Supporting HDMI resolution to 1920x1200 (WUXGA) for Android 7.1
74
Posted at 5/15/2018 17:04:45      View6455 | Replies2        Print      Only Author   [Copy Link] 1#
Hello,
I want to support HDMI resolution to 1920x1200 (WUXGA) for Android 7.1
So I modified device/rockchip/rk3399/rk3399_firefly_aio_box/system.prop like below, and then rebuild firmware and download it.
persist.sys.framebuffer.main=1920x1080
persist.sys.framebuffer.main=1920x1200
Fortunately, HDMI output looks good. It seems that HDMI output is set to 1920x1200 resolution correctly. :-)
I'm wondering that this is all? Do I MIGHT need an additional modification?
Because I used Firefly-RK3288 reload before, at that time I have to modify some kernel configurations (ie, dts file) for same job.
But for Firefly-RK3399, I couldn't find any resolution related code in dts file, so I didn't modify any kernel code or configuration.
Thank you in advance.
Best Regards,
Sinjin
restricted members
Posted at 1/25/2026 21:13:15        Only Author  2#
Your article is truly stunning; I appreciate your sharing! Latest real C_BCSBN_2502 exam has fantastic materials, and it's offered to you free of charge.
Posted at 2/24/2026 08:30:09        Only Author  3#
This article is superb, I appreciate you sharing it. The SAP-C02 accurate test content is amazing, and you can get it for free.
