[General] Free PDF Quiz Efficient 1Z0-1123-25 - Test Oracle Cloud Infrastructure 2025 Migr
99
General Free PDF Quiz Efficient 1Z0-1123-25 - Test Oracle Cloud Infrastructure 2025 Migr
Posted at 1/8/2026 21:37:13      View245 | Replies3        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Pass4cram 1Z0-1123-25 dumps from Cloud Storage: https://drive.google.com/open?id=1woAFdivc0jCsFPSPAenGbPlpZscwbXfK
There are some education platforms in the market which limits the user groups of products to a certain extent. And we have the difference compared with the other 1Z0-1123-25 quiz materials for our 1Z0-1123-25 study dumps have different learning segments for different audiences. We have three different versions of our 1Z0-1123-25 Exam Questions on the formats: the PDF, the Software and the APP online. Though the content is the same, the varied formats indeed bring lots of conveniences to our customers.
Oracle 1Z0-1123-25 Exam Syllabus Topics:
  • Design and Implement Migrations Using Oracle Cloud VMware Solution (OCVS):This section measures the skills of VMware Cloud Engineers in migrating on-premises VMware environments to OCI. It covers source discovery to assess existing infrastructure, designing the target OCVS environment, and understanding migration prerequisites. Candidates will also explore Hybrid Cloud Extension as a tool for seamless migration and integration between VMware workloads and OCI.
  • Fundamentals of Cloud Migrations: This section of the exam measures the skills of Cloud Migration Engineers in understanding the core principles of cloud migrations. It covers the key drivers behind cloud adoption, the benefits of moving to Oracle Cloud Infrastructure (OCI), and the challenges businesses may face during migration. Candidates will gain insights into the different migration strategies and methodologies used to ensure seamless transitions from on-premises environments to the cloud.
  • Migrate Infrastructure Workloads Between OCI Regions: This section assesses the skills of Cloud Operations Engineers in managing workload replication across OCI regions. It covers OCI Object Storage Replication, Block Volume Replication, and File System Replication to ensure business continuity. Additionally, candidates will learn how to design and implement full-stack disaster recovery strategies using OCI Full Stack Disaster Recovery Service to minimize downtime and data loss.
Pass Guaranteed 2026 1Z0-1123-25: High Hit-Rate Test Oracle Cloud Infrastructure 2025 Migration Architect Professional Vce FreePass4cram is aware that in todays routines many Oracle Cloud Infrastructure 2025 Migration Architect Professional 1Z0-1123-25 exam candidates are under time pressures. Therefore, Pass4cram offers Oracle Exams questions in three formats that are 1Z0-1123-25 desktop practice test software, web-based practice test, and PDF dumps. These formats of our Oracle Cloud Infrastructure 2025 Migration Architect Professional 1Z0-1123-25 updated exam study material give you multiple training options so that you can meet your Oracle 1Z0-1123-25 exam preparation objectives. Keep reading because we have discussed the specifications of Pass4cram 1Z0-1123-25 exam questions preparation material in three user-friendly formats.
Oracle Cloud Infrastructure 2025 Migration Architect Professional Sample Questions (Q48-Q53):NEW QUESTION # 48
A cluster of physical servers running in an on-premises data center is configured with a total of 100 GB physical memory. The total virtual memory allocated across all the VMs running on this cluster is 200 GB. Which term describes the virtual-to-physical memory allocation ratio for this cluster?
  • A. Thick provisioning
  • B. Oversubscription
  • C. Overprovisioning
  • D. Encapsulation
Oversubscription occurs when the total virtual memory allocated across all VMs exceeds the total physical memory available in the cluster.
NEW QUESTION # 49
Which three transfer mediums does the OCI Database Migration service use to perform the initial load of the databases?
  • A. Data Pump via File Storage
  • B. Data Pump via Object Storage
  • C. Data Guard via replication
  • D. Data Pump dump upload via OCI CLI
  • E. Data Pump via network link
Answer: B,D,E
Data Pump via Object Storage, Data Pump via network link, and Data Pump dump upload via OCI CLI are all valid transfer mediums used by the OCI Database Migration service for the initial load of databases.
NEW QUESTION # 50
You plan to perform migrations between on-premises and OCI. What is the minimum bandwidth required with FastConnect as the dedicated network link between the environments?
  • A. 100 Gbps
  • B. 50 Gbps
  • C. 1 Gbps
  • D. 10 Gbps
The minimum bandwidth required for FastConnect is 1 Gbps to ensure fast and reliable data transfer between the environments.
NEW QUESTION # 51
Your company is planning to migrate on-premises workloads to Oracle Cloud Infrastructure (OCI). As a migration cloud architect, you are considering Oracle Cloud Migrations service for this initiative. Which two are core features of Oracle Cloud Migrations service?
  • A. Estimate the cost to run the migrated workloads in the OCI environment
  • B. Group and organize discovered workloads to represent applications & lines of business
  • C. Provide detailed application topology to choose the target OCI Region
  • D. Transfer large volumes of data through a storage appliance
  • E. Automatic containerization of Virtual Machines to Oracle Container Engine for Kubernetes (OKE)
Estimating the cost to run the migrated workloads in the OCI environment and grouping and organizing discovered workloads to represent applications & lines of business are core features of the Oracle Cloud Migrations service.
NEW QUESTION # 52
Which Hybrid Cloud Extension (HCX) migration type is designed for large-scale migration of workloads that cannot afford downtime?
  • A. HCX OS Assisted Replication
  • B. HCX vMotion
  • C. HCX Bulk Migration
  • D. HCX Replication Assisted vMotion
HCX Replication Assisted vMotion is designed for large-scale migrations of workloads that cannot afford downtime. It allows for continuous replication of data while the workload is running, ensuring minimal disruption during the migration process.
NEW QUESTION # 53
Would you like to distinguish yourself in IT industry? And would you like to get much more professional recognition? Come on and sign up for Oracle 1Z0-1123-25 Certification Exam to further improve your skills. Pass4cram can help you achieve your wishes. Here has professional knowledge, powerful exam dumps and quality service, which can let you master knowledge and skill with high speed and high efficiency. What's more, it can help you are easy to cross the border and help you access to success.
Latest 1Z0-1123-25 Exam Testking: https://www.pass4cram.com/1Z0-1123-25_free-download.html
2026 Latest Pass4cram 1Z0-1123-25 PDF Dumps and 1Z0-1123-25 Exam Engine Free Share: https://drive.google.com/open?id=1woAFdivc0jCsFPSPAenGbPlpZscwbXfK
Posted at 1/17/2026 16:23:42        Only Author  2#
Im really grateful for your article, it truly made an impression. Free Valid SC-900 exam bootcamp materials exam questionsyour key to career growth and a better salary!
Posted at 1/18/2026 19:22:34        Only Author  3#
The article gave me so much to think about. Wishing myself all the best for the Exam CAMS7 Topics exam!
Posted at 2/17/2026 13:01:48        Only Author  4#
Your article is absolutely mind-blowing, thank you for sharing! Explore the rich content of Valid 312-97 exam dumps, offered free to assist you.
