[General] Pass Guaranteed ServiceNow - CSA - ServiceNow Certified System Administrator¨CHig
45
¡¾General¡¿ Pass Guaranteed ServiceNow - CSA - ServiceNow Certified System Administrator¨CHig
Posted at 1/11/2026 03:25:25      View£º216 | Replies£º1        Print      Only Author   [Copy Link] 1#
What's more, part of that PassLeaderVCE CSA dumps now are free: https://drive.google.com/open?id=1vOnnjCTpENzBCr_9d9pLe_zkS7CPTaR9
Our agreeable staffs are obliging to offer help 24/7 without self-seeking intention and present our after-seals services in a most favorable light. We have patient colleagues offering help and solve your problems and questions of our materials all the way. Besides, we remunerate exam candidates who fail the CSA Exam Torrent after choosing our CSA study tools, which kind of situation is rare but we still support your dream and help you avoid any kind of loss. Just try it do it, and we will be your strong backup.
ServiceNow CSA exam covers a wide range of topics, including system administration fundamentals, user interface and navigation, data management, security, reporting and analytics, integrations, and workflow automation. CSA exam is designed to test the candidate's ability to configure, administer, and maintain the ServiceNow platform. CSA Exam consists of 60 multiple-choice questions, and candidates have 90 minutes to complete it.
ServiceNow certification CSA exam training programsWe can confidently say that our CSA training quiz will help you. First of all, our company is constantly improving our CSA exam materials according to the needs of users. As you can see that there are three versions of our CSA learning questions on our website for you to choose: the PDF, Software and APP online. As long as you have a try on our CSA study prep, you will want our CSA study materials to prapare for the exam for sure.
ServiceNow CSA Exam is designed to test the candidate's ability to configure, customize, and administer the ServiceNow platform. It covers a range of topics such as user administration, data management, system administration, security, and reporting. By passing the ServiceNow CSA Exam, candidates demonstrate that they have the skills and knowledge required to manage and support the ServiceNow platform effectively.
ServiceNow Certified System Administrator Sample Questions (Q233-Q238):NEW QUESTION # 233
Which form element displays the list of activities, or history, on a task form?
  • A. Activity Formatter
  • B. Sidebar
  • C. Action Formatter
  • D. Action Stream
Activity Formatteris a UI element in ServiceNow forms that logs allupdates, comments, and historyrelated to a task.
It consolidates user interactions and system-generated updates in one place.
ServiceNow Docs - Activity Formatter
NEW QUESTION # 234
Which are states that you can make a field on a form using UI Policy?
  • A. Hidden
  • B. write-only
  • C. Mandatory
  • D. Necessary
  • E. Empty
  • F. read-only
Answer: A,C,F
In ServiceNow, UI Policies allow administrators to dynamically control form fields based on conditions without using scripts. With UI Policies, you can change the behavior of a field by making it:
Read-only ¡ú The user can view the field but cannot edit it.
Mandatory ¡ú The field becomes required, and the user must fill it out before submitting the form.
Hidden ¡ú The field is removed from visibility on the form.
Explanation of Each Option:
✅ A. Read-only - Correct
A UI Policy can make a field read-only, meaning users can see the field but cannot modify its value.
Example: A field like Request Number (REQ0001) is typically read-only after submission.
❌ B. Write-only - Incorrect
ServiceNow does not have a "write-only" field setting in UI Policies.
If a field is editable, users can both read and write; if it's hidden or read-only, writing is not possible.
❌ C. Necessary - Incorrect
There is no "Necessary" field state in ServiceNow UI Policies.
If the intent is to make a field required, the correct term is "Mandatory".
✅ D. Mandatory - Correct
UI Policies can make a field mandatory, requiring the user to enter a value before submitting the form.
Example: An Incident Description field might be mandatory before an incident is submitted.
❌ E. Empty - Incorrect
UI Policies cannot directly enforce an "empty" state. However, a default value could be cleared using a client script, but this is not a UI Policy feature.
✅ F. Hidden - Correct
UI Policies can hide a field, making it invisible on the form.
Example: A "Manager Approval" field may be hidden until a certain condition (e.g., request cost > $1000) is met.
Final Answer:
✅ Read-only
✅ Mandatory
✅ Hidden
Reference from Certified System Administrator (CSA) Documentation:
ServiceNow Docs - UI Policies and UI Policy Actions
https://docs.servicenow.com
ServiceNow Learning - Form Configuration & UI Policies
ServiceNow Developer Portal - Controlling Form Behavior with UI Policies
NEW QUESTION # 235
The baseline Service Catalog homepage contains links to which of the following components?
  • A. Order Guides, Catalog Items, and Workflows
  • B. Record Producers, Order Guides, and Catalog Items
  • C. Order Guides, Item Variables, and Workflows
  • D. Record Producers, Order Guides, and Item Variables
TheService Catalogis a core feature in ServiceNow that provides users with a structured interface to request services and products. Thebaseline Service Catalog homepageincludes links to key components that help users navigate and submit requests efficiently. These components are:
Record Producers- These are forms that allow users to create records in tables other than the Request table (e.
g., submitting an incident or a change request).
Order Guides- These help users request multiple related items in a single submission, streamlining complex orders.
Catalog Items- These are the individual products or services users can request, such as software installations, hardware requests, or access requests.
Option B: "Order Guides, Item Variables, and Workflows"- Incorrect, becauseItem VariablesandWorkflowsare not direct links on the Service Catalog homepage. Item Variables are attributes of Catalog Items, and Workflows handle backend processing but are not listed as a navigational component.
Option C: "Order Guides, Catalog Items, and Workflows"- Incorrect, because Workflows are not directly linked from the homepage.
Option D: "Record Producers, Order Guides, and Item Variables"- Incorrect, because Item Variables are part of Catalog Items but not a distinct link on the homepage.
ServiceNow Product Documentation - Service Catalog Overview
ServiceNow CSA Study Guide - Service Catalog Fundamentals
ServiceNow Docs: Service Catalog Components
Explanation of Incorrect Options:References from Certified System Administrator (CSA) Documentation:
NEW QUESTION # 236
What instance resource allows you to access guided tours, information about actions, and instructions an how to use inputs and outputs in your flaw?
  • A. Help Panel (question mark icon)
  • B. Community
  • C. Docs
  • D. Wiki
NEW QUESTION # 237
On a filter condition, which component is always a choice list?
  • A. Operation
  • B. Filter Criteria
  • C. Match Criteria
  • D. Operator
https://docs.servicenow.com/bund ... ments/concept/c_Con
NEW QUESTION # 238
CSA Frenquent Update: https://www.passleadervce.com/Certified-System-Administrator/reliable-CSA-exam-learning-guide.html
P.S. Free 2026 ServiceNow CSA dumps are available on Google Drive shared by PassLeaderVCE: https://drive.google.com/open?id=1vOnnjCTpENzBCr_9d9pLe_zkS7CPTaR9
Posted at 1/23/2026 04:49:53        Only Author  2#
×î¤â¥ê¥é¥Ã¥¯¥¹¤·¤¿×´‘B¤Ç¤¹¤Ù¤Æ¤Î¿àëy¤ËÖ±Ãæ¤·¤Æ¤¤¤Þ¤¹¡£BCS¤ÎBAPv5¡¸BCS Practitioner Certificate in Business Analysis Practice v5.0¡¹Ô‡òY¤Ï¤È¤Æ¤âëy¤·¤¤¤Ç¤¹¤¬¡¢ÊÜòYÉú¤Î½Ô¤¬¥ê¥é¥Ã¥¯¥¹¤·¤¿×´‘B¤ÇÔ‡òY¤òÊܤ±¤ë¤Ù¤­¤Ç¤¹¡£¡£ShikenPASS¤ÎBCS¤ÎBAPv5Ô‡òY¥È¥ì©`¥Ë¥ó¥°ÙYÁϤÏ˽ß_¤òÖú¤±¤é¤ì¤Þ¤¹¡£ShikenPASS¤¬¤½¤Ð¤Ë¤¤¤Æ¤¯¤ì¤ë¤È¡¢¿Ö¤¯¤Ê¤¯¤Ê¤ê¡¢ÃÔ¤ï¤Ê¤¯¤Ê¤ê¤Þ¤¹¡£ShikenPASS¤ÎBCS¤ÎBAPv5Ô‡òY¥È¥ì©`¥Ë¥ó¥°ÙYÁϤÏ˽ß_ÊÜòYÉú¤Î×îÁ¼¤Îßx’k¤Ç¤¹¡£
