New Topic
[Linux] Firmware upgrade for board YS-M99
35
Linux Firmware upgrade for board YS-M99
Posted at 6/15/2023 21:19:16      View5935 | Replies15        Print      Only Author   [Copy Link] 1#
Hello,
I've a board that pretend to be a Rockchip RK3399 (Model: Firefly-RK3399 Board (Linux Opensource))
The constructor reference is YS-M99
http://www.yishengtec.cn/en/?list_83/218.html
I try to install linux on it, but no luck for the moment, i tried in OTG and got this error on the serial debug console:
sdhci_complete_adma: transfer error, stat 0xa8001,
I burnt the sd card with the SD_Firmware_Tool but it doesnt boot completly (see atached logs)
I tried ubuntu 18 and 20 from
https://en.t-firefly.com/doc/download/3.html
It stuck on the boot according to my serial output:
[    2.360164] sensor_register_slave:mma8452,id=17
[    2.360579] sensor_register_slave:lis3dh,id=7
[    2.360986] sensor_register_slave:mma7660,id=18
[    2.361398] sensor_register_slave:lsm303d,id=23
[    2.361819] sensor_register_slave:gs_mc3230,id=24
[    2.362238] [Gsensor]   gsensor_init
[    2.362560] sensor_register_slave:mpu6880_acc,id=25
[    2.363004] sensor_register_slave:mpu6500_acc,id=26
[    2.363440] sensor_register_slave:lsm330_acc,id=27
[    2.363884] sensor_register_slave:akm8975,id=31
[    2.364296] sensor_register_slave:akm8963,id=32
[    2.364717] sensor_register_slave:l3g4200d,id=46
[    2.365129] sensor_register_slave:l3g20d,id=47
[    2.365530] sensor_register_slave:ewtsa,id=48
[    2.365928] sensor_register_slave:lsm330_gyro,id=52
[    2.366364] sensor_register_slave:cm3217,id=54
[    2.366773] sensor_register_slave:cm3218,id=55
[    2.367661] i2c /dev entries driver
[    2.369206] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    2.369891] fan53555-reg: supplied by vcc5v0_sys
Anyone have a suggestion to bring this board to life on linux?
Thank you!
PH
log_boot.zip
9.93 KB, Down times: 0
administrator
Rank: 9Rank: 9Rank: 9
Posted at 6/16/2023 09:55:48        Only Author  2#
Sorry, I am confused. What kind of board do you use? YS-M99 or Firefly-RK3399?
Posted at 6/16/2023 21:21:10        Only Author  3#
Hello,
It's an YS-M99. This boot log output gave me some hope:
Thanks for your reply!
Posted at 6/27/2023 21:57:25        Only Author  4#
Any chance to run this board or it's garbage?
Posted at 6/28/2023 09:45:59        Only Author  5#
hachpai Posted at 6/27/2023 21:57
I guess you can ask the board's after sales for help. Isn't it an YS-M99?
Posted at 7/14/2023 22:40:35        Only Author  6#
Yes it is, but the after sales dont want to help, at all :-(
Posted at 7/17/2023 10:27:03        Only Author  7#
hachpai Posted at 7/14/2023 22:40
How about their forum?
Posted at 8/23/2023 21:39:46        Only Author  8#
No forum...
Posted at 6/17/2025 18:15:13        Only Author  9#
Love the thrill of Grand Mondial's slots? Switch gears and create your own beats withץ󥭩` where every tap crafts a winning melody, no wagering required
Posted at 7/13/2025 12:09:12        Only Author  10#
Heic To Jpg C Fast & Easy HEIC Image Converter.
Heic to Jpg is a fast, free, and reliable online tool designed to convert HEIC images to JPG format with just a few clicks. No software installation required simply upload your HEIC files and download the high-quality JPG versions instantly. Whether you're working with photos from your iPhone or other Apple devices, our converter ensures full compatibility and excellent image quality.
Return to List
12
