[General] Oracle 1Z0-082 Questions–Reduce Your Chance of Failure [2026]
85
【General】 Oracle 1Z0-082 Questions–Reduce Your Chance of Failure [2026]
Posted at 1/15/2026 04:54:52      View:132 | Replies:1        Print      Only Author   [Copy Link] 1#
What's more, part of that PDF4Test 1Z0-082 dumps now are free: https://drive.google.com/open?id=148gAlYXkrwKfg8TS0epuDS0bJdJusk_e
Please don’t worry about the purchase process because it’s really simple for you. The first step is to select the 1Z0-082 test guide, choose your favorite version, the contents of different versionof our 1Z0-082 exam questions are the same, but different in their ways of using. We have three different versions for you to choose: PDF, Soft and APP versions. The second step: fill in with your email and make sure it is correct, because we send our 1Z0-082 learn tool to you through the email. Later, if there is an update, our system will automatically send you the latest 1Z0-082 version.
Oracle 1Z1-082 exam, also known as the Oracle Database Administration I exam, is designed for individuals who want to become certified database administrators on Oracle Database 19c. 1Z0-082 exam is the first step towards becoming an Oracle Certified Professional, which is a highly sought-after certification in the IT industry. 1Z0-082 Exam Tests the candidate's knowledge and skills in various areas such as installation, configuration, backup and recovery, database security, and network administration.
Exam 1Z0-082 Introduction, Official 1Z0-082 Study GuidePDF4Test also offers Oracle 1Z0-082 desktop practice exam software which is accessible without any internet connection after the verification of the required license. This software is very beneficial for all those applicants who want to prepare in a scenario which is similar to the Oracle Database Administration I real examination.
Oracle Database Administration I Sample Questions (Q143-Q148):NEW QUESTION # 143
Examine the description of the CUSTOMERS table:
You want to display details of all customers who reside in cities starting with the letter D followed by at least two characters.
Which query can be used?
  • A. SELECT * FROM customers WHERE city = `%D_';
  • B. SELECT * FROM customers WHERE city LIKE `D_';
  • C. SELECT * FROM customers WHERE city = `D_%';
  • D. SELECT * FROM customers WHERE city LIKE `D_%';
NEW QUESTION # 144
You execute this query:
SELECT TO_CHAR(NEXT_DAY(LAST_DAY(SYSDATE), 'MON'), 'dd "Monday for" fmMonth rrrr') What is the result?
  • A. It executes successfully but does not return any result
  • B. It returns the date for the last Monday of the current month
  • C. It generates an error
  • D. It returns the date for the first Monday of the next month
NEW QUESTION # 145
Your database instance was shut down normally and then started in NOMOUNT state. You then execute this command:
ALTER DATABASE MOUNT;
Which two actions are performed? (Choose two.)
  • A. The Oracle background processes are started
  • B. The online redo logs are opened
  • C. The initialization parameter file is read
  • D. The online data files are opened
  • E. The control file is read
  • F. The alert log records the execution details
Answer: A,E
NEW QUESTION # 146
The SCOTT/TIGER user exists in two databases, BOSTON_DB and DALLAS_DB, in two different locations.
Each database has a tnsnames.ora file defining DALLAS_DB as a service name.
Examine this command:
CREATE DATABASE LINK dblink1 CONNECT TO scott IDENTIFIED BY tiger USING 'dallas_db'; How do you execute the command so that only SCOTT in BOSTON_DB can access the SCOTT schema in DALLAS_DB?
  • A. as SCOTT in both the databases
  • B. as SCOTT in DALLAS_DB
  • C. as SCOTT in BOSTON_DB and SYS in DALLAS_DB
  • D. as SCOTT in BOSTON_DB
  • E. as SYS in both the databases
Answer: E
NEW QUESTION # 147
Which three statements are true about the Automatic Diagnostic Repository (ADR)?
  • A. It is only used for Oracle Database diagnostic information.
  • B. It can be used for problem diagnosis of a database when that database's instance is down.
  • C. It Is held Inside an Oracle database schema.
  • D. The ADR base is specified In the diagnostic_dest database parameter.
  • E. It is a file-based repository held outside any database.
Answer: C,D,E
NEW QUESTION # 148
As far as the top features of PDF4Test 1Z0-082 exam questions formats are concerned, the Oracle 1Z0-082 desktop practice test software and web-based practice test software both are customizable and track your performance. These 1Z0-082 practice tests are specifically designed to give you a real-time 1Z0-082 Exam environment for preparation. You can trust both 1Z0-082 practice test software and start preparing today. The desktop software runs on Windows computers. The web-based 1Z0-082 practice exam is supported by all browsers and operating systems.
Exam 1Z0-082 Introduction: https://www.pdf4test.com/1Z0-082-dump-torrent.html
P.S. Free 2026 Oracle 1Z0-082 dumps are available on Google Drive shared by PDF4Test: https://drive.google.com/open?id=148gAlYXkrwKfg8TS0epuDS0bJdJusk_e
Posted at 1/29/2026 14:18:02        Only Author  2#
This article is rich in content and has given me many insights. Here goes the C_S4PM2_2507 valid exam study guide exam! Hoping for success!
