New Topic
[Hardware] USB Type C Display Issue
47
Hardware USB Type C Display Issue
Posted at 6/3/2019 11:39:40      View5951 | Replies10        Print      Only Author   [Copy Link] 1#
Hi,
We tested ROC-RK3399-PC USB type C display performance and had two problems:
1. Connect to DP 4K Monitor with USB Type C to DP Dongle
-->Monitor works only on certain side of USB Type C connector.
2. Connect to USB Type C Monitor (Dell U3219Q)
-->No Function. Nothing displays on the monitor.
Does anyone have the similar issue and know how to fix it?
Thanks in advance!
vip
Rank: 6Rank: 6
Posted at 6/5/2019 14:16:37        Only Author  2#
Could you elaborate a bit about "on certain side of USB Type C connector"?
Posted at 6/6/2019 11:44:25        Only Author  3#
Thanks for asking. As far as we know, USB-C plug may be inserted either side (the connector is reversible so that it can be used in any orientation). But in our test, when using USB-C to DP Dongle, the USB-C on the ROC-RK3399-PC only displayed (have function) in one side. If we turned to the other side and stick in the USB-C connector, the monitor showed nothing.
How about the second issue? (connecting to USB Type C Monitor) What's the potential cause?
Posted at 6/17/2019 15:00:57        Only Author  4#
Any update on this?
vip
Rank: 6Rank: 6
Posted at 6/18/2019 16:59:53        Only Author  5#
This has been confirmed. It's the driver problem.
  1. 2. Connect to USB Type C Monitor (Dell U3219Q)
  2. -->No Function. Nothing displays on the monitor.
Copy the code
We haven't this monitor, so would you please attach a kernel log with monitor plug out and in.
Posted at 1/13/2026 12:09:31        Only Author  6#
This article is incredible, thank you for sharing such brilliance! Free Test AZ-204 registration resources are available heregood luck!
Posted at 1/23/2026 00:56:07        Only Author  7#
PRINCE2Foundation-Deutsch ist eine der PRINCE2 Zertifizierungsprfungen. IT-Fachmann mit PRINCE2 Zertifikat sind sehr beliebt in der IT-Branche. Deshalb legen imme mehr Leute die PRINCE2Foundation-Deutsch Zertifizierungsprfung. Jedoch ist es nicht so einfach, die PRINCE2 PRINCE2Foundation-Deutsch Zertifizierungsprfung zu bestehen. Wenn Sie nicht an den entprechenden Kursen teilnehmen, brauchen Sie viel Zeit und Energie, sich auf die Prfung vorzubereiten. Nun kann PrfungFrage Ihnen viel Zeit und Energie ersparen.
Posted at 2/2/2026 01:49:48        Only Author  8#
Thank you for your article, it gave me such a fresh perspective. AWS-Developer new test camp materials is free and offers rich content to help you on your educational journey.
Posted at 2/8/2026 12:22:08        Only Author  9#
The article is written with great depth, and I have learned a lot of practical knowledge. With New 350-701 braindumps, you get access to valuable content at no cost, designed for your benefit.
Posted at 2/18/2026 19:51:40        Only Author  10#
VMware2V0-15.25J^ԇYITIˤȤƤҪʵλ뤳Ȥߤʤ䤹^Ȥ뤳ȤϤǤϤޤ󡣤ޤЈˤȤƤ褤}̽ȤyǤPassTestJǃITYϤΥ֥ȤǡVMware 2V0-15.25JԇYVMware Cloud Foundation 9.0 Support݅νUYȕԇYβϤҊĤ뤳ȤǤȤȤ˲֤¤ԇY}ĿԔشoϤ˥`ɤȤǤޤ衣
Return to List
12
