc:686)
[   11.669565] init: processing action (sys.boot_completed=1) from (/init.rk30board.rc:230)
[   11.671956] init: cannot find '/system/bin/glgps', disabling 'gpsd': No such file or directory
[   11.672153] init: starting service 'mode_switch'...
[   11.673533] type=1400 audit(1540455867.566:77): avc: denied { getattr } for pid=406 comm="Binder:406_1" path="/dev/__properties__/u:object_r:ctsgts_prop:s0" dev="tmpfs" ino=16040 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[   11.673589] type=1400 audit(1540455869.703:78): avc: denied { entrypoint } for pid=1010 comm="init" path="/system/bin/usb_mode_switch.sh" dev="mmcblk0p11" ino=1551 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[   11.676957] type=1400 audit(1540455869.703:78): avc: denied { entrypoint } for pid=1010 comm="init" path="/system/bin/usb_mode_switch.sh" dev="mmcblk0p11" ino=1551 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[   11.677011] type=1400 audit(1540455869.706:79): avc: denied { getattr } for pid=1010 comm="usb_mode_switch" path="/system/bin/sh" dev="mmcblk0p11" ino=1451 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[   11.679029] type=1400 audit(1540455869.706:79): avc: denied { getattr } for pid=1010 comm="usb_mode_switch" path="/system/bin/sh" dev="mmcblk0p11" ino=1451 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[   11.679066] type=1400 audit(1540455869.710:80): avc: denied { read } for pid=1010 comm="usb_mode_switch" path="/system/bin/sh" dev="mmcblk0p11" ino=1451 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[   11.680271] init: processing action (sys.boot_completed=1) from (init.rk3399.rc:1)
[   11.680754] init: processing action (sys.boot_completed=1 && sys.logbootcomplete=1) from (/system/etc/init/bootstat.rc:66)
[   11.681012] init: starting service 'exec 7 (/system/bin/bootstat --record_boot_complete)'...
[   11.683012] init: SVC_EXEC pid 1011 (uid 1000 gid 1007+0 context default) started; waiting...
[   11.687346] type=1400 audit(1540455869.710:80): avc: denied { read } for pid=1010 comm="usb_mode_switch" path="/system/bin/sh" dev="mmcblk0p11" ino=1451 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[   11.687434] type=1400 audit(1540455869.716:81): avc: denied { read } for pid=1010 comm="usb_mode_switch" name="usb_mode_switch.sh" dev="mmcblk0p11" ino=1551 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[   11.687641] type=1400 audit(1540455869.716:81): avc: denied { read } for pid=1010 comm="usb_mode_switch" name="usb_mode_switch.sh" dev="mmcblk0p11" ino=1551 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[   11.687659] type=1400 audit(1540455869.716:82): avc: denied { open } for pid=1010 comm="usb_mode_switch" path="/system/bin/usb_mode_switch.sh" dev="mmcblk0p11" ino=1551 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[   11.689956] type=1400 audit(1540455869.716:82): avc: denied { open } for pid=1010 comm="usb_mode_switch" path="/system/bin/usb_mode_switch.sh" dev="mmcblk0p11" ino=1551 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[   11.690026] type=1400 audit(1540455869.720:83): avc: denied { getattr } for pid=1012 comm="usb_mode_switch" path="/system/bin/toybox" dev="mmcblk0p11" ino=1586 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[   11.691747] type=1400 audit(1540455869.720:83): avc: denied { getattr } for pid=1012 comm="usb_mode_switch" path="/system/bin/toybox" dev="mmcblk0p11" ino=1586 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[   11.691775] type=1400 audit(1540455869.720:84): avc: denied { execute } for pid=1012 comm="usb_mode_switch" name="toybox" dev="mmcblk0p11" ino=1586 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[   11.691909] type=1400 audit(1540455869.720:84): avc: denied { execute } for pid=1012 comm="usb_mode_switch" name="toybox" dev="mmcblk0p11" ino=1586 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[   11.691924] type=1400 audit(1540455869.720:85): avc: denied { read open } for pid=1012 comm="usb_mode_switch" path="/system/bin/toybox" dev="mmcblk0p11" ino=1586 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[   11.692022] type=1400 audit(1540455869.720:85): avc: denied { read open } for pid=1012 comm="usb_mode_switch" path="/system/bin/toybox" dev="mmcblk0p11" ino=1586 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[   11.692036] type=1400 audit(1540455869.720:86): avc: denied { execute_no_trans } for pid=1012 comm="usb_mode_switch" path="/system/bin/toybox" dev="mmcblk0p11" ino=1586 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[   11.704388] init: Service 'exec 7 (/system/bin/bootstat --record_boot_complete)' (pid 1011) exited with status 0 waiting took 0.023000 seconds
[   11.705244] init: starting service 'exec 8 (/system/bin/bootstat --record_boot_reason)'...
[   11.706460] init: SVC_EXEC pid 1013 (uid 1000 gid 1007+0 context default) started; waiting...
[   11.708443] type=1400 audit(1540455869.720:86): avc: denied { execute_no_trans } for pid=1012 comm="usb_mode_switch" path="/system/bin/toybox" dev="mmcblk0p11" ino=1586 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[   11.708491] type=1400 audit(1540455869.740:87): avc: denied { getattr } for pid=1010 comm="usb_mode_switch" path="/sys/kernel/debug/usb@fe800000/rk_usb_force_mode" dev="debugfs" ino=8177 scontext=u:r:mode_switch:s0 tcontext=u:object_r:debugfs:s0 tclass=f
[   11.708674] type=1400 audit(1540455869.740:87): avc: denied { getattr } for pid=1010 comm="usb_mode_switch" path="/sys/kernel/debug/usb@fe800000/rk_usb_force_mode" dev="debugfs" ino=8177 scontext=u:r:mode_switch:s0 tcontext=u:object_r:debugfs:s0 tclass=f
[   11.708696] type=1400 audit(1540455869.740:88): avc: denied { write } for pid=1010 comm="usb_mode_switch" name="rk_usb_force_mode" dev="debugfs" ino=8177 scontext=u:r:mode_switch:s0 tcontext=u:object_r:debugfs:s0 tclass=f
[   11.708793] type=1400 audit(1540455869.740:88): avc: denied { write } for pid=1010 comm="usb_mode_switch" name="rk_usb_force_mode" dev="debugfs" ino=8177 scontext=u:r:mode_switch:s0 tcontext=u:object_r:debugfs:s0 tclass=f
[   11.708806] type=1400 audit(1540455869.740:89): avc: denied { open } for pid=1010 comm="usb_mode_switch" path="/sys/kernel/debug/usb@fe800000/rk_usb_force_mode" dev="debugfs" ino=8177 scontext=u:r:mode_switch:s0 tcontext=u:object_r:debugfs:s0 tclass=f
[   11.719272] init: Service 'exec 8 (/system/bin/bootstat --record_boot_reason)' (pid 1013) exited with status 0 waiting took 0.014000 seconds
[   11.720439] init: starting service 'exec 9 (/system/bin/bootstat --record_time_since_factory_reset)'...
[   11.722031] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[   11.722318] init: SVC_EXEC pid 1016 (uid 1000 gid 1007+0 context default) started; waiting...
[   11.722697] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 7
[   11.725594] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[   11.725656] xhci-hcd xhci-hcd.10.auto: irq 235, io mem 0xfe800000
[   11.725845] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[   11.725860] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   11.725869] usb usb7: Product: xHCI Host Controller
[   11.725878] usb usb7: Manufacturer: Linux 4.4.126 xhci-hcd
[   11.725885] usb usb7: SerialNumber: xhci-hcd.10.auto
[   11.728121] hub 7-0:1.0: USB hub found
[   11.728197] hub 7-0:1.0: 1 port detected
[   11.728504] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[   11.729453] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 8
[   11.729564] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[   11.729660] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[   11.729673] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   11.729682] usb usb8: Product: xHCI Host Controller
[   11.729691] usb usb8: Manufacturer: Linux 4.4.126 xhci-hcd
[   11.729698] usb usb8: SerialNumber: xhci-hcd.10.auto
[   11.732011] hub 8-0:1.0: USB hub found
[   11.732083] hub 8-0:1.0: 1 port detected
[   11.732394] rockchip-dwc3 usb@fe800000: USB HOST connected
[   11.732462] init: Service 'exec 9 (/system/bin/bootstat --record_time_since_factory_reset)' (pid 1016) exited with status 0 waiting took 0.012000 seconds
[   11.733648] init: starting service 'exec 10 (/system/bin/bootstat -l)'...
[   11.734925] init: SVC_EXEC pid 1017 (uid 1000 gid 1007+0 context default) started; waiting...
[   11.735157] init: Service 'mode_switch' (pid 1010) exited with status 0
[   11.753214] init: Service 'exec 10 (/system/bin/bootstat -l)' (pid 1017) exited with status 0 waiting took 0.020000 seconds
[   11.753598] init: processing action (sys.boot_completed=1 && sys.wifitracing.started=0) from (/system/etc/init/wifi-events.rc:20)
[   11.821857] init: processing action (sys.usb.config=none && sys.usb.configfs=1) from (init.rk30board.usb.rc:31)
[   11.822080] init: processing action (sys.usb.config=none && sys.usb.configfs=1) from (/init.usb.configfs.rc:1)
[   11.822285] configfs-gadget gadget: unbind function 'Function FS Gadget'/ffffffc069c57c38
[   11.822374] android_work: did not send uevent (0 0           (null))
[   11.822542] init: Sending signal 9 to service 'adbd' (pid 586) process group...
[   11.828030] init: Successfully killed process cgroup uid 0 pid 586 in 5ms
[   11.828500] init: Service 'adbd' (pid 586) killed by signal 9
[   11.830154] init: processing action (init.svc.adbd=stopped) from (init.rk30board.usb.rc:35)
[   11.830181] init: processing action (init.svc.adbd=stopped) from (/init.usb.configfs.rc:15)
[   11.871886] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (init.rk30board.usb.rc:64)
[   11.872012] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (/init.usb.configfs.rc:18)
[   11.872095] init: starting service 'adbd'...
[   11.873208] init: property_set("ro.boottime.adbd", "11868531542") failed: property already set
[   11.874705] init: Created socket '/dev/socket/adbd', mode 660, user 1000, group 1000
[   11.893672] read descriptors
[   11.893718] read strings
[   11.896694] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/init.usb.configfs.rc:21)
[   11.897446] dwc3 fe800000.dwc3: failed to enable ep0out
[   11.941997] init: processing action (sys.usb.config=none && sys.usb.configfs=1) from (init.rk30board.usb.rc:31)
[   11.942245] init: processing action (sys.usb.config=none && sys.usb.configfs=1) from (/init.usb.configfs.rc:1)
[   11.942469] configfs-gadget gadget: unbind function 'Function FS Gadget'/ffffffc068b26038
[   11.942803] android_work: did not send uevent (0 0           (null))
[   11.943270] init: Sending signal 9 to service 'adbd' (pid 1080) process group...
[   11.949175] init: Successfully killed process cgroup uid 0 pid 1080 in 5ms
[   11.950850] init: Service 'adbd' (pid 1080) killed by signal 9
[   11.953841] init: processing action (init.svc.adbd=stopped) from (init.rk30board.usb.rc:35)
[   11.954750] init: processing action (init.svc.adbd=stopped) from (/init.usb.configfs.rc:15)
[   11.992974] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (init.rk30board.usb.rc:64)
[   11.993072] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (/init.usb.configfs.rc:18)
[   11.993128] init: starting service 'adbd'...
[   11.994872] init: Created socket '/dev/socket/adbd', mode 660, user 1000, group 1000
[   11.996035] init: property_set("ro.boottime.adbd", "11989541721") failed: property already set
[   12.001217] read descriptors
[   12.001461] read strings
[   12.002027] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/init.usb.configfs.rc:21)
[   12.002774] dwc3 fe800000.dwc3: failed to enable ep0out
[   15.302526] type=1400 audit(1540455869.740:89): avc: denied { open } for pid=1010 comm="usb_mode_switch" path="/sys/kernel/debug/usb@fe800000/rk_usb_force_mode" dev="debugfs" ino=8177 scontext=u:r:mode_switch:s0 tcontext=u:object_r:debugfs:s0 tclass=f
[   15.302602] type=1400 audit(1540455873.330:90): avc: denied { read } for pid=1127 comm=".update.service" name="u:object_r:serialno_prop:s0" dev="tmpfs" ino=16054 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=f
[   15.303045] type=1400 audit(1540455873.330:90): avc: denied { read } for pid=1127 comm=".update.service" name="u:object_r:serialno_prop:s0" dev="tmpfs" ino=16054 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=f
[   15.303084] type=1400 audit(1540455873.333:91): avc: denied { open } for pid=1127 comm=".update.service" path="/dev/__properties__/u:object_r:serialno_prop:s0" dev="tmpfs" ino=16054 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=f
[   15.303289] type=1400 audit(1540455873.333:91): avc: denied { open } for pid=1127 comm=".update.service" path="/dev/__properties__/u:object_r:serialno_prop:s0" dev="tmpfs" ino=16054 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=f
[   15.303321] type=1400 audit(1540455873.333:92): avc: denied { getattr } for pid=1127 comm=".update.service" path="/dev/__properties__/u:object_r:serialno_prop:s0" dev="tmpfs" ino=16054 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=f
[   63.845194] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
1500000
Posted at 11/8/2018 19:32:45        Only Author  5#
RakeshDesai Posted at 11/7/2018 18:12
Hi Leung,
Pls see debug log :
I had found out the problem . It will be fixed later .
Posted at 1/11/2026 09:16:18        Only Author  6#
The content of the article is thought-provoking, and Ive learned a lot from it. Free Reliable CAS-005 test pass4sure resources for exam success. Wishing you the best!
Posted at 1/14/2026 01:16:51        Only Author  7#
The content is excellent, and Im giving it a like. Get the New JN0-253 learning materials test that contributed to my promotion and salary raise, available for free today. Best wishes for your career!
Posted at 1/15/2026 14:02:01        Only Author  8#
ҡSalesforceAP-205}ʹäԇY˺ϸ񤷤ʤȫ~ǤηZΤϱƷ˲ŤǤϤʤОǤäҡ\ʾޤSalesforceAP-205}ΌIǤСե`ӥμĤǤСҡMogiExamϤ͘ĤُIäޤ͘ΜҡMǤ
Posted at 2/15/2026 14:04:17        Only Author  9#
Im grateful for the inspiration this article provides, thanks for sharing! With Latest CHRP-KE cram materials, you get access to valuable content at no cost, designed for your benefit.
