[Linux] mipi_dphy0 enabling error in dts file
67
Linux mipi_dphy0 enabling error in dts file
Posted at 9/27/2023 16:33:48      View3373 | Replies8        Print      Only Author   [Copy Link] 1#
  • SDK Package Name: ROC-RK3566-PC-MIPI_Rk356x_v1.3.2f_230926
  • Modification Content: -
  • Log: test.zip
I'm trying enable to mipi dsi on RK3566-PC.
For that I'am using this documantation. https://download.t-firefly.com/product/Board/Common/Document/Developer/Rockchip_Developer_Guide_DRM_Panel_Porting_CN.pdf
In this documantation there is a step for  enable to mipi_dphy0.
When I change the device tree for enable to mipi_dphy0, I take a kernel dts build error.
When I added the code in following file to kernel/arch/arm64/boot/dts/rockchip/rk3566-firefly-roc-pc-mipi101_M101014_BE45_A1.dts file,
&mipi_dphy0 {
    status = "okay";
&mipi_dphy1 {
    status = "disabled";
I took the error at following line:
scripts/kconfig/conf  --syncconfig Kconfig
  DTC     arch/arm64/boot/dts/rockchip/rk3566-firefly-roc-pc-mipi101_M101014_BE45_A1.dtb
  CALL    scripts/checksyscalls.sh
Error: arch/arm64/boot/dts/rockchip/rk3566-firefly-roc-pc-mipi101_M101014_BE45_A1.dts:71.1-12 syntax error
FATAL ERROR: Unable to parse input tree
scripts/Makefile.lib:307: recipe for target 'arch/arm64/boot/dts/rockchip/rk3566-firefly-roc-pc-mipi101_M101014_BE45_A1.dtb' failed
make[1]: *** [arch/arm64/boot/dts/rockchip/rk3566-firefly-roc-pc-mipi101_M101014_BE45_A1.dtb] Error 1
arch/arm64/Makefile:145: recipe for target 'rockchip/rk3566-firefly-roc-pc-mipi101_M101014_BE45_A1.dtb' failed
make: *** [rockchip/rk3566-firefly-roc-pc-mipi101_M101014_BE45_A1.dtb] Error 2
make: *** Waiting for unfinished jobs....
ERROR: Running build_extboot failed!
ERROR: exit code 2 from line 774:
    make ARCH=$RK_ARCH $RK_KERNEL_DTS.img -j$RK_JOBS
How can I enable the mipi_dsi0 like says on documentation ?
test.zip
3.06 KB, Down times: 1
Posted at 9/28/2023 10:39:37        Only Author  2#
syntax error because you are missing a ";" at end of "}"
BUT this is not the point.
There's no mipi_dphy nodes in RK356x but video_phy instead. The doc you read is not suitable for RK356X
You can find more accurate docs under docs/ in SDK
rk3566-firefly-roc-pc-mipi101_M101014_BE45_A1.dts is already well configured, you can find video_phy0 is enabled in it.
So you don't need to modify anything about dts, mipi dsi0 works if you choose the right mk file when building, for example:
# choose to build ubuntu firmware with mipi support
./build.sh roc-rk3566-pc-mipi-ubuntu.mk
# start build
./build.sh
Posted at 1/11/2026 07:42:01        Only Author  3#
I felt like I walked away from that article with so much more knowledge. Wishing you all the best on your exams! Free New PEGACPSA24V1 exam tips questions available now!
Posted at 1/11/2026 18:31:47        Only Author  4#
Instant like; this content is too good. Best of luck on your exam! Heres the free Managing-Cloud-Security new dumps sheet content.
Posted at 1/19/2026 10:59:24        Only Author  5#
Your article truly left me in awe, thank you for sharing! Were providing FCP_FGT_AD-7.6 questions pdf, packed with valuable resources, for free, to help you.
Posted at 1/23/2026 02:20:22        Only Author  6#
Thank you for sharing such a motivational article! Free Latest TDA-C01 exam question resources for exam success. Wishing you the best!
Posted at 2/6/2026 14:27:50        Only Author  7#
Your article is breathtaking, I really appreciate you sharing it! The content in L4M4 real question is rich and free of charge, created with your success in mind.
Posted at 2/17/2026 05:08:15        Only Author  8#
This is truly a magnificent article, thank you for sharing. With the Valid Salesforce-Data-Cloud test vce, I advanced in my career and earned a salary increase. Now, it's free for everyone. Wishing you quick promotions!
Posted at 2/17/2026 07:14:26        Only Author  9#
WGUǤϡयηҰΌTҤäInformation-Technology-ManagementѧɤɤƤ뤿ᡢѧ̲ĤƷ|ĤƤäޤ ˡInformation-Technology-ManagementԇY}Υ󥹤˻ŤԇYΜʂ򤹤뤳ȤǡPassTestNMC򉈤䤷oϤ뤳ȤǤޤ äơWGU Information Technology Management QGC1ԇYܤʂ䤬Ǥ顢Information-Technology-Managementѧ̲ĤäǤޤ ΤߤˤʤꤿϡΤäƤޤ Information-Technology-Managementѧ̲Ĥُ뤷Ƥ
