Issue flashing ubuntu
14
Posted at 4/24/2019 03:15:11      View:4119 | Replies:3        Print      Only Author   [Copy Link] 1#
When I connect the firefly 3399 with my ubuntu laptop, I get a following error Unable to assess firefly 3399 / Unable to open MTP device '[usb001,039]'.
Any ideas or pointers
Error
Error
Posted at 4/24/2019 15:38:36        Only Author  2#
An update to this thread. I could not fix the problem above but could flash ubuntu on firefly with the windows tools. It worked for me as given in the documentation. Please not that you will be two version on the Android upgrade tool, one to erase the firmware and the second to flash the new firmware.
Posted at 6/6/2019 23:53:12        Only Author  3#
I'm very surprised that there is no answer for any thread for AIO-3399C ...
In order to flash your device with any image (Android or Ubuntu), you need to enter bootloader mode and use the "Linux_Upgrade_Tool". As You said in your message, you will need 2 versions of the tool.
The wiki does not describe very well the different step, it took time for me also to succeed in flashing Ubuntu from Android 7.1
Posted at 1/9/2026 22:16:40        Only Author  4#
ITZert wird nicht nur Ihren Wunsch erfüllen, sondern Ihnen einen einjährigen kostenlosen Update-Service und Kundendienst bieten. Die Prüfungsfragen von ITZert sind alle richtig, die Ihnen beim Bestehen der Amazon CLF-C02 Zertifizierungsprüfung helfen. Im ITZert können Sie kostenlos einen Teil der Fragen und Antworten zur Amazon CLF-C02 Zertifizierungsprüfung als Probe herunterladen.
