[General] GitHub GitHub-Advanced-Security Musterprüfungsfragen, GitHub-Advanced-Security D
102
【General】 GitHub GitHub-Advanced-Security Musterprüfungsfragen, GitHub-Advanced-Security D
Posted at 1/11/2026 02:57:40      View:159 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Die neuesten Pass4Test GitHub-Advanced-Security PDF-Versionen Prüfungsfragen und GitHub-Advanced-Security Fragen und Antworten sind kostenlos verfügbar: https://drive.google.com/open?id=1oQZnnanDU0fuLQKBN7LxLm51MsZ4TrMO
Sie können im Inernet kostenlos die Lerntipps und einen Teil der Prüfungsfragen und Antworten zur GitHub GitHub-Advanced-Security Zertifizierungsprüfung von Pass4Test als Probe herunterladen.
GitHub GitHub-Advanced-Security Prüfungsplan:
ThemaEinzelheiten
Thema 1
  • Configure and use code scanning: This section of the exam measures skills of a DevSecOps Engineer and covers enabling and customizing GitHub code scanning with built?in or marketplace rulesets. Examinees must know how to interpret scan results, triage findings, and configure exclusion or override settings to reduce noise and focus on high?priority vulnerabilities.
Thema 2
  • Describe GitHub Advanced Security best practices: This section of the exam measures skills of a GitHub Administrator and covers outlining recommended strategies for adopting GitHub Advanced Security at scale. Test?takers will explain how to apply security policies, enforce branch protections, shift left security checks, and use metrics from GHAS tools to continuously improve an organization’s security posture.
Thema 3
  • Describe the GHAS security features and functionality: This section of the exam measures skills of a GitHub Administrator and covers identifying and explaining the built?in security capabilities that GitHub Advanced Security provides. Candidates should be able to articulate how features such as code scanning, secret scanning, and dependency management integrate into GitHub repositories and workflows to enhance overall code safety.
Thema 4
  • Configure and use secret scanning: This section of the exam measures skills of a DevSecOps Engineer and covers setting up and managing secret scanning in organizations and repositories. Test?takers must demonstrate how to enable secret scanning, interpret the alerts generated when sensitive data is exposed, and implement policies to prevent and remediate credential leaks.
Thema 5
  • Use code scanning with CodeQL: This section of the exam measures skills of a DevSecOps Engineer and covers working with CodeQL to write or customize queries for deeper semantic analysis. Candidates should demonstrate how to configure CodeQL workflows, understand query suites, and interpret CodeQL alerts to uncover complex code issues beyond standard static analysis.
Thema 6
  • Configure and use dependency management: This section of the exam measures skills of a DevSecOps Engineer and covers configuring dependency management workflows to identify and remediate vulnerable or outdated packages. Candidates will show how to enable Dependabot for version updates, review dependency alerts, and integrate these tools into automated CI
  • CD pipelines to maintain secure software supply chains.
GitHub-Advanced-Security Übungsmaterialien & GitHub-Advanced-Security realer Test & GitHub-Advanced-Security TestvorbereitungDas GitHub GitHub-Advanced-Security Zertifikat kann nicht nur Ihre Fähigkeiten, sondern auch Ihre Fachkenntnisse und Erfahrungen beweisen. Der Boss hat Sie doch nicht umsonst eingestellt. Zur Zeit braucht IT-Branche eine zuverlässige Ressourcen zur GitHub GitHub-Advanced-Security Zertifizierungsprüfung. Pass4Test ist eine gute Wahl. Sie können die GitHub GitHub-Advanced-Security Prüfung in kurzer Zeit bestehen, ohne viel Zeit und Energie zu verwenden, und eine glänzende Zukunft haben.
GitHub Advanced Security GHAS Exam GitHub-Advanced-Security Prüfungsfragen mit Lösungen (Q29-Q34):29. Frage
Which of the following features helps to prioritize secret scanning alerts that present an immediate risk?
  • A. Push protection
  • B. Non-provider patterns
  • C. Custom pattern dry runs
  • D. Secret validation
Begründung:
Secret validationchecks whether a secret found in your repository is still valid and active with the issuing provider (e.g., AWS, GitHub, Stripe). If a secret is confirmed to be active, the alert ismarked as verified, which means it's considered ahigh-priority issuebecause it presents an immediate security risk.
This helps teams respond faster tovalid, exploitablesecrets rather than wasting time on expired or fake tokens.
30. Frage
Which of the following statements most accurately describes push protection for secret scanning custom patterns?
  • A. Push protection is enabled by default for new custom patterns.
  • B. Push protection is not available for custom patterns.
  • C. Push protection must be enabled for all, or none, of a repository's custom patterns.
  • D. Push protection is an opt-in experience for each custom pattern.
Begründung:
Push protection for secret scanning custom patterns is an opt-in feature. This means that for each custom pattern defined in a repository, maintainers can choose to enable or disable push protectionindividually. This provides flexibility, allowing teams to enforce push protection on sensitive patterns while leaving it disabled for others.
31. Frage
Which Dependabot configuration fields are required? (Each answer presents part of the solution. Choose three.)
  • A. directory
  • B. allow
  • C. schedule.interval
  • D. package-ecosystem
  • E. milestone
Antwort: A,C,D
Begründung:
When configuring Dependabot via the dependabot.yml file, the following fields are mandatory for each update configuration:
directory: Specifies the location of the package manifest within the repository. This tellsDependabot where to look for dependency files.
package-ecosystem: Indicates the type of package manager (e.g., npm, pip, maven) used in the specified directory.
schedule.interval: Defines how frequently Dependabot checks for updates (e.g., daily, weekly). This ensures regular scanning for outdated or vulnerable dependencies.
The milestone field is optional and used for associating pull requests with milestones. The allow field is also optional and used to specify which dependencies to update.
GitLab
32. Frage
How many alerts are created when two instances of the same secret value are in the same repository?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
Antwort: C
Begründung:
Whenmultiple instances of the same secret valueappear in a repository,only one alertis generated. Secret scanning works by identifying exposed credentials and token patterns, and it groups identical matches into a single alertto reduce noise and avoid duplication.
This makes triaging easier and helps teams focus on remediating the actual exposed credential rather than reviewing multiple redundant alerts.
33. Frage
You have enabled security updates for a repository. When does GitHub mark a Dependabot alert as resolved for that repository?
  • A. When the pull request checks are successful
  • B. When you merge a pull request that contains a security update
  • C. When you dismiss the Dependabot alert
  • D. When Dependabot creates a pull request to update dependencies
Begründung:
A Dependabot alert is marked asresolvedonly after the relatedpull request is mergedinto the repository. This indicates that the vulnerable dependency has been officially replaced with a secure version in the active codebase.
Simply generating a PR or passing checks does not change the alert status; merging is the key step.
34. Frage
Pass4Test hilft Ihnen, GitHub GitHub-Advanced-Security Prüfungsfragen und Antworten in einer echten Umgebung zu machen. Wenn Sie Einsteiger sind und Ihre beruflichen Fähigkeiten verbessern wollen, werden die Fragenkataloge zur GitHub GitHub-Advanced-Security Zertifizierungsprüfung von Pass4Test Ihnen helfen, Ihren Traum Schritt für Schritt zu verwirklichen. Wir werden alle Ihren Fragen bezüglich der Prüfung lösen. Innerhalb eines Jahres bieten wir Ihnen kostenlosen Update-Service. Bitte schenken Sie unserer Website mehr Aufmerksamkeit.
GitHub-Advanced-Security Deutsche Prüfungsfragen: https://www.pass4test.de/GitHub-Advanced-Security.html
P.S. Kostenlose und neue GitHub-Advanced-Security Prüfungsfragen sind auf Google Drive freigegeben von Pass4Test verfügbar: https://drive.google.com/open?id=1oQZnnanDU0fuLQKBN7LxLm51MsZ4TrMO
